Hi all,
I am trying to understand the reduction sample program. However while i try to execute I get this unspecified driver error. I am on a 64-bit machine running 32-bit fedora 10, having devdriver_3.0_linux_32_195.36.15 for the nvidia geforce 8600 GT driver.
what is the problem here?
[student@localhost ~]$ cd ~/NVIDIA_GPU_Computing_SDK/C/bin/linux/release/
[student@localhost release]$ ./reduction
./reduction Starting...
Using Device 0: GeForce 8600 GT
Reducing array of type int
16777216 elements
256 threads (max)
64 blocks
reduction.cpp(476) : cudaSafeCallNoSync() Runtime API error : unspecified driver error.
[student@localhost release]$ uname -a
Linux localhost.localdomain 2.6.27.5-117.fc10.i686.PAE #1 SMP Tue Nov 18 12:08:10 EST 2008 i686 i686 i386 GNU/Linux
[student@localhost release]$ lspci -nn | grep 'VGA\|NV'
01:00.0 VGA compatible controller [0300]: nVidia Corporation GeForce 8600 GT [10de:0402] (rev a1)
However, later i tried this :
[student@localhost release]$ ./vectorAdd
Vector addition
vectorAdd.cu(71) : cudaSafeCall() Runtime API error : unspecified driver error.
[student@localhost release]$ cd ..
[student@localhost linux]$ cd ..
[student@localhost bin]$ cd ..
[student@localhost C]$ cd src/
[student@localhost src]$ cd deviceQuery
[student@localhost deviceQuery]$ ls
deviceQuery.cpp Makefile
[student@localhost deviceQuery]$ make
deviceQuery.cpp:120:11: warning: extra tokens at end of #else directive
deviceQuery.cpp:129:11: warning: extra tokens at end of #else directive
deviceQuery.cpp: In function ‘int main(int, const char**)’:
deviceQuery.cpp:121: warning: format ‘%d’ expects type ‘int’, but argument 3 has type ‘const char*’
deviceQuery.cpp:121: warning: too many arguments for format
[student@localhost deviceQuery]$ cd ..
[student@localhost src]$ cd ..
[student@localhost C]$ cd bin/linux/release/
deviceQuery reduction reduction.txt vectorAdd
[student@localhost release]$ ./deviceQuery
./deviceQuery Starting...
CUDA Device Query (Runtime API) version (CUDART static linking)
There is 1 device supporting CUDA
Device 0: "GeForce 8600 GT"
CUDA Driver Version: 3.0
CUDA Runtime Version: 3.0
CUDA Capability Major revision number: 1
CUDA Capability Minor revision number: 1
Total amount of global memory: 536150016 bytes
Number of multiprocessors: 4
Number of cores: 32
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 32
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.19 GHz
Concurrent copy and execution: Yes
Run time limit on kernels: Yes
Integrated: No
Support host page-locked memory mapping: No
Compute mode: Default (multiple host threads can use this device simultaneously)
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 134564155, CUDA Runtime Version = 3.0, NumDevs = 1, Device = GeForce 8600 GT
PASSED
Press <Enter> to Quit...
alignedTypes/ convolutionSeparable/ FDTD3d/ MersenneTwister/ recursiveGaussian/ simpleTemplates/ template/
asyncAPI/ convolutionTexture/ fluidsGL/ MonteCarlo/ reduction/ simpleTexture/ threadFenceReduction/
bandwidthTest/ cppIntegration/ histogram/ MonteCarloMultiGPU/ scalarProd/ simpleTexture3D/ threadMigration/
bicubicTexture/ dct8x8/ imageDenoising/ nbody/ simpleAtomicIntrinsics/ simpleTextureDrv/ transpose/
binomialOptions/ deviceQuery/ lineOfSight/ oceanFFT/ simpleCUBLAS/ simpleVoteIntrinsics/ transposeNew/
BlackScholes/ deviceQueryDrv/ Mandelbrot/ particles/ simpleCUFFT/ simpleZeroCopy/ vectorAdd/
boxFilter/ dwtHaar1D/ marchingCubes/ postProcessGL/ simpleGL/ smokeParticles/ vectorAddDrv/
clock/ dxtc/ matrixMul/ ptxjit/ simpleMultiGPU/ SobelFilter/ volumeRender/
concurrentKernels/ eigenvalues/ matrixMulDrv/ quasirandomGenerator/ simplePitchLinearTexture/ SobolQRNG/
convolutionFFT2D/ fastWalshTransform/ matrixMulDynlinkJIT/ radixSort/ simpleStreams/ sortingNetworks/
[student@localhost C]$ cd src/d
dct8x8/ deviceQuery/ deviceQueryDrv/ dwtHaar1D/ dxtc/
[student@localhost C]$ cd src/deviceQueryDrv/
[student@localhost deviceQueryDrv]$ ls
deviceQueryDrv.cpp Makefile
[student@localhost deviceQueryDrv]$ make
deviceQueryDrv.cpp: In function ‘int main(int, char**)’:
deviceQueryDrv.cpp:44: warning: unused variable ‘err’
[student@localhost deviceQueryDrv]$ cd ..
deviceQuery deviceQueryDrv deviceQuery.txt reduction reduction.txt SdkMasterLog.csv vectorAdd
[student@localhost release]$ ./deviceQueryDrv
CUDA Device Query (Driver API) statically linked version
Number of cores: 32
Warp size: 32
Integrated: No
PASSED
Press ENTER to exit...
The device Query program runs fine.
The runtime api and the driver api seems to be working fine, if i understand them correct. So, what’s the problem?
Thanks and Regards,
kg
