Hello, everyone. Recently I have learned Stereo Semi Global Matching by cuda. This code is from the github https://github.com/fixstars/libSGM. It is normal when I run this code on PC (GPU is GTX1050). But there is an error on Nvidia TX2.:
CUDA ERROR #4 (using FilterMedian kernel #2): unspecified launch failure
stereo_test: /home/nvidia/newlibSGM/libSGM/src/median_filter.cu:31: void sgm::details::median_filter(const uint16_t*, uint16_t*, void*, int, int): Assertionstatus == 0' failed. Aborted (core dumped)`
Even if I delete the FilterMedian kernel, there is “unspecified launch failure” for cudaMemcpy.
And the CUDA_NVCC_FLAGS is set to compute_62 on TX2.
set(CUDA_NVCC_FLAGS
${CUDA_NVCC_FLAGS};
-O3 -lineinfo
-gencode arch=compute_62,code=sm_62
What parameters should I set? What configuration parameters should I modify?
