Has anyone had luck with either gtjoseph github repo:
https://github.com/gtjoseph/jetson-nano-support
or rt-net:
https://github.com/rt-net/JetsonNano_DT_SPI
I tried gtjosheph scripts, but it never enabled /dev/spidev* interfaces. I then tried rt-net, run.sh script and it did enable /dev/spidev0.0.
But when I transmit data through it I don’t see the SCLK, CS, MOSI toggle. I tried to use spidev_test:
nlbutts@jetson:~/projects$ sudo ./spidev_test -D /dev/spidev0.0 -v -p "test" -C
spi mode: 0x4
bits per word: 8
max speed: 500000 Hz (500 KHz)
TX | 74 65 73 74 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | test
RX | 00 00 00 00 __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ __ | ....
But this is the result on the pins:
https://photos.app.goo.gl/RbJZrtEwc9nxprV16
When I run gpioinfo I get the following:
sudo gpioinfo | grep spi
gpiochip0 - 256 lines:
line 0: unnamed unused input active-high
line 1: unnamed unused input active-high
line 2: unnamed "pcie_wake" input active-high [used]
line 3: unnamed unused input active-high
line 4: unnamed unused input active-high
line 5: unnamed unused input active-high
line 6: unnamed "vdd-usb-hub-en" output active-high [used]
line 7: unnamed unused input active-high
line 8: unnamed unused input active-high
line 9: unnamed unused input active-high
line 10: unnamed unused input active-high
line 11: unnamed unused input active-high
line 12: unnamed unused input active-high
line 13: unnamed unused input active-high
line 14: unnamed unused input active-high
line 15: unnamed unused input active-high
line 16: unnamed unused input active-high
line 17: unnamed unused input active-high
line 18: unnamed unused input active-high
line 19: unnamed unused input active-high
line 20: unnamed unused input active-high
line 21: unnamed unused input active-high
line 22: unnamed unused input active-high
line 23: unnamed unused input active-high
line 24: unnamed unused input active-high
line 25: unnamed unused input active-high
line 26: unnamed unused input active-high
line 27: unnamed unused input active-high
line 28: unnamed unused input active-high
line 29: unnamed unused input active-high
line 30: unnamed unused input active-high
line 31: unnamed unused input active-high
line 32: unnamed unused input active-high
line 33: unnamed unused input active-high
line 34: unnamed unused input active-high
line 35: unnamed unused input active-high
line 36: unnamed unused input active-high
line 37: unnamed unused input active-high
line 38: unnamed unused input active-high
line 39: unnamed unused input active-high
line 40: unnamed unused input active-high
line 41: unnamed unused input active-high
line 42: unnamed unused input active-high
line 43: unnamed unused input active-high
line 44: unnamed unused input active-high
line 45: unnamed unused input active-high
line 46: unnamed unused input active-high
line 47: unnamed unused input active-high
line 48: unnamed unused input active-high
line 49: unnamed unused input active-high
line 50: unnamed unused input active-high
line 51: unnamed unused input active-high
line 52: unnamed unused input active-high
line 53: unnamed unused input active-high
Any ideas?
