cuda visual profile failed with the following error:
File write operation failed
Failed while flushing trace record buffers
the application runs fine without visual profiler.
It could work again after shutdowning/startup a few times of cuda visual profile, and changed visual profiler’s temp working folder permissions.
I don’t have a clue of which file and folder would cause the problem.
thanks for your help in advance.
