We updated the pinmux (JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegra234-mb1-bct-gpio-p3767-dp-a03.dtsi) and run the following commands below:
sudo ./build_l4t_bup.sh jetson-orin-nano-devkit nvme0n1p1
sudo ./l4t_generate_soc_bup.sh -e t23x_3767_bl_spec t23x
./generate_capsule/l4t_generate_soc_capsule.sh -i bootloader/payloads_t23x/bl_only_payload -o ./TEGRA_BL.Cap t234
And here are the outputs:
ubuntu@ubuntu-desktop:~/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TAR
GETS/Linux_for_Tegra$ sudo ./build_l4t_bup.sh jetson-orin-nano-devkit nvme0n1p1
[sudo] password for ubuntu:
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
copying emc_fuse_dev_params(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-diag-boot.dts)... done.
copying device_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3767-0000.dts)... done.
copying misc_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3767-0000.dts)... done.
./tegraflash.py --chip 0x23 --applet "/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin" --skipuid --cfg readinfo_t234_min_prod.xml --dev_params tegra234-br-bct-diag-boot.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --bins "mb2_applet applet_t234.bin" --cmd "dump eeprom cvm cvm.bin; dump custinfo custinfo_out.bin; reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[ 0.0354 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 0.0372 ] File rcm_state open failed
[ 0.0379 ] ERROR: failed to read rcm_state
[ 0.0379 ]
[ 0.0389 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0392 ] Assuming zero filled SBK key
[ 0.0385 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.0793 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.0938 ] Parsing partition layout
[ 0.0952 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.0977 ] Kernel DTB used: None
[ 0.0977 ] WARNING: dce base dtb is not provided
[ 0.0977 ] Parsing partition layout
[ 0.0990 ] tegraparser_v2 --pt readinfo_t234_min_prod.xml.tmp
[ 0.1010 ] Creating list of images to be signed
[ 0.1024 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --list images_list.xml zerosbk
[ 0.1036 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.1049 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.1053 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 0.1104 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 0.1108 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1154 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1158 ] adding BCH for mb2_t234_aligned.bin
[ 0.1185 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 0.1311 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 0.1314 ] adding BCH for mb2_t234_aligned.bin
[ 0.1468 ] Filling MB1 storage info
[ 0.1468 ] Parsing dev params for multi chains
[ 0.1572 ] Generating br-bct
[ 0.1592 ] Updating dev and MSS params in BR BCT
[ 0.1592 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1611 ] Updating bl info
[ 0.1634 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin
[ 0.1652 ] WARNING: boot chain is not completed. set to 0
[ 0.1659 ] Generating signatures
[ 0.1669 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.1671 ] Assuming zero filled SBK key
[ 0.1864 ] Warning: pub_key.key is not found
[ 0.1857 ] Parsing dev params for multi chains
[ 0.1857 ] Generating br-bct
[ 0.1870 ] Updating dev and MSS params in BR BCT
[ 0.1871 ] tegrabct_v2 --dev_param tegra234-br-bct-diag-boot_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 0.1892 ] Updating bl info
[ 0.1910 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.1927 ] WARNING: boot chain is not completed. set to 0
[ 0.1943 ] Get Signed section of bct
[ 0.1968 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 0.1988 ] Signing BCT
[ 0.1998 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2001 ] Assuming zero filled SBK key
[ 0.2052 ] Sha saved in br_bct_BR.sha
[ 0.2058 ] Warning: pub_key.key is not found
[ 0.2049 ] Updating BCT with signature
[ 0.2067 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 0.2085 ] Offset :4608 Len :3584
[ 0.2089 ] Generating SHA2 Hash
[ 0.2099 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 0.2101 ] Assuming zero filled SBK key
[ 0.2102 ] Assuming zero filled SBK key
[ 0.2154 ] Sha saved in br_bct_BR.sha
[ 0.2149 ] Updating BCT with SHA2 Hash
[ 0.2169 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 0.2184 ] Offset :4608 Len :3584
[ 0.2187 ] Offset :68 Len :8124
[ 0.2190 ] Generating coldboot mb1-bct
[ 0.2207 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.2224 ] MB1-BCT version: 0.10
[ 0.2228 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2235 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2242 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2249 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2249 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.2249 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.2250 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.2250 ]
[ 0.2250 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.2251 ] Added Platform Config 9 data with size :- 100
[ 0.2251 ]
[ 0.2251 ] Updating mb1-bct with firmware information
[ 0.2270 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.2316 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 0.2359 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 0.2382 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 0.2404 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2406 ] Assuming zero filled SBK key
[ 0.2426 ] Warning: pub_key.key is not found
[ 0.2436 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.2456 ] Generating recovery mb1-bct
[ 0.2474 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.2491 ] MB1-BCT version: 0.10
[ 0.2496 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2503 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2510 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 0.2516 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2519 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 0.2519 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 0.2519 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 0.2519 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 0.2519 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 0.2519 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 0.2519 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 0.2519 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 0.2520 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 0.2520 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 0.2520 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 0.2520 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 0.2520 ]
[ 0.2520 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 0.2520 ] Added Platform Config 9 data with size :- 100
[ 0.2520 ]
[ 0.2521 ] Updating mb1-bct with firmware information
[ 0.2539 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo readinfo_t234_min_prod.xml.bin
[ 0.2579 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 0.2621 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 0.2642 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 0.2665 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.2668 ] Assuming zero filled SBK key
[ 0.2703 ] Warning: pub_key.key is not found
[ 0.2719 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 0.2744 ] Error: Skip generating mem_bct because sdram_config is not defined
[ 0.2745 ] Copying signatures
[ 0.2763 ] tegrahost_v2 --chip 0x23 0 --partitionlayout readinfo_t234_min_prod.xml.bin --updatesig images_list_signed.xml
[ 0.2833 ] mb1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2836 ] psc_bl1_t234_prod_aligned_sigheader.bin.encrypt filename is from images_list
[ 0.2836 ] Boot Rom communication
[ 0.2858 ] tegrarcm_v2 --new_session --chip 0x23 0 --uid --download bct_br br_bct_BR.bct --download mb1 mb1_t234_prod_aligned_sigheader.bin.encrypt --download psc_bl1 psc_bl1_t234_prod_aligned_sigheader.bin.encrypt --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt
[ 0.2876 ] BR_CID: 0x80012344705DD75B6C00000007FF0280
[ 0.4888 ] Sending bct_br
[ 0.6918 ] Sending mb1
[ 0.6923 ] Sending psc_bl1
[ 0.7007 ] Sending bct_mb1
[ 0.7060 ] Boot Rom communication completed
[ 0.7084 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 0.7119 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --appendsigheader applet_t234_aligned.bin zerosbk
[ 0.7136 ] adding BCH for applet_t234_aligned.bin
[ 0.7322 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 0.7325 ] Assuming zero filled SBK key
[ 0.7367 ] Warning: pub_key.key is not found
[ 0.7378 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 0.7433 ] Sending mb2_applet...
[ 0.7452 ] tegrarcm_v2 --chip 0x23 0 --pollbl --download applet applet_t234_sigheader.bin.encrypt
[ 0.7469 ] BL: version 0.32.0.0-t234-54845784-57325615 last_boot_error: 0
[ 0.9361 ] Sending applet
[ 1.1611 ] completed
[ 1.1633 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.1657 ] MB2 Applet version 01.00.0000
[ 1.3789 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 1.3806 ] MB2 Applet version 01.00.0000
[ 1.5833 ] Retrieving board information
[ 1.5853 ] tegrarcm_v2 --chip 0x23 0 --oem platformdetails chip chip_info.bin
[ 1.5873 ] MB2 Applet version 01.00.0000
[ 1.7815 ] Saved platform info in chip_info.bin
[ 1.7868 ] Chip minor revision: 1
[ 1.7869 ] Bootrom revision: 0x7
[ 1.7870 ] Ram code: 0x0
[ 1.7870 ] Chip sku: 0xd3
[ 1.7871 ] Chip Sample: prod
[ 1.7876 ] Retrieving EEPROM data
[ 1.7877 ] tegrarcm_v2 --oem platformdetails eeprom cvm /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin --chip 0x23 0
[ 1.7894 ] MB2 Applet version 01.00.0000
[ 1.9895 ] Saved platform info in /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/cvm.bin
[ 2.0233 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 2.0249 ] MB2 Applet version 01.00.0000
[ 2.2233 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 2.2251 ] MB2 Applet version 01.00.0000
[ 2.3696 ] Dumping customer Info
[ 2.3722 ] tegrarcm_v2 --chip 0x23 0 --oem dump bct tmp.bct
[ 2.3745 ] MB2 Applet version 01.00.0000
[ 2.5656 ] Saved bct in tmp.bct
[ 2.5750 ] tegrabct_v2 --brbct tmp.bct --chip 0x23 0 --custinfo /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin
[ 2.5770 ] Custo[ 2.5775 ] mer data saved in /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/custinfo_out.bin successfully
[ 2.5776 ] Rebooting to recovery mode
[ 2.5796 ] tegrarcm_v2 --chip 0x23 0 --ismb2
[ 2.7797 ] tegrarcm_v2 --chip 0x23 0 --ismb2applet
[ 2.7819 ] MB2 Applet version 01.00.0000
[ 2.9775 ] Booting to recovery mode
[ 2.9794 ] tegrarcm_v2 --chip 0x23 0 --reboot recovery
[ 2.9816 ] MB2 Applet version 01.00.0000
Board ID(3767) version(RC1) sku(0000) revision(B.6)
Chip SKU(00:00:00:D3) ramcode(00:00:00:00) fuselevel(fuselevel_production) board_FAB(RC1)
emc_opt_disable_fuse:(0)
copying bctfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-sdram-l4t.dts)... done.
copying minratchet_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-ratchet-p3767-0000.dts)... done.
copying pinmux_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi)... done.
copying gpioint_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3767-0000.dts)... done.
copying pmic_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3767-0000-a02.dts)... done.
copying pmc_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi)... done.
copying deviceprod_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3767-0000.dts)... done.
copying prod_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3767-0000.dts)... done.
copying scr_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3767-0000.dts)... done.
copying wb0sdram(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3767-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3767-0000.dts)... done.
Existing uphylane_config(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3767-0000-l4t.dts)... done.
copying dev_params_b(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3767-0000-l4t.dts)... done.
copying mb2bct_cfg(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3767-0000.dts)... done.
Existing pscfwfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... done.
Not signing of boot.img
Existing sosfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing tegraboot(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing cpu_bootloader(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing mb2blfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
Existing xusbfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/xusb_t234_prod.bin) reused.
Existing dcefile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/display-t234-dce.bin) reused.
Existing nvdecfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/nvdec_t234_prod.fw) reused.
Existing psc_rf(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/psc_rf_t234_prod.bin) reused.
Existing mb2_rf(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb2rf_t234.bin) reused.
Existing mb1file(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/mb1_t234_prod.bin) reused.
Existing bpffile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/bpmp_t234-TE990M-A1_prod.bin) reused.
copying bpfdtbfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/tegra234-bpmp-3767-0000-a02-3509-a02.dtb)... done.
Existing scefile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/camera-rtcpu-t234-rce.img) reused.
Existing apefile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/adsp-fw.bin) reused.
Existing spefile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/spe_t234.bin) reused.
Existing wb0boot(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/sc7_t234_prod.bin) reused.
Existing tosfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tos-optee_t234.img) reused.
Existing eksfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/eks_t234.img) reused.
copying dtbfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3768-0000-a0.dtb)... done.
Copying nv_boot_control.conf to rootfs
Skip generating system.img
Not signing of kernel-dtb
Existing tbcfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/uefi_jetson.bin) reused.
copying tbcdtbfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-0000-p3768-0000-a0.dtb)... done.
copying cfgfile(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/t186ref/cfg/flash_t234_qspi_sd.xml) to flash.xml... done.
Existing flashapp(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/tegraflash.py) reused.
copying overlay_dtb(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/L4TConfiguration.dtbo)... done.
copying overlay_dtb(/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/kernel/dtb/tegra234-p3767-overlay.dtbo)... done.
./tegraflash.py --bl uefi_jetson_with_dtb.bin --odmdata gbe-uphy-config-9,hsstp-lane-map-3,hsio-uphy-config-0 --overlay_dtb L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo, --bldtb tegra234-p3767-0000-p3768-0000-a0.dtb --applet mb1_t234_prod.bin --cmd "sign" --cfg flash.xml --chip 0x23 --concat_cpubl_bldtb --cpubl uefi_jetson.bin --minratchet_config tegra234-mb1-bct-ratchet-p3767-0000.dts --device_config tegra234-mb1-bct-device-p3767-0000.dts --misc_config tegra234-mb1-bct-misc-p3767-0000.dts --pinmux_config tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi --gpioint_config tegra234-mb1-bct-gpioint-p3767-0000.dts --pmic_config tegra234-mb1-bct-pmic-p3767-0000-a02.dts --pmc_config tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi --deviceprod_config tegra234-mb1-bct-cprod-p3767-0000.dts --prod_config tegra234-mb1-bct-prod-p3767-0000.dts --scr_config tegra234-mb2-bct-scr-p3767-0000.dts --wb0sdram_config tegra234-p3767-0000-wb0sdram-l4t.dts --br_cmd_config tegra234-mb1-bct-reset-p3767-0000.dts --uphy tegra234-mb1-bct-uphylane-si.dtsi --dev_params tegra234-br-bct-p3767-0000-l4t.dts,tegra234-br-bct_b-p3767-0000-l4t.dts --mb2bct_cfg tegra234-mb2-bct-misc-p3767-0000.dts --bins "psc_fw pscfw_t234_prod.bin; mts_mce mce_flash_o10_cr_prod.bin; mb2_applet applet_t234.bin; mb2_bootloader mb2_t234.bin; xusb_fw xusb_t234_prod.bin; dce_fw display-t234-dce.bin; nvdec nvdec_t234_prod.fw; bpmp_fw bpmp_t234-TE990M-A1_prod.bin; bpmp_fw_dtb tegra234-bpmp-3767-0000-a02-3509-a02.dtb; sce_fw camera-rtcpu-sce.img; rce_fw camera-rtcpu-t234-rce.img; ape_fw adsp-fw.bin; spe_fw spe_t234.bin; tos tos-optee_t234.img; eks eks_t234.img" --sdram_config tegra234-p3767-0000-sdram-l4t.dts --cust_info custinfo_out.bin --secondary_gpt_backup --bct_backup --boot_chain A
saving flash command in /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/flashcmd.txt
saving Windows flash command to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/flash_win.bat
*** Sign and generate BUP... ***
Signing with zerosbk ...
rollback info is parsed and saved in rollback.bin
WARNING: failed to find rollback config for " t186ref "
pad ZEROs to the end of rollback.bin
Generating signed binaries for 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit- ...
version 1.0.0
[ 0.0256 ] tegrasign_v3.py --key None --getmode mode.txt
[ 0.0257 ] Assuming zero filled SBK key
[ 0.0297 ] Parsing partition layout
[ 0.0315 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.0377 ] Change tegra234-bpmp-3767-0000-a02-3509-a02.dtb to tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb
[ 0.0655 ] /usr/bin/python3 dtbcheck.py -c t234 -o tegra234-bpmp-3767-0000-a02-3509-a02_with_odm.dtb tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_tmp.dtb
[ 0.4809 ] Concatenating L4TConfiguration.dtbo,tegra234-p3767-overlay.dtbo to tegra234-p3767-0000-p3768-0000-a0_with_odm_overlay.dtb
[ 0.4811 ] Concatenating bl dtb to cpubl binary
[ 0.4855 ] MB2 binary: mb2_t234.bin
[ 0.4855 ] Pre-processing mb2bct config: tegra234-mb2-bct-misc-p3767-0000.dts
[ 0.5005 ] Pre-processing mb2bct config: tegra234-mb2-bct-scr-p3767-0000.dts
[ 0.7211 ] Generating coldboot mb2-bct
[ 0.7211 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct.cfg --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 0.7227 ] WARNING: unknown property 'tfc_version'
[ 0.7240 ] WARNING: unknown property 'addr_header_version'
[ 0.7385 ] Updating mb2-bct with storage information
[ 0.7412 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_cold_boot_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 0.7440 ] Concatenating mb2-bct to mb2 binary
[ 0.7440 ] mb2_bin_file = mb2_t234.bin
[ 0.7440 ] mb2_bct_file = mb2_cold_boot_bct_MB2.bct
[ 0.7511 ] DCE binary: display-t234-dce.bin
[ 0.7512 ] Kernel DTB used: kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
[ 0.7512 ] Concatenating kernel-dtb to dce-fw binary
[ 0.7512 ] dce_bin = display-t234-dce.bin
[ 0.7513 ] kernel_dtb = kernel_tegra234-p3767-0000-p3768-0000-a0.dtb
[ 0.7513 ] dce_with_dtb = display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0.bin
[ 0.7719 ] Update display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0.bin to dce_fw partitions
[ 0.7767 ] Parsing partition layout
[ 0.7794 ] tegraparser_v2 --pt flash.xml.tmp
[ 0.7822 ] Creating list of images to be signed
[ 0.7849 ] Generating ratchet blob
[ 0.7850 ] Pre-processing config: tegra234-mb1-bct-reset-p3767-0000.dts
[ 0.7967 ] Pre-processing config: tegra234-mb1-bct-device-p3767-0000.dts
[ 0.8076 ] Pre-processing config: tegra234-mb1-bct-cprod-p3767-0000.dts
[ 0.8176 ] Pre-processing config: tegra234-mb1-bct-gpioint-p3767-0000.dts
[ 0.8304 ] Pre-processing config: tegra234-mb1-bct-misc-p3767-0000.dts
[ 0.8453 ] Pre-processing config: tegra234-mb1-bct-pinmux-p3767-dp-a03.dtsi
[ 0.8660 ] Pre-processing config: tegra234-mb1-bct-padvoltage-p3767-dp-a03.dtsi
[ 0.8761 ] Pre-processing config: tegra234-mb1-bct-pmic-p3767-0000-a02.dts
[ 0.8895 ] Pre-processing config: tegra234-mb1-bct-prod-p3767-0000.dts
[ 0.9005 ] Pre-processing config: tegra234-p3767-0000-sdram-l4t.dts
[ 2.7329 ] Pre-processing config: tegra234-mb1-bct-uphylane-si.dtsi
[ 2.7436 ] Pre-processing config: tegra234-p3767-0000-wb0sdram-l4t.dts
[ 4.5769 ] Pre-processing config: tegra234-mb1-bct-ratchet-p3767-0000.dts
[ 4.5896 ] Generating coldboot mb1-bct
[ 4.5912 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 4.5933 ] MB1-BCT version: 0.10
[ 4.5938 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 4.5946 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 4.5952 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 4.5958 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 4.5965 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 4.5971 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 4.5978 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 4.5982 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 4.5989 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 4.5995 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 4.6002 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 4.6002 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 4.6002 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 4.6002 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 4.6002 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 4.6002 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 4.6002 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 4.6002 ]
[ 4.6002 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 4.6002 ] Added Platform Config 0 data with size :- 2416
[ 4.6002 ]
[ 4.6003 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 4.6003 ] WARNING: unknown node 'g2'
[ 4.6003 ] WARNING: unknown node 'g9'
[ 4.6003 ] Added Platform Config 2 data with size :- 24
[ 4.6003 ]
[ 4.6003 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 4.6003 ] Added Platform Config 4 data with size :- 288
[ 4.6003 ]
[ 4.6003 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 4.6003 ] Added Platform Config 3 data with size :- 52
[ 4.6003 ]
[ 4.6003 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 4.6004 ] WARNING: unknown property 'major'
[ 4.6004 ] WARNING: unknown property 'minor'
[ 4.6004 ] Added Platform Config 5 data with size :- 500
[ 4.6004 ]
[ 4.6004 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 4.6004 ] Added Platform Config 7 data with size :- 380
[ 4.6004 ]
[ 4.6004 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 4.6004 ] Added Platform Config 8 data with size :- 24
[ 4.6004 ]
[ 4.6004 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 4.6004 ] Added Platform Config 9 data with size :- 100
[ 4.6005 ]
[ 4.6005 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 4.6005 ] ModuleCount 0 NumProdNames 0
[ 4.6005 ] Added Platform Config 6 data with size :- 16
[ 4.6005 ]
[ 4.6005 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 4.6005 ]
[ 4.6005 ] Updating mb1-bct with firmware information
[ 4.6027 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 4.6107 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 4.6150 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 4.6176 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 4.6202 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 4.6204 ] Assuming zero filled SBK key
[ 4.6234 ] Warning: pub_key.key is not found
[ 4.6246 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 4.6269 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[ 4.6290 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 4.6311 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 4.6319 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 4.6410 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 4.6415 ] Header already present for nvdec_t234_prod_aligned.fw
[ 4.6464 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 4.6576 ] adding BCH for xusb_t234_prod_aligned.bin
[ 4.6812 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 4.6889 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 4.7058 ] Header already present for pscfw_t234_prod_aligned.bin
[ 4.7108 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 4.7171 ] Header already present for sc7_t234_prod.bin
[ 4.7203 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 4.7233 ] adding BCH for mb2rf_t234_aligned.bin
[ 4.7254 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 4.7370 ] adding BCH for tos-optee_t234_aligned.img
[ 4.8378 ] adding BCH for eks_t234_aligned.img
[ 4.8707 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin
[ 5.0323 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin, ratio = 7%
[ 5.0476 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned_blob_w_bin_aligned.bin
[ 5.0657 ] adding BCH for spe_t234_aligned.bin
[ 5.0778 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 5.0874 ] adding BCH for adsp-fw_aligned.bin
[ 5.1047 ] MB1: Nvheader already present is mb1_t234_prod_aligned.bin
[ 5.1178 ] Header already present for mb1_t234_prod_aligned_sigheader.bin
[ 5.1183 ] MB1: Nvheader already present is psc_bl1_t234_prod_aligned.bin
[ 5.1231 ] Header already present for psc_bl1_t234_prod_aligned_sigheader.bin
[ 5.1234 ] Header already present for nvdec_t234_prod_aligned.fw
[ 5.1259 ] adding BCH for mb2_t234_with_mb2_cold_boot_bct_MB2_aligned.bin
[ 5.1320 ] adding BCH for xusb_t234_prod_aligned.bin
[ 5.1459 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 5.1542 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 5.1714 ] Header already present for pscfw_t234_prod_aligned.bin
[ 5.1766 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 5.1832 ] Header already present for sc7_t234_prod.bin
[ 5.1863 ] Header already present for psc_rf_t234_prod_aligned.bin
[ 5.1894 ] adding BCH for mb2rf_t234_aligned.bin
[ 5.1917 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 5.2046 ] adding BCH for tos-optee_t234_aligned.img
[ 5.3069 ] adding BCH for eks_t234_aligned.img
[ 5.3404 ] INFO: compressing display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin
[ 5.5106 ] INFO: complete compression, display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned.bin, ratio = 7%
[ 5.5262 ] adding BCH for display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned_blob_w_bin_aligned.bin
[ 5.5451 ] adding BCH for spe_t234_aligned.bin
[ 5.5578 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 5.5675 ] adding BCH for adsp-fw_aligned.bin
[ 5.5982 ] Filling MB1 storage info
[ 5.5982 ] Parsing dev params for multi chains
[ 5.6106 ] Generating br-bct
[ 5.6121 ] Updating dev and MSS params in BR BCT
[ 5.6121 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 5.7143 ] Updating bl info
[ 5.7166 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 5.7338 ] Generating br-bct
[ 5.7360 ] Updating dev and MSS params in BR BCT
[ 5.7361 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 5.8139 ] Updating bl info
[ 5.8160 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin
[ 5.8190 ] Generating BCT backup image
[ 5.8191 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 5.8240 ] 32768+0 records in
[ 5.9229 ] 32768+0 records out
[ 5.9229 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0982161 s, 334 kB/s
[ 5.9229 ]
[ 5.9230 ] Concatenating BCT for chain A to bct_backup.img
[ 5.9230 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 5.9257 ] 8192+0 records in
[ 5.9538 ] 8192+0 records out
[ 5.9538 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.027316 s, 300 kB/s
[ 5.9539 ]
[ 5.9539 ] Concatenating BCT for chain B to bct_backup.img
[ 5.9539 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 5.9572 ] 8192+0 records in
[ 5.9832 ] 8192+0 records out
[ 5.9833 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0254428 s, 322 kB/s
[ 5.9833 ]
[ 5.9833 ] Generating signatures
[ 5.9844 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key --sha sha512
[ 5.9846 ] Assuming zero filled SBK key
[ 6.1358 ] Warning: pub_key.key is not found
[ 6.1375 ] Parsing dev params for multi chains
[ 6.1375 ] Generating br-bct
[ 6.1390 ] Updating dev and MSS params in BR BCT
[ 6.1391 ] tegrabct_v2 --dev_param tegra234-br-bct-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.2143 ] Updating customer data section
[ 6.2159 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 6.2177 ] Updating bl info
[ 6.2198 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.2225 ] Get Signed section of bct
[ 6.2246 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 6.2263 ] Signing BCT
[ 6.2273 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.2275 ] Assuming zero filled SBK key
[ 6.2333 ] Sha saved in br_bct_BR.sha
[ 6.2336 ] Warning: pub_key.key is not found
[ 6.2326 ] Updating BCT with signature
[ 6.2342 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 6.2357 ] Offset :4608 Len :3584
[ 6.2362 ] Generating SHA2 Hash
[ 6.2372 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 6.2376 ] Assuming zero filled SBK key
[ 6.2448 ] Sha saved in br_bct_BR.sha
[ 6.2445 ] Updating BCT with SHA2 Hash
[ 6.2466 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 6.2492 ] Offset :4608 Len :3584
[ 6.2496 ] Offset :68 Len :8124
[ 6.2499 ] Generating br-bct
[ 6.2519 ] Updating dev and MSS params in BR BCT
[ 6.2520 ] tegrabct_v2 --dev_param tegra234-br-bct_b-p3767-0000-l4t_cpp.dtb --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --brbct br_bct.cfg --chip 0x23 0
[ 6.3291 ] Updating customer data section
[ 6.3306 ] tegrabct_v2 --chip 0x23 0 --brbct br_bct_BR.bct --update_custinfo custinfo_out.bin
[ 6.3325 ] Updating bl info
[ 6.3345 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[ 6.3372 ] Get Signed section of bct
[ 6.3394 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --listbct bct_list.xml
[ 6.3419 ] Signing BCT
[ 6.3429 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.3431 ] Assuming zero filled SBK key
[ 6.3480 ] Sha saved in br_bct_BR.sha
[ 6.3484 ] Warning: pub_key.key is not found
[ 6.3474 ] Updating BCT with signature
[ 6.3489 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesig bct_list_signed.xml
[ 6.3509 ] Offset :4608 Len :3584
[ 6.3517 ] Generating SHA2 Hash
[ 6.3527 ] tegrasign_v3.py --key None --list bct_list.xml --sha sha512
[ 6.3531 ] Assuming zero filled SBK key
[ 6.3597 ] Sha saved in br_bct_BR.sha
[ 6.3594 ] Updating BCT with SHA2 Hash
[ 6.3619 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x23 0 --updatesha bct_list_signed.xml
[ 6.3644 ] Offset :4608 Len :3584
[ 6.3650 ] Offset :68 Len :8124
[ 6.3654 ] Generating BCT backup image
[ 6.3654 ] dd if=/dev/zero of=bct_backup.img bs=1 count=32768
[ 6.3672 ] 32768+0 records in
[ 6.4405 ] 32768+0 records out
[ 6.4405 ] 32768 bytes (33 kB, 32 KiB) copied, 0.0726497 s, 451 kB/s
[ 6.4405 ]
[ 6.4405 ] Concatenating BCT for chain A to bct_backup.img
[ 6.4406 ] dd if=br_bct_BR.bct of=bct_backup.img bs=1 seek=0 conv=notrunc
[ 6.4438 ] 8192+0 records in
[ 6.4687 ] 8192+0 records out
[ 6.4687 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.024235 s, 338 kB/s
[ 6.4687 ]
[ 6.4688 ] Concatenating BCT for chain B to bct_backup.img
[ 6.4688 ] dd if=br_bct_b_BR.bct of=bct_backup.img bs=1 seek=16384 conv=notrunc
[ 6.4711 ] 8192+0 records in
[ 6.4888 ] 8192+0 records out
[ 6.4888 ] 8192 bytes (8.2 kB, 8.0 KiB) copied, 0.0173082 s, 473 kB/s
[ 6.4889 ]
[ 6.4889 ] Generating coldboot mb1-bct
[ 6.4911 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 6.4937 ] MB1-BCT version: 0.10
[ 6.4940 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.4948 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.4954 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.4961 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.4967 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.4973 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.4979 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 6.4983 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 6.4989 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 6.4994 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 6.4999 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 6.5003 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 6.5003 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 6.5003 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 6.5003 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 6.5003 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 6.5003 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 6.5003 ]
[ 6.5003 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 6.5004 ] Added Platform Config 0 data with size :- 2416
[ 6.5004 ]
[ 6.5004 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 6.5004 ] WARNING: unknown node 'g2'
[ 6.5004 ] WARNING: unknown node 'g9'
[ 6.5004 ] Added Platform Config 2 data with size :- 24
[ 6.5004 ]
[ 6.5004 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 6.5004 ] Added Platform Config 4 data with size :- 288
[ 6.5004 ]
[ 6.5004 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 6.5004 ] Added Platform Config 3 data with size :- 52
[ 6.5004 ]
[ 6.5004 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 6.5005 ] WARNING: unknown property 'major'
[ 6.5005 ] WARNING: unknown property 'minor'
[ 6.5005 ] Added Platform Config 5 data with size :- 500
[ 6.5005 ]
[ 6.5005 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 6.5005 ] Added Platform Config 7 data with size :- 380
[ 6.5005 ]
[ 6.5005 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 6.5005 ] Added Platform Config 8 data with size :- 24
[ 6.5005 ]
[ 6.5005 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 6.5005 ] Added Platform Config 9 data with size :- 100
[ 6.5005 ]
[ 6.5006 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 6.5006 ] ModuleCount 0 NumProdNames 0
[ 6.5006 ] Added Platform Config 6 data with size :- 16
[ 6.5006 ]
[ 6.5006 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 6.5006 ]
[ 6.5006 ] Updating mb1-bct with firmware information
[ 6.5033 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[ 6.5094 ] tegrahost_v2 --chip 0x23 0 --align mb1_cold_boot_bct_MB1_aligned.bct
[ 6.5136 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1_aligned.bct zerosbk
[ 6.5157 ] adding BCH for mb1_cold_boot_bct_MB1_aligned.bct
[ 6.5178 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.5181 ] Assuming zero filled SBK key
[ 6.5215 ] Warning: pub_key.key is not found
[ 6.5228 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_cold_boot_bct_MB1_aligned_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 6.5256 ] Generating recovery mb1-bct
[ 6.5282 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct.cfg --misc tegra234-mb1-bct-misc-p3767-0000_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --pinmux tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb --pmc tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb --pmic tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb --brcommand tegra234-mb1-bct-reset-p3767-0000_cpp.dtb --prod tegra234-mb1-bct-prod-p3767-0000_cpp.dtb --gpioint tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb --uphy tegra234-mb1-bct-uphylane-si_cpp.dtb --device tegra234-mb1-bct-device-p3767-0000_cpp.dtb --deviceprod tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb --minratchet tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb --ratchet_blob ratchet_blob.bin
[ 6.5303 ] MB1-BCT version: 0.10
[ 6.5306 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.5312 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.5319 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_UNUSED5/ is not supported
[ 6.5325 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.5332 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.5337 ] ERROR: carveout /misc/carveout/aux_info@CARVEOUT_MCE_COVERAGE/ is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_locking_config is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_locking_diff_configuration is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_locking_ref_frequency_configuration is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_locking_control is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_configuration is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_locking_fast_adjust_configuration is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_delta_control is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_capture_control_ptx is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_capture_config_ptx is not supported
[ 6.5337 ] ERROR: /misc/tsc_controls/tsc_stscrsr is not supported
[ 6.5338 ] ERROR: /misc/tsc_controls/tsc_locking_adjust_num_control is not supported
[ 6.5338 ]
[ 6.5338 ] Parsing config file :tegra234-mb1-bct-pinmux-p3767-dp-a03_cpp.dtb
[ 6.5338 ] Added Platform Config 0 data with size :- 2416
[ 6.5338 ]
[ 6.5338 ] Parsing config file :tegra234-mb1-bct-padvoltage-p3767-dp-a03_cpp.dtb
[ 6.5338 ] WARNING: unknown node 'g2'
[ 6.5338 ] WARNING: unknown node 'g9'
[ 6.5338 ] Added Platform Config 2 data with size :- 24
[ 6.5338 ]
[ 6.5339 ] Parsing config file :tegra234-mb1-bct-pmic-p3767-0000-a02_cpp.dtb
[ 6.5339 ] Added Platform Config 4 data with size :- 288
[ 6.5339 ]
[ 6.5339 ] Parsing config file :tegra234-mb1-bct-reset-p3767-0000_cpp.dtb
[ 6.5339 ] Added Platform Config 3 data with size :- 52
[ 6.5339 ]
[ 6.5339 ] Parsing config file :tegra234-mb1-bct-prod-p3767-0000_cpp.dtb
[ 6.5339 ] WARNING: unknown property 'major'
[ 6.5339 ] WARNING: unknown property 'minor'
[ 6.5339 ] Added Platform Config 5 data with size :- 500
[ 6.5339 ]
[ 6.5339 ] Parsing config file :tegra234-mb1-bct-gpioint-p3767-0000_cpp.dtb
[ 6.5340 ] WARNING: unknown property 'major'
[ 6.5340 ] WARNING: unknown property 'minor'
[ 6.5340 ] Added Platform Config 7 data with size :- 380
[ 6.5340 ]
[ 6.5340 ] Parsing config file :tegra234-mb1-bct-uphylane-si_cpp.dtb
[ 6.5340 ] Added Platform Config 8 data with size :- 24
[ 6.5340 ]
[ 6.5340 ] Parsing config file :tegra234-mb1-bct-device-p3767-0000_cpp.dtb
[ 6.5340 ] Added Platform Config 9 data with size :- 100
[ 6.5340 ]
[ 6.5340 ] Parsing config file :tegra234-mb1-bct-cprod-p3767-0000_cpp.dtb
[ 6.5340 ] ModuleCount 0 NumProdNames 0
[ 6.5341 ] Added Platform Config 6 data with size :- 16
[ 6.5341 ]
[ 6.5341 ] Parsing config file :tegra234-mb1-bct-ratchet-p3767-0000_cpp.dtb
[ 6.5341 ]
[ 6.5342 ] Updating mb1-bct with firmware information
[ 6.5368 ] tegrabct_v2 --chip 0x23 0 --mb1bct mb1_bct_MB1.bct --recov --updatefwinfo flash.xml.bin
[ 6.5427 ] tegrahost_v2 --chip 0x23 0 --align mb1_bct_MB1_aligned.bct
[ 6.5476 ] tegrahost_v2 --chip 0x23 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1_aligned.bct zerosbk
[ 6.5501 ] adding BCH for mb1_bct_MB1_aligned.bct
[ 6.5528 ] tegrasign_v3.py --key None --list mb1_bct_MB1_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.5531 ] Assuming zero filled SBK key
[ 6.5572 ] Warning: pub_key.key is not found
[ 6.5590 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb1_bct_MB1_aligned_sigheader.bct.encrypt mb1_bct_MB1_aligned_sigheader.bct.hash zerosbk
[ 6.5619 ] Generating coldboot mem-bct
[ 6.5646 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[ 6.5666 ] packing sdram params with Wb0 file tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb
[ 6.6445 ] Packing sdram param for instance[0]
[ 6.6446 ] Packing sdram param for instance[1]
[ 6.6448 ] Packing sdram param for instance[2]
[ 6.6450 ] Packing sdram param for instance[3]
[ 6.6452 ] Packing sdram param for instance[4]
[ 6.6454 ] Packing sdram param for instance[5]
[ 6.6456 ] Packing sdram param for instance[6]
[ 6.6457 ] Packing sdram param for instance[7]
[ 6.6459 ] Packing sdram param for instance[8]
[ 6.6461 ] Packing sdram param for instance[9]
[ 6.6462 ] Packing sdram param for instance[10]
[ 6.6464 ] Packing sdram param for instance[11]
[ 6.6466 ] Packing sdram param for instance[12]
[ 6.6467 ] Packing sdram param for instance[13]
[ 6.6469 ] Packing sdram param for instance[14]
[ 6.6470 ] Packing sdram param for instance[15]
[ 6.7233 ] Getting sector size from pt
[ 6.7254 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[ 6.7278 ] BlockSize read from layout is 0x200
[ 6.7299 ] tegrahost_v2 --chip 0x23 0 --blocksize 512 --magicid MEMB --addsigheader_multi tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[ 6.7315 ] Binary 0 length is 58752
[ 6.7318 ] Binary 0 align length is 58880
[ 6.7326 ] Binary 1 length is 58752
[ 6.7328 ] Binary 1 align length is 58880
[ 6.7336 ] Binary 2 length is 58752
[ 6.7337 ] Binary 2 align length is 58880
[ 6.7345 ] Binary 3 length is 58752
[ 6.7347 ] Binary 3 align length is 58880
[ 6.7355 ] Buffer length is 235520
[ 6.7356 ] adding BCH for tegra234-p3767-0000-sdram-l4t_cpp_1.bct
[ 6.7358 ] new length is 243712
[ 6.7386 ] tegrahost_v2 --chip 0x23 0 --align mem_coldboot_aligned.bct
[ 6.7430 ] tegrahost_v2 --chip 0x23 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot_aligned.bct zerosbk
[ 6.7448 ] Header already present for mem_coldboot_aligned.bct
[ 6.7475 ] tegrasign_v3.py --key None --list mem_coldboot_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.7479 ] Assuming zero filled SBK key
[ 6.7525 ] Warning: pub_key.key is not found
[ 6.7538 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_coldboot_aligned_sigheader.bct.encrypt mem_coldboot_aligned_sigheader.bct.hash zerosbk
[ 6.7592 ] Generating recovery mem-bct
[ 6.7613 ] tegrabct_v2 --chip 0x23 0 --sdram tegra234-p3767-0000-sdram-l4t_cpp.dtb --wb0sdram tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb --membct tegra234-p3767-0000-sdram-l4t_cpp_1.bct tegra234-p3767-0000-sdram-l4t_cpp_2.bct tegra234-p3767-0000-sdram-l4t_cpp_3.bct tegra234-p3767-0000-sdram-l4t_cpp_4.bct
[ 6.7633 ] packing sdram params with Wb0 file tegra234-p3767-0000-wb0sdram-l4t_cpp.dtb
[ 6.8383 ] Packing sdram param for instance[0]
[ 6.8385 ] Packing sdram param for instance[1]
[ 6.8387 ] Packing sdram param for instance[2]
[ 6.8389 ] Packing sdram param for instance[3]
[ 6.8391 ] Packing sdram param for instance[4]
[ 6.8393 ] Packing sdram param for instance[5]
[ 6.8395 ] Packing sdram param for instance[6]
[ 6.8397 ] Packing sdram param for instance[7]
[ 6.8398 ] Packing sdram param for instance[8]
[ 6.8400 ] Packing sdram param for instance[9]
[ 6.8402 ] Packing sdram param for instance[10]
[ 6.8404 ] Packing sdram param for instance[11]
[ 6.8406 ] Packing sdram param for instance[12]
[ 6.8408 ] Packing sdram param for instance[13]
[ 6.8410 ] Packing sdram param for instance[14]
[ 6.8412 ] Packing sdram param for instance[15]
[ 6.9144 ] Reading ramcode from backup chip_info.bin file
[ 6.9145 ] RAMCODE Read from Device: 0
[ 6.9145 ] Using ramcode 0
[ 6.9145 ] Disabled BPMP dtb trim, using default dtb
[ 6.9145 ]
[ 6.9171 ] tegrahost_v2 --chip 0x23 0 --align mem_rcm_aligned.bct
[ 6.9211 ] tegrahost_v2 --chip 0x23 0 --magicid MEM0 --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm_aligned.bct zerosbk
[ 6.9231 ] adding BCH for mem_rcm_aligned.bct
[ 6.9290 ] tegrasign_v3.py --key None --list mem_rcm_aligned_sigheader.bct_list.xml --pubkeyhash pub_key.key --sha sha512
[ 6.9293 ] Assuming zero filled SBK key
[ 6.9340 ] Warning: pub_key.key is not found
[ 6.9354 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mem_rcm_aligned_sigheader.bct.encrypt mem_rcm_aligned_sigheader.bct.hash zerosbk
[ 6.9389 ] Copying signatures
[ 6.9416 ] tegrahost_v2 --chip 0x23 0 --partitionlayout flash.xml.bin --updatesig images_list_signed.xml
[ 7.0233 ] tegraparser_v2 --generategpt --pt flash.xml.bin
[ 7.0254 ] gpt_secondary_3_0.bin:
[ 7.0259 ] partition_id partition_name StartingLba EndingLba
[ 7.0263 ] 1 BCT 0 2047
[ 7.0268 ] 2 A_mb1 2048 3071
[ 7.0273 ] 3 A_psc_bl1 3072 3583
[ 7.0278 ] 4 A_MB1_BCT 3584 3839
[ 7.0283 ] 5 A_MEM_BCT 3840 4351
[ 7.0288 ] 6 A_tsec-fw 4352 6399
[ 7.0288 ] 7 A_nvdec 6400 8447
[ 7.0288 ] 8 A_mb2 8448 9471
[ 7.0288 ] 9 A_xusb-fw 9472 9983
[ 7.0288 ] 10 A_bpmp-fw 9984 13055
[ 7.0288 ] 11 A_bpmp-fw-dtb 13056 21247
[ 7.0288 ] 12 A_psc-fw 21248 22783
[ 7.0288 ] 13 A_mts-mce 22784 23807
[ 7.0289 ] 14 A_sc7 23808 24191
[ 7.0289 ] 15 A_pscrf 24192 24575
[ 7.0289 ] 16 A_mb2rf 24576 24831
[ 7.0289 ] 17 A_cpu-bootloader 24832 31999
[ 7.0289 ] 18 A_secure-os 32000 40191
[ 7.0289 ] 19 A_smm-fw 40192 44287
[ 7.0289 ] 20 A_eks 44288 44799
[ 7.0289 ] 21 A_dce-fw 44800 55039
[ 7.0289 ] 22 A_spe-fw 55040 56191
[ 7.0289 ] 23 A_rce-fw 56192 58239
[ 7.0289 ] 24 A_adsp-fw 58240 62335
[ 7.0290 ] 25 A_reserved_on_boot 62336 65023
[ 7.0290 ] 26 B_mb1 65024 66047
[ 7.0290 ] 27 B_psc_bl1 66048 66559
[ 7.0290 ] 28 B_MB1_BCT 66560 66815
[ 7.0290 ] 29 B_MEM_BCT 66816 67327
[ 7.0290 ] 30 B_tsec-fw 67328 69375
[ 7.0290 ] 31 B_nvdec 69376 71423
[ 7.0290 ] 32 B_mb2 71424 72447
[ 7.0290 ] 33 B_xusb-fw 72448 72959
[ 7.0290 ] 34 B_bpmp-fw 72960 76031
[ 7.0291 ] 35 B_bpmp-fw-dtb 76032 84223
[ 7.0291 ] 36 B_psc-fw 84224 85759
[ 7.0291 ] 37 B_mts-mce 85760 86783
[ 7.0291 ] 38 B_sc7 86784 87167
[ 7.0291 ] 39 B_pscrf 87168 87551
[ 7.0291 ] 40 B_mb2rf 87552 87807
[ 7.0291 ] 41 B_cpu-bootloader 87808 94975
[ 7.0291 ] 42 B_secure-os 94976 103167
[ 7.0291 ] 43 B_smm-fw 103168 107263
[ 7.0292 ] 44 B_eks 107264 107775
[ 7.0292 ] 45 B_dce-fw 107776 118015
[ 7.0292 ] 46 B_spe-fw 118016 119167
[ 7.0292 ] 47 B_rce-fw 119168 121215
[ 7.0292 ] 48 B_adsp-fw 121216 125311
[ 7.0292 ] 49 B_reserved_on_boot 125312 127999
[ 7.0292 ] 50 uefi_variables 128000 128511
[ 7.0292 ] 51 uefi_ftw 128512 129535
[ 7.0292 ] 52 worm 129920 130303
[ 7.0293 ] 53 BCT-boot-chain_backup 130304 130431
[ 7.0293 ] 54 reserved_partition 130432 130559
[ 7.0293 ] 55 secondary_gpt_backup 130560 130687
[ 7.0293 ] 56 B_VER 130688 130815
[ 7.0293 ] 57 A_VER 130816 130943
[ 7.0293 ] gpt_primary_6_0.bin:
[ 7.0293 ] partition_id partition_name StartingLba EndingLba
[ 7.0293 ] 1 APP 3050048118393407
[ 7.0293 ] 2 A_kernel 40 262183
[ 7.0293 ] 3 A_kernel-dtb 262184 263719
[ 7.0293 ] 4 A_reserved_on_user 263720 328487
[ 7.0294 ] 5 B_kernel 328488 590631
[ 7.0294 ] 6 B_kernel-dtb 590632 592167
[ 7.0294 ] 7 B_reserved_on_user 592168 656935
[ 7.0294 ] 8 recovery 656936 820775
[ 7.0294 ] 9 recovery-dtb 820776 821799
[ 7.0294 ] 10 esp 821800 952871
[ 7.0294 ] 11 recovery_alt 952872 1116711
[ 7.0294 ] 12 recovery-dtb_alt 1116712 1117735
[ 7.0294 ] 13 esp_alt 1117736 1248807
[ 7.0294 ] 14 reserved 1248808 3050023
[ 7.0295 ] gpt_secondary_6_0.bin:
[ 7.0295 ] partition_id partition_name StartingLba EndingLba
[ 7.0295 ] 1 APP 3050048118393407
[ 7.0295 ] 2 A_kernel 40 262183
[ 7.0295 ] 3 A_kernel-dtb 262184 263719
[ 7.0295 ] 4 A_reserved_on_user 263720 328487
[ 7.0295 ] 5 B_kernel 328488 590631
[ 7.0295 ] 6 B_kernel-dtb 590632 592167
[ 7.0295 ] 7 B_reserved_on_user 592168 656935
[ 7.0295 ] 8 recovery 656936 820775
[ 7.0295 ] 9 recovery-dtb 820776 821799
[ 7.0296 ] 10 esp 821800 952871
[ 7.0296 ] 11 recovery_alt 952872 1116711
[ 7.0296 ] 12 recovery-dtb_alt 1116712 1117735
[ 7.0296 ] 13 esp_alt 1117736 1248807
[ 7.0296 ] 14 reserved 1248808 3050023
[ 7.0296 ]
[ 7.0322 ] Get magic id
[ 7.0345 ] tegraparser_v2 --get_magic psc_fw
[ 7.0365 ] PFWP
[ 7.0366 ] partition type psc_fw, magic id = PFWP
[ 7.0400 ] tegrahost_v2 --chip 0x23 0 --align pscfw_t234_prod_aligned.bin
[ 7.0446 ] tegrahost_v2 --chip 0x23 0 --magicid PFWP --ratchet_blob ratchet_blob.bin --appendsigheader pscfw_t234_prod_aligned.bin zerosbk
[ 7.0471 ] Header already present for pscfw_t234_prod_aligned.bin
[ 7.0609 ] tegrasign_v3.py --key None --list pscfw_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.0612 ] Assuming zero filled SBK key
[ 7.0665 ] Warning: pub_key.key is not found
[ 7.0678 ] tegrahost_v2 --chip 0x23 0 --updatesigheader pscfw_t234_prod_aligned_sigheader.bin.encrypt pscfw_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 7.0742 ] Get magic id
[ 7.0768 ] tegraparser_v2 --get_magic mts_mce
[ 7.0788 ] MTSM
[ 7.0790 ] partition type mts_mce, magic id = MTSM
[ 7.0819 ] tegrahost_v2 --chip 0x23 0 --align mce_flash_o10_cr_prod_aligned.bin
[ 7.0862 ] tegrahost_v2 --chip 0x23 0 --magicid MTSM --ratchet_blob ratchet_blob.bin --appendsigheader mce_flash_o10_cr_prod_aligned.bin zerosbk
[ 7.0882 ] Header already present for mce_flash_o10_cr_prod_aligned.bin
[ 7.0930 ] tegrasign_v3.py --key None --list mce_flash_o10_cr_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.0932 ] Assuming zero filled SBK key
[ 7.0966 ] Warning: pub_key.key is not found
[ 7.0978 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mce_flash_o10_cr_prod_aligned_sigheader.bin.encrypt mce_flash_o10_cr_prod_aligned_sigheader.bin.hash zerosbk
[ 7.1009 ] Get magic id
[ 7.1029 ] tegraparser_v2 --get_magic mb2_applet
[ 7.1049 ] MB2A
[ 7.1052 ] partition type mb2_applet, magic id = MB2A
[ 7.1086 ] tegrahost_v2 --chip 0x23 0 --align applet_t234_aligned.bin
[ 7.1135 ] tegrahost_v2 --chip 0x23 0 --magicid MB2A --ratchet_blob ratchet_blob.bin --appendsigheader applet_t234_aligned.bin zerosbk
[ 7.1156 ] adding BCH for applet_t234_aligned.bin
[ 7.1259 ] tegrasign_v3.py --key None --list applet_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.1261 ] Assuming zero filled SBK key
[ 7.1293 ] Warning: pub_key.key is not found
[ 7.1300 ] tegrahost_v2 --chip 0x23 0 --updatesigheader applet_t234_aligned_sigheader.bin.encrypt applet_t234_aligned_sigheader.bin.hash zerosbk
[ 7.1364 ] Generating recovery mb2-bct
[ 7.1365 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct.cfg --recov --mb2bctcfg tegra234-mb2-bct-misc-p3767-0000_cpp.dtb --scr tegra234-mb2-bct-scr-p3767-0000_cpp.dtb
[ 7.1383 ] WARNING: unknown property 'tfc_version'
[ 7.1397 ] WARNING: unknown property 'addr_header_version'
[ 7.1470 ] Updating mb2-bct with storage information for RCM
[ 7.1497 ] tegrabct_v2 --chip 0x23 0 --mb2bct mb2_bct_MB2.bct --updatestorageinfo flash.xml.bin
[ 7.1532 ] Concatenating mb2-bct to mb2 binary
[ 7.1532 ] mb2_bin_file = mb2_t234.bin
[ 7.1532 ] mb2_bct_file = mb2_bct_MB2.bct
[ 7.1545 ] Get magic id
[ 7.1571 ] tegraparser_v2 --get_magic mb2_bootloader
[ 7.1596 ] MB2B
[ 7.1599 ] partition type mb2_bootloader, magic id = MB2B
[ 7.1631 ] tegrahost_v2 --chip 0x23 0 --align mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 7.1680 ] tegrahost_v2 --chip 0x23 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader mb2_t234_with_mb2_bct_MB2_aligned.bin zerosbk
[ 7.1705 ] adding BCH for mb2_t234_with_mb2_bct_MB2_aligned.bin
[ 7.1988 ] tegrasign_v3.py --key None --list mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.1991 ] Assuming zero filled SBK key
[ 7.2045 ] Warning: pub_key.key is not found
[ 7.2063 ] tegrahost_v2 --chip 0x23 0 --updatesigheader mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.encrypt mb2_t234_with_mb2_bct_MB2_aligned_sigheader.bin.hash zerosbk
[ 7.2114 ] Get magic id
[ 7.2135 ] tegraparser_v2 --get_magic xusb_fw
[ 7.2157 ] XUSB
[ 7.2159 ] partition type xusb_fw, magic id = XUSB
[ 7.2188 ] tegrahost_v2 --chip 0x23 0 --align xusb_t234_prod_aligned.bin
[ 7.2232 ] tegrahost_v2 --chip 0x23 0 --magicid XUSB --ratchet_blob ratchet_blob.bin --appendsigheader xusb_t234_prod_aligned.bin zerosbk
[ 7.2252 ] adding BCH for xusb_t234_prod_aligned.bin
[ 7.2321 ] tegrasign_v3.py --key None --list xusb_t234_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.2324 ] Assuming zero filled SBK key
[ 7.2371 ] Warning: pub_key.key is not found
[ 7.2384 ] tegrahost_v2 --chip 0x23 0 --updatesigheader xusb_t234_prod_aligned_sigheader.bin.encrypt xusb_t234_prod_aligned_sigheader.bin.hash zerosbk
[ 7.2434 ] Get magic id
[ 7.2459 ] tegraparser_v2 --get_magic dce_fw
[ 7.2484 ] DCEF
[ 7.2486 ] partition type dce_fw, magic id = DCEF
[ 7.2708 ] tegrahost_v2 --chip 0x23 0 --align display-t234-dce_aligned.bin
[ 7.2757 ] tegrahost_v2 --chip 0x23 0 --magicid DCEF --ratchet_blob ratchet_blob.bin --appendsigheader display-t234-dce_aligned.bin zerosbk
[ 7.2782 ] adding BCH for display-t234-dce_aligned.bin
[ 7.5875 ] tegrasign_v3.py --key None --list display-t234-dce_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.5878 ] Assuming zero filled SBK key
[ 7.6339 ] Warning: pub_key.key is not found
[ 7.6359 ] tegrahost_v2 --chip 0x23 0 --updatesigheader display-t234-dce_aligned_sigheader.bin.encrypt display-t234-dce_aligned_sigheader.bin.hash zerosbk
[ 7.6849 ] Get magic id
[ 7.6877 ] tegraparser_v2 --get_magic nvdec
[ 7.6904 ] NDEC
[ 7.6906 ] partition type nvdec, magic id = NDEC
[ 7.6929 ] tegrahost_v2 --chip 0x23 0 --align nvdec_t234_prod_aligned.fw
[ 7.6972 ] tegrahost_v2 --chip 0x23 0 --magicid NDEC --ratchet_blob ratchet_blob.bin --appendsigheader nvdec_t234_prod_aligned.fw zerosbk
[ 7.6993 ] Header already present for nvdec_t234_prod_aligned.fw
[ 7.7124 ] tegrasign_v3.py --key None --list nvdec_t234_prod_aligned_sigheader.fw_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.7127 ] Assuming zero filled SBK key
[ 7.7177 ] Warning: pub_key.key is not found
[ 7.7196 ] tegrahost_v2 --chip 0x23 0 --updatesigheader nvdec_t234_prod_aligned_sigheader.fw.encrypt nvdec_t234_prod_aligned_sigheader.fw.hash zerosbk
[ 7.7243 ] Get magic id
[ 7.7264 ] tegraparser_v2 --get_magic bpmp_fw
[ 7.7284 ] BPMF
[ 7.7286 ] partition type bpmp_fw, magic id = BPMF
[ 7.7344 ] tegrahost_v2 --chip 0x23 0 --align bpmp_t234-TE990M-A1_prod_aligned.bin
[ 7.7394 ] tegrahost_v2 --chip 0x23 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader bpmp_t234-TE990M-A1_prod_aligned.bin zerosbk
[ 7.7416 ] Header already present for bpmp_t234-TE990M-A1_prod_aligned.bin
[ 7.7749 ] tegrasign_v3.py --key None --list bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.7752 ] Assuming zero filled SBK key
[ 7.7825 ] Warning: pub_key.key is not found
[ 7.7845 ] tegrahost_v2 --chip 0x23 0 --updatesigheader bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.encrypt bpmp_t234-TE990M-A1_prod_aligned_sigheader.bin.hash zerosbk
[ 7.7950 ] Using bpmp-dtb concatenated with odmdata
[ 7.7950 ] Get magic id
[ 7.7972 ] tegraparser_v2 --get_magic bpmp_fw_dtb
[ 7.7995 ] BPMD
[ 7.7998 ] partition type bpmp_fw_dtb, magic id = BPMD
[ 7.8026 ] tegrahost_v2 --chip 0x23 0 --align tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 7.8071 ] tegrahost_v2 --chip 0x23 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb zerosbk
[ 7.8097 ] adding BCH for tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned.dtb
[ 7.8205 ] tegrasign_v3.py --key None --list tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.8208 ] Assuming zero filled SBK key
[ 7.8247 ] Warning: pub_key.key is not found
[ 7.8260 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb.encrypt tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_aligned_sigheader.dtb.hash zerosbk
[ 7.8295 ] Get magic id
[ 7.8321 ] tegraparser_v2 --get_magic sce_fw
[ 7.8348 ] SCEF
[ 7.8350 ] partition type sce_fw, magic id = SCEF
[ 7.8373 ] tegrahost_v2 --chip 0x23 0 --align camera-rtcpu-sce_aligned.img
[ 7.8414 ] tegrahost_v2 --chip 0x23 0 --magicid SCEF --ratchet_blob ratchet_blob.bin --appendsigheader camera-rtcpu-sce_aligned.img zerosbk
[ 7.8430 ] adding BCH for camera-rtcpu-sce_aligned.img
[ 7.8499 ] tegrasign_v3.py --key None --list camera-rtcpu-sce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.8502 ] Assuming zero filled SBK key
[ 7.8543 ] Warning: pub_key.key is not found
[ 7.8562 ] tegrahost_v2 --chip 0x23 0 --updatesigheader camera-rtcpu-sce_aligned_sigheader.img.encrypt camera-rtcpu-sce_aligned_sigheader.img.hash zerosbk
[ 7.8598 ] Get magic id
[ 7.8625 ] tegraparser_v2 --get_magic rce_fw
[ 7.8645 ] RCEF
[ 7.8647 ] partition type rce_fw, magic id = RCEF
[ 7.8691 ] tegrahost_v2 --chip 0x23 0 --align camera-rtcpu-t234-rce_aligned.img
[ 7.8739 ] tegrahost_v2 --chip 0x23 0 --magicid RCEF --ratchet_blob ratchet_blob.bin --appendsigheader camera-rtcpu-t234-rce_aligned.img zerosbk
[ 7.8764 ] adding BCH for camera-rtcpu-t234-rce_aligned.img
[ 7.9107 ] tegrasign_v3.py --key None --list camera-rtcpu-t234-rce_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.9110 ] Assuming zero filled SBK key
[ 7.9167 ] Warning: pub_key.key is not found
[ 7.9180 ] tegrahost_v2 --chip 0x23 0 --updatesigheader camera-rtcpu-t234-rce_aligned_sigheader.img.encrypt camera-rtcpu-t234-rce_aligned_sigheader.img.hash zerosbk
[ 7.9253 ] Get magic id
[ 7.9275 ] tegraparser_v2 --get_magic ape_fw
[ 7.9301 ] APEF
[ 7.9303 ] partition type ape_fw, magic id = APEF
[ 7.9342 ] tegrahost_v2 --chip 0x23 0 --align adsp-fw_aligned.bin
[ 7.9396 ] tegrahost_v2 --chip 0x23 0 --magicid APEF --ratchet_blob ratchet_blob.bin --appendsigheader adsp-fw_aligned.bin zerosbk
[ 7.9420 ] adding BCH for adsp-fw_aligned.bin
[ 7.9607 ] tegrasign_v3.py --key None --list adsp-fw_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 7.9610 ] Assuming zero filled SBK key
[ 7.9664 ] Warning: pub_key.key is not found
[ 7.9681 ] tegrahost_v2 --chip 0x23 0 --updatesigheader adsp-fw_aligned_sigheader.bin.encrypt adsp-fw_aligned_sigheader.bin.hash zerosbk
[ 7.9745 ] Get magic id
[ 7.9772 ] tegraparser_v2 --get_magic spe_fw
[ 7.9797 ] SPEF
[ 7.9800 ] partition type spe_fw, magic id = SPEF
[ 7.9831 ] tegrahost_v2 --chip 0x23 0 --align spe_t234_aligned.bin
[ 7.9884 ] tegrahost_v2 --chip 0x23 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader spe_t234_aligned.bin zerosbk
[ 7.9909 ] adding BCH for spe_t234_aligned.bin
[ 8.0092 ] tegrasign_v3.py --key None --list spe_t234_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.0095 ] Assuming zero filled SBK key
[ 8.0144 ] Warning: pub_key.key is not found
[ 8.0163 ] tegrahost_v2 --chip 0x23 0 --updatesigheader spe_t234_aligned_sigheader.bin.encrypt spe_t234_aligned_sigheader.bin.hash zerosbk
[ 8.0205 ] Get magic id
[ 8.0231 ] tegraparser_v2 --get_magic tos
[ 8.0255 ] TOSB
[ 8.0258 ] partition type tos, magic id = TOSB
[ 8.0317 ] tegrahost_v2 --chip 0x23 0 --align tos-optee_t234_aligned.img
[ 8.0365 ] tegrahost_v2 --chip 0x23 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader tos-optee_t234_aligned.img zerosbk
[ 8.0386 ] adding BCH for tos-optee_t234_aligned.img
[ 8.0738 ] tegrasign_v3.py --key None --list tos-optee_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.0740 ] Assuming zero filled SBK key
[ 8.0806 ] Warning: pub_key.key is not found
[ 8.0825 ] tegrahost_v2 --chip 0x23 0 --updatesigheader tos-optee_t234_aligned_sigheader.img.encrypt tos-optee_t234_aligned_sigheader.img.hash zerosbk
[ 8.0931 ] Get magic id
[ 8.0957 ] tegraparser_v2 --get_magic eks
[ 8.0981 ] EKSB
[ 8.0983 ] partition type eks, magic id = EKSB
[ 8.1012 ] tegrahost_v2 --chip 0x23 0 --align eks_t234_aligned.img
[ 8.1064 ] tegrahost_v2 --chip 0x23 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader eks_t234_aligned.img zerosbk
[ 8.1088 ] adding BCH for eks_t234_aligned.img
[ 8.1112 ] tegrasign_v3.py --key None --list eks_t234_aligned_sigheader.img_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.1115 ] Assuming zero filled SBK key
[ 8.1157 ] Warning: pub_key.key is not found
[ 8.1177 ] tegrahost_v2 --chip 0x23 0 --updatesigheader eks_t234_aligned_sigheader.img.encrypt eks_t234_aligned_sigheader.img.hash zerosbk
[ 8.1333 ] tegrahost_v2 --chip 0x23 0 --align uefi_jetson_with_dtb_aligned.bin
[ 8.1381 ] tegrahost_v2 --chip 0x23 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader uefi_jetson_with_dtb_aligned.bin zerosbk
[ 8.1406 ] adding BCH for uefi_jetson_with_dtb_aligned.bin
[ 8.2662 ] tegrasign_v3.py --key None --list uefi_jetson_with_dtb_aligned_sigheader.bin_list.xml --pubkeyhash pub_key.key --sha sha512
[ 8.2666 ] Assuming zero filled SBK key
[ 8.2828 ] Warning: pub_key.key is not found
[ 8.2848 ] tegrahost_v2 --chip 0x23 0 --updatesigheader uefi_jetson_with_dtb_aligned_sigheader.bin.encrypt uefi_jetson_with_dtb_aligned_sigheader.bin.hash zerosbk
[ 8.3041 ] Copying enc\/signed file in /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3592 ] Copying br bct for multi chains
[ 8.3593 ] Signed BCT for boot chain A is copied to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/br_bct_BR.bct
[ 8.3594 ] Signed BCT for boot chain B is copied to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/br_bct_b_BR.bct
[ 8.3594 ] Copying BCT backup image bct_backup.img to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/bct_backup.img
[ 8.3630 ] Copying pscfw_t234_prod_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3636 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/pscfw_t234_prod_sigheader.bin.encrypt
[ 8.3636 ] Copying mce_flash_o10_cr_prod_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3640 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mce_flash_o10_cr_prod_sigheader.bin.encrypt
[ 8.3640 ] Copying applet_t234_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3644 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/applet_t234_sigheader.bin.encrypt
[ 8.3644 ] Copying mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3650 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/mb2_t234_with_mb2_bct_MB2_sigheader.bin.encrypt
[ 8.3650 ] Copying xusb_t234_prod_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3653 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/xusb_t234_prod_sigheader.bin.encrypt
[ 8.3653 ] Copying display-t234-dce_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3753 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/display-t234-dce_sigheader.bin.encrypt
[ 8.3753 ] Copying nvdec_t234_prod_sigheader.fw.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3758 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/nvdec_t234_prod_sigheader.fw.encrypt
[ 8.3758 ] Copying bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3775 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt
[ 8.3775 ] Copying tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3778 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt
[ 8.3778 ] Copying camera-rtcpu-sce_sigheader.img.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3780 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/camera-rtcpu-sce_sigheader.img.encrypt
[ 8.3780 ] Copying camera-rtcpu-t234-rce_sigheader.img.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3789 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/camera-rtcpu-t234-rce_sigheader.img.encrypt
[ 8.3790 ] Copying adsp-fw_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3796 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/adsp-fw_sigheader.bin.encrypt
[ 8.3796 ] Copying spe_t234_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3801 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/spe_t234_sigheader.bin.encrypt
[ 8.3801 ] Copying tos-optee_t234_sigheader.img.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3817 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/tos-optee_t234_sigheader.img.encrypt
[ 8.3817 ] Copying eks_t234_sigheader.img.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3818 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/eks_t234_sigheader.img.encrypt
[ 8.3818 ] Copying uefi_jetson_with_dtb_sigheader.bin.encrypt to /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed
[ 8.3865 ] Signed file: /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/uefi_jetson_with_dtb_sigheader.bin.encrypt
[ 8.3898 ] tegraparser_v2 --pt flash.xml.bin --generateflashindex /home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/signed/flash.xml.tmp flash.idx
signing images succeeded
Creating update payloads for Jetson-3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit- board ...
Warning: No A_tsec-fw image for the commong spec.
Warning: No mb2-applet image for the commong spec.
creating bl payload
PARTITION INFO : multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/BCT/br_bct_BR.bct.prod BCT 3531 2 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/BCT_A/br_bct_BR.bct.prod BCT_A 3531 2 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/BCT_B/br_bct_b_BR.bct.prod BCT_B 3531 2 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/BCT-boot-chain_backup/bct_backup.img.prod BCT-boot-chain_backup 3531 2 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_mb1/mb1_t234_prod_aligned_sigheader.bin.encrypt mb1 3531 2 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/A_psc_bl1_fuselevel_production/psc_bl1_t234_prod_aligned_sigheader.bin.encrypt psc_bl1 3531 2 common; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_MB1_BCT/mb1_cold_boot_bct_MB1_sigheader.bct.encrypt MB1_BCT 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_MEM_BCT/mem_coldboot_sigheader.bct.encrypt MEM_BCT 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/A_nvdec_fuselevel_production/nvdec_t234_prod_sigheader.fw.encrypt nvdec 3531 2 common; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_mb2/mb2_t234_with_mb2_cold_boot_bct_MB2_sigheader.bin.encrypt mb2 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_bpmp-fw/bpmp_t234-TE990M-A1_prod_sigheader.bin.encrypt bpmp-fw 3531 2 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_bpmp-fw-dtb/tegra234-bpmp-3767-0000-a02-3509-a02_with_odm_sigheader.dtb.encrypt bpmp-fw-dtb 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/A_psc-fw_fuselevel_production/pscfw_t234_prod_sigheader.bin.encrypt psc-fw 3531 2 common; multi_signed/A_mts-mce_fuselevel_production/mce_flash_o10_cr_prod_sigheader.bin.encrypt mts-mce 3531 2 common; multi_signed/A_sc7_fuselevel_production/sc7_t234_prod_sigheader.bin.encrypt sc7 3531 2 common; multi_signed/A_pscrf_fuselevel_production/psc_rf_t234_prod_sigheader.bin.encrypt pscrf 3531 2 common; signed/mb2rf_t234_sigheader.bin.encrypt mb2rf 3531 0 common; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_cpu-bootloader/uefi_jetson_with_dtb_sigheader.bin.encrypt cpu-bootloader 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; signed/tos-optee_t234_sigheader.img.encrypt secure-os 3531 0 common; signed/eks_t234_sigheader.img.encrypt eks 3531 0 common; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_dce-fw/display-t234-dce_with_kernel_tegra234-p3767-0000-p3768-0000-a0_aligned_blob_w_bin_sigheader.bin.encrypt dce-fw 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; signed/spe_t234_sigheader.bin.encrypt spe-fw 3531 0 common; signed/camera-rtcpu-t234-rce_sigheader.img.encrypt rce-fw 3531 0 common; signed/adsp-fw_sigheader.bin.encrypt adsp-fw 3531 0 common; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_VER/qspi_bootblob_ver.txt VER 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/A_xusb-fw_fuselevel_production/xusb_t234_prod_sigheader.bin.encrypt xusb-fw 3531 2 common; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/secondary_gpt/gpt_secondary_3_0.bin secondary_gpt 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/secondary_gpt_backup/gpt_secondary_3_0.bin secondary_gpt_backup 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-
SUCCESS: bl_only_payload created
creating kernel payload
PARTITION INFO : boot.img kernel 3531 0 common; multi_signed/3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-/A_kernel-dtb/kernel_tegra234-p3767-0000-p3768-0000-a0.dtb kernel-dtb 3531 0 3767-RC1-0000-B.6-1-1-jetson-orin-nano-devkit-
SUCCESS: kernel_only_payload created
Payloads saved to "/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/bootloader/payloads_t23x/"
ubuntu@ubuntu-desktop:~/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TAR
GETS/Linux_for_Tegra$ sudo ./l4t_generate_soc_bup.sh -e t23x_3767_bl_spec t23x
Generate Multi-Spec BUP Tool
Error. Unknown target soc: NULL
This script generates bootloader and kernel payloads based on the
specifications listed in the vars at the end this script and the
supplied <target_soc>.
Usage:
l4t_generate_soc_bup.sh [-h|--help] [-u <key_file>] [-v <SBK key file>] [-b <board>] [-p <option>] [-f <boardspec file>] [-e <boardspec entry>] <target_soc>
-h|--help Displays this help prompt.
-u <PKC key file> Optional RSA key file for signing binaries.
-v <SBK key file> Optional Secure Boot Key (SBK) key used for ODM fused board.
This option must used with PKC key, and only support for t19x.
-p <option> Pass options to flash.sh when generating the BUP.
<target_soc> Must be "t19x", "t23x".
Must be compatible with current build environment.
(t19x under t186ref)
-b <board> This option specifies one particular board for corresponding target_soc.
Supported boards are:
For "t19x": "jetson-xavier-maxn", "jetson-xavier-slvs-ec",
"jetson-xavier-nx-devkit", "jetson-xavier-nx-devkit-emmc",
"clara-agx-xavier-devkit", "jetson-agx-xavier-industrial";
"jetson-agx-xavier-devkit", "jetson-agx-xavier-industrial-mxn";
For "t23x": "jetson-agx-orin-devkit", "holoscan-devkit",
"jetson-orin-nano-devkit";
-f <boardspec file> This option specifies user provided board spec file.
-e <boardspec entry> This option specifies board spec entry in user provided board spec file, like:
"jetson_tx2_devkit_ota_emmc_r28_3_spec" in the "ota_board_specs.conf"
-d|--debug Keep intermediate files during create payload
Examples:
l4t_generate_soc_bup.sh t19x
(generates bl, kernel multi-spec payloads for t19x SoC)
l4t_generate_soc_bup.sh -b jetson-xavier-nx-devkit-emmc t19x
(generates bl, kernel multi-spec payloads for t19x SoC, Jetson Xavier NX devkit)
l4t_generate_soc_bup.sh -u pkc.key -v sbk.key -p "--user_key user.key" t19x
(generates secured bl, kernel multi-spec payloads for t19x SoC)
Notes:
- generates bl_only_payload, kernel_only_payload for t19x
- payloads are under "Linux_for_Tegra/bootloader/payloads_"
These generated payloads are consumed by nv_update_engine on the target
to update bootloader and kernel partitions on the device.
GETS/Linux_for_Tegra$ ./generate_capsule/l4t_generate_soc_capsule.sh -i bootloader/payloads_t23x/bl_only_payload -o ./TEGRA_BL.Cap t234
Read binary input file bootloader/payloads_t23x/bl_only_payload
FMP_PAYLOAD_HEADER.Signature = 3153534D (MSS1)
FMP_PAYLOAD_HEADER.HeaderSize = 00000010
FMP_PAYLOAD_HEADER.FwVersion = 00230301
FMP_PAYLOAD_HEADER.LowestSupportedVersion = 00230301
sizeof (Payload) = 0098BDDD
"openssl" smime -sign -binary -outform DER -md sha256 -signer "/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/generate_capsule/Pkcs7Sign/TestCert.pem" -certfile "/home/ubuntu/nvidia/nvidia_sdk/JetPack_5.1.1_Linux_JETSON_ORIN_NX_TARGETS/Linux_for_Tegra/generate_capsule/Pkcs7Sign/TestSub.pub.pem"
EFI_FIRMWARE_IMAGE_AUTHENTICATION.MonotonicCount = 0000000000000001
EFI_FIRMWARE_IMAGE_AUTHENTICATION.AuthInfo.Hdr.dwLength = 00000AED
EFI_FIRMWARE_IMAGE_AUTHENTICATION.AuthInfo.Hdr.wRevision = 0200
EFI_FIRMWARE_IMAGE_AUTHENTICATION.AuthInfo.Hdr.wCertificateType = 0EF1
EFI_FIRMWARE_IMAGE_AUTHENTICATION.AuthInfo.CertType = 4AAFD29D-68DF-49EE-8AA9-347D375665A7
sizeof (EFI_FIRMWARE_IMAGE_AUTHENTICATION.AuthInfo.CertData) = 00000AD5
sizeof (Payload) = 0098BDED
EFI_FIRMWARE_MANAGEMENT_CAPSULE_HEADER.Version = 00000001
EFI_FIRMWARE_MANAGEMENT_CAPSULE_HEADER.EmbeddedDriverCount = 00000000
EFI_FIRMWARE_MANAGEMENT_CAPSULE_HEADER.PayloadItemCount = 00000001
EFI_FIRMWARE_MANAGEMENT_CAPSULE_HEADER.ItemOffsetList =
0000000000000010
EFI_FIRMWARE_MANAGEMENT_CAPSULE_IMAGE_HEADER.Version = 00000003
EFI_FIRMWARE_MANAGEMENT_CAPSULE_IMAGE_HEADER.UpdateImageTypeId = BF0D4599-20D4-414E-B2C5-3595B1CDA402
EFI_FIRMWARE_MANAGEMENT_CAPSULE_IMAGE_HEADER.UpdateImageIndex = 00000001
EFI_FIRMWARE_MANAGEMENT_CAPSULE_IMAGE_HEADER.UpdateImageSize = 0098C8E2
EFI_FIRMWARE_MANAGEMENT_CAPSULE_IMAGE_HEADER.UpdateVendorCodeSize = 00000000
EFI_FIRMWARE_MANAGEMENT_CAPSULE_IMAGE_HEADER.UpdateHardwareInstance = 0000000000000000
EFI_FIRMWARE_MANAGEMENT_CAPSULE_IMAGE_HEADER.ImageCapsuleSupport = 0000000000000001
sizeof (Payload) = 0098C8E2
sizeof (VendorCodeBytes) = 00000000
EFI_CAPSULE_HEADER.CapsuleGuid = 6DCBD5ED-E82D-4C44-BDA1-7194199AD92A
EFI_CAPSULE_HEADER.HeaderSize = 00000020
EFI_CAPSULE_HEADER.Flags = 00000000
OEM Flags = 0000
EFI_CAPSULE_HEADER.CapsuleImageSize = 0098C942
sizeof (Payload) = 0098C922
Write binary output file ./TEGRA_BL.Cap
Success
Then we moved the capsule payload (TEGRA_BL.Cap) to the Jetson and run these commands below to update it:
esp_uuid=$(lsblk -o name,partlabel,uuid | grep "nvme0n1" | awk '{ if($2 == "esp") print $3 }')
sudo mount UUID=$esp_uuid /mnt/
sudo mkdir /mnt/EFI/UpdateCapsule
sudo mv TEGRA_BL.Cap /mnt/EFI/UpdateCapsule/
cd /sys/firmware/efi/efivars/
printf "\x07\x00\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00" > /tmp/var_tmp.bin
sudo dd if=/tmp/var_tmp.bin of=OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c bs=12;sync
And the results
nvidia@nvidia-desktop:~$ esp_uuid=$(lsblk -o name,partlabel,uuid | grep "mmcblk0" | awk '{ if($2 == "esp") print $3 }')
nvidia@nvidia-desktop:~$ sudo mount UUID=$esp_uuid /mnt/
nvidia@nvidia-desktop:~$ sudo mkdir /mnt/EFI/UpdateCapsule
nvidia@nvidia-desktop:~$ sudo mv TEGRA_BL.Cap /mnt/EFI/UpdateCapsule/
mv: failed to preserve ownership for '/mnt/EFI/UpdateCapsule/TEGRA_BL.Cap': Operation not permitted
nvidia@nvidia-desktop:~$ cd /sys/firmware/efi/efivars/
nvidia@nvidia-desktop:/sys/firmware/efi/efivars$ printf "\x07\x00\x00\x00\x04\x00\x00\x00\x00\x00\x00\x00" > /tmp/var_tmp.bin
nvidia@nvidia-desktop:/sys/firmware/efi/efivars$ sudo dd if=/tmp/var_tmp.bin of=OsIndications-8be4df61-93ca-11d2-aa0d-00e098032b8c bs=12;sync
1+0 records in
1+0 records out
12 bytes copied, 0.00591013 s, 2.0 kB/s
nvidia@nvidia-desktop:/sys/firmware/efi/efivars$ sudo reboot
After the Jetson rebooted, the nvbootctrl returns 0
nvidia@nvidia-desktop:~$ sudo nvbootctrl dump-slots-info
[sudo] password for nvidia:
Current version: 0.0.1
Capsule update status: 0
Current bootloader slot: A
Active bootloader slot: A
num_slots: 2
slot: 0, status: normal
slot: 1, status: normal
Did we missed anything to apply this payload (While moving the payload file, it gave permission denied message but moved it)?
