I’m studying and using a framework that requires CUDA 10 to work properly and the NVIDIA Deep Learning Institute only gives CUDA 9.0 how can i do to update or run applications on CUDA 10 inside of that machines to accomplish my studies?? Thanks for your attention, i’m waiting for help, regards.
You are supposed to use those machines to pursue the material that is contained in the course notebook. That work can all be done using the machine setup as provided.
You are not supposed to be doing your own work or your own studies on those machines.
