There is sticker on your module.
I thought that there is no DP output is because USB is otg, and I have modified the dtb and changed the mode of USB from otg to host. When I burned this dtb, the error "
ProcessExtLinuxConfig: Failed to open file: Not Found
L4TLauncher: Unable to process extlinux config: Not Found
"appeared.
If I don’t modify the dtb, the module can be burned successfully and bringed up successfully.
But there is a problem there is no DP output after log appeared when the debug serial reached at login step.Do you have any suggestion?
The following is the last section of bringup.
[ 12.136812] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[ 12.143689] tegra_actmon d230000.actmon: in actmon_register()…
[ 12.150040] tegra_actmon d230000.actmon: bwmgr_disable = 1
[ 12.156041] tegra_actmon d230000.actmon: initialization Completed for the device mc_all
[ 12.164433] hvc_sysfs: hypervisor is not present
[ 12.206728] ALSA device list:
[ 12.209778] No soundcards found.
[ 12.213853] Freeing unused kernel memory: 3968K
[ 12.218592] Run /init as init process
[ 12.234009] Root device found: mmcblk0p1
[ 12.238521] Found dev node: /dev/mmcblk0p1
[ 12.265062] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 12.274212] Rootfs mounted over mmcblk0p1
[ 12.294044] Switching from initrd to actual rootfs
[ 12.395251] systemd[1]: System time before build time, advancing clock.
[ 12.442975] systemd[1]: systemd 245.4-4ubuntu3.15 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN2 -IDN +PCRE2 default-hierarchy=hybrid)
[ 12.466597] systemd[1]: Detected architecture arm64.
[ 12.525260] systemd[1]: No hostname configured.
[ 12.529936] systemd[1]: Set hostname to .
[ 12.712067] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 12.737251] systemd[1]: Reached target Slices.
[ 12.753232] systemd[1]: Reached target Swap.
[ 12.769437] systemd[1]: Listening on RPCbind Server Activation Socket.
[ 12.789319] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 12.813283] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 12.833414] systemd[1]: Listening on Journal Audit Socket.
[ 12.853317] systemd[1]: Listening on Journal Socket (/dev/log).
[ 12.873325] systemd[1]: Listening on Journal Socket.
[ 12.893330] systemd[1]: Listening on udev Control Socket.
[ 12.913288] systemd[1]: Listening on udev Kernel Socket.
[ 12.933414] systemd[1]: dev-hugepages.mount: unit configures an IP firewall, but the local system does not support BPF/cgroup firewalling.
[ 12.946214] systemd[1]: (This warning is only shown for the first unit using IP firewalling.)
[ 12.956163] systemd[1]: Mounting Huge Pages File System…
[ 12.974190] systemd[1]: Mounting POSIX Message Queue File System…
[ 12.994104] systemd[1]: Mounting Kernel Debug File System…
[ 13.014197] systemd[1]: Mounting Kernel Trace File System…
System Configuration
┌───────────────────────────┤ Installing system ├───────────────────────────┐
│ Finding the distribution to copy… │
│ 0% │
May I know how you update this dtb? I mean the steps.
First, decode the dtb
dtc -I dtb -O dts *.dtb > tmp.dtsi
Then, modify the dtsi, and encode the dtsi
dtc -I dts -O dtb tmp.dtsi > *.dtb
Last, use flash.sh to burn the module.
Where do you put this dtb to? What dtb is in use? Could you specific the file name?
And how did you flash the module?
I put it in “Linux_for_Tegra/kernel/dtb”.
The used dtb is tegra234-p3701-0004-p3737-0000.dtb.
The flash cmd is “sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1”
So your actual command to update dtb is
dtc -I dtb -O dts tegra234-p3701-0004-p3737-0000.dtb > tmp.dtsi
Like this?
Yes
If you don’t change any content in the dtb but directly change it from dtb → dts and then dtb, will you hit this error?
If I do as you say, there is no error hited.
I retry the dtb which is modified from otg to host, and the module can be brought up successfully.
But there is a problem that the DP has no output after the picture of log appeared for a little time.
Hi,WayneWWW
If you can flash the board now, please file a new topic.
