I’m using DXIFRShim to capture a game (World of Warcraft). I`m getting the NvIFR.h264 encoded file. But when I go to play the NvIFR.h264 using FFmpeg I’m getting a total black screen. So the D3D9.shim.log says that UpdateBackBuffer() failed:
[code][DEBUG][08:04:56] Direct3DCreate9_Proxy
[DEBUG][08:04:56] pDirect3D9=0x00000270056F8EE0
[DEBUG][08:04:56] IDirect3D9_CreateDevice_Proxy
[INFO ][08:04:56] Only one adapter found. Using it without further checks.
[DEBUG][08:04:56] This=0x00000270056F8EE0, *ppReturnedDeviceInterface=0x0000027008E36420
[DEBUG][08:04:56] pDirect3D9=0x00000270141FBE00
[DEBUG][08:04:56] succeeded to create NvIFRToH264HWEncoder
[DEBUG][08:04:56] Codec (H264=4, HEVC=7): 4
[DEBUG][08:04:56] Encoding Parameters:
Average Bit Rate: 4.06901MB
Peak Bit Rate: 4.06901MB
Frame Rate: 50/1
GOP Length: 250
VBV Buffer Size: 682664B
VBV Initial Delay: 85333B
Enable YUV444 Encoding: 0
Rate Control: 2
Preset: 0
[DEBUG][08:04:56] NvIFRSetUpH264HWEncoder succeeded, target size: 1024x768
[DEBUG][08:04:56] UpdateBackBuffer() failed= 1
[DEBUG][08:04:56] Shared surface is created.
[DEBUG][08:04:56] ret=
[DEBUG][08:04:57] ret=
[DEBUG][08:04:57] UpdateBackBuffer() failed= 1
[DEBUG][08:04:58] ret=
[DEBUG][08:04:58] UpdateBackBuffer() failed= 1
[DEBUG][08:04:59] ret=
[DEBUG][08:04:59] UpdateBackBuffer() failed= 1
[DEBUG][08:05:00] ret=
[DEBUG][08:05:00] UpdateBackBuffer() failed= 1
[DEBUG][08:05:01] ret=
[DEBUG][08:05:01] UpdateBackBuffer() failed= 1
[DEBUG][08:05:02] ret=
[DEBUG][08:05:02] UpdateBackBuffer() failed= 1
[DEBUG][08:05:03] ret=
[DEBUG][08:05:03] UpdateBackBuffer() failed= 1
[DEBUG][08:05:04] ret=
[DEBUG][08:05:04] UpdateBackBuffer() failed= 1
[DEBUG][08:05:05] ret=
[DEBUG][08:05:05] UpdateBackBuffer() failed= 1
[DEBUG][08:05:06] ret=
[DEBUG][08:05:06] UpdateBackBuffer() failed= 1
[DEBUG][08:05:07] ret=
[DEBUG][08:05:07] UpdateBackBuffer() failed= 1
[DEBUG][08:05:08] ret=
[DEBUG][08:05:08] UpdateBackBuffer() failed= 1
[DEBUG][08:05:09] ret=
[DEBUG][08:05:09] UpdateBackBuffer() failed= 1
