In the DT file, the pin-map is defined in the existing DT file for the UNUSED pin (ex: L19pin: PEX_C6_CLKREQ_N: GPIO3_PAF.02 Input No Enable Disable
) Should I select “unused PEX_L6_CLKREQ_N” for this?
Hi netkerl,
Are you using the devkit or custom board?
I’m not clear about what do you mean about “unused”.
Could you help to provide the DT file you are modifying?
I’m using the custom board (my own H/W design board using NVIDIA-provided schematic)
Linux is not ported yet, and I’m preparing Linux porting.
I changed to unused xxx for not using CVM connector pin as following
AO_HV (3.3V Capable) | VDDIO_C | ||||||||
D59 | CAN0_DOUT | CAN0_DOUT | GP17_CAN0_DOUT | 19.5K +/- 35% | z | unused_CAN0_DOUT | Not Assigned | Int PU | |
F58 | CAN0_DIN | CAN0_DIN | GP18_CAN0_DIN | 19.5K +/- 35% | z | unused_CAN0_DIN | Not Assigned | Int PD | No |
H61 | CAN1_DOUT | CAN1_DOUT | GP19_CAN1_DOUT | 19.5K +/- 35% | z | unused_CAN1_DOUT | Not Assigned | Int PU | |
B61 | CAN1_DIN | CAN1_DIN | GP20_CAN1_DIN | 19.5K +/- 35% | z | unused_CAN1_DIN | Not Assigned | Int PD | No |
E59 | GPIO06 | CAN0_STB | GP21 | 19.5K +/- 35% | pd | unused_CAN0_STB | Not Assigned | Int PD | No |
If you are developing a custom carrier board for AGX Orin, please just using pinmux spreasheet to configure them or just configure them as GPIO instead of CAN usage (in your case).
