I’m using NVIDIA deepstream 5.0 - I would like to update pre-cluster-threshold/eps from gstreamer, but it seems like this is not possible - is the only way to update these values to update the config file (ie, dstest1_pgie_config.txt)?
gst-inspect-1.0 nvinfer seems to indicate this is the case, however the example config files say that we can update the values through G_OBJECTS.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
Thank you for the response - so just to confirm - there is no way to programmatically update these values from within gstreamer and they can only be updated through the config files, correct?
