cuda visual profile failed with the following error:
File write operation failed
Failed while flushing trace record buffers
The even log reads like this:
Faulting application name: apps.exe, version: 2.20.2214.0, time stamp: 0x4eb1b50a
Faulting module name: cudaapitrace64.dll, version: 0.0.0.0, time stamp: 0x4d554080
Exception code: 0xc0000005
Fault offset: 0x000000000001207f
Faulting process id: 0x28c4
Faulting application start time: 0x01cc9b08d4d1a429
Faulting application path: …\apps.exe
Faulting module path: C:\Program Files\NVIDIA GPU Computing Toolkit\CUDA\v4.0\computeprof\bin\cudaapitrace64.dll
Report Id: 1d488b19-06fc-11e1-b5f4-00259027a06d
the application runs fine without visual profiler.
It could work again after shutdowning/startup a few times of cuda visual profile, and changed visual profiler’s temp working folder permissions.
I don’t have a clue of which file and folder would cause the problem.
