First of all, thank you for the incredible work you are doing to help us make the most of the DGX Spark.
Yesterday, I downloaded the latest version from the repository and ran ./swift15/setup.sh and ./eugr-setup.sh to test the model derived from swift15.
Since then, I haven’t been able to launch either the Qwen3.8-Flash-Next-125B-A5B-INT4-AutoRound or the Qwen3.8-Flash-Next-Swift1.5 models; they run out of memory.
I have tried using both ./run-recipe.sh and ./serve.sh.
System memory usage is 2.78 GB before startup.
I’ve attached the log—could you please take a look and help me out?
docker logs -f cd57bedde110
WARNING 11-06 23:00:58 \[argparse_utils.py:441\] Found duplicate keys --max-num-seqs, --kv-cache-memory-bytes, --served-model-name
(APIServer pid=97) INFO 11-06 23:00:58 \[api_utils.py:347\]
(APIServer pid=97) INFO 11-06 23:00:58 \[api_utils.py:347\] █ █ █▄ ▄█
(APIServer pid=97) INFO 11-06 23:00:58 \[api_utils.py:347\] ▄▄ ▄█ █ █ █ ▀▄▀ █ version 0.1.dev21830+g8244d1c44.d20261102
(APIServer pid=97) INFO 11-06 23:00:58 \[api_utils.py:347\] █▄█▀ █ █ █ █ model /workspace/flashnext/model
(APIServer pid=97) INFO 11-06 23:00:58 \[api_utils.py:347\] ▀▀ ▀▀▀▀▀ ▀▀▀▀▀ ▀ ▀
(APIServer pid=97) INFO 11-06 23:00:58 \[api_utils.py:286\] non-default args: {'model_tag': '/workspace/flashnext/model', 'chat_template': '/workspace/flashnext/model/medium_chat_template.jinja', 'enable_auto_tool_choice': True, 'tool_call_parser': 'qwen3_coder', 'host': '0.0.0.0', 'model': '/workspace/flashnext/model', 'trust_remote_code': True, 'dtype': 'bfloat16', 'max_model_len': 262144, 'served_model_name': \['qwen3.8-flash-next-a5b'\], 'override_generation_config': {'presence_penalty': 0.1, 'temperature': 0.6}, 'load_format': 'fastsafetensors', 'reasoning_parser': 'qwen3', 'enable_expert_parallel': True, 'block_size': 1632, 'gpu_memory_utilization': 0.01, 'kv_cache_memory_bytes': 20000000000, 'enable_prefix_caching': True, 'recurrent_checkpoint_policy': 'aligned', 'mamba_cache_mode': 'align', 'mm_encoder_tp_mode': 'data', 'max_num_batched_tokens': 8192, 'max_num_seqs': 8, 'enable_chunked_prefill': True, 'enable_flashinfer_autotune': False, 'linear_backend': 'b12x', 'speculative_config': {'method': 'mtp', 'num_speculative_tokens': 5, 'model': '/workspace/flashnext/draft-k10', 'rejection_sample_method': 'block', 'draft_sample_method': 'greedy'}, 'gdn_decode_kernel': 'b12x'}
(APIServer pid=97) WARNING 11-06 23:00:58 \[envs.py:2630\] Unknown vLLM environment variable detected: VLLM_MTP_DRAFT_SCALE
(APIServer pid=97) WARNING 11-06 23:00:58 \[envs.py:2630\] Unknown vLLM environment variable detected: VLLM_FP8_HYBRID
(APIServer pid=97) WARNING 11-06 23:00:58 \[envs.py:2630\] Unknown vLLM environment variable detected: VLLM_BASE_DIR
(APIServer pid=97) \[transformers\] Unrecognized keys in rope_parameters for 'rope_type'='default': {'mrope_interleaved', 'mrope_section'}
(APIServer pid=97) /usr/local/lib/python3.12/dist-packages/transformers/configuration_utils.py:723: FutureWarning: rope_scaling is deprecated and will be removed in a future version. Set rope_parameters instead, with rope_type and rope_theta included.
(APIServer pid=97) warnings.warn(
(APIServer pid=97) INFO 11-06 23:00:59 \[model.py:693\] Resolved architecture: Qwen4ExpForConditionalGeneration
(APIServer pid=97) INFO 11-06 23:00:59 \[model.py:2063\] Using max model len 262144
(APIServer pid=97) INFO 11-06 23:00:59 \[vllm_fp8_hybrid.py:125\] fp8 hybrid patch applied to AutoGPTQConfig
(APIServer pid=97) INFO 11-06 23:01:01 \[model.py:693\] Resolved architecture: Qwen4ExpMTP
(APIServer pid=97) INFO 11-06 23:01:01 \[model.py:2063\] Using max model len 262144
(APIServer pid=97) WARNING 11-06 23:01:01 \[speculative.py:1506\] Enabling num_speculative_tokens > 1 will run multiple times of forward on same MTP layer,which may result in lower acceptance rate
(APIServer pid=97) INFO 11-06 23:01:01 \[scheduler.py:403\] Chunked prefill is enabled with max_num_batched_tokens=8192.
(APIServer pid=97) INFO 11-06 23:01:01 \[vllm.py:1497\] Resolved Engram configuration: EngramConfig(cpu_offload=True, embedding_across_dp=False, dp_shared_memory=False, table_memory='device', disk_resident_scales=False, projection_tp=False)
(APIServer pid=97) INFO 11-06 23:01:01 \[vllm_fp8_hybrid.py:87\] fp8 hybrid: 300 blockwise-fp8 layers detected
(APIServer pid=97) INFO 11-06 23:01:01 \[vllm.py:929\] Auto-enabling VLLM_USE_BREAKABLE_CUDAGRAPH=1. Set VLLM_USE_BREAKABLE_CUDAGRAPH=0 to opt out.
(APIServer pid=97) INFO 11-06 23:01:01 \[kernel.py:430\] Final IR op priority after setting platform defaults: IrOpPriorityConfig(rms_norm=\['vllm_c', 'native'\], fused_add_rms_norm=\['vllm_c', 'native'\], gelu_and_mul_sparse=\['triton', 'native'\])
(APIServer pid=97) INFO 11-06 23:01:02 \[compilation.py:336\] Enabled custom fusions: norm_quant, act_quant
(APIServer pid=97) \[transformers\] The use_fast parameter is deprecated and will be removed in a future version. Use backend="torchvision" instead of use_fast=True, or backend="pil" instead of use_fast=False.
INFO 11-06 23:01:11 \[vllm_fp8_hybrid.py:125\] fp8 hybrid patch applied to AutoGPTQConfig
(EngineCore pid=217) INFO 11-06 23:01:11 \[core.py:124\] Initializing a V1 LLM engine (v0.1.dev21830+g8244d1c44.d20261102) with config: model='/workspace/flashnext/model', speculative_config=SpeculativeConfig(method='mtp', model='/workspace/flashnext/draft-k10', num_spec_tokens=5), tokenizer='/workspace/flashnext/model', skip_tokenizer_init=False, tokenizer_mode=auto, revision=None, tokenizer_revision=None, trust_remote_code=True, dtype=torch.bfloat16, max_seq_len=262144, download_dir=None, load_format=fastsafetensors, tensor_parallel_size=1, pipeline_parallel_size=1, data_parallel_size=1, decode_context_parallel_size=1, dcp_comm_backend=ag_rs, disable_custom_all_reduce=False, quantization=auto_gptq, quantization_config=None, enforce_eager=False, enable_return_routed_experts=False, kv_cache_dtype=auto, device_config=cuda, structured_outputs_config=StructuredOutputsConfig(backend='auto', disable_any_whitespace=False, disable_additional_properties=False, reasoning_parser='qwen3', reasoning_parser_plugin='', enable_in_reasoning=False), observability_config=ObservabilityConfig(show_hidden_metrics_for_version=None, otlp_traces_endpoint=None, collect_detailed_traces=None, per_request_spec_decode_metrics='none', kv_cache_metrics=False, kv_cache_metrics_sample=0.01, cudagraph_metrics=False, enable_layerwise_nvtx_tracing=False, enable_mfu_metrics=False, enable_mm_processor_stats=False, enable_logging_iteration_details=False, jit_monitor_mode='warn', jit_monitor_verbose=False), seed=0, served_model_name=qwen3.8-flash-next-a5b, enable_prefix_caching=True, enable_chunked_prefill=True, pooler_config=None, compilation_config={'mode': <CompilationMode.NONE: 0>, 'debug_dump_path': None, 'cache_dir': '', 'compile_cache_save_format': 'binary', 'backend': 'inductor', 'custom_ops': \['all'\], 'ir_enable_torch_wrap': False, 'splitting_ops': [ ], 'compile_mm_encoder': False, 'cudagraph_mm_encoder': False, 'encoder_cudagraph_token_budgets': [ ], 'encoder_cudagraph_max_vision_items_per_batch': 0, 'encoder_cudagraph_max_frames_per_batch': None, 'compile_sizes': [ ], 'compile_ranges_endpoints': \[8192\], 'inductor_compile_config': {'enable_auto_functionalized_v2': False, 'combo_kernels': True, 'benchmark_combo_kernel': True}, 'inductor_passes': {}, 'cudagraph_mode': <CUDAGraphMode.FULL_AND_PIECEWISE: (2, 1)>, 'cudagraph_num_of_warmups': 1, 'cudagraph_capture_sizes': \[1, 2, 4, 6, 8, 12, 16, 24, 32, 40, 48, 56, 64, 72, 80, 88, 96\], 'cudagraph_copy_inputs': False, 'cudagraph_specialize_lora': True, 'use_inductor_graph_partition': False, 'pass_config': {'fuse_norm_quant': True, 'fuse_act_quant': True, 'fuse_attn_quant': False, 'enable_sp': False, 'fuse_gemm_comms': False, 'fuse_allreduce_rms': False, 'enable_qk_norm_rope_fusion': False, 'fuse_rope_kvcache_cat_mla': False, 'fuse_act_padding': False, 'fuse_qk_norm_rope_kvcache': False}, 'max_cudagraph_capture_size': 96, 'dynamic_shapes_config': {'type': <DynamicShapesType.BACKED: 'backed'>, 'evaluate_guards': False, 'assume_32_bit_indexing': False}, 'local_cache_dir': None, 'fast_moe_cold_start': False, 'static_all_moe_layers': [ ]}, kernel_config=KernelConfig(ir_op_priority=IrOpPriorityConfig(rms_norm=\['vllm_c', 'native'\], fused_add_rms_norm=\['vllm_c', 'native'\], gelu_and_mul_sparse=\['triton', 'native'\]), enable_flashinfer_autotune=False, enable_b12x_autotune=True, enable_cutedsl_warmup=True, enable_jit_warmup=True, enable_bf16x3_router_gemm=False, moe_backend='auto', sparse_indexer_topk_backend='auto', linear_backend='b12x', linear_backend_per_quant=None)
(EngineCore pid=217) \[transformers\] Unrecognized keys in rope_parameters for 'rope_type'='default': {'mrope_section', 'mrope_interleaved'}
(EngineCore pid=217) /usr/local/lib/python3.12/dist-packages/transformers/configuration_utils.py:723: FutureWarning: rope_scaling is deprecated and will be removed in a future version. Set rope_parameters instead, with rope_type and rope_theta included.
(EngineCore pid=217) warnings.warn(
(EngineCore pid=217) INFO 11-06 23:01:12 \[parallel_state.py:1909\] world_size=1 rank=0 local_rank=0 distributed_init_method=file:///tmp/vllm_dist_8c610814c7c14a078876ad5064969802 backend=nccl
(EngineCore pid=217) INFO 11-06 23:01:12 \[parallel_state.py:2349\] rank 0 in world size 1 is assigned as DP rank 0, PP rank 0, PCP rank 0, TP rank 0, ETP rank 0, EP rank 0, EPLB rank N/A
(EngineCore pid=217) INFO 11-06 23:01:12 \[gpu_worker.py:480\] Using V2 Model Runner
(EngineCore pid=217) /usr/local/lib/python3.12/dist-packages/torch/cuda/init.py:1300: UserWarning: Attempting to run cuBLAS, but there was no current CUDA context! Attempting to set the primary context... (Triggered internally at /\__w/pytorch/pytorch/aten/src/ATen/cuda/CublasHandlePool.cpp:408.)
(EngineCore pid=217) return torch.\_C.\_cuda_getCurrentBlasHandle()
(EngineCore pid=217) INFO 11-06 23:01:13 \[model_runner.py:424\] Loading model from scratch...
(EngineCore pid=217) INFO 11-06 23:01:13 \[cuda.py:611\] Using backend AttentionBackendEnum.FLASH_ATTN for vit attention
(EngineCore pid=217) INFO 11-06 23:01:13 \[mm_encoder_attention.py:372\] Using AttentionBackendEnum.FLASH_ATTN for MMEncoderAttention.
(EngineCore pid=217) INFO 11-06 23:01:16 \[init.py:726\] Selected B12xFp8BlockScaledMMKernel for Fp8LinearMethod
(EngineCore pid=217) INFO 11-06 23:01:16 \[qwen_gdn_linear_attn.py:425\] Using b12x CuTeDSL GDN prefill kernel (requested=b12x, head_k_dim=128).
(EngineCore pid=217) INFO 11-06 23:01:16 \[qwen_gdn_linear_attn.py:821\] GDN decode kernel: b12x
(EngineCore pid=217) INFO 11-06 23:01:16 \[int_wna16.py:325\] Using 'MARLIN' WNA16 MoE backend.
(EngineCore pid=217) INFO 11-06 23:01:16 \[mamba_utils.py:38\] VLLM_SSM_CONV_STATE_LAYOUT env detected. Setting SSM conv state layout to DS.
(APIServer pid=97) \[transformers\] Qwen3VL video processing does not apply the per-frame pixel cap the reference implementation (qwen-vl-utils) applies, so some videos cost far more tokens than they would there. In v5.22 the capped behavior will become the default and cap_pixels_per_frame will be removed. Pass cap_pixels_per_frame=True to adopt the reference behavior now, or False to keep the current behavior and silence this warning.
(APIServer pid=97) INFO 11-06 23:01:19 \[base.py:261\] Multi-modal warmup completed in 8.118s
(APIServer pid=97) INFO 11-06 23:01:19 \[base.py:261\] Readonly multi-modal warmup completed in 0.522s
(EngineCore pid=217) WARNING 11-06 23:01:21 \[init.py:366\] --linear-backend=b12x has no kernel for this linear layer type; using automatic selection for that layer type.
(EngineCore pid=217) INFO 11-06 23:01:21 \[auto_gptq.py:353\] Using MarlinLinearKernel for AutoGPTQLinearMethod
(EngineCore pid=217) /usr/local/lib/python3.12/dist-packages/fastsafetensors/copier/gds.py:471: UserWarning: GDS device node /dev/nvidia-fs0 not found; falling back to nogds copier to avoid cuFileDriverOpen() corrupting fd 0.
Loading fastsafetensors checkpoint shards: 0% Completed | 0/1 \[00:00<?, ?it/s\]
Loading fastsafetensors checkpoint shards: 100% Completed | 1/1 \[00:00<00:00, 2.70it/s\]
Loading fastsafetensors checkpoint shards: 100% Completed | 1/1 \[00:00<00:00, 2.69it/s\]
(EngineCore pid=217) INFO 11-06 23:01:47 \[default_loader.py:575\] Loading weights took 24.84 seconds
(EngineCore pid=217) INFO 11-06 23:01:47 \[int_wna16.py:435\] Using MoEPrepareAndFinalizeNoDPEPModular
(EngineCore pid=217) INFO 11-06 23:01:47 \[int_wna16.py:436\] Using MarlinExperts
(EngineCore pid=217) INFO 11-06 23:01:55 \[vllm.py:1497\] Resolved Engram configuration: EngramConfig(cpu_offload=True, embedding_across_dp=False, dp_shared_memory=False, table_memory='device', disk_resident_scales=False, projection_tp=False)
(EngineCore pid=217) INFO 11-06 23:01:55 \[kernel.py:430\] Final IR op priority after setting platform defaults: IrOpPriorityConfig(rms_norm=\['vllm_c', 'native'\], fused_add_rms_norm=\['vllm_c', 'native'\], gelu_and_mul_sparse=\['triton', 'native'\])
(EngineCore pid=217) INFO 11-06 23:01:55 \[compilation.py:336\] Enabled custom fusions: norm_quant, act_quant
(EngineCore pid=217) INFO 11-06 23:01:55 \[unquantized.py:319\] Using FlashInfer CUTLASS Unquantized MoE backend out of potential backends: \['FlashInfer TRTLLM', 'FlashInfer CUTLASS', 'TRITON', 'BATCHED_TRITON'\].
(EngineCore pid=217) INFO 11-06 23:01:56 \[weight_utils.py:705\] Safetensors index filter selected 3/3 checkpoint shards.
Loading fastsafetensors checkpoint shards: 100% Completed | 1/1 \[00:00<00:00, 3.68it/s\]
Loading fastsafetensors checkpoint shards: 100% Completed | 1/1 \[00:00<00:00, 11.08it/s\]
Loading fastsafetensors checkpoint shards: 100% Completed | 1/1 \[00:01<00:00, 1.03s/it\]
(EngineCore pid=217) INFO 11-06 23:01:57 \[default_loader.py:575\] Loading weights took 1.40 seconds
(EngineCore pid=217) INFO 11-06 23:01:57 \[unquantized.py:400\] Using MoEPrepareAndFinalizeNoDPEPModular
(EngineCore pid=217) INFO 11-06 23:01:57 \[unquantized.py:401\] Using FlashInferExperts MoE backend
(EngineCore pid=217) WARNING 11-06 23:01:57 \[speculator.py:240\] Draft model Qwen4ExpMTP does not support external multimodal embeddings. Embeddings from the target model will not be passed to the drafter; using text-only draft inputs instead.
(EngineCore pid=217) INFO 11-06 23:01:58 \[model_runner.py:456\] Model loading took 73.47 GiB memory and 44.932671 seconds
(EngineCore pid=217) INFO 11-06 23:01:58 \[topk_topp_sampler.py:80\] Using FlashInfer for top-p & top-k sampling.
(EngineCore pid=217) INFO 11-06 23:01:58 \[interface.py:1084\] Padding mamba page size by 4.15% to ensure that mamba page size and attention page size are exactly equal.
(EngineCore pid=217) INFO 11-06 23:01:58 \[utils.py:407\] Using BLHNC KV cache layout.
(EngineCore pid=217) \[transformers\] The use_fast parameter is deprecated and will be removed in a future version. Use backend="torchvision" instead of use_fast=True, or backend="pil" instead of use_fast=False.
(EngineCore pid=217) INFO 11-06 23:02:01 \[b12x_prepare.py:576\] b12x weights preparation uses 4 compiler workers
b12x selecting gemm.blockscaled.fixed: 0/152 ready, candidates 0/1 prepared, 0 measured, 3 cached, 0 compilations, 0:00
b12x priming gemm.blockscaled.fixed: 64/152 ready, candidates 0/1 prepared, 0 measured, 3 cached, 0 compilations, 0:00
b12x selecting norm.hyperconnection: 116/152 ready, 0 measured, 3 cached, 0 compilations, 0:00
b12x ready sequence.mtp_feedback: 152/152 ready, 0 measured, 3 cached, 0 compilations, 0:01
(EngineCore pid=217) INFO 11-06 23:02:03 \[encoder_runner.py:131\] Encoder cache will be initialized with a budget of 16384 tokens, and profiled with 1 image items of the maximum feature size.
(EngineCore pid=217) 2026-11-06 23:02:19,544 - INFO - core.py:595 - flashinfer.jit: Building JIT module fused_moe_120; this can take several minutes on first use.
(APIServer pid=97) INFO 11-06 23:02:32 \[utils.py:632\] \[shutdown\] Process manager: send sigterm to process EngineCore
(APIServer pid=97) Traceback (most recent call last):
(APIServer pid=97) File "/usr/local/bin/vllm", line 10, in
(APIServer pid=97) sys.exit(main())
(APIServer pid=97) ^^^^^^
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/cli/main.py", line 106, in main
(APIServer pid=97) args.dispatch_function(args)
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/cli/serve.py", line 184, in cmd
(APIServer pid=97) uvloop.run(run_server(args))
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/uvloop/init.py", line 96, in run
(APIServer pid=97) return \__asyncio.run(
(APIServer pid=97) ^^^^^^^^^^^^^^
(APIServer pid=97) File "/usr/lib/python3.12/asyncio/runners.py", line 194, in run
(APIServer pid=97) return runner.run(main)
(APIServer pid=97) ^^^^^^^^^^^^^^^^
(APIServer pid=97) File "/usr/lib/python3.12/asyncio/runners.py", line 118, in run
(APIServer pid=97) return self.\_loop.run_until_complete(task)
(APIServer pid=97) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=97) File "uvloop/loop.pyx", line 1515, in uvloop.loop.Loop.run_until_complete
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/uvloop/init.py", line 48, in wrapper
(APIServer pid=97) return await main
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/launchers/api_server/entry.py", line 176, in run_server
(APIServer pid=97) await run_server_worker(listen_address, sock, args, \*\*uvicorn_kwargs)
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/launchers/api_server/entry.py", line 190, in run_server_worker
(APIServer pid=97) async with build_async_engine_client(
(APIServer pid=97) File "/usr/lib/python3.12/contextlib.py", line 210, in aenter
(APIServer pid=97) return await anext(self.gen)
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/launchers/api_server/entry.py", line 58, in build_async_engine_client
(APIServer pid=97) async with build_async_engine_client_from_engine_args(
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/entrypoints/launchers/api_server/entry.py", line 94, in build_async_engine_client_from_engine_args
(APIServer pid=97) async_llm = AsyncLLM.from_vllm_config(
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/async_llm.py", line 238, in from_vllm_config
(APIServer pid=97) return cls(
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/async_llm.py", line 172, in init
(APIServer pid=97) self.engine_core = EngineCoreClient.make_async_mp_client(
(APIServer pid=97) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/tracing/otel.py", line 178, in sync_wrapper
(APIServer pid=97) return func(\*args, \*\*kwargs)
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core_client.py", line 163, in make_async_mp_client
(APIServer pid=97) return AsyncMPClient(
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core_client.py", line 1096, in init
(APIServer pid=97) super().init(
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/core_client.py", line 681, in init
(APIServer pid=97) with launch_core_engines(
(APIServer pid=97) File "/usr/lib/python3.12/contextlib.py", line 144, in exit
(APIServer pid=97) next(self.gen)
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/utils.py", line 1253, in launch_core_engines
(APIServer pid=97) wait_for_engine_startup(
(APIServer pid=97) File "/usr/local/lib/python3.12/dist-packages/vllm/v1/engine/utils.py", line 1333, in wait_for_engine_startup
(APIServer pid=97) raise RuntimeError(
(APIServer pid=97) RuntimeError: Engine core initialization failed. See root cause above. Failed core proc(s): {}
/usr/lib/python3.12/multiprocessing/resource_tracker.py:254: UserWarning: resource_tracker: There appear to be 1 leaked semaphore objects to clean up at shutdown
warnings.warn('resource_tracker: There appear to be %d '
