Update Needed for Tutorial - EfficientViT
The article Tutorial - EfficientViT requires some updates for newbies like me:
  • The model file has been relocated to a new folder at HuggingFace
  • The model filename has the prefix efficientvit_sam_
  • The Python script benchmark.py needs the default argument parameter changed vis-a-vis the new filename
  • Resolution needed for the following error message when the script is run:
Re-running torch.loadwithweights_onlyset toFalse will likely succeed, but it can result in arbitrary code execution.
The last one is above my job grade. Guidance will be appreciated. Thanks.
Regards.
Thanks for your suggestoions, let me forward your comments to internal team to improve it.
