Unzipping a 4 Gb+ dataset on a local machine
Hi there.
Is there a simple, one-off way to unzip a 4 Gb+ dataset on a local machine?
Many thanks
Do you mean you would like to put same data to each device? If this is the use-case, you can put it in rootfs and clone the image out. And can flash the image to other devices. Please check developer guide:
Jetson Linux Developer Guide
To clone a Jetson device and flash
Hi Dane LLL
What I mean is:
" Links to download the data: train_data, val_data and annotations.
Please unzip the images into the $LOCAL_DATA_DIR directory"
Pre-supposes that I have access to a program on my local machine that can unzip a 25Gb .zip, such as
http://images.cocodataset.org/zips/train2017.zip), [val_data]
I do not have such a program.
Please point me to one.
I do not have cloud storage.
Thank you
7-zip (https://www.7-zip.org) appears to be a good choice as it can handle .zips considerably larger than 25 Gb.
You could perhaps consider adding this information to the text in the notebook.
Looks like the links are from 3rdparty:
COCO - Common Objects in Context
We don’t have much experience about it. Many thanks for sharing your experience for deploying it on Jetson Nano.
