Hi There,
I would be happy if you can help me find an updated tlt-detectnet_v2 configuration file with the nms_parameter, and other new parameters added to the configuration file.
Thank you!
Hi There,
Thank you!
Can you download jupyter notebooks and refer to it?
Hi @Morganh,
I am unable to add “enable_qat” argument to the "Training Config Component in the spec fie…
If I do so I am getting an error which says …
Message type “TrainingConfig” has no field named “enable_qat”.
any help would be appreciated.
Which tlt/tao version did you use?
Can you run below to check?
$ tlt info --verbose
or
$ tao info --verbose
