This installed the version 1.7.3 of the package and it worked fine.
Lately however I am in the need of a functionality that is only present in a newer vesion (>1.8.0).
I tried to adjust my extension.toml file to look like the following, but this did not help, my code is still using the 1.7.3 version:
Hi @jominga. We actually don’t support that currently. If you want to upgrade, you’ll need to remove the package from it’s install location first. Here is an example of where the Python packages are installed by default:
