Unusual behaviour where deepstream lags inference in docker but not in bare metal on a rtx 5060
amd64 cpu with a RTX 5060
• DeepStream Version
DeepStream 7.1
• TensorRT Version
10.12.0.36-1+cuda12.9
Driver Version: 575.64
Bugs
Trying to run gst-launch-1.0 rtspsrc protocols=4 <…> latency=100 ! queue ! rtph264depay ! queue ! h264parse ! queue ! nvv4l2decoder ! queue ! .sink_0 nvstreammux batch-size=1 width=1920 height=1080 ! queue ! nvinfer config-file-path=<…>/dstest3_pgie_config.txt ! fakesink
Ive tried starting out with the triton development docker image on nvcr.io but it either ran the pipeline very slow(given that i piped the result to a filesink) or not at all
So i decided to run a custom docker built from 22.04 provided by canonical, and even though after fixing a bunch of issues, it ran on a 2060(with some issues but atleast it ran immediately with 4 streams and i) i cant get it to run without problems on a 5060.
dstest3_pgie_config.txt:
[property]
gpu-id=0
net-scale-factor=1
model-color-format=1
onnx-file=<…>YOLOX_Large_640x640_21_05_2025.onnx
model-engine-file=<…>/model_b1_gpu0_fp16.engine
labelfile-path=<…>/labels.txt
batch-size=1
network-mode=2
num-detected-classes=2
interval=0
gie-unique-id=1
process-mode=1
network-type=0
cluster-mode=2
maintain-aspect-ratio=1
symmetric-padding=0
parse-bbox-func-name=NvDsInferParseYoloCuda
custom-lib-path=/usr/local/lib/libnvdsinfer_custom_impl_Yolo.so
engine-create-func-name=NvDsInferYoloCudaEngineGet
[class-attrs-all]
nms-iou-threshold=0.45
pre-cluster-threshold=0.5
topk=300
the models are being built from onnx right as docker launches and baremetal ran perfectly on two different 5060 machines.
and as im writting this after a while of leaving the image(wrote this very post) to run the full program(that does the above pipeline and more) on its own, and out of nowhere it works, but seems to be lagging ever other second.
The program is a standalone binary that executes a pipeline a bit more complex than the above (in fact i launch 4 streams) but i noticed the main problem is between nvinfer and streammux/preprocessing as they tipically run beyond slow.
Replicated it by launching the docker(which on its own launches the program that does nothing as it waits for a connection) waited 10-20 minutes and suddenly the program works once again although lagged.
The graphics card seems under stress which is unusual as when i run the program outside of docker it runs rather smoothly although the first ever launch on a machine always goes wrong for some reason
Nvidia container toolkit is at 1.17.8-1
Due to the version of tensorrt, deepstream cannot currently support the latest GPU architecture.
Please refer to this topic
Is there any publicly announced date for the release?
It will be released in the near future. Please pay attention to the forum announcement for the specific date.
DeepStream 8.0 GA is released.
