Hi all,
I tried to call the histogram256 kernel (provided with nVidia CUDA SDK). During the execution it either shows “unspecified launch error” or BSOD. When I checked the DUMP, it shows that the “stop error message” THREAD_STUCK_IN_DEVICE_DRIVER_M and DEFAULT_BUCKET_ID: GRAPHICS_DRIVER_FAULT
I’m calling the kernel something 1000 iterations with fixed data
[codebox]
// srand(2007);
// for(i = 0; i < DATA_N; i++)
// h_Data[i] = rand() % 256;
memset( h_Data, 0, DATA_SIZE ); // instead of 0 we can give any values[/font]
[/codebox]
It show unspecified launch error. What could be the reason for this?
I checked the CUDA kernel code and found that the following function making the problem
[codebox]
device inline void addData256(volatile unsigned int *s_WarpHist, unsigned int data, unsigned int threadTag)
unsigned int count;
do{
count = s_WarpHist[data] & 0x07FFFFFFU;
count = threadTag | (count + 1);
s_WarpHist[data] = count;
}while(s_WarpHist[data] != count);
[/codebox]
when I commented as follows, the it resolved this issue (even if I wont get the correct output).
[codebox]device inline void addData256(volatile unsigned int *s_WarpHist, unsigned int data, unsigned int threadTag){
unsigned int count;
// do{
// }while(s_WarpHist[data] != count);
}[/codebox]
I’m running the program under
nVidia 8880 GT - 512 MB
BIOS Version: 62.92.16.00.05
Driver Version: nv4_disp 6.14.11.7813 (Forceware 178.13) /XP
Windows XP - SP3
I’ve attached the problematic source code.
Thanks in Advance
histogram256.rar (15.5 KB)
