Updating BPMP DTB to enable CAN clock PLLAON breaks HDMI
After following the documentation to update the CAN clock to PLLAON, the clock is successfully updated, but the HDMI port doesn’t seem to be working correctly. After booting, the screen just shows NVIDIA logo. I have narrowed it down to the BPMP DTB change:
@@ -849,13 +849,13 @@
                clock@can1 {
                        allow_fractional_divider = <0x1>;
-                       allowed-parents = <0x121 0x5b 0x13a>;
+                       allowed-parents = <0x121 0x5b 0x13a 0x5e>;
                        clk-id = <0x9>;
                clock@can2 {
                        clk-id = <0xb>;
If this is reverted the HDMI port works again.
Test system info:
Jetson: Xavier AGX 32Gb dev kit
Tested on L4T: r32.5.2, r32.7.2
L4T boot device: EMMC (NVME is connected but not booted from)
Display: 7inch Capacitive Touch Screen LCD (H) with Case and Toughened Glass Cover, 1024×600, HDMI, IPS, Various Devices & Systems Support
Boot logs after a fresh flash with HDMI display connected:
Relevant (I think) logs
[0002.293] I> enabling 'vdd-hdmi-5v0' regulator
[0002.299] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.300] I> hdmi cable connected
[0002.302] W> set volts not configured for 'vdd-1v0'
[0002.304] W> set volts not configured for 'vdd-1v8-hs'
[0002.308] E> invalid display type
[0002.313] E> invalid display type
[0002.314] E> cannot find any other nvdisp nodes
[0002.331] I> edid read success
[0002.343] I> edid read success
[0002.344] I> width = 640, height = 480, frequency = 25174825
[0002.345] I> width = 1024, height = 600, frequency = 49000000
[0002.345] I> width = 720, height = 576, frequency = 27000000
[0002.349] I> width = 720, height = 480, frequency = 26973026
[0002.354] I> width = 720, height = 480, frequency = 26973026
[0002.360] I> width = 720, height = 576, frequency = 26973026
[0002.365] I> width = 720, height = 576, frequency = 26973026
[0002.371] I> width = 1280, height = 720, frequency = 74175824
[0002.376] I> width = 1280, height = 720, frequency = 74175824
[0002.382] I> width = 1920, height = 1080, frequency = 148351648
[0002.388] I> width = 1920, height = 1080, frequency = 148351648
[0002.394] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.408] I> hdmi_enable, starting HDMI initialisation
[0002.413] I> hdmi_enable, HDMI initialisation complete
[    2.246959] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[    2.247114] tegradc 15200000.nvdisplay: failed to register ihub bw client
[    6.498505] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[    6.498735] tegradc 15220000.nvdisplay: failed to register ihub bw client
[    6.502782] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[    6.503037] tegradc 15210000.nvdisplay: failed to register ihub bw client
Full logs
[0001.436] I> 19) Base:0xf2200000 Size:0x00600000
[0001.486] I> 20) Base:0x4004e000 Size:0x00002000
[0001.491] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.495] I> 22) Base:0x00000000 Size:0x00000000
[0001.500] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.504] I> 24) Base:0xf6000000 Size:0x02000000
[0001.509] I> 25) Base:0x40050000 Size:0x00002000
[0001.513] I> 26) Base:0x40040000 Size:0x00006000
[0001.517] I> 27) Base:0xf1800000 Size:0x00400000
[0001.522] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.526] I> 29) Base:0xf1400000 Size:0x00400000
[0001.531] I> 30) Base:0x00000000 Size:0x00000000
[0001.535] I> 31) Base:0x00000000 Size:0x00000000
[0001.540] I> 32) Base:0xf8000000 Size:0x08000000
[0001.544] I> 33) Base:0x00000000 Size:0x00000000
[0001.549] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.553] I> 35) Base:0xab000000 Size:0x01000000
[0001.558] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.562] I> 37) Base:0xf2800000 Size:0x00800000
[0001.567] I> 38) Base:0x80000000 Size:0x20000000
[0001.571] I> 39) Base:0xb0000000 Size:0x08000000
[0001.575] I> 40) Base:0x00000000 Size:0x00000000
[0001.580] I> 41) Base:0x00000000 Size:0x00000000
[0001.584] I> 42) Base:0x00000000 Size:0x00000000
[0001.589] I> 43) Base:0x00000000 Size:0x00000000
[0001.593] I> 44) Base:0x00000000 Size:0x00000000
[0001.598] I> 45) Base:0x00000000 Size:0x00000000
[0001.602] GIC-SPI Target CPU: 0
[0001.605] Interrupts Init done
[0001.608] calling constructors
[0001.611] initializing heap
[0001.614] I> Heap: [0xa0694618 ... 0xab000000]
[0001.618] initializing threads
[0001.621] initializing timers
[0001.624] creating bootstrap completion thread
[0001.628] top of bootstrap2()
[0001.631] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.635] initializing platform
[0001.638] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.644] W> device prod register failed
[0001.647] I> Bl_dtb @0xaaf00000
[0001.655] W> "plugin-manager" doesn't exist, creating
[0001.655] W> "ids" doesn't exist, creating
[0001.660] W> "connection" doesn't exist, creating
[0001.664] W> "configs" doesn't exist, creating
[0001.678] I> Find /i2c@3160000's alias i2c0
[0001.679] I> Reading eeprom i2c=0 address=0x50
[0001.706] I> Device at /i2c@3160000:0x50
[0001.706] I> Reading eeprom i2c=0 address=0x56
[0001.730] I> Device at /i2c@3160000:0x56
[0001.733] I> Find /i2c@3180000's alias i2c2
[0001.733] I> Reading eeprom i2c=2 address=0x54
[0001.736] E> I2C: slave not found in slaves.
[0001.736] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.737] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.738] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.745] E> eeprom: Failed to read I2C slave device
[0001.749] I> Eeprom read failed 0x3526070d
[0001.753] I> Reading eeprom i2c=2 address=0x57
[0001.758] E> I2C: slave not found in slaves.
[0001.762] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.770] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.775] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.785] E> eeprom: Failed to read I2C slave device
[0001.789] I> Eeprom read failed 0x3526070d
[0001.793] I> Reading eeprom i2c=2 address=0x52
[0001.798] E> I2C: slave not found in slaves.
[0001.802] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.810] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.815] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.825] E> eeprom: Failed to read I2C slave device
[0001.829] I> Eeprom read failed 0x3526070d
[0001.835] I> Find /i2c@c240000's alias i2c1
[0001.837] I> Reading eeprom i2c=1 address=0x52
[0001.844] E> I2C: slave not found in slaves.
[0001.846] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.854] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.859] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.869] E> eeprom: Retry to read I2C slave device.
[0001.874] E> I2C: slave not found in slaves.
[0001.878] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.886] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.891] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.901] E> eeprom: Failed to read I2C slave device
[0001.905] I> Eeprom read failed 0x3526070d
[0001.909] I> Reading eeprom i2c=1 address=0x50
[0001.914] E> I2C: slave not found in slaves.
[0001.918] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.926] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.931] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.941] E> eeprom: Retry to read I2C slave device.
[0001.946] E> I2C: slave not found in slaves.
[0001.950] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.958] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.963] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.973] E> eeprom: Failed to read I2C slave device
[0001.977] I> Eeprom read failed 0x3526070d
[0001.981] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.986] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.997] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.003] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.014] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0002.021] W> "i2c@3160000" doesn't exist, creating
[0002.025] W> "module@0x50" doesn't exist, creating
[0002.030] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0002.037] W> "module@0x56" doesn't exist, creating
[0002.045] I> Adding plugin-manager/cvm
[0002.045] W> "chip-id" doesn't exist, creating
[0002.050] I> Adding plugin-manager/chip-id/A02P
[0002.054] I> Plugin-manager override starting
[0002.059] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0002.070] I> node /plugin-manager/fragement-soft-wdt matches
[0002.084] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0002.088] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0002.100] I> Disable plugin-manager status in FDT
[0002.100] I> Plugin-manager override finished successfully
[0002.101] I> gpio framework initialized
[0002.102] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0002.104] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0002.110] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0002.117] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.125] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.132] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.138] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0002.145] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0002.153] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0002.159] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0002.167] I> fixed regulator driver initialized
[0002.178] I> register 'maxim' power off handle
[0002.179] I> virtual i2c enabled
[0002.180] I> registered 'maxim,max20024' pmic
[0002.181] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.188] I> Boot-device: eMMC
[0002.191] I> Boot_device: SDMMC_BOOT instance: 3
[0002.200] I> sdmmc-3 params source = boot args
[0002.200] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0002.205] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.216] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.221] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.232] I> sdmmc bdev is already initialized
[0002.236] I> sdmmc-3 params source = boot args
[0002.267] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.280] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.430] I> Load in CBoot Boot Options partition and parse it
[0002.436] E> Error -9 when finding node with path /boot-configuration
[0002.437] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.437] I> Using default boot order
[0002.438] I> boot-dev-order :-
[0002.438] I> 1.sd
[0002.438] I> 2.usb
[0002.439] I> 3.nvme
[0002.441] I> 4.emmc
[0002.443] I> 5.net
[0002.445] I> Hit any key to stop autoboot:     4       3       2       1
[0004.452] initializing target
[0004.452] calling apps_init()
[0004.453] starting app kernel_boot_app
[0004.473] I> found decompressor handler: lz4-legacy
[0004.473] I> decompressing BMP blob ...
[0004.488] I> Kernel type = Normal
[0004.488] I> Loading kernel-bootctrl from partition
[0004.489] I> Loading partition kernel-bootctrl at 0xa4ad0000 from device(0x1)
[0004.495] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0004.496] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0004.496] I> ########## SD (0) boot ##########
[0004.497] I> No sdcard
[0004.498] I> -0 params source =
[0004.501] E> Blockdev open: exit error
[0004.505] E> SD boot failed, err: 724238353
[0004.509] I> ########## USB (0) boot ##########
[0004.520] W> No valid slot number is found in scratch register
[0004.521] W> Return default slot: _a
[0004.535] I> USB Firmware Version: 60.06 release
[0004.590] I> regulator of usb2-0 already enabled
[0004.596] I> regulator of usb2-1 already enabled
[0004.603] I> regulator of usb2-2 already enabled
[0004.611] I> enabling 'vdd-5v-sata' regulator
[0005.615] E> failed to initialize xhci controller
[0005.616] E> Error in init of XUSB host driver, err: 79790026
[0005.616] W> Failed to initialize device 5-0
[0005.617] E> USB boot failed, err: 2037973030
[0005.617] I> ########## Fixed storage boot ##########
[0005.623] I> Already published: 00010003
[0005.624] I> Look for boot partition
[0005.624] I> Fallback: assuming 0th partition is boot partition
[0005.627] I> Detect filesystem
[0005.654] I> Loading extlinux.conf ...
[0005.654] I> rootfs path: /sdmmc_user/boot/extlinux/extlinux.conf
[0005.691] I> L4T boot options
[0005.691] I> [1]: "primary kernel"
[0005.692] I> Enter choice:
[0008.693] I> Continuing with default option: 1
[0008.693] I> Loading kernel sig file from rootfs ...
[0008.693] I> rootfs path: /sdmmc_user/boot/Image.sig
[0008.718] I> Loading kernel binary from rootfs ...
[0008.718] I> rootfs path: /sdmmc_user/boot/Image
[0008.948] I> overload load_size to 34338824 (from 34338832)
[0008.970] I> Validate kernel ...
[0008.971] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0009.284] I> Encryption fuse is not ON
[0009.330] I> No kernel-dtb binary path
[0009.330] W> No valid slot number is found in scratch register
[0009.331] W> Return default slot: _a
[0009.331] I> A/B: bin_type (38) slot 0
[0009.332] I> Loading kernel-dtb from partition
[0009.332] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0009.343] I> Validate kernel-dtb ...
[0009.344] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0009.347] I> Encryption fuse is not ON
[0009.350] I> Loading ramdisk from rootfs ...
[0009.350] I> Loading initrd sig file from rootfs ...
[0009.355] I> rootfs path: /sdmmc_user/boot/initrd.sig
[0009.384] I> Loading initrd binary from rootfs ...
[0009.385] I> rootfs path: /sdmmc_user/boot/initrd
[0009.444] I> overload load_size to 7237307 (from 7237312)
[0009.449] I> Validate initrd ...
[0009.449] I> T19x: Authenticate initrd (bin_type: 49), max size 0x4000000
[0009.516] I> Encryption fuse is not ON
[0009.553] I> Kernel hdr @0xa4ad0000
[0009.553] I> Kernel dtb @0x90000000
[0009.554] I> decompressor handler not found
[0009.554] I> Copying kernel image (34338824 bytes) from 0xa4ad0000 to 0x80080000 ... [0009.584] I> Done
[0009.586] I> Updated bpmp info to DTB
[0009.587] I> Ramdisk: Base: 0x92000000; Size: 0x6e6ebb
[0009.587] I> Updated initrd info to DTB
[0009.587] W> WARN: Fail to override "console=none" in commandline
[0009.588] I> Active rootfs suffix:
[0009.588] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.589] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0009.597] W> No valid slot number is found in scratch register
[0009.602] W> Return default slot: _a
[0009.606] I> Active slot suffix:
[0009.609] I> add_boot_slot_suffix: slot_suffix =
[0009.613] I> Linux Cmdline: console=ttyTCU0,115200 video=tegrafb no_console_suspend=1 earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06a4000 lut_mem=0x2008@0xa069f000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0009.645] I> Updated bootarg info to DTB
[0009.648] W> MAC addr invalid!
[0009.651] E> Failed to get WIFI MAC address
[0009.655] W> MAC addr invalid!
[0009.658] E> Failed to get Bluetooth MAC address
[0009.663] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3a:a5:91
[0009.670] W> "plugin-manager" doesn't exist, creating
[0009.674] I> Adding /chosen/plugin-manager/cvm
[0009.678] W> "chip-id" doesn't exist, creating
[0009.682] I> Adding /chosen/plugin-manager/chip-id
[0009.687] W> "configs" doesn't exist, creating
[0009.691] I> Adding /chosen/plugin-manager/configs
[0009.696] W> "ids" doesn't exist, creating
[0009.700] I> Adding /chosen/plugin-manager/ids
[0009.704] W> "odm-data" doesn't exist, creating
[0009.708] I> Adding /chosen/plugin-manager/odm-data
[0009.716] W> "memory" doesn't exist, creating
[0009.718] I> [0] START: 0x80000000, END: 0xac000000
[0009.722] I> [1] START: 0xac004000, END: 0xf0ad0000
[0009.727] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0009.731] I> dram_block larger than 80000000
[0009.736] I> [3] START: 0x100000000, END: 0x880000000
[0009.740] I> added [base:0x80000000, size:0x2c000000] to /memory
[0009.746] I> added [base:0xac200000, size:0x44800000] to /memory
[0009.752] I> added [base:0x100000000, size:0x780000000] to /memory
[0009.759] I> Updated memory info to DTB
[0009.762] E> add_disp_param: failed to get display params for du=1
[0009.768] W> "reset" doesn't exist, creating
[0009.772] I> Adding ecid(0000000164017147080000000d0280c0) to DT
[0009.778] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0009.783] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0009.787] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0009.792] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0009.797] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0009.802] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0009.806] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0009.811] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0009.817] W> "misc-data" doesn't exist, creating
[0009.820] I> Boot-device: eMMC
[0009.823] I> Add boot-sdmmc to plugin-manager/misc-data
[0009.828] I> Add storage-sdmmc to plugin-manager/misc-data
[0009.834] W> Unknown storage device
[0009.837] I> Add serial number:1561221004859 as DT property
[0009.843] I> Plugin-manager override starting
[0009.847] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0009.854] I> node /plugin-manager/fragement-soft-wdt matches
[0009.861] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0009.866] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0009.876] I> Disable plugin-manager status in FDT
[0009.877] I> Plugin-manager override finished successfully
[0009.880] I> tegrabl_load_kernel_and_dtb: Done
[0009.924] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.9.201-tegra (buildbrain@mobile-u64-p211-d7000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Fri Jul 9 08:56:59 PDT 2021
[    0.000000] Boot CPU: AArch64 Processor [4e0f0040]
[    0.000000] OF: fdt:memory scan node memory, reg size 48,
[    0.000000] OF: fdt: - 80000000 ,  2c000000
[    0.000000] OF: fdt: - ac200000 ,  44800000
[    0.000000] OF: fdt: - 100000000 ,  780000000
[    0.000000] earlycon: tegra_comb_uart0 at MMIO32 0x000000000c168000 (options '')
[    0.000000] bootconsole [tegra_comb_uart0] enabled
[    0.000000] Found tegra_fbmem: 00800000@a06a4000
[    0.000000] Found lut_mem: 00002008@a069f000
[    7.832248] cgroup: cgroup2: unknown option "nsdelegate"
[    9.831141] using random self ethernet address
[    9.831361] using random host ethernet address
If the HDMI display is connected after boot it remains black after being plugged in.
I believe this issue shall be only happened in release before 32.7. Please share detail steps to reproduce issue.
After flashing the Jetson with stock the L4T sample rootfs, I updated the BPMP DTB and then flashed the BPMP DTB partition with
flash.sh -k bpmp-fw-dtb jetson-agx-xavier-devkit mmcblk0p1
Repeating this with r32.5.2 and r32.7.2 didn’t seem to change anything.
The first logs were for r32.5.2. Here are the logs for r32.7.2 (the issue still persists)
[0001.250] I> 18) Base:0x4004c000 Size:0x00002000
[0001.254] I> 19) Base:0xf2200000 Size:0x00600000
[0001.259] I> 20) Base:0x4004e000 Size:0x00002000
[0001.263] I> 21) Base:0xf0ad0000 Size:0x0000c000
[0001.268] I> 22) Base:0x00000000 Size:0x00000000
[0001.272] I> 23) Base:0xf0ae0000 Size:0x00020000
[0001.277] I> 24) Base:0xf6000000 Size:0x02000000
[0001.281] I> 25) Base:0x40050000 Size:0x00002000
[0001.285] I> 26) Base:0x40040000 Size:0x00006000
[0001.290] I> 27) Base:0xf1800000 Size:0x00400000
[0001.294] I> 28) Base:0xf4c00000 Size:0x01400000
[0001.299] I> 29) Base:0xf1400000 Size:0x00400000
[0001.303] I> 30) Base:0x00000000 Size:0x00000000
[0001.308] I> 31) Base:0x00000000 Size:0x00000000
[0001.312] I> 32) Base:0xf8000000 Size:0x08000000
[0001.317] I> 33) Base:0x00000000 Size:0x00000000
[0001.321] I> 34) Base:0xf3c00000 Size:0x01000000
[0001.326] I> 35) Base:0xab000000 Size:0x01000000
[0001.330] I> 36) Base:0xa0000000 Size:0x0b000000
[0001.335] I> 37) Base:0xf2800000 Size:0x00800000
[0001.339] I> 38) Base:0x80000000 Size:0x20000000
[0001.343] I> 39) Base:0xb0000000 Size:0x08000000
[0001.348] I> 40) Base:0x00000000 Size:0x00000000
[0001.352] I> 41) Base:0x00000000 Size:0x00000000
[0001.357] I> 42) Base:0x00000000 Size:0x00000000
[0001.361] I> 43) Base:0x00000000 Size:0x00000000
[0001.366] I> 44) Base:0x00000000 Size:0x00000000
[0001.370] I> 45) Base:0x00000000 Size:0x00000000
[0001.375] GIC-SPI Target CPU: 0
[0001.378] Interrupts Init done
[0001.381] calling constructors
[0001.383] initializing heap
[0001.386] I> Heap: [0xa069ab80 ... 0xab000000]
[0001.390] initializing threads
[0001.393] initializing timers
[0001.396] creating bootstrap completion thread
[0001.400] top of bootstrap2()
[0001.403] CPU: MIDR: 0x4E0F0040, MPIDR: 0x80000000
[0001.408] initializing platform
[0001.411] E> DEVICE_PROD: Invalid value data = 0, size = 0.
[0001.416] W> device prod register failed
[0001.420] I> Bl_dtb @0xaaf00000
[0001.427] W> "plugin-manager" doesn't exist, creating
[0001.428] W> "ids" doesn't exist, creating
[0001.432] W> "connection" doesn't exist, creating
[0001.436] W> "configs" doesn't exist, creating
[0001.449] E> failed to read label property for node 227404: 13
[0001.453] E> failed to read reg property for node 227492: 13
[0001.456] E> failed to read label property for node 227544: 13
[0001.460] E> failed to read label property for node 227612: 13
[0001.464] E> failed to read label property for node 227648: 13
[0001.470] E> failed to read label property for node 227684: 13
[0001.475] E> failed to read reg property for node 227752: 13
[0001.481] E> failed to read label property for node 227804: 13
[0001.487] I> Find /i2c@3160000's alias i2c0
[0001.490] I> Reading eeprom i2c=0 address=0x50
[0001.521] I> Device at /i2c@3160000:0x50
[0001.521] I> Reading eeprom i2c=0 address=0x56
[0001.546] I> Device at /i2c@3160000:0x56
[0001.547] I> Find /i2c@3180000's alias i2c2
[0001.547] I> Reading eeprom i2c=2 address=0x54
[0001.550] E> I2C: slave not found in slaves.
[0001.550] E> I2C: Could not write 0 bytes to slave: 0x00a8 with repeat start true.
[0001.552] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.552] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa8 at 0x00000000 via instance 2.
[0001.560] E> eeprom: Failed to read I2C slave device
[0001.564] I> Eeprom read failed 0x3526070d
[0001.568] I> Reading eeprom i2c=2 address=0x57
[0001.573] E> I2C: slave not found in slaves.
[0001.577] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.585] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.590] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 2.
[0001.600] E> eeprom: Failed to read I2C slave device
[0001.604] I> Eeprom read failed 0x3526070d
[0001.608] I> Reading eeprom i2c=2 address=0x52
[0001.613] E> I2C: slave not found in slaves.
[0001.617] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.625] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.630] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 2.
[0001.640] E> eeprom: Failed to read I2C slave device
[0001.645] I> Eeprom read failed 0x3526070d
[0001.649] I> Find /i2c@c240000's alias i2c1
[0001.653] I> Reading eeprom i2c=1 address=0x52
[0001.659] E> I2C: slave not found in slaves.
[0001.661] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.669] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.674] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.684] E> eeprom: Retry to read I2C slave device.
[0001.689] E> I2C: slave not found in slaves.
[0001.693] E> I2C: Could not write 0 bytes to slave: 0x00a4 with repeat start true.
[0001.701] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.706] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa4 at 0x00000000 via instance 1.
[0001.716] E> eeprom: Failed to read I2C slave device
[0001.721] I> Eeprom read failed 0x3526070d
[0001.724] I> Reading eeprom i2c=1 address=0x50
[0001.729] E> I2C: slave not found in slaves.
[0001.733] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.741] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.746] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.756] E> eeprom: Retry to read I2C slave device.
[0001.761] E> I2C: slave not found in slaves.
[0001.765] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.773] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.778] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 1.
[0001.788] E> eeprom: Failed to read I2C slave device
[0001.792] I> Eeprom read failed 0x3526070d
[0001.796] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0001.802] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.813] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0001.818] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0001.829] I> Adding plugin-manager/ids/2888-0004-400=/i2c@3160000:module@0x50
[0001.836] W> "i2c@3160000" doesn't exist, creating
[0001.840] W> "module@0x50" doesn't exist, creating
[0001.845] I> Adding plugin-manager/ids/2822-0000-700=/i2c@3160000:module@0x56
[0001.852] W> "module@0x56" doesn't exist, creating
[0001.858] I> Adding plugin-manager/cvm
[0001.861] W> "chip-id" doesn't exist, creating
[0001.865] I> Adding plugin-manager/chip-id/A02P
[0001.869] I> Plugin-manager override starting
[0001.874] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0001.882] I> node /plugin-manager/fragement-soft-wdt matches
[0001.891] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0001.895] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0001.909] I> Disable plugin-manager status in FDT
[0001.909] I> Plugin-manager override finished successfully
[0001.910] I> gpio framework initialized
[0001.911] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio' driver
[0001.918] I> tegrabl_gpio_driver_register: register 'nvidia,tegra194-gpio-aon' driver
[0001.925] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x46
[0001.932] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.940] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.947] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.953] I> tegrabl_tca9539_init: i2c bus: 1, slave addr: 0x44
[0001.960] W> fetch_driver_phandle_from_dt: failed to get node with compatible ti,tca9539
[0001.968] W> fetch_driver_phandle_from_dt: failed to get node with compatible nxp,tca9539
[0001.974] W> tegrabl_tca9539_init: failed to fetch phandle from dt
[0001.982] I> fixed regulator driver initialized
[0001.995] I> register 'maxim' power off handle
[0001.996] I> virtual i2c enabled
[0001.996] I> registered 'maxim,max20024' pmic
[0001.997] I> tegrabl_gpio_driver_register: register 'max20024-gpio' driver
[0002.003] I> Boot-device: eMMC
[0002.006] I> Boot_device: SDMMC_BOOT instance: 3
[0002.015] I> sdmmc-3 params source = boot args
[0002.015] I> create_pm_ids: id: 2888-0004-400-M, len: 15
[0002.020] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.031] I> create_pm_ids: id: 2822-0000-700-K, len: 15
[0002.036] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 93
[0002.047] I> sdmmc bdev is already initialized
[0002.051] I> sdmmc-3 params source = boot args
[0002.082] I> Found 17 partitions in SDMMC_BOOT (instance 3)
[0002.095] I> Found 42 partitions in SDMMC_USER (instance 3)
[0002.106] I> enabling 'vdd-hdmi-5v0' regulator
[0002.112] I> regulator 'vdd-hdmi-5v0' already enabled
[0002.113] I> hdmi cable connected
[0002.115] W> set volts not configured for 'vdd-1v0'
[0002.117] W> set volts not configured for 'vdd-1v8-hs'
[0002.117] I> retrieved tmds range from prod_list_hdmi_soc
[0002.123] E> invalid display type
[0002.127] E> invalid display type
[0002.128] E> cannot find any other nvdisp nodes
[0002.145] I> edid read success
[0002.157] I> edid read success
[0002.158] I> width = 640, height = 480, frequency = 25174825
[0002.159] I> width = 640, height = 480, frequency = 25174825
[0002.159] I> width = 1024, height = 600, frequency = 49000000
[0002.159] I> width = 720, height = 576, frequency = 27000000
[0002.163] I> width = 720, height = 480, frequency = 26973026
[0002.168] I> width = 720, height = 480, frequency = 26973026
[0002.174] I> width = 720, height = 576, frequency = 26973026
[0002.179] I> width = 720, height = 576, frequency = 26973026
[0002.185] I> width = 1280, height = 720, frequency = 74175824
[0002.191] I> width = 1280, height = 720, frequency = 74175824
[0002.196] I> width = 1920, height = 1080, frequency = 148351648
[0002.202] I> width = 1920, height = 1080, frequency = 148351648
[0002.208] I> Best mode Width = 1920, Height = 1080, freq = 148351648
[0002.222] I> hdmi_enable, starting HDMI initialisation
[0002.228] I> hdmi_enable, HDMI initialisation complete
[0002.244] I> Load in CBoot Boot Options partition and parse it
[0002.251] E> Error -9 when finding node with path /boot-configuration
[0002.251] E> tegrabl_cbo_parse_info: "boot-configuration" not found in CBO file.
[0002.252] I> Using default boot order
[0002.252] I> boot-dev-order :-
[0002.252] I> 1.sd
[0002.252] I> 2.usb
[0002.253] I> 3.nvme
[0002.255] I> 4.emmc
[0002.257] I> 5.net
[0002.259] I> Hit any key to stop autoboot:     4       3       2       1
[0004.267] initializing target
[0004.267] calling apps_init()
[0004.268] starting app kernel_boot_app
[0004.288] I> found decompressor handler: lz4-legacy
[0004.288] I> decompressing BMP blob ...
[0004.302] I> Kernel type = Normal
[0004.302] I> ########## SD (0) boot ##########
[0004.303] I> No sdcard
[0004.303] I> sdcard-0 params source = DT-BL
[0004.304] E> Blockdev open: exit error
[0004.304] E> SD boot failed, err: 724238353
[0004.304] I> ########## USB (0) boot ##########
[0004.311] W> No valid slot number is found in scratch register
[0004.312] W> Return default slot: _a
[0004.318] I> Validate XUSB-FW ...
[0004.319] I> T19x: Authenticate XUSB-FW (bin_type: 11), max size 0x28000
[0004.323] I> Encryption fuse is not ON
[0004.325] I> USB Firmware Version: 60.09 release
[0004.384] I> regulator of usb2-0 already enabled
[0004.391] I> regulator of usb2-1 already enabled
[0004.397] I> regulator of usb2-2 already enabled
[0004.405] I> enabling 'vdd-5v-sata' regulator
[0005.409] E> failed to initialize xhci controller
[0005.409] E> Error in init of XUSB host driver, err: 79790026
[0005.410] W> Failed to initialize device 5-0
[0005.410] E> USB boot failed, err: 2037973030
[0005.410] I> ########## NVME (0) boot ##########
[0005.411] I> Initializing nvme device instance 0
[0005.411] I> Initializing nvme controller
[0005.415] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0005.422] I> vpcie3v3-supply not found
[0005.425] I> vpcie12v-supply not found
[0005.429] W> Failed to get nvidia,plat-gpios
[0005.433] I> tegrabl_pcie_soc_preinit: (0):
[0005.437] I> Unpowergate
[0005.440] I> tegrabl_car_clk_disable(0) ...
[0005.443] I> tegrabl_car_rst_set(CORE, 0) ...
[0005.448] I> tegrabl_car_rst_set(APB, 0) ...
[0005.452] I> tegrabl_car_clk_enable(0) ...
[0005.456] I> tegrabl_car_rst_clear(APB, 0) ...
[0005.460] I> tegrabl_set_ctrl_state(0)
[0005.464] I> CLR PCIE_APB:6
[0005.466] I> tegrabl_pcie_soc_init: (0):
[0005.470] I> APPL initialization ...
[0005.473] I> poweron phys
[0005.476] I> tegrabl_locate_pcie_ctrl_in_dt: found match at 0x14180000
[0005.482] I> tegrabl_power_on_phy: power on phy @0x3e30000
[0005.487] I> tegrabl_power_on_phy: power on phy @0x3e40000
[0005.493] I> tegrabl_power_on_phy: power on phy @0x3e50000
[0005.498] I> tegrabl_power_on_phy: power on phy @0x3e60000
[0005.630] I> PCIe controller-0 link is up
[0005.630] I> tegra_pcie_info[0].cfg0_base = 0x38000000
[0005.631] I> tegra_pcie_info[0].cfg1_base = 0x38020000
[0005.631] I> tegra_pcie_info[0].atu_dma_base = 0x38040000
[0005.632] I> tegra_pcie_bus[0].mem = 0x38200000
[0005.632] I> Scanning busnr: 0 devfn: 0
[0005.632] I> PCIe IDs: 0x1ad010de
[0005.635] I> PCIe RID_CC: 0x60400a1
[0005.639] I> Scanning busnr: 1 devfn: 0
[0005.642] I> PCIe IDs: 0xa80a144d
[0005.645] I> PCIe RID_CC: 0x1080200
[0005.649] I> PCI Config: I/O=0x38100000, Memory=0x38200000
[0005.654] I> MEM64 bar_num=0 bar=0x38200000
[0005.658] I> Number of PCIe devices detected: 2
[0005.663] I> NVME page size: 4096
[0005.667] I> NVMe serial number: S5NYNG0R704587R
[0005.671] I> NVMe model number: Samsung SSD 980 PRO 500GB
[0005.677] I> NVMe firmware revision: 3B2QGXA7
[0005.681] I> block_count: 976773168
[0005.685] I> supported_lba: 0
[0005.687] I> block_size_log2: 0x9
[0005.691] I> tegrabl_create_io_queue_cmd: queue size: 2
[0005.696] I> tegrabl_create_io_queue_cmd: queue size: 2
[0005.701] I> nvme device id 000a0000
[0005.704] I> nvme-0 params source =
[0005.708] I> Found 1 partitions in NVME (instance 0)
[0005.712] I> Look for boot partition
[0005.716] I> Fallback: assuming 0th partition is boot partition
[0005.728] I> Detect filesystem
[0005.730] I> Loading kernel-bootctrl from partition
[0005.730] I> Loading partition kernel-bootctrl at 0xa4b30000 from device(0x1)
[0005.742] W> tegrabl_get_kernel_bootctrl: magic number(0x00000000) is invalid
[0005.743] W> tegrabl_get_kernel_bootctrl: use default dummy boot control data
[0005.750] I> Loading extlinux.conf ...
[0005.754] I> Loading extlinux.conf binary from rootfs ...
[0005.759] I> rootfs path: /nvme/boot/extlinux/extlinux.conf
[0005.819] I> lookup_linear_dir:457: Invalid file block num
[0005.819] I> ext2_walk:142: 'extlinux' lookup failed
[0005.819] I> ext4_open_file:676: '/boot/extlinux/extlinux.conf' lookup failed
[0005.820] E> file /nvme/boot/extlinux/extlinux.conf open failed!!
[0005.820] W> Failed to load extlinux.conf binary from rootfs (err=202113041)
[0005.824] E> Failed to find/load /boot/extlinux/extlinux.conf
[0005.829] I> Loading kernel ...
[0005.832] I> No kernel binary path
[0005.835] I> Continue to load from partition ...
[0005.840] W> No valid slot number is found in scratch register
[0005.846] W> Return default slot: _a
[0005.849] I> A/B: bin_type (37) slot 0
[0005.853] I> Loading kernel from partition
[0005.856] I> Loading partition kernel at 0xa4b30000 from device(0x1)
[0006.363] I> Validate kernel ...
[0006.363] I> T19x: Authenticate kernel (bin_type: 37), max size 0x5000000
[0006.743] I> Encryption fuse is not ON
[0006.790] I> Checking boot.img header magic ... [0006.790] I> [OK]
[0006.790] I> Loading kernel-dtb ...
[0006.790] I> No kernel-dtb binary path
[0006.791] I> Continue to load from partition ...
[0006.791] W> No valid slot number is found in scratch register
[0006.791] W> Return default slot: _a
[0006.792] I> A/B: bin_type (38) slot 0
[0006.795] I> Loading kernel-dtb from partition
[0006.799] I> Loading partition kernel-dtb at 0x91000000 from device(0x1)
[0006.817] I> Validate kernel-dtb ...
[0006.817] I> T19x: Authenticate kernel-dtb (bin_type: 38), max size 0x400000
[0006.821] I> Encryption fuse is not ON
[0006.823] I> PCIe (0) link is UP
[0006.834] I> removable_boot_load_kernel_and_dtb: force NVME bdev to close !!!
[0006.835] I> Kernel hdr @0xa4b30000
[0006.835] I> Kernel dtb @0x90000000
[0006.836] I> decompressor handler not found
[0006.840] I> Copying kernel image (34484232 bytes) from 0xa4b30800 to 0x80080000 ... [0006.877] I> Done
[0006.878] I> Move ramdisk (len: 7238366) from 0xa6c14000 to 0x92000000
[0006.885] I> Updated bpmp info to DTB
[0006.887] I> Ramdisk: Base: 0x92000000; Size: 0x6e72de
[0006.887] I> Updated initrd info to DTB
[0006.887] W> WARN: Fail to override "console=none" in commandline
[0006.888] I> Active rootfs suffix:
[0006.888] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0006.889] E> tegrabl_linuxboot_add_disp_param, du 1 failed to get display params
[0006.897] W> No valid slot number is found in scratch register
[0006.902] W> Return default slot: _a
[0006.906] I> Active slot suffix:
[0006.909] I> add_boot_slot_suffix: slot_suffix =
[0006.913] I> Linux Cmdline: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4  video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06ab000 lut_mem=0x2008@0xa06a6000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[0006.954] I> Updated bootarg info to DTB
[0006.958] W> MAC addr invalid!
[0006.961] E> Failed to get WIFI MAC address
[0006.965] W> MAC addr invalid!
[0006.968] E> Failed to get Bluetooth MAC address
[0006.972] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:3a:a5:91
[0006.979] W> "plugin-manager" doesn't exist, creating
[0006.983] I> Adding /chosen/plugin-manager/cvm
[0006.987] W> "chip-id" doesn't exist, creating
[0006.992] I> Adding /chosen/plugin-manager/chip-id
[0006.996] W> "configs" doesn't exist, creating
[0007.001] I> Adding /chosen/plugin-manager/configs
[0007.005] W> "ids" doesn't exist, creating
[0007.009] I> Adding /chosen/plugin-manager/ids
[0007.014] W> "odm-data" doesn't exist, creating
[0007.018] I> Adding /chosen/plugin-manager/odm-data
[0007.026] W> "memory" doesn't exist, creating
[0007.027] I> [0] START: 0x80000000, END: 0xac000000
[0007.031] I> [1] START: 0xac004000, END: 0xf0ad0000
[0007.036] I> [2] START: 0xf0adc000, END: 0xf0ae0000
[0007.041] I> dram_block larger than 80000000
[0007.045] I> [3] START: 0x100000000, END: 0x880000000
[0007.050] I> added [base:0x80000000, size:0x2c000000] to /memory
[0007.056] I> added [base:0xac200000, size:0x44800000] to /memory
[0007.062] I> added [base:0x100000000, size:0x780000000] to /memory
[0007.069] I> Updated memory info to DTB
[0007.072] E> add_disp_param: failed to get display params for du=1
[0007.078] W> "reset" doesn't exist, creating
[0007.082] I> Adding ecid(0000000164017147080000000d0280c0) to DT
[0007.088] I> NVG: Logical CPU: 0; MPIDR: 0x80000000
[0007.092] I> NVG: Logical CPU: 1; MPIDR: 0x80000001
[0007.097] I> NVG: Logical CPU: 2; MPIDR: 0x80000100
[0007.102] I> NVG: Logical CPU: 3; MPIDR: 0x80000101
[0007.106] I> NVG: Logical CPU: 4; MPIDR: 0x80000200
[0007.111] I> NVG: Logical CPU: 5; MPIDR: 0x80000201
[0007.116] I> NVG: Logical CPU: 6; MPIDR: 0x80000300
[0007.120] I> NVG: Logical CPU: 7; MPIDR: 0x80000301
[0007.126] W> "misc-data" doesn't exist, creating
[0007.130] I> Boot-device: eMMC
[0007.132] I> Add boot-sdmmc to plugin-manager/misc-data
[0007.138] I> Add storage-sdmmc to plugin-manager/misc-data
[0007.143] W> Unknown storage device
[0007.147] I> Add serial number:1561221004859 as DT property
[0007.153] I> Plugin-manager override starting
[0007.156] I> node /plugin-manager/fragement-tegra-wdt-en matches
[0007.163] I> node /plugin-manager/fragement-soft-wdt matches
[0007.170] I> node /plugin-manager/fragment-pcie-c5-rp matches
[0007.175] I> node /plugin-manager/fragment-tegra-ufs-lane10 matches
[0007.186] I> Disable plugin-manager status in FDT
[0007.186] I> Plugin-manager override finished successfully
[0007.189] I> tegrabl_load_kernel_and_dtb: Done
[0007.235] I> Kernel EP: 0x80080000, DTB: 0x90000000
[    0.000000] Linux version 4.9.253-tegra (buildbrain@mobile-u64-5374-d5000) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Sun Apr 17 02:37:44 PDT 2022
[    0.000000] Found tegra_fbmem: 00800000@a06ab000
[    0.000000] Found lut_mem: 00002008@a06a6000
[    0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[    0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[    0.000000] OF: reserved mem: initialized node grid-of-semaphores, compatible id nvidia,gosmem
[    0.000000] cma: Reserved 64 MiB at 0x00000000c2000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] percpu: Embedded 24 pages/cpu s57624 r8192 d32488 u98304
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8192517
[    0.000000] Kernel command line: console=ttyTCU0,115200 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyTCU0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4  video=tegrafb earlycon=tegra_comb_uart,mmio32,0x0c168000 gpt rootfs.slot_suffix= tegra_fbmem=0x800000@0xa06ab000 lut_mem=0x2008@0xa06a6000 usbcore.old_scheme_first=1 tegraid=19.1.2.0.0 maxcpus=8 boot.slot_suffix= boot.ratchetvalues=0.4.2 vpr_resize sdhci_tegra.en_boot_part_access=1
[    0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[    0.000000] log_buf_len total cpu_extra contributions: 229376 bytes
[    0.000000] log_buf_len min size: 32768 bytes
[    0.000000] log_buf_len: 262144 bytes
[    0.000000] early log buf free: 29944(91%)
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes)
[    0.000000] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes)
[    0.000000] Memory: 31917284K/33290228K available (15358K kernel code, 2956K rwdata, 6696K rodata, 8640K init, 612K bss, 619280K reserved, 753664K cma-reserved)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 MB)
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000   (   250 GB)
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008f80000   ( 15360 KB)
[    0.000000]     .rodata : 0xffffff8008f80000 - 0xffffff8009610000   (  6720 KB)
[    0.000000]       .init : 0xffffff8009610000 - 0xffffff8009e80000   (  8640 KB)
[    0.000000]       .data : 0xffffff8009e80000 - 0xffffff800a163008   (  2957 KB)
[    0.000000]        .bss : 0xffffff800a163008 - 0xffffff800a1fc0b4   (   613 KB)
[    0.000000]     fixed   : 0xffffffbefe7fd000 - 0xffffffbefec00000   (  4108 KB)
[    0.000000]     PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000   (    16 MB)
[    0.000000]     vmemmap : 0xffffffbf00000000 - 0xffffffc000000000   (     4 GB maximum)
[    0.000000]               0xffffffbf00000000 - 0xffffffbf20000000   (   512 MB actual)
[    0.000000]     memory  : 0xffffffc000000000 - 0xffffffc800000000   ( 32768 MB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=8.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=8
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arm_arch_timer: Architected cp15 timer(s) running at 31.25MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[    0.000012] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[    0.009909] Console: colour dummy device 80x25
[    0.012420] console [tty0] enabled
[    0.015620] bootconsole [tegra_comb_uart0] disabled
[    0.020875] kmemleak: Kernel memory leak detector disabled
[    0.020933] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[    0.020975] pid_max: default: 32768 minimum: 301
[    0.022189] Security Framework initialized
[    0.022801] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.022832] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes)
[    0.026038] ftrace: allocating 47098 entries in 184 pages
[    0.477785] sched-energy: Sched-energy-costs installed from DT
[    0.477871] ASID allocator initialised with 65536 entries
[    0.519761] tegra-id: chipid=21917.
[    0.519823] tegra-id: opt_subrevision=1.
[    0.519877] Tegra Revision: A02p SKU: 0xd0 CPU Process: 0 SoC Process: 0
[    0.520011] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[    0.520082] DTB Build time: Apr 17 2022 02:42:31
[    0.570727] CPU1: Booted secondary processor [4e0f0040]
[    0.602758] CPU2: Booted secondary processor [4e0f0040]
[    0.634967] CPU3: Booted secondary processor [4e0f0040]
[    0.667498] CPU4: Booted secondary processor [4e0f0040]
[    0.699424] CPU5: Booted secondary processor [4e0f0040]
[    0.732165] CPU6: Booted secondary processor [4e0f0040]
[    0.767899] CPU7: Booted secondary processor [4e0f0040]
[    0.768346] Brought up 8 CPUs
[    0.768632] SMP: Total of 8 processors activated.
[    0.768667] CPU features: detected feature: Privileged Access Never
[    0.768731] CPU features: detected feature: LSE atomic instructions
[    0.768781] CPU features: detected feature: User Access Override
[    0.768809] CPU features: detected feature: 32-bit EL0 Support
[    0.774136] CPU: All CPU(s) started at EL2
[    0.774299] alternatives: patching kernel code
[    0.807473] devtmpfs: initialized
[    0.866460] Initilizing CustomIPI irq domain
[    0.866903] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.866962] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    0.880304] pinctrl core: initialized pinctrl subsystem
[    0.881080] OS set in device tree is not L4T.
[    0.881822] regulator-dummy: no parameters
[    0.882223] Initializing plugin-manager
[    0.882422] Plugin module not found
[    0.882518] Plugin-manager status disabled
[    0.886014] NET: Registered protocol family 16
[    0.888254] persistent_ram: found existing invalid buffer, size 17105878, start 374476734
[    0.888303] pstore: using zlib compression
[    0.890312] console [pstore-1] enabled
[    0.890345] pstore: Registered ramoops as persistent store backend
[    0.890382] ramoops: attached 0x200000@0xf0800000, ecc: 0/0
[    0.905365] cpuidle: using governor menu
[    0.908554] bpmp: waiting for handshake
[    0.908621] bpmp: handshake completed
[    0.908740] bpmp: synchronizing channels
[    0.908797] bpmp: channels synchronized
[    0.908837] bpmp: mail init ok
[    0.913580] t19x-arm-smmu 12000000.iommu: found 3 SMMUs and ISO SMMU id is 2
[    0.913891] t19x-arm-smmu 12000000.iommu: probing hardware configuration...
[    0.913973] t19x-arm-smmu 12000000.iommu: SMMUv2 with:
[    0.914013] t19x-arm-smmu 12000000.iommu:    stage 1 translation
[    0.914080] t19x-arm-smmu 12000000.iommu:    stage 2 translation
[    0.914117] t19x-arm-smmu 12000000.iommu:    nested translation
[    0.914187] t19x-arm-smmu 12000000.iommu:    stream matching with 128 register groups, mask 0x7f80
[    0.914251] t19x-arm-smmu 12000000.iommu: SMMU address space size (0x800000) differs from mapped region size (0x1000000)!
[    0.914296] t19x-arm-smmu 12000000.iommu:    64 context banks (0 stage-2 only)
[    0.914354] t19x-arm-smmu 12000000.iommu:    Stage-1: 39-bit VA -> 48-bit IPA
[    0.914393] t19x-arm-smmu 12000000.iommu:    Stage-2: 39-bit IPA -> 48-bit PA
[    0.919503] vdso: 2 pages (1 code @ ffffff8008f87000, 1 data @ ffffff8009e84000)
[    0.919642] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.924400] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[    0.927357] tegra_aon_clk_init: ok
[    0.927446] Registering BPMP clocks...
[    0.927735] tegra_bpmp_clk_init: clock init ok (400 clks)
[    0.929606] Serial: AMBA PL011 UART driver
[    0.930058] tegra_powergate_init: DONE
[    0.930241] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/../../../../../../hardware/nvidia/platform/t19x/galen/kernel-dts/common/tegra194-p2888-0001-p2822-0000-common.dtsi
[    0.930319] DTB Build time: Apr 17 2022 02:42:31
[    0.936472] Tegra reboot handler registered.
[    0.947627] iommu: Adding device 14180000.pcie to group 0
[    0.948797] iommu: Adding device 14100000.pcie to group 1
[    0.949837] iommu: Adding device 14140000.pcie to group 2
[    0.951407] iommu: Adding device 141a0000.pcie to group 3
[    0.953597] iommu: Adding device 2490000.ether_qos to group 4
[    0.954519] iommu: Adding device 3100000.serial to group 5
[    0.955458] iommu: Adding device 3110000.serial to group 6
[    0.956021] iommu: Adding device 3140000.serial to group 7
[    0.957020] tegra-pmc c360000.pmc: scratch reg offset dts data not present
[    0.957393] tegra-pmc: get_secure_pmc_setting: done secure_pmc=0
[    0.957487] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[    0.957527] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_L1
[    0.957560] tegra-pmc: ### PMC reset status reg: 0x2d
[    0.957682] tegra-pmc: PMC Prod config success
[    0.958028] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[    0.958091] tegra-pmc c360000.pmc: IO padctrl driver initialized
[    0.958733] iommu: Adding device 3460000.sdhci to group 8
[    0.959568] iommu: Adding device 3400000.sdhci to group 9
[    0.960491] iommu: Adding device 2450000.ufshci to group 10
[    0.961477] iommu: Adding device 3210000.spi to group 11
[    0.962018] iommu: Adding device c260000.spi to group 12
[    0.963496] iommu: Adding device 3160000.i2c to group 13
[    0.964296] iommu: Adding device c240000.i2c to group 14
[    0.964947] iommu: Adding device 3180000.i2c to group 15
[    0.965472] iommu: Adding device 3190000.i2c to group 16
[    0.966309] iommu: Adding device 31b0000.i2c to group 17
[    0.966917] iommu: Adding device 31c0000.i2c to group 18
[    0.967542] iommu: Adding device c250000.i2c to group 19
[    0.968076] iommu: Adding device 31e0000.i2c to group 20
[    0.969101] iommu: Adding device sound to group 21
[    0.969794] iommu: Adding device 3510000.hda to group 22
[    0.970752] iommu: Adding device bc00000.rtcpu to group 23
[    0.973415] iommu: Adding device 13e10000.host1x to group 24
[    0.974142] iommu: Adding device 13e10000.host1x:ctx0 to group 25
[    0.974891] iommu: Adding device 13e10000.host1x:ctx1 to group 26
[    0.975571] iommu: Adding device 13e10000.host1x:ctx2 to group 27
[    0.976213] iommu: Adding device 13e10000.host1x:ctx3 to group 28
[    0.976995] iommu: Adding device 13e10000.host1x:ctx4 to group 29
[    0.977727] iommu: Adding device 13e10000.host1x:ctx5 to group 30
[    0.979045] iommu: Adding device 13e10000.host1x:ctx6 to group 31
[    0.979862] iommu: Adding device 13e10000.host1x:ctx7 to group 32
[    0.980784] iommu: Adding device 15340000.vic to group 33
[    0.981703] iommu: Adding device 15380000.nvjpg to group 34
[    0.982164] iommu: Adding device 15500000.tsec to group 35
[    0.982543] iommu: Adding device 15100000.tsecb to group 36
[    0.983056] iommu: Adding device 15480000.nvdec to group 37
[    0.983546] iommu: Adding device 15140000.nvdec1 to group 38
[    0.983942] iommu: Adding device 154c0000.nvenc to group 39
[    0.984334] iommu: Adding device 15a80000.nvenc1 to group 40
[    0.985042] iommu: Adding device 15880000.nvdla0 to group 41
[    0.985629] iommu: Adding device 158c0000.nvdla1 to group 42
[    0.986410] iommu: Adding device 15200000.nvdisplay to group 43
[    0.987037] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06ab000(800000)
[    0.987101] platform 15200000.nvdisplay: IOVA linear map 0x00000000a06a6000(3000)
[    0.992676] platform 15200000.nvdisplay: IOVA linear map 0x00000000c6000000(2a000000)
[    0.992887] t19x-arm-smmu: Adding 15200000.nvdisplay to ISO SMMU client
[    0.995172] iommu: Adding device 15210000.nvdisplay to group 44
[    0.995512] t19x-arm-smmu: Adding 15210000.nvdisplay to ISO SMMU client
[    0.996565] iommu: Adding device 15220000.nvdisplay to group 45
[    0.996707] t19x-arm-smmu: Adding 15220000.nvdisplay to ISO SMMU client
[    1.000025] iommu: Adding device 15c10000.vi to group 46
[    1.000588] t19x-arm-smmu: Adding 15c10000.vi to ISO SMMU client
[    1.001264] iommu: Adding device 14800000.isp to group 47
[    1.002722] iommu: Adding device 16000000.pva0 to group 48
[    1.003713] iommu: Adding device 16800000.pva1 to group 49
[    1.004484] iommu: Adding device 15810000.se to group 50
[    1.005082] iommu: Adding device 15820000.se to group 51
[    1.005488] iommu: Adding device 15830000.se to group 52
[    1.005841] iommu: Adding device 15840000.se to group 53
[    1.006223] iommu: Adding device c1a0000.aon to group 54
[    1.008532] iommu: Adding device d000000.bpmp to group 55
[    1.009273] bpmp: ping status is 0
[    1.009579] bpmp d000000.bpmp: firmware tag is e73a758761f0c6d24a1e69a2ac6b5035
[    1.016453] bpmp d000000.bpmp: probe ok
[    1.018888] tegra-reset 0.bpmp_reset: registered 190 resets.
[    1.019550] iommu: Adding device smmu_test to group 56
[    1.021285] mc: mapped MMIO address: 0xffffff800a5e0000 -> 0x2c10000
[    1.021512] mc: mapped MMIO address: 0xffffff800a7b0000 -> 0x2c20000
[    1.021688] mc: mapped MMIO address: 0xffffff800a7d0000 -> 0x2c30000
[    1.021772] mc: mapped MMIO address: 0xffffff800b010000 -> 0x2c40000
[    1.021845] mc: mapped MMIO address: 0xffffff800b030000 -> 0x2c50000
[    1.021916] mc: mapped MMIO address: 0xffffff800b050000 -> 0x2b80000
[    1.021985] mc: mapped MMIO address: 0xffffff800b070000 -> 0x2b90000
[    1.022090] mc: mapped MMIO address: 0xffffff800b090000 -> 0x2ba0000
[    1.022212] mc: mapped MMIO address: 0xffffff800b0b0000 -> 0x2bb0000
[    1.022285] mc: mapped MMIO address: 0xffffff800b0d0000 -> 0x1700000
[    1.022365] mc: mapped MMIO address: 0xffffff800b0f0000 -> 0x1710000
[    1.022426] mc: mapped MMIO address: 0xffffff800b110000 -> 0x1720000
[    1.022481] mc: mapped MMIO address: 0xffffff800b130000 -> 0x1730000
[    1.022579] mc: mapped MMIO address: 0xffffff800b150000 -> 0x1740000
[    1.022633] mc: mapped MMIO address: 0xffffff800b170000 -> 0x1750000
[    1.022690] mc: mapped MMIO address: 0xffffff800b190000 -> 0x1760000
[    1.022743] mc: mapped MMIO address: 0xffffff800b1b0000 -> 0x1770000
[    1.022925] mc-err: mcerr ops are set to t19x
[    1.029614] iommu: Adding device 2600000.dma to group 57
[    1.035100] gpio gpiochip0: gpio-line-names specifies 210 line names but there are 224 lines on the chip
[    1.036316] GPIO line 339 (wifi-enable) hogged as output/high
[    1.037055] gpiochip_setup_dev: registered GPIOs 288 to 511 on device: gpiochip0 (tegra-gpio)
[    1.045842] gpio gpiochip1: gpio-line-names specifies 30 line names but there are 40 lines on the chip
[    1.046061] GPIO line 253 (pex-refclk-sel-low) hogged as output/low
[    1.046770] gpiochip_setup_dev: registered GPIOs 248 to 287 on device: gpiochip1 (tegra-gpio-aon)
[    1.049978] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_83 = 0x10a
[    1.050050] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CTRL_0 = 3
[    1.050105] tegra186-aowake c370000.pmc: WAKE_AOWAKE_CNTRL_24(PMU_INT) = 256
[    1.051501] iommu: Adding device 3550000.xudc to group 58
[    1.052785] iommu: Adding device 3610000.xhci to group 59
[    1.056087] arm64_ras arm64_ras: probed
[    1.056989] ras_fhi_enable: FHI 479 enabled on CPU0
[    1.057113] ras_fhi_enable: FHI 480 enabled on CPU1
[    1.057446] ras_fhi_enable: FHI 481 enabled on CPU2
[    1.057657] ras_fhi_enable: FHI 482 enabled on CPU3
[    1.057865] ras_fhi_enable: FHI 483 enabled on CPU4
[    1.058131] ras_fhi_enable: FHI 484 enabled on CPU5
[    1.058360] ras_fhi_enable: FHI 485 enabled on CPU6
[    1.058644] ras_fhi_enable: FHI 486 enabled on CPU7
[    1.059194] carmel_ras_enable: RAS enabled on cpu0
[    1.059667] carmel_ras_enable: RAS enabled on cpu1
[    1.060186] carmel_ras_enable: RAS enabled on cpu2
[    1.060717] carmel_ras_enable: RAS enabled on cpu3
[    1.061208] carmel_ras_enable: RAS enabled on cpu4
[    1.061650] carmel_ras_enable: RAS enabled on cpu5
[    1.062099] carmel_ras_enable: RAS enabled on cpu6
[    1.062561] carmel_ras_enable: RAS enabled on cpu7
[    1.062845] carmel_ras carmel_ras: probed
[    1.066327] tegra-cbb 2300000.cbb-noc: noc_secure_irq = 488, noc_nonsecure_irq = 487>
[    1.067239] tegra-cbb c600000.aon-noc: noc_secure_irq = 490, noc_nonsecure_irq = 489>
[    1.069067] tegra-cbb d600000.bpmp-noc: noc_secure_irq = 492, noc_nonsecure_irq = 491>
[    1.070790] tegra-cbb be00000.rce-noc: noc_secure_irq = 494, noc_nonsecure_irq = 493>
[    1.072265] tegra-cbb b600000.sce-noc: noc_secure_irq = 496, noc_nonsecure_irq = 495>
[    1.072792] tegra-cbb 14040000.cv-noc: defer probe as CV-NOC not probed yet
[    1.077342] vdd-3v3-cvb: 3300 mV
[    1.077953] vdd-1v8-cvb: 1800 mV
[    1.078743] vdd-1v8-sd: 1800 mV
[    1.079205] vdd-epb-1v0: 1000 mV
[    1.079886] vdd-epb-1v0: supplied by vdd-3v3-cvb
[    1.080261] vdd-sdmmc1-sw: 3300 mV
[    1.080909] avdd-cam-2v8: 2800 mV
[    1.081332] vdd-sata-1v5: 1500 mV
[    1.081816] vdd-1v8-slt: 1800 mV
[    1.082270] vdd-3v3-slt: 3300 mV
[    1.082757] vdd-fan: 5000 mV
[    1.083259] vdd-hdmi-5v0: 5000 mV
[    1.083763] vdd_sys_en: 1200 mV
[    1.084271] vdd-5v-sata: 5000 mV
[    1.085124] vdd-3v3-pcie: 3300 mV
[    1.085748] vdd-12v-pcie: 1200 mV
[    1.086367] vdd-ac-bat: 5000 mV
[    1.086737] vdd-5v-sata: supplied by vdd-ac-bat
[    1.125218] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    1.134736] eventlib_kernel: keventlib is initialized, test id: 0
[    1.135439] SCSI subsystem initialized
[    1.136398] usbcore: registered new interface driver usbfs
[    1.136556] usbcore: registered new interface driver hub
[    1.136744] usbcore: registered new device driver usb
[    1.163467] tegra-i2c 31e0000.i2c: could not find pctldev for node /host1x/dpaux@155F0000/pinmux@0, deferring probe
[    1.168795] max77620 4-003c: PMIC Version OTP:0x51 and ES:0x1
[    1.177670] vdd-1v0: at 1000 mV
[    1.181655] vdd-1v8-hs: at 1800 mV
[    1.185713] vdd-1v8-ls: at 1800 mV
[    1.189722] vdd-1v8-ao: at 1800 mV
[    1.193736] vddio-ddr-1v1: at 1100 mV
[    1.197446] vdd-rtc: at 800 mV
[    1.199128] spmic-ldo1: at 2375 mV
[    1.205565] vdd-ao-3v3: at 3300 mV
[    1.213621] vddio-emmc-3v3: at 3300 mV
[    1.215706] spmic-ldo4: at 1587 mV
[    1.225708] vdd-usb-3v3: at 3300 mV
[    1.233737] vddio-sdmmc1-3v3: at 3300 mV
[    1.237768] vdd-csi-1v2: at 1200 mV
[    1.239851] spmic-ldo8: at 1800 mV
[    1.246873] GPIO line 246 (gpio_default) hogged as output/high
[    1.248753] GPIO line 247 (gpio_default) hogged as output/high
[    1.249849] gpiochip_setup_dev: registered GPIOs 240 to 247 on device: gpiochip2 (max77620-gpio)
[    1.250662] max77620 4-003c: max77620 probe successful
[    1.252384] media: Linux media interface: v0.10
[    1.252542] Linux video capture interface: v2.00
[    1.256505] pps_core: LinuxPPS API ver. 1 registered
[    1.256626] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.256734] PTP clock support registered
[    1.257593] tegra_wdt_t18x 30c0000.watchdog: Expiry count is deprecated
[    1.258435] tegra_wdt_t18x 30c0000.watchdog: Tegra WDT init timeout = 120 sec
[    1.258553] tegra_wdt_t18x 30c0000.watchdog: Registered successfully
[    1.262862] trusty trusty: trusty version: Built: 02:25:37 Apr 17 2022
[    1.263003] trusty trusty: selected api version: 3 (requested 3)
[    1.264718] Advanced Linux Sound Architecture Driver Initialized.
[    1.265885] Bluetooth: Core ver 2.22
[    1.266009] NET: Registered protocol family 31
[    1.266051] Bluetooth: HCI device and connection manager initialized
[    1.266139] Bluetooth: HCI socket layer initialized
[    1.266193] Bluetooth: L2CAP socket layer initialized
[    1.266274] Bluetooth: SCO socket layer initialized
[    1.271908] camchar: rtcpu character device driver loaded
[    1.273941] clocksource: Switched to clocksource arch_sys_counter
[    1.335249] VFS: Disk quotas dquot_6.6.0
[    1.335560] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.336363] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    1.339452] tegra-carveouts tegra-carveouts: assigned reserved memory node grid-of-semaphores
[    1.339637] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000c6000000, size=0x2a000000
[    1.340778] cma: enabled page replacement for spfn=c6000, epfn=f0000
[    1.340879] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[    1.340999] nvmap: nvmap_select_cache_ops() nvmap cache ops set to scf
[    1.341069] nvmap_page_pool_init: Total RAM pages: 8167737
[    1.341114] nvmap_page_pool_init: nvmap page pool size: 1020967 pages (3988 MB)
[    1.341627] nvmap_background_zero_thread: PP zeroing thread starting.
[    1.343358] misc nvmap: created heap vpr base 0x00000000c6000000 size (688128KiB)
[    1.345390] tegra-gpcdma 2600000.dma: GPC DMA driver register 31 channels
[    1.365928] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    1.366464] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    1.366877] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type AUX-therm
[    1.367173] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type AO-therm
[    1.367519] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[    1.367875] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type Tboard_tegra
[    1.368076] thermal thermal_zone6: Registering thermal zone thermal_zone6 for type Tdiode_tegra
[    1.369931] la/ptsa driver initialized.
[    1.370436] NET: Registered protocol family 2
[    1.370731] IP idents hash table entries: 262144 (order: 9, 2097152 bytes)
[    1.379205] TCP established hash table entries: 262144 (order: 9, 2097152 bytes)
[    1.380655] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[    1.381350] TCP: Hash tables configured (established 262144 bind 65536)
[    1.381589] UDP hash table entries: 16384 (order: 7, 524288 bytes)
[    1.382276] UDP-Lite hash table entries: 16384 (order: 7, 524288 bytes)
[    1.383501] NET: Registered protocol family 1
[    1.384867] RPC: Registered named UNIX socket transport module.
[    1.384919] RPC: Registered udp transport module.
[    1.384952] RPC: Registered tcp transport module.
[    1.384987] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.385595] Trying to unpack rootfs image as initramfs...
[    1.642726] Freeing initrd memory: 7068K
[    1.670353] random: fast init done
[    1.677768] host1x 13e10000.host1x: initialized
[    1.682631] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.691832] audit: initializing netlink subsys (disabled)
[    1.692056] audit: type=2000 audit(1.236:1): initialized
[    1.693284] workingset: timestamp_bits=46 max_order=23 bucket_order=0
[    1.704434] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.706179] ntfs: driver 2.1.32 [Flags: R/W].
[    1.707186] 9p: Installing v9fs 9p2000 file system support
[    1.715707] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[    1.716105] io scheduler noop registered
[    1.716471] io scheduler cfq registered (default)
[    1.724836] gic 2a41000.agic-controller: GIC IRQ controller registered
[    1.782233] iommu: Adding device 2993000.adsp to group 60
[    1.963312] iommu: Adding device aconnect@2a41000:adsp_audio to group 61
[    1.965205] tegra-aconnect aconnect@2a41000: Tegra ACONNECT bus registered
[    1.988263] tegra-pwm 3280000.pwm: PWM clk can sleep in ops
[    1.989269] tegra-pwm c340000.pwm: PWM clk can sleep in ops
[    1.990487] tegra-pwm 32c0000.pwm: PWM clk can sleep in ops
[    1.991241] tegra-pwm 32f0000.pwm: PWM clk can sleep in ops
[    1.997389] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[    1.998106] misc tegra_camera_ctrl: tegra_camera_isomgr_register tpg_max_iso = 3916800KBs
[    1.998170] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=4687500, vi_iso_bw=1500000, max_bw=4687500
[    2.004871] tsec 15500000.tsec: initialized
[    2.008290] tsec 15100000.tsecb: initialized
[    2.016704] nvdec 15480000.nvdec: initialized
[    2.022346] nvdec 15140000.nvdec1: initialized
[    2.033708] falcon 15340000.vic: initialized
[    2.038289] falcon 15380000.nvjpg: initialized
[    2.042171] falcon 154c0000.nvenc: initialized
[    2.045988] falcon 15a80000.nvenc1: initialized
[    2.049639] iommu_context_dev 13e10000.host1x:ctx0: initialized (streamid=56)
[    2.052226] iommu_context_dev 13e10000.host1x:ctx1: initialized (streamid=57)
[    2.054386] iommu_context_dev 13e10000.host1x:ctx2: initialized (streamid=58)
[    2.056422] iommu_context_dev 13e10000.host1x:ctx3: initialized (streamid=59)
[    2.058490] iommu_context_dev 13e10000.host1x:ctx4: initialized (streamid=60)
[    2.060546] iommu_context_dev 13e10000.host1x:ctx5: initialized (streamid=61)
[    2.062466] iommu_context_dev 13e10000.host1x:ctx6: initialized (streamid=62)
[    2.064439] iommu_context_dev 13e10000.host1x:ctx7: initialized (streamid=63)
[    2.071885] t194-nvcsi 15a00000.nvcsi: initialized
[    2.081185] scare-pigeon 13e10000.host1x:vi-thi@15f00000: initialized
[    2.082004] scare-pigeon 14b00000.isp-thi: initialized
[    2.098436] pva 16000000.pva0: initialized
[    2.136160] pva 16800000.pva1: initialized
[    2.173996] nvdla 15880000.nvdla0: initialized
[    2.208248] nvdla 158c0000.nvdla1: initialized
[    2.211964] tegradccommon 15200000.dc_common: host1x channel mapped
[    2.212059] tegradccommon 15200000.dc_common: dc_common syncpt # 1 allocated
[    2.212207] tegradccommon 15200000.dc_common: dma mapping done
[    2.212820] tegra_cec 3960000.tegra_cec: dt=1 start=0x03960000 end=0x03960FFF irq=85
[    2.212915] tegra_cec 3960000.tegra_cec: Unpowergate DISP: 0.
[    2.213506] tegra_cec 3960000.tegra_cec: Enable clock result: 0.
[    2.214238] tegra_cec 3960000.tegra_cec: tegra_cec_init started
[    2.214421] tegra_cec 3960000.tegra_cec: cec_add_sysfs ret=0
[    2.214458] tegra_cec 3960000.tegra_cec: probed
[    2.216547] tegradc 15200000.nvdisplay: disp0 connected to head0->/host1x/sor2
[    2.216873] generic_infoframe_type: 0x87
[    2.217298] tegradc 15200000.nvdisplay: DT parsed successfully
[    2.217502] tegradc 15200000.nvdisplay: Display dc.ffffff800bce0000 registered with id=0
[    2.228205] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[    2.228316] tegradc 15200000.nvdisplay: failed to register ihub bw client
[    2.229043] tegradc: probe of 15200000.nvdisplay failed with error -7
[    2.229740] Could not get extcon-dev /host1x/nvdisplay@15210000:typec0(0)
[    2.230378] Could not get extcon-dev /host1x/nvdisplay@15220000:typec1(1)
[    2.237184] tegra-adma 2930000.adma: Tegra210 ADMA driver registered 32 channels
[    2.238860] tegra-fuse-burn 3820000.efuse:efuse-burn: shutdown limit check disabled
[    2.238933] tegra-fuse-burn 3820000.efuse:efuse-burn: Fuse burn driver initialized
[    2.239516] kfuse 3830000.kfuse: initialized
[    2.247794] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.252314] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 51, base_baud = 0) is a TEGRA_UART
[    2.255047] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 52, base_baud = 0) is a TEGRA_UART
[    2.256500] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 53, base_baud = 0) is a TEGRA_UART
[    3.237981] tegra_cec 3960000.tegra_cec: Can't find physical addresse.
[    3.237997] tegra_cec 3960000.tegra_cec: tegra_cec_init Done.
[    4.758438] console [ttyTCU0] enabled
[    4.762917] [drm] Initialized
[    4.783211] brd: module loaded
[    4.792760] loop: module loaded
[    4.793152] tegra_profiler: version: 1.145, samples/io: 49/28
[    4.793572] tegra_profiler: auth: init
[    4.795224] nct1008_nct72 4-004c: starting parse dt
[    4.795701] nct1008_nct72 4-004c: !!!Found deprecated property!!!
[    4.795900] nct1008_nct72 4-004c: success parsing dt
[    4.796515] THERMAL EST: found 3 subdevs
[    4.796875] nct1008_nct72 4-004c: success in enabling tmp451 VDD rail
[    4.806726] THERMAL EST num_resources: 0
[    4.810945] [THERMAL EST subdev 0]
[    4.813864] [THERMAL EST subdev 1]
[    4.817538] [THERMAL EST subdev 2]
[    4.820721] THERMAL EST: Found 2 profiles, default profile is quiet
[    4.827566] thermal thermal_zone7: Registering thermal zone thermal_zone7 for type thermal-fan-est
[    4.833005] nct1008_nct72 4-004c: LOC shutdown limit 107
[    4.834059] nct1008_nct72 4-004c: EXT shutdown limit 109
[    4.847038] THERMAL EST: thz register success.
[    4.851659] THERMAL EST: end of probe, return err: 0
[    4.858642] ufs_tegra 2450000.ufshci: freq-table-hz property not specified
[    4.863339] ufs_tegra 2450000.ufshci: ufshcd_populate_vreg: Unable to find vdd-hba-supply regulator, assuming enabled
[    4.870735] nct1008_nct72 4-004c: initial LOC temp: 38000
[    4.871408] nct1008_nct72 4-004c: initial EXT temp: 50000
[    4.872750] nct1008_nct72 4-004c: hi_b:-10, lo_b:128
[    4.874360] nct1008_nct72 4-004c: nct1008_probe: initialized
[    4.897658] ufs_tegra 2450000.ufshci: wakeup init done, cdirq 461
[    4.901853] gpio tegra-gpio-aon wake25 for gpio=32(EE:0)
[    4.925360] sd: No Scsi addr parsed to reserve index
[    4.925721] hisi_sas: driver version v1.6
[    4.937269] libphy: Fixed MDIO Bus: probed
[    4.938541] tun: Universal TUN/TAP device driver, 1.6
[    4.938674] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.940885] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[    4.941104] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    4.943918] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[    4.950736] igb: Copyright (c) 2007-2014 Intel Corporation.
[    4.956557] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[    4.964265] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    4.970450] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver - version 4.4.0-k
[    4.978012] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    4.999414] eqos 2490000.ether_qos: failed to read eqos_auto_cal_config_0_reg
[    5.000635] eqos 2490000.ether_qos: Setting local MAC: 48 b0 2d 3a a5 91
[    5.000850] Using phyrst_lpmode = 1 from DT
[    5.001628] libphy: dwc_phy: probed
[    5.009423] PPP generic driver version 2.4.2
[    5.010094] PPP BSD Compression module registered
[    5.014255] PPP Deflate Compression module registered
[    5.019457] PPP MPPE Compression module registered
[    5.024028] NET: Registered protocol family 24
[    5.028841] usbcore: registered new interface driver r8152
[    5.034063] usbcore: registered new interface driver asix
[    5.039730] usbcore: registered new interface driver ax88179_178a
[    5.045953] usbcore: registered new interface driver cdc_ether
[    5.051846] usbcore: registered new interface driver net1080
[    5.057430] usbcore: registered new interface driver cdc_subset
[    5.063212] usbcore: registered new interface driver zaurus
[    5.068908] usbcore: registered new interface driver cdc_ncm
[    5.074975] VFIO - User Level meta-driver version: 0.3
[    5.082440] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    5.085976] ehci-pci: EHCI PCI platform driver
[    5.090591] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    5.096799] ohci-pci: OHCI PCI platform driver
[    5.101026] ohci-platform: OHCI generic platform driver
[    5.115996] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[    5.116225] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[    5.122424] Could not get extcon-dev /xhci@3610000:id(0)
[    5.128286] usbcore: registered new interface driver uas
[    5.128557] usbcore: registered new interface driver usb-storage
[    5.134655] usbcore: registered new interface driver usbserial
[    5.145824] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[    5.146174] Could not get extcon-dev /xudc@3550000:vbus(0)
[    5.155876] ucsi_ccg 1-0008: FW1 Version: gn v12.06, [Base 3.1.2.1487]
[    5.158039] ucsi_ccg 1-0008: FW2 Version: gn v12.06, [Base 3.1.2.1487]
[    5.165901] ucsi_ccg 1-0008: fw_mode: 2
[    5.168373] ucsi_ccg 1-0008: fw1_invalid: 0
[    5.172617] ucsi_ccg 1-0008: fw2_invalid: 0
[    5.176806] ucsi_ccg 1-0008: silicon_id: 0x1f00
[    5.181788] ucsi_ccg 1-0008: typec-port0 extcon dev created
[    5.187349] ucsi_ccg 1-0008: typec-port1 extcon dev created
[    5.192901] ucsi_ccg 1-0008: typec-pd extcon dev created
[    5.198762] gpio tegra-gpio-aon wake48 for gpio=10(BB:2)
[    5.205974] ucsi_ccg 1-0008: [typec-port0] Cable state:1, cable id:1
[    5.214155] ucsi_ccg 1-0008: HPI Command Success.
[    5.216882] ucsi_ccg 1-0008: HPI Command Success.
[    5.219477] ucsi_ccg 1-0008: ucsi_ccg_init: complete
[    5.226351] mousedev: PS/2 mouse device common for all mice
[    5.230650] usbcore: registered new interface driver xpad
[    5.374348] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[    5.377853] Wake73 for irq=42
[    5.379591] rtc rtc1: alarm rtc device
[    5.379746] tegra_rtc c2a0000.rtc: rtc core: registered c2a0000.rtc as rtc1
[    5.380035] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[    5.380535] i2c /dev entries driver
[    5.385003] max77620-power max20024-power: Event recorder REG_NVERC : 0x80
[    5.399158] tegra-thermal-throttle bthrot_cdev: cpufreq policy is not ready defer
[    5.400452] FAN dev name: pwm-fan
[    5.400701] FAN:gpio request success.
[    5.400829] FAN: can't find tach_gpio
[    5.400956] pwm_fan_driver pwm-fan: Found 2 profiles, default profile is quiet
[    5.401206] pwm_fan_driver pwm-fan: cap state:4, cap pwm:255
[    5.401885] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[    5.402043] pwm_fan_driver pwm-fan: tach period: 1000
[    5.403859] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[    5.404120] pwm_fan_driver pwm-fan: index 1: pwm=77, rpm=1000, rru=2, rrd=2, state:2
[    5.404297] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[    5.404446] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[    5.404609] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[    5.404818] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[    5.410466] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[    5.418226] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[    5.425855] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[    5.433524] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[    5.443836] tegra-oc-event d280000.soctherm-oc-event: OC driver initialized
[    5.450598] device-mapper: uevent: version 1.0.3
[    5.454571] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[    5.471509] tegra194_cpufreq_probe: platform driver Initialization: pass
[    5.474245] cpuidle: Initializing cpuidle driver
[    5.477090] sdhci: Secure Digital Host Controller Interface driver
[    5.480190] sdhci: Copyright(c) Pierre Ossman
[    5.484366] sdhci-pltfm: SDHCI platform and OF driver helper
[    5.493914] sdhci-tegra 3460000.sdhci: Client registration for eMC Successful
[    5.500640] CMDQ: cmdq_platfm_init successful
[    5.503075] sdhci-tegra 3400000.sdhci: Got CD GPIO
[    5.510798] sdhci-tegra 3400000.sdhci: Client registration for eMC Successful
[    5.517982] sdhci-tegra 3400000.sdhci: wakeup init done, cdirq 256
[    5.527578] tegra-se-nvhost 15810000.se: initialized
[    5.533577] tegra-se-nvhost 15810000.se: tegra_se_probe: complete
[    5.535969] tegra-se-nvhost 15820000.se: initialized
[    5.540505] tegra-se-nvhost 15820000.se: tegra_se_probe: complete
[    5.544285] tegra-se-nvhost 15830000.se: initialized
[    5.550162] mmc0: SDHCI controller on 3460000.sdhci [3460000.sdhci] using ADMA 64-bit with 64 bit addr
[    5.550178] tegra-se-nvhost 15830000.se: tegra_se_probe: complete
[    5.563799] tegra-se-nvhost 15840000.se: initialized
[    5.570533] gpio tegra-gpio wake8 for gpio=55(G:7)
[    5.571435] tegra-se-nvhost 15840000.se: tegra_se_probe: complete
[    5.578817] tegra-se-elp 3ad0000.se_elp: tegra_se_elp_probe: complete
[    5.579158] hidraw: raw HID events driver (C) Jiri Kosina
[    5.583354] usbcore: registered new interface driver usbhid
[    5.583373] usbhid: USB HID core driver
[    5.600622] mmc1: SDHCI controller on 3400000.sdhci [3400000.sdhci] using ADMA 64-bit with 64 bit addr
[    5.616002] tegra186-cam-rtcpu bc00000.rtcpu: deferring, 14800000.isp is not probed
[    5.621056] tegra_aon c1a0000.aon: tegra aon driver probe OK
[    5.624788] tegra186-aondbg aondbg: aondbg driver probe() OK
[    5.629524] denver_knobs_init:MTS_VERSION:54811859
[    5.634655] tegra19x_actmon d230000.actmon: in actmon_register()...
[    5.642598] tegra19x_actmon d230000.actmon: initialization Completed for the device mc_all
[    5.649676] t19x_cache tegra-cache: probed
[    5.663498] misc nvmap: cvsram :dma coherent mem declare 0x0000000050000000,4194304
[    5.663757] misc nvmap: created heap cvsram base 0x0000000050000000 size (4096KiB)
[    5.669637] carmel-pmu-drv carmel-pmu: Registered Carmel PMU
[    5.674316] PLL_AON clock registered
[    5.683933] Clocks initialized successfully
[    5.688711] nvpmodel: initialized successfully
[    5.692172] mmc0: mmc_decode_ext_csd: CMDQ supported: depth: 31, cmdq_support: 1
[    5.694649] trusty-virtio trusty:virtio: initializing
[    5.698319] trusty_ipc virtio0: vring0: va(pa)  ffffffc7d76ca000(0) qsz 32 notifyid 1
[    5.705531] trusty_ipc virtio0: vring1: va(pa)  ffffffc7d76cc000(0) qsz 32 notifyid 2
[    5.708277] mmc0: periodic cache flush enabled
[    5.708343] mmc0: new HS400 Enhanced strobe MMC card at address 0001
[    5.710176] mmcblk0: mmc0:0001 HBG4a2 29.1 GiB
[    5.710895] mmcblk0boot0: mmc0:0001 HBG4a2 partition 1 8.00 MiB
[    5.711424] mmcblk0boot1: mmc0:0001 HBG4a2 partition 2 8.00 MiB
[    5.711932] mmcblk0rpmb: mmc0:0001 HBG4a2 partition 3 4.00 MiB
[    5.724614]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15 p16 p17 p18 p19 p20 p21 p22 p23 p24 p25 p26 p27 p28 p29 p30 p31 p32 p33 p34 p35 p36 p37 p38 p39 p40 p41 p42
[    5.763624] trusty-virtio trusty:virtio: initializing done
[    5.764127] trusty_ipc virtio0: is online
[    5.778562] tegra-hda 3510000.hda: Override SDO lines to 4
[    5.779930] usbcore: registered new interface driver snd-usb-audio
[    5.799917] input: tegra-hda-galen-t194 HDMI/DP,pcm=3 as /devices/3510000.hda/sound/card0/input0
[    5.800487] input: tegra-hda-galen-t194 HDMI/DP,pcm=7 as /devices/3510000.hda/sound/card0/input1
[    5.801970] input: tegra-hda-galen-t194 HDMI/DP,pcm=8 as /devices/3510000.hda/sound/card0/input2
[    5.810818] input: tegra-hda-galen-t194 HDMI/DP,pcm=9 as /devices/3510000.hda/sound/card0/input3
[    7.642931] gpio tegra-gpio wake12 for gpio=149(S:5)
[    7.883621] OPE platform probe
[    7.884026] OPE platform probe successful
[    8.060135] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[    8.060798] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[    8.061233] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[    8.061610] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[    8.062112] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[    8.062505] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[    8.062826] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[    8.063248] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[    8.063593] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[    8.063947] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[    8.064296] tegra-asoc: sound: ADMAIF11 <-> ADMAIF11 mapping ok
[    8.064630] tegra-asoc: sound: ADMAIF12 <-> ADMAIF12 mapping ok
[    8.065037] tegra-asoc: sound: ADMAIF13 <-> ADMAIF13 mapping ok
[    8.065368] tegra-asoc: sound: ADMAIF14 <-> ADMAIF14 mapping ok
[    8.065673] tegra-asoc: sound: ADMAIF15 <-> ADMAIF15 mapping ok
[    8.066125] tegra-asoc: sound: ADMAIF16 <-> ADMAIF16 mapping ok
[    8.066452] tegra-asoc: sound: ADMAIF17 <-> ADMAIF17 mapping ok
[    8.068417] tegra-asoc: sound: ADMAIF18 <-> ADMAIF18 mapping ok
[    8.074779] tegra-asoc: sound: ADMAIF19 <-> ADMAIF19 mapping ok
[    8.080703] tegra-asoc: sound: ADMAIF20 <-> ADMAIF20 mapping ok
[    8.142183] input: tegra-snd-t19x-mobile-rt565x Headset Jack as /devices/sound/sound/card1/input4
[    8.148240] u32 classifier
[    8.148412]     Actions configured
[    8.148751] Initializing XFRM netlink socket
[    8.149881] NET: Registered protocol family 10
[    8.151820] NET: Registered protocol family 17
[    8.152000] NET: Registered protocol family 15
[    8.152211] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    8.152859] Bluetooth: RFCOMM socket layer initialized
[    8.153078] Bluetooth: RFCOMM ver 1.11
[    8.153204] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[    8.153365] Bluetooth: HIDP socket layer initialized
[    8.153607] 9pnet: Installing 9P2000 support
[    8.156360] Key type dns_resolver registered
[    8.161412] Registered cp15_barrier emulation handler
[    8.166044] Registered setend emulation handler
[    8.173564] registered taskstats version 1
[    8.176647] tegra-pcie-dw 14180000.pcie: Setting init speed to max speed
[    8.184831] OF: PCI: host bridge /pcie@14180000 ranges:
[    8.186988] OF: PCI:    IO 0x38100000..0x381fffff -> 0x38100000
[    8.192920] OF: PCI:   MEM 0x1b40000000..0x1bffffffff -> 0x40000000
[    8.199243] OF: PCI:   MEM 0x1800000000..0x1b3fffffff -> 0x1800000000
[    8.318007] tegra-pcie-dw 14180000.pcie: link is up
[    8.318986] tegra-pcie-dw 14180000.pcie: PCI host bridge to bus 0000:00
[    8.319201] pci_bus 0000:00: root bus resource [bus 00-ff]
[    8.319368] pci_bus 0000:00: root bus resource [io  0x0000-0xfffff] (bus address [0x38100000-0x381fffff])
[    8.319569] pci_bus 0000:00: root bus resource [mem 0x1b40000000-0x1bffffffff] (bus address [0x40000000-0xffffffff])
[    8.319772] pci_bus 0000:00: root bus resource [mem 0x1800000000-0x1b3fffffff pref]
[    8.321091] iommu: Adding device 0000:00:00.0 to group 62
[    8.323686] iommu: Adding device 0000:01:00.0 to group 63
[    8.327479] pci 0000:00:00.0: BAR 14: assigned [mem 0x1b40000000-0x1b400fffff]
[    8.327731] pci 0000:01:00.0: BAR 0: assigned [mem 0x1b40000000-0x1b40003fff 64bit]
[    8.327990] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    8.328110] pci 0000:00:00.0:   bridge window [mem 0x1b40000000-0x1b400fffff]
[    8.328313] pci 0000:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    8.328619] pci 0000:01:00.0: Max Payload Size set to  256/ 256 (was  128), Max Read Rq  512
[    8.329358] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    8.334137] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    8.342326] nvme nvme0: pci function 0000:01:00.0
[    8.345502] nvme 0000:01:00.0: enabling device (0000 -> 0002)
[    8.346407] tegra-pcie-dw 14100000.pcie: Setting init speed to max speed
[    8.348954] OF: PCI: host bridge /pcie@14100000 ranges:
[    8.349016] OF: PCI:    IO 0x30100000..0x301fffff -> 0x30100000
[    8.349066] OF: PCI:   MEM 0x1230000000..0x123fffffff -> 0x40000000
[    8.349074] OF: PCI:   MEM 0x1200000000..0x122fffffff -> 0x1200000000
[    8.461901] tegra-pcie-dw 14100000.pcie: link is up
[    8.462554] tegra-pcie-dw 14100000.pcie: PCI host bridge to bus 0001:00
[    8.462747] pci_bus 0001:00: root bus resource [bus 00-ff]
[    8.462871] pci_bus 0001:00: root bus resource [io  0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[    8.463058] pci_bus 0001:00: root bus resource [mem 0x1230000000-0x123fffffff] (bus address [0x40000000-0x4fffffff])
[    8.463254] pci_bus 0001:00: root bus resource [mem 0x1200000000-0x122fffffff pref]
[    8.464169] iommu: Adding device 0001:00:00.0 to group 64
[    8.466739] iommu: Adding device 0001:01:00.0 to group 65
[    8.481439] pci 0001:00:00.0: BAR 14: assigned [mem 0x1230000000-0x12300fffff]
[    8.481657] pci 0001:00:00.0: BAR 13: assigned [io  0x100000-0x100fff]
[    8.481904] pci 0001:01:00.0: BAR 6: assigned [mem 0x1230000000-0x123000ffff pref]
[    8.482058] pci 0001:01:00.0: BAR 5: assigned [mem 0x1230010000-0x12300101ff]
[    8.482285] pci 0001:01:00.0: BAR 4: assigned [io  0x100000-0x10000f]
[    8.482530] pci 0001:01:00.0: BAR 0: assigned [io  0x100010-0x100017]
[    8.482726] pci 0001:01:00.0: BAR 2: assigned [io  0x100018-0x10001f]
[    8.485693] pci 0001:01:00.0: BAR 1: assigned [io  0x100020-0x100023]
[    8.492646] pci 0001:01:00.0: BAR 3: assigned [io  0x100024-0x100027]
[    8.498799] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    8.503818] pci 0001:00:00.0:   bridge window [io  0x100000-0x100fff]
[    8.510299] pci 0001:00:00.0:   bridge window [mem 0x1230000000-0x12300fffff]
[    8.517592] pci 0001:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    8.526643] pci 0001:01:00.0: Max Payload Size set to  256/ 512 (was  128), Max Read Rq  512
[    8.535707] pcieport 0001:00:00.0: Signaling PME through PCIe PME interrupt
[    8.541959] pci 0001:01:00.0: Signaling PME through PCIe PME interrupt
[    8.550576] ahci 0001:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    8.556760] ahci 0001:01:00.0: flags: 64bit ncq sntf led only pmp fbs pio slum part sxs
[    8.566799] scsi host1: ahci
[    8.567979] ata1: SATA max UDMA/133 abar m512@0x1230010000 port 0x1230010100 irq 821
[    8.576523] tegra-pcie-dw 14140000.pcie: Setting init speed to max speed
[    8.582069]  nvme0n1: p1
[    8.584485] OF: PCI: host bridge /pcie@14140000 ranges:
[    8.589415] OF: PCI:    IO 0x34100000..0x341fffff -> 0x34100000
[    8.595226] OF: PCI:   MEM 0x12b0000000..0x12bfffffff -> 0x40000000
[    8.601324] OF: PCI:   MEM 0x1280000000..0x12afffffff -> 0x1280000000
[    8.889642] ata1: SATA link down (SStatus 0 SControl 300)
[    9.126372] tegra-pcie-dw 14140000.pcie: link is down
[    9.127349] tegra-pcie-dw 14140000.pcie: PCI host bridge to bus 0003:00
[    9.127552] pci_bus 0003:00: root bus resource [bus 00-ff]
[    9.127738] pci_bus 0003:00: root bus resource [io  0x200000-0x2fffff] (bus address [0x34100000-0x341fffff])
[    9.127931] pci_bus 0003:00: root bus resource [mem 0x12b0000000-0x12bfffffff] (bus address [0x40000000-0x4fffffff])
[    9.128167] pci_bus 0003:00: root bus resource [mem 0x1280000000-0x12afffffff pref]
[    9.129373] iommu: Adding device 0003:00:00.0 to group 66
[    9.130207] pci 0003:00:00.0: PCI bridge to [bus 01-ff]
[    9.130385] pci 0003:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    9.131034] pcieport 0003:00:00.0: Signaling PME through PCIe PME interrupt
[    9.132300] iommu: Removing device 0003:00:00.0 from group 66
[    9.134529] tegra-pcie-dw 14140000.pcie: PCIe link is not up...!
[    9.136321] tegra-pcie-dw 141a0000.pcie: Setting init speed to max speed
[    9.246982] OF: PCI: host bridge /pcie@141a0000 ranges:
[    9.247244] OF: PCI:    IO 0x3a100000..0x3a1fffff -> 0x3a100000
[    9.247394] OF: PCI:   MEM 0x1f40000000..0x1fffffffff -> 0x40000000
[    9.247538] OF: PCI:   MEM 0x1c00000000..0x1f3fffffff -> 0x1c00000000
[    9.766014] tegra-pcie-dw 141a0000.pcie: link is down
[    9.766853] tegra-pcie-dw 141a0000.pcie: PCI host bridge to bus 0005:00
[    9.767044] pci_bus 0005:00: root bus resource [bus 00-ff]
[    9.767169] pci_bus 0005:00: root bus resource [io  0x300000-0x3fffff] (bus address [0x3a100000-0x3a1fffff])
[    9.767362] pci_bus 0005:00: root bus resource [mem 0x1f40000000-0x1fffffffff] (bus address [0x40000000-0xffffffff])
[    9.767600] pci_bus 0005:00: root bus resource [mem 0x1c00000000-0x1f3fffffff pref]
[    9.768673] iommu: Adding device 0005:00:00.0 to group 66
[    9.769876] pci 0005:00:00.0: PCI bridge to [bus 01-ff]
[    9.770037] pci 0005:00:00.0: Max Payload Size set to  256/ 256 (was  256), Max Read Rq  512
[    9.770796] pcieport 0005:00:00.0: Signaling PME through PCIe PME interrupt
[    9.771988] iommu: Removing device 0005:00:00.0 from group 66
[    9.774694] tegra-pcie-dw 141a0000.pcie: PCIe link is not up...!
[    9.802362] tegra-cbb 14040000.cv-noc: noc_secure_irq = 100, noc_nonsecure_irq = 99>
[    9.820094] tegra194-isp5 14800000.isp: initialized
[    9.831339] tegra194-vi5 15c10000.vi: using default number of vi channels, 36
[    9.841109] tegra194-vi5 15c10000.vi: initialized
[    9.848930] tegra194-vi5 15c10000.vi: ep of_device is not enabled /host1x/vi@15c10000/ports/port@0/endpoint.
[    9.854225] tegradc 15210000.nvdisplay: disp0 connected to head1->/host1x/sor
[    9.854582] tegradc 15210000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[    9.855406] tegradc 15210000.nvdisplay: DT parsed successfully
[    9.855763] tegradc 15210000.nvdisplay: Display dc.ffffff8011050000 registered with id=0
[    9.857106] tegra-xusb 3610000.xhci: USB2 port 0 has OTG_CAP
[    9.857305] tegra-xusb 3610000.xhci: USB3 port 2 has OTG_CAP
[    9.860885] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[    9.861139] tegradc 15210000.nvdisplay: failed to register ihub bw client
[    9.862045] tegradc: probe of 15210000.nvdisplay failed with error -7
[    9.862209] tegradc 15220000.nvdisplay: disp0 connected to head2->/host1x/sor1
[    9.862247] tegradc 15220000.nvdisplay: parse_dp_settings: No dp-lt-settings node
[    9.862349] tegradc 15220000.nvdisplay: DT parsed successfully
[    9.862458] tegradc 15220000.nvdisplay: Display dc.ffffff80110d0000 registered with id=0
[    9.863105] tegra-xusb 3610000.xhci: extcon 0: ffffffc7d7ac3400 id
[    9.864321] tegra_nvdisp_bandwidth_register_max_config: couldn't find valid max config!
[    9.864332] tegradc 15220000.nvdisplay: failed to register ihub bw client
[    9.864600] tegradc: probe of 15220000.nvdisplay failed with error -7
[    9.865984] tegra-xudc-new 3550000.xudc: PMQOS CPU boost enabled
[    9.866044] tegra-xudc-new 3550000.xudc: device count: 1
[    9.868324] tegra-xudc-new 3550000.xudc: vbus state: 1
[    9.868360] tegra-xudc-new 3550000.xudc: device mode on: 0
[    9.868712] tegra-xudc-new 3550000.xudc: active: 0 => 1
[    9.868721] tegra-xudc-new 3550000.xudc: Initialize boost_cpufreq work
[    9.869196] tegra-xusb 3610000.xhci: Firmware timestamp: 2020-09-11 16:55:03 UTC, Version: 60.09 release
[    9.869303] tegra-xusb 3610000.xhci: xHCI Host Controller
[    9.869347] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 1
[    9.870151] tegra-xusb 3610000.xhci: hcc params 0x0184ff25 hci version 0x110 quirks 0x00050810
[    9.870240] tegra-xusb 3610000.xhci: irq 474, io mem 0x03610000
[    9.870559] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    9.870563] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.870567] usb usb1: Product: xHCI Host Controller
[    9.870570] usb usb1: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[    9.870572] usb usb1: SerialNumber: 3610000.xhci
[    9.871015] tegra-thermal-throttle bthrot_cdev: clk:cpu max:2265600000, min:115200000 steps:28
[    9.871393] hub 1-0:1.0: USB hub found
[    9.871473] hub 1-0:1.0: 4 ports detected
[    9.871966] tegra-xusb 3610000.xhci: xHCI Host Controller
[    9.871975] tegra-xusb 3610000.xhci: new USB bus registered, assigned bus number 2
[    9.871996] tegra-xusb 3610000.xhci: Host supports USB 3.1 Enhanced SuperSpeed
[    9.872253] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[    9.872256] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    9.872267] usb usb2: Product: xHCI Host Controller
[    9.872269] usb usb2: Manufacturer: Linux 4.9.253-tegra xhci-hcd
[    9.872272] usb usb2: SerialNumber: 3610000.xhci
[    9.872963] hub 2-0:1.0: USB hub found
[    9.873026] hub 2-0:1.0: 4 ports detected
[    9.874253] Wake76 for irq=199
[    9.874265] Wake77 for irq=199
[    9.874271] Wake78 for irq=199
[    9.874280] Wake79 for irq=199
[    9.874284] Wake80 for irq=199
[    9.874288] Wake81 for irq=199
[    9.874295] Wake82 for irq=199
[    9.874377] tegra-xusb 3610000.xhci: Upgrade port 0 to USB3.0
[    9.874381] tegra-xusb 3610000.xhci: Upgrade port 1 to USB3.0
[    9.930928] tegra-thermal-throttle bthrot_cdev: clk:gpu max:1377000000, min:114750000 steps:13
[    9.931024] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:0:cpu off:0 slope-adj:200
[    9.931029] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced clk:1:gpu off:0 slope-adj:400
[    9.931321] tegra-thermal-throttle bthrot_cdev: cdev:skin-balanced max_state:56 cutoff:0
[    9.931412] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:0:cpu off:0 slope-adj:400
[    9.931416] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced clk:1:gpu off:0 slope-adj:400
[    9.987879] tegra-thermal-throttle bthrot_cdev: cdev:gpu-balanced max_state:52 cutoff:1
[    9.988014] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:0:cpu off:0 slope-adj:200
[    9.988049] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced clk:1:gpu off:365500000 slope-adj:300
[    9.988450] usb usb1: usb_suspend_both: status 0
[    9.988685] usb usb2: usb_suspend_both: status 0
[    9.988997] tegra-thermal-throttle bthrot_cdev: cdev:cpu-balanced max_state:56 cutoff:0
[    9.989075] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:0:cpu off:38400000 slope-adj:10
[    9.989078] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced clk:1:gpu off:25500000 slope-adj:10
[    9.990557] tegra-thermal-throttle bthrot_cdev: cdev:emergency-balanced max_state:2 cutoff:0
[    9.990646] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:0:cpu off:0 slope-adj:400
[    9.990650] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced clk:1:gpu off:0 slope-adj:400
[    9.991320] tegra-thermal-throttle bthrot_cdev: cdev:aux-balanced max_state:52 cutoff:1
[    9.994250] tegra186-cam-rtcpu bc00000.rtcpu: Trace buffer configured at IOVA=0xbff00000
[   10.339926] tegra-ivc ivc-bc00000.rtcpu: region 0: iova=0xbfee0000-0xbfefffff size=131072
[   10.341100] tegra-ivc ivc-bc00000.rtcpu:echo@0: echo: ver=0 grp=1 RX[16x64]=0x1000-0x1480 TX[16x64]=0x1480-0x1900
[   10.342000] tegra-ivc ivc-bc00000.rtcpu:dbg@1: dbg: ver=0 grp=1 RX[1x384]=0x1900-0x1b00 TX[1x384]=0x1b00-0x1d00
[   10.342596] tegra-ivc ivc-bc00000.rtcpu:dbg@2: dbg: ver=0 grp=1 RX[1x8192]=0x1d00-0x3d80 TX[1x8192]=0x3d80-0x5e00
[   10.343845] tegra-ivc ivc-bc00000.rtcpu:ivccontrol@3: ivccontrol: ver=0 grp=1 RX[64x320]=0x5e00-0xae80 TX[64x320]=0xae80-0xff00
[   10.344366] tegra-ivc ivc-bc00000.rtcpu:ivccapture@4: ivccapture: ver=0 grp=1 RX[512x64]=0xff00-0x17f80 TX[512x64]=0x17f80-0x20000
[   10.345386] tegra186-cam-rtcpu bc00000.rtcpu: using cam RTCPU IRQ (71)
[   10.345547] tegra186-cam-rtcpu bc00000.rtcpu: tegra_camrtc_mon_create is successful
[   10.354085] tegra186-cam-rtcpu bc00000.rtcpu: firmware version cpu=rce cmd=5 sha1=4c29076f2400b1aca1797dafeba3d8643d889753
[   10.365211] Wake83 for irq=211
[   10.366686] gpio tegra-gpio wake67 for gpio=48(G:0)
[   10.371502] gpio tegra-gpio-aon wake29 for gpio=36(EE:4)
[   10.377213] input: gpio-keys as /devices/gpio-keys/input/input5
[   10.415948] tegra_rtc c2a0000.rtc: setting system clock to 2022-06-21 10:34:26 UTC (1655807666)
[   10.418572] mmcblk mmc0:0001: Card claimed for testing.
[   10.496552] bpmp: mounted debugfs mirror
[   10.514202] ALSA device list:
[   10.514372]   #0: tegra-hda-galen-t194 at 0x3518000 irq 70
[   10.514482]   #1: tegra-snd-t19x-mobile-rt565x
[   10.521007] Freeing unused kernel memory: 8640K
[   10.596470] Root device found: mmcblk0p1
[   10.598951] Found dev node: /dev/mmcblk0p1
[   10.677038] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[   10.684175] Rootfs mounted over mmcblk0p1
[   10.730893] Switching from initrd to actual rootfs
[   11.074937] ip_tables: (C) 2000-2006 Netfilter Core Team
[   11.083230] cgroup: cgroup2: unknown option "nsdelegate"
[   11.104100] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[   11.106120] systemd[1]: Detected architecture arm64.
[   11.133228] systemd[1]: Set hostname to <tegra-ubuntu>.
[   11.357459] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[   11.358103] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[   11.739809] random: systemd: uninitialized urandom read (16 bytes read)
[   11.741332] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   11.742697] random: systemd: uninitialized urandom read (16 bytes read)
[   11.750951] systemd[1]: Created slice System Slice.
[   11.751996] random: systemd: uninitialized urandom read (16 bytes read)
[   11.752962] systemd[1]: Listening on udev Control Socket.
[   11.753889] systemd[1]: Listening on Syslog Socket.
[   11.754460] systemd[1]: Listening on fsck to fsckd communication Socket.
[   11.837479] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[   11.925409] nvgpu: 17000000.gv11b          nvgpu_nvhost_syncpt_init:291  [INFO]  syncpt_unit_base 60000000 syncpt_unit_size 400000 size 1000
[   11.925409]
[   13.532243] random: crng init done
If you only de-compile and re-compile the bpmp dtb but without changing anything, will you still hit this issue?
I did try this as well, and if I did this then the HDMI port worked.
I also just tested on r32.7.1, and the problem was also there.
BTW, why are you referring to a rel-34 document for your rel-32.7?
Sorry I just put the latest there, but the steps are identical in both r32 and r34 documentation:
@WayneWWW I must retract this. I tested again and it seems decompiling and recompiling also causes the issue. Do you know what could be causing this? I’m using the dtc binary provided in kernel/dtc.
Yes, I guess the issue is due to the RAMCODE according to the error log. But this shouldn’t happen after rel-32.7.
Could you try to compare the original bpmp dtb and the one you are using now?
Luckily I made a backup before any changes were made; however, there is no diff. Using dtdiff returns nothing
dtdiff bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.bak.dtb bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb
For reference the dtdiff after applying the patch is
$ dtdiff bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.BAK.dtb bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb
--- /dev/fd/63  2022-06-21 11:58:11.474820891 +0000
+++ /dev/fd/62  2022-06-21 11:58:11.481487588 +0000
@@ -849,13 +849,13 @@
                clock@can1 {
                        allow_fractional_divider = <0x1>;
-                       allowed-parents = <0x121 0x5b 0x13a>;
+                       allowed-parents = <0x121 0x5b 0x13a 0x5e>;
                        clk-id = <0x9>;
                clock@can2 {
                        clk-id = <0xb>;
Then could you share the flash log from your host when you flash the bpmp dtb?
If the file itself is same, have you tried to directly run flash bpmp dtb command? I mean maybe there is no need to change bpmp dtb, the problem is from the flash command.
Sure here are all the logs I could think to test.
Flashing the decompiled and recompiled BPMP DTB
Here’s the logs for only flashing the BPMP DTB partition, but the BPMP DTB is just decompiled and then recompiled (i.e. no changes). This breaks the display still.
Here’s how I decompiled and recompiled the DTB
$ kernel/dtc  --sort  -I dtb  -O dts  -o bootloader/tegra194-a02-bpmp-p2888-a04.dts  bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb
$kernel/dtc  --sort -I dts  -O dtb  -o bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb  bootloader/tegra194-a02-bpmp-p2888-a04.dts
$dtdiff bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.BAK.dtb bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb
root@clint-g55590:/mnt/pigeon/.local/build_bpmp_r32.7.2# ./flash.sh -k bpmp-fw-dtb jetson-agx-xavier-devkit mmcblk0p1
# L4T BSP Information:
# R32 , REVISION: 7.2
# Target Board Information:
# Name: jetson-agx-xavier-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0036 ] Generating RCM messages
[   0.0058 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin zerosbk
[   0.0064 ] Header already present for /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin
[   0.0092 ]
[   0.0114 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0115 ] Assuming zero filled SBK key
[   0.0136 ] tegrasign_v3.py --file /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0136 ] Assuming zero filled SBK key
[   0.0175 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0206 ]
[   0.0228 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0236 ]
[   0.0255 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0263 ] RCM 0 is saved as rcm_0.rcm
[   0.0287 ] RCM 1 is saved as rcm_1.rcm
[   0.0289 ] RCM 2 is saved as rcm_2.rcm
[   0.0289 ] List of rcm files are saved in rcm_list.xml
[   0.0289 ]
[   0.0289 ] Signing RCM messages
[   0.0309 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0309 ] Assuming zero filled SBK key
[   0.0367 ] Copying signature to RCM mesages
[   0.0387 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0399 ]
[   0.0400 ] Boot Rom communication
[   0.0419 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0426 ] RCM version 0X190001
[   0.0676 ] Boot Rom communication completed
[   1.0828 ]
[   2.0889 ] tegrarcm_v2 --isapplet
[   2.0917 ] Applet version 01.00.0000
[   2.1599 ]
[   2.1648 ] tegrarcm_v2 --ismb2
[   2.2394 ]
[   2.2432 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[   2.2464 ]
[   2.2512 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[   2.2541 ] adding BCH for nvtboot_applet_t194.bin
[   2.2650 ]
[   2.2720 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.2723 ] Assuming zero filled SBK key
[   2.2852 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[   2.2906 ]
[   2.2935 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.2947 ] Applet version 01.00.0000
[   2.3655 ] Sending mb2
[   2.3655 ] [................................................] 100%
[   2.3811 ]
[   2.3838 ] tegrarcm_v2 --boot recovery
[   2.3851 ] Applet version 01.00.0000
[   2.4607 ]
[   3.4666 ] tegrarcm_v2 --isapplet
[   3.5370 ]
[   3.5421 ] tegrarcm_v2 --ismb2
[   3.5447 ] MB2 Applet version 01.00.0000
[   3.6139 ]
[   3.6161 ] tegrarcm_v2 --ismb2
[   3.6169 ] MB2 Applet version 01.00.0000
[   3.7036 ]
[   3.7082 ] Retrieving board information
[   3.7123 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   3.7148 ] MB2 Applet version 01.00.0000
[   3.7860 ] Saved platform info in chip_info.bin
[   3.7903 ] Chip minor revision: 2
[   3.7905 ] Bootrom revision: 0xf
[   3.7906 ] Ram code: 0x2
[   3.7907 ] Chip sku: 0xd0
[   3.7908 ] Chip Sample: non es
[   3.7909 ]
[   3.7911 ] Retrieving EEPROM data
[   3.7911 ] tegrarcm_v2 --oem platformdetails eeprom cvm /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/cvm.bin
[   3.7918 ] MB2 Applet version 01.00.0000
[   3.8627 ] Saved platform info in /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/cvm.bin
[   3.8983 ]
[   3.8985 ] Rebooting to recovery mode
[   3.9030 ] tegrarcm_v2 --ismb2
[   3.9056 ] MB2 Applet version 01.00.0000
[   3.9730 ]
[   3.9731 ] Rebooting to recovery mode
[   3.9766 ] tegrarcm_v2 --reboot recovery
[   3.9781 ] MB2 Applet version 01.00.0000
[   4.0692 ]
Board ID(2888) version(400) sku(0004) revision(M.0)
copying bctfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
Existing bootloader(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/tegraflash.py --chip 0x19 --key  --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign boot.img kernel
version 1.0.0
[   0.0004 ] Generating signature
[   0.0027 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0027 ] Assuming zero filled SBK key : not reading
[   0.0028 ] Generating ratchet blob
[   0.0046 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0052 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0053 ]
[   0.0054 ] header_magic: 414e4452
[   0.0073 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[   0.0081 ]
[   0.0101 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[   0.0107 ] adding BCH for 1_boot.img
[   0.7552 ]
[   0.7581 ] tegrasign_v3.py --key  --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[   0.7581 ] Assuming zero filled SBK key : not reading
[   0.8304 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[   1.2081 ]
[   1.2332 ] Signed file: /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27cb800 to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Existing sosfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing scefile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/spe_t194.bin) reused.
Existing wb0boot(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/eks.img) reused.
copying dtbfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/tegraflash.py --chip 0x19 --key  --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign kernel_tegra194-p2888-0001-p2822-0000.dtb kernel_dtb
version 1.0.0
[   0.0028 ] Assuming zero filled SBK key : not reading
[   0.0027 ] Generating ratchet blob
[   0.0054 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0054 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0055 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0055 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0055 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0055 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0055 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0055 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0055 ]
[   0.0055 ] header_magic: d00dfeed
[   0.0075 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[   0.0085 ]
[   0.0104 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[   0.0110 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[   0.0166 ]
[   0.0196 ] tegrasign_v3.py --key  --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0197 ] Assuming zero filled SBK key : not reading
[   0.0245 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[   0.0279 ]
[   0.0284 ] Signed file: /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x45767 to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
        populating kernel to rootfs... done.
        populating initrd to rootfs... done.
        populating kernel_tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Existing tbcfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
Existing flasher(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/tegraflash.py) reused.
*** Updating [bpmp-fw-dtb] with tegra194-a02-bpmp-p2888-a04.dtb ***
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin  --chip 0x19 --applet mb1_t194_prod.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --cfg  flash.xml --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"  --odmdata 0x9190000  --cmd "signwrite bpmp-fw-dtb tegra194-a02-bpmp-p2888-a04.dtb; reboot"
version 1.0.0
[   0.0083 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0084 ] Assuming zero filled SBK key
[   0.0084 ] header_magic: d00dfeed
[   0.0105 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-a02-bpmp-p2888-a04.dtb
[   0.0115 ]
[   0.0135 ] tegrahost_v2 --chip 0x19 0 --magicid  --appendsigheader 1_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[   0.0143 ] adding BCH for 1_tegra194-a02-bpmp-p2888-a04.dtb
[   0.0322 ]
[   0.0345 ] tegrasign_v3.py --key None --list 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0345 ] Assuming zero filled SBK key
[   0.0398 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[   0.0624 ]
[   0.0625 ] Generating RCM messages
[   0.0644 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0651 ] Header already present for mb1_t194_prod.bin
[   0.0677 ]
[   0.0697 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0697 ] Assuming zero filled SBK key
[   0.0716 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0717 ] Assuming zero filled SBK key
[   0.0756 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0788 ]
[   0.0806 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0815 ]
[   0.0833 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0840 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0841 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0841 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0841 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0841 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0841 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0841 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0842 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0842 ]
[   0.0860 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0866 ] RCM 0 is saved as rcm_0.rcm
[   0.0892 ] RCM 1 is saved as rcm_1.rcm
[   0.0893 ] RCM 2 is saved as rcm_2.rcm
[   0.0893 ] List of rcm files are saved in rcm_list.xml
[   0.0893 ]
[   0.0893 ] Signing RCM messages
[   0.0915 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0915 ] Assuming zero filled SBK key
[   0.0971 ] Copying signature to RCM mesages
[   0.0991 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1002 ]
[   0.1002 ] Boot Rom communication
[   0.1021 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.1028 ] BR_CID: 0x8802191164017147080000000d0280c0
[   0.1280 ] RCM version 0X190001
[   0.1692 ] Boot Rom communication completed
[   1.1838 ]
[   2.1895 ] tegrarcm_v2 --isapplet
[   2.1923 ] Applet version 01.00.0000
[   2.2593 ]
[   2.2617 ] tegrasign_v3.py --getmode mode.txt --key None
[   2.2618 ] Assuming zero filled SBK key
[   2.2619 ] Parsing partition layout
[   2.2640 ] tegraparser_v2 --pt flash.xml.tmp
[   2.2654 ]
[   2.2654 ] Creating list of images to be signed
[   2.2674 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   2.2686 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.2692 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.2698 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.2724 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.2825 ] adding BCH for spe_t194.bin
[   2.2847 ] adding BCH for spe_t194.bin
[   2.2866 ] adding BCH for nvtboot_t194.bin
[   2.2885 ] adding BCH for nvtboot_t194.bin
[   2.2916 ] Header already present for preboot_c10_prod_cr.bin
[   2.2949 ] Header already present for preboot_c10_prod_cr.bin
[   2.2952 ] Header already present for mce_c10_prod_cr.bin
[   2.2955 ] Header already present for mce_c10_prod_cr.bin
[   2.2968 ] adding BCH for mts_c10_prod_cr.bin
[   2.3000 ] adding BCH for mts_c10_prod_cr.bin
[   2.3628 ] adding BCH for cboot_t194.bin
[   2.4232 ] adding BCH for cboot_t194.bin
[   2.4317 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.4402 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.4451 ] adding BCH for tos-trusty_t194.img
[   2.4502 ] adding BCH for tos-trusty_t194.img
[   2.4574 ] adding BCH for eks.img
[   2.4646 ] adding BCH for eks.img
[   2.4647 ] adding BCH for bpmp_t194.bin
[   2.4652 ] adding BCH for bpmp_t194.bin
[   2.4807 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.4969 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.5148 ] adding BCH for xusb_sil_rel_fw
[   2.5446 ] adding BCH for xusb_sil_rel_fw
[   2.5474 ] adding BCH for camera-rtcpu-rce.img
[   2.5498 ] adding BCH for camera-rtcpu-rce.img
[   2.5546 ] adding BCH for adsp-fw.bin
[   2.5595 ] adding BCH for adsp-fw.bin
[   2.5609 ] Header already present for warmboot_t194_prod.bin
[   2.5627 ] Header already present for warmboot_t194_prod.bin
[   2.5633 ] adding BCH for boot.img
[   2.5838 ] adding BCH for boot.img
[   3.3115 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[   4.0202 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[   4.0312 ]
[   4.0312 ] Filling MB1 storage info
[   4.0312 ] Generating br-bct
[   4.0338 ] Performing cfg overlay
[   4.0338 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[   4.0344 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1.cfg
[   4.0697 ]
[   4.0699 ] Updating dev and MSS params in BR BCT
[   4.0699 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.1463 ]
[   4.1464 ] Updating bl info
[   4.1486 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   4.1503 ]
[   4.1504 ] Generating signatures
[   4.1525 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   4.1526 ] Assuming zero filled SBK key
[   4.4462 ] Send BCT from Host
[   4.4462 ] Generating br-bct
[   4.4485 ] Performing cfg overlay
[   4.4485 ] ['/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1.cfg']
[   4.4485 ] Updating dev and MSS params in BR BCT
[   4.4486 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.5249 ]
[   4.5250 ] Updating bl info
[   4.5271 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.5296 ]
[   4.5296 ] Updating smd info
[   4.5315 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   4.5325 ]
[   4.5325 ] Updating Odmdata
[   4.5343 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   4.5353 ]
[   4.5353 ] Get Signed section of bct
[   4.5373 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   4.5381 ]
[   4.5400 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   4.5408 ] Assuming zero filled SBK key
[   4.5714 ]
[   4.5714 ] Updating BCT with signature
[   4.5735 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   4.5746 ]
[   4.5747 ] Generating coldboot mb1-bct
[   4.5767 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   4.5775 ] MB1-BCT version: 0x1
[   4.5777 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   4.5782 ] Added Platform Config 0 data with size :- 3168
[   4.5799 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   4.5801 ] File read failed
[   4.5843 ] File read failed
[   4.5927 ] Added Platform Config 1 data with size :- 19640
[   4.5929 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   4.5933 ] Added Platform Config 2 data with size :- 24
[   4.5935 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   4.5939 ] Added Platform Config 4 data with size :- 348
[   4.5942 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   4.5945 ] Added Platform Config 3 data with size :- 92
[   4.5945 ]
[   4.5945 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   4.5945 ] Added Platform Config 5 data with size :- 68
[   4.5945 ]
[   4.5945 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   4.5945 ] Added Platform Config 7 data with size :- 392
[   4.5945 ]
[   4.5945 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   4.5945 ] Added Platform Config 8 data with size :- 12
[   4.5945 ]
[   4.5945 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   4.5945 ] Added Platform Config 9 data with size :- 32
[   4.5945 ]
[   4.5946 ] Updating mb1-bct with firmware information
[   4.5964 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.5970 ] MB1-BCT version: 0x1
[   4.5973 ]
[   4.5974 ] Updating mb1-bct with storage information
[   4.5991 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   4.5998 ] MB1-BCT version: 0x1
[   4.6002 ]
[   4.6002 ] Updating mb1-bct with ratchet information
[   4.6021 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   4.6027 ] MB1-BCT version: 0x1
[   4.6029 ] FwIndex: 1, MinRatchetLevel: 0
[   4.6031 ] FwIndex: 2, MinRatchetLevel: 0
[   4.6031 ] FwIndex: 3, MinRatchetLevel: 0
[   4.6031 ] FwIndex: 4, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 5, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 6, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 7, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 11, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 12, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 13, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 14, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 15, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 16, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 17, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 18, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 19, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 30, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 31, MinRatchetLevel: 0
[   4.6032 ] FwIndex: 32, MinRatchetLevel: 0
[   4.6032 ]
[   4.6050 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[   4.6058 ]
[   4.6076 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[   4.6084 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[   4.6090 ]
[   4.6113 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.6114 ] Assuming zero filled SBK key
[   4.6153 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[   4.6165 ]
[   4.6166 ] Generating recovery mb1-bct
[   4.6187 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   4.6195 ] MB1-BCT version: 0x1
[   4.6198 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   4.6202 ] Added Platform Config 0 data with size :- 3168
[   4.6217 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   4.6220 ] File read failed
[   4.6261 ] File read failed
[   4.6349 ] Added Platform Config 1 data with size :- 19640
[   4.6351 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   4.6355 ] Added Platform Config 2 data with size :- 24
[   4.6358 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   4.6362 ] Added Platform Config 4 data with size :- 348
[   4.6364 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   4.6368 ] Added Platform Config 3 data with size :- 92
[   4.6368 ]
[   4.6368 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   4.6368 ] Added Platform Config 5 data with size :- 68
[   4.6368 ]
[   4.6368 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   4.6368 ] Added Platform Config 7 data with size :- 392
[   4.6368 ]
[   4.6368 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   4.6368 ] Added Platform Config 8 data with size :- 12
[   4.6368 ]
[   4.6368 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   4.6368 ] Added Platform Config 9 data with size :- 32
[   4.6368 ]
[   4.6369 ] Updating mb1-bct with firmware information
[   4.6389 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.6396 ] MB1-BCT version: 0x1
[   4.6403 ]
[   4.6404 ] Updating mb1-bct with storage information
[   4.6423 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   4.6430 ] MB1-BCT version: 0x1
[   4.6433 ]
[   4.6433 ] Updating mb1-bct with ratchet information
[   4.6453 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   4.6460 ] MB1-BCT version: 0x1
[   4.6461 ] FwIndex: 1, MinRatchetLevel: 0
[   4.6463 ] FwIndex: 2, MinRatchetLevel: 0
[   4.6465 ] FwIndex: 3, MinRatchetLevel: 0
[   4.6465 ] FwIndex: 4, MinRatchetLevel: 0
[   4.6465 ] FwIndex: 5, MinRatchetLevel: 0
[   4.6465 ] FwIndex: 6, MinRatchetLevel: 0
[   4.6465 ] FwIndex: 7, MinRatchetLevel: 0
[   4.6465 ] FwIndex: 11, MinRatchetLevel: 0
[   4.6465 ] FwIndex: 12, MinRatchetLevel: 0
[   4.6465 ] FwIndex: 13, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 14, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 15, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 16, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 17, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 18, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 19, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 30, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 31, MinRatchetLevel: 0
[   4.6466 ] FwIndex: 32, MinRatchetLevel: 0
[   4.6466 ]
[   4.6485 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[   4.6492 ]
[   4.6511 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1.bct zerosbk
[   4.6517 ] adding BCH for mb1_bct_MB1.bct
[   4.6524 ]
[   4.6547 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.6547 ] Assuming zero filled SBK key
[   4.6586 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[   4.6597 ]
[   4.6598 ] Generating coldboot mem-bct
[   4.6617 ] tegrabct_v2 --chip 0x19 0 --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1.cfg --membct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_4.bct
[   4.6625 ] Packing sdram param for instance[0]
[   4.7375 ] Packing sdram param for instance[1]
[   4.7377 ] Packing sdram param for instance[2]
[   4.7379 ] Packing sdram param for instance[3]
[   4.7380 ] Packing sdram param for instance[4]
[   4.7380 ] Packing sdram param for instance[5]
[   4.7380 ] Packing sdram param for instance[6]
[   4.7380 ] Packing sdram param for instance[7]
[   4.7380 ] Packing sdram param for instance[8]
[   4.7380 ] Packing sdram param for instance[9]
[   4.7380 ] Packing sdram param for instance[10]
[   4.7380 ] Packing sdram param for instance[11]
[   4.7381 ] Packing sdram param for instance[12]
[   4.7381 ] Packing sdram param for instance[13]
[   4.7381 ] Packing sdram param for instance[14]
[   4.7381 ] Packing sdram param for instance[15]
[   4.7381 ]
[   4.7381 ] Getting sector size from pt
[   4.7401 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   4.7408 ]
[   4.7409 ] BlockSize read from layout is 200
[   4.7428 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_4.bct
[   4.7435 ] adding BCH for /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_1.bct
[   4.7455 ]
[   4.7473 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[   4.7480 ]
[   4.7499 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct zerosbk
[   4.7506 ] Header already present for mem_coldboot.bct
[   4.7508 ]
[   4.7531 ] tegrasign_v3.py --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.7532 ] Assuming zero filled SBK key
[   4.7572 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[   4.7583 ]
[   4.7584 ] Generating recovery mem-bct
[   4.7603 ] tegrabct_v2 --chip 0x19 0 --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1.cfg --membct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/10729/tmplpssm3es1_4.bct
[   4.7610 ] Packing sdram param for instance[0]
[   4.8357 ] Packing sdram param for instance[1]
[   4.8359 ] Packing sdram param for instance[2]
[   4.8361 ] Packing sdram param for instance[3]
[   4.8362 ] Packing sdram param for instance[4]
[   4.8363 ] Packing sdram param for instance[5]
[   4.8363 ] Packing sdram param for instance[6]
[   4.8363 ] Packing sdram param for instance[7]
[   4.8363 ] Packing sdram param for instance[8]
[   4.8363 ] Packing sdram param for instance[9]
[   4.8363 ] Packing sdram param for instance[10]
[   4.8363 ] Packing sdram param for instance[11]
[   4.8363 ] Packing sdram param for instance[12]
[   4.8363 ] Packing sdram param for instance[13]
[   4.8363 ] Packing sdram param for instance[14]
[   4.8363 ] Packing sdram param for instance[15]
[   4.8363 ]
[   4.8364 ] Reading ramcode from backup chip_info.bin file
[   4.8365 ] RAMCODE Read from Device: 2
[   4.8387 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[   4.8396 ]
[   4.8417 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm.bct zerosbk
[   4.8424 ] adding BCH for mem_rcm.bct
[   4.8437 ]
[   4.8459 ] tegrasign_v3.py --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.8460 ] Assuming zero filled SBK key
[   4.8500 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[   4.8513 ]
[   4.8514 ] Sending BCTs
[   4.8534 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   4.8542 ] Applet version 01.00.0000
[   4.9264 ] Sending bct_bootrom
[   4.9266 ] [................................................] 100%
[   4.9277 ] Sending bct_mb1
[   4.9325 ] [................................................] 100%
[   4.9364 ] Sending bct_mem
[   4.9829 ] [................................................] 100%
[   5.0651 ]
[   5.0652 ] Generating blob
[   5.0677 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[   5.0685 ]
[   5.0706 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[   5.0713 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[   5.0763 ]
[   5.0788 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.0789 ] Assuming zero filled SBK key
[   5.0831 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[   5.0864 ]
[   5.0887 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[   5.0895 ]
[   5.0914 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[   5.0921 ] adding BCH for blob_nvtboot_recovery_t194.bin
[   5.0959 ]
[   5.0985 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.0986 ] Assuming zero filled SBK key
[   5.1031 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[   5.1058 ]
[   5.1079 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[   5.1088 ]
[   5.1107 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[   5.1115 ] Header already present for blob_preboot_c10_prod_cr.bin
[   5.1120 ]
[   5.1142 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.1143 ] Assuming zero filled SBK key
[   5.1187 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.1200 ]
[   5.1221 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[   5.1229 ]
[   5.1248 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[   5.1254 ] Header already present for blob_mce_c10_prod_cr.bin
[   5.1270 ]
[   5.1293 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.1294 ] Assuming zero filled SBK key
[   5.1333 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.1355 ]
[   5.1375 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[   5.1382 ]
[   5.1401 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[   5.1407 ] adding BCH for blob_mts_c10_prod_cr.bin
[   5.2022 ]
[   5.2047 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.2048 ] Assuming zero filled SBK key
[   5.2146 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.2476 ]
[   5.2501 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[   5.2508 ]
[   5.2526 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t194.bin zerosbk
[   5.2533 ] adding BCH for blob_bpmp_t194.bin
[   5.2691 ]
[   5.2716 ] tegrasign_v3.py --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.2717 ] Assuming zero filled SBK key
[   5.2773 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[   5.2868 ]
[   5.2891 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04.dtb
[   5.2900 ]
[   5.2921 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[   5.2927 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04.dtb
[   5.3108 ]
[   5.3133 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   5.3134 ] Assuming zero filled SBK key
[   5.3191 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[   5.3300 ]
[   5.3326 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[   5.3334 ]
[   5.3353 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194.bin zerosbk
[   5.3361 ] adding BCH for blob_spe_t194.bin
[   5.3382 ]
[   5.3407 ] tegrasign_v3.py --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.3408 ] Assuming zero filled SBK key
[   5.3450 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[   5.3468 ]
[   5.3490 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[   5.3502 ]
[   5.3522 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-trusty_t194.img zerosbk
[   5.3533 ] adding BCH for blob_tos-trusty_t194.img
[   5.3613 ]
[   5.3642 ] tegrasign_v3.py --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[   5.3643 ] Assuming zero filled SBK key
[   5.3694 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[   5.3745 ]
[   5.3768 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[   5.3775 ]
[   5.3795 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks.img zerosbk
[   5.3802 ] adding BCH for blob_eks.img
[   5.3804 ]
[   5.3825 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[   5.3826 ] Assuming zero filled SBK key
[   5.3865 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[   5.3875 ]
[   5.3896 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[   5.3903 ]
[   5.3924 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[   5.3931 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[   5.3985 ]
[   5.4008 ] tegrasign_v3.py --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   5.4009 ] Assuming zero filled SBK key
[   5.4051 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[   5.4088 ]
[   5.4111 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   5.4119 ] number of images in blob are 11
[   5.4121 ] blobsize is 6691752
[   5.4123 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 264064
[   5.4146 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 181152
[   5.4151 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   5.4155 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[   5.4159 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   5.4165 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[   5.4174 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 993088
[   5.4180 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[   5.4183 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[   5.4188 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[   5.4191 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 288624
[   5.4218 ]
[   5.4218 ] Sending bootloader and pre-requisite binaries
[   5.4239 ] tegrarcm_v2 --download blob blob.bin
[   5.4248 ] Applet version 01.00.0000
[   5.4951 ] Sending blob
[   5.4955 ] [................................................] 100%
[   6.4203 ]
[   6.4225 ] tegrarcm_v2 --boot recovery
[   6.4233 ] Applet version 01.00.0000
[   6.4942 ]
[   7.4975 ] tegrarcm_v2 --isapplet
[   7.9160 ]
[   7.9208 ] tegrarcm_v2 --ismb2
[   7.9902 ]
[   7.9925 ] tegradevflash_v2 --iscpubl
[   7.9933 ] Bootloader version 01.00.0000
[   8.0368 ] Bootloader version 01.00.0000
[   8.0382 ]
[   8.0382 ] Writing partition
[   8.0403 ] tegradevflash_v2 --write bpmp-fw-dtb 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
[   8.0410 ] Bootloader version 01.00.0000
[   8.0872 ] Writing partition bpmp-fw-dtb with 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
[   8.0886 ] [................................................] 100%
[   8.1554 ]
[   8.1557 ] Coldbooting the device
[   8.1594 ] tegrarcm_v2 --ismb2
[   8.2303 ]
[   8.2324 ] tegradevflash_v2 --reboot coldboot
[   8.2331 ] Bootloader version 01.00.0000
[   8.2742 ]
*** The [bpmp-fw-dtb] has been updated successfully. ***
Flashing the patched BPMP DTB enabling PLLAON
Here’s the logs for only flashing the BPMP DTB partition, but with the PLLAON update. This breaks the display still.
--- /dev/fd/63  2022-06-21 12:43:15.062475852 +0000
+++ /dev/fd/62  2022-06-21 12:43:15.062475852 +0000
                clock@can1 {
                        clk-id = <0x9>;
                clock@can2 {
                        clk-id = <0xb>;
$ ./flash.sh -k bpmp-fw-dtb jetson-agx-xavier-devkit mmcblk0p1
version 1.0.0
[   0.0069 ] Generating RCM messages
[   0.0089 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin zerosbk
[   0.0095 ] Header already present for /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin
[   0.0122 ]
[   0.0142 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0143 ] Assuming zero filled SBK key
[   0.0165 ] tegrasign_v3.py --file /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0165 ] Assuming zero filled SBK key
[   0.0205 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0236 ]
[   0.0257 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0265 ]
[   0.0284 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0292 ] RCM 0 is saved as rcm_0.rcm
[   0.0318 ] RCM 1 is saved as rcm_1.rcm
[   0.0319 ] RCM 2 is saved as rcm_2.rcm
[   0.0319 ] List of rcm files are saved in rcm_list.xml
[   0.0319 ]
[   0.0319 ] Signing RCM messages
[   0.0340 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0340 ] Assuming zero filled SBK key
[   0.0399 ] Copying signature to RCM mesages
[   0.0417 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0429 ]
[   0.0429 ] Boot Rom communication
[   0.0448 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0455 ] RCM version 0X190001
[   0.0707 ] Boot Rom communication completed
[   1.0867 ]
[   2.0929 ] tegrarcm_v2 --isapplet
[   2.0960 ] Applet version 01.00.0000
[   2.1619 ]
[   2.1640 ] tegrarcm_v2 --ismb2
[   2.2498 ]
[   2.2542 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[   2.2571 ]
[   2.2613 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[   2.2637 ] adding BCH for nvtboot_applet_t194.bin
[   2.2751 ]
[   2.2816 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.2818 ] Assuming zero filled SBK key
[   2.2901 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[   2.2937 ]
[   2.2961 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.2971 ] Applet version 01.00.0000
[   2.3668 ] Sending mb2
[   2.3672 ] [................................................] 100%
[   2.3826 ]
[   2.3875 ] tegrarcm_v2 --boot recovery
[   2.3907 ] Applet version 01.00.0000
[   2.4629 ]
[   3.4674 ] tegrarcm_v2 --isapplet
[   3.5424 ]
[   3.5449 ] tegrarcm_v2 --ismb2
[   3.5475 ] MB2 Applet version 01.00.0000
[   3.6300 ]
[   3.6345 ] tegrarcm_v2 --ismb2
[   3.6371 ] MB2 Applet version 01.00.0000
[   3.7069 ]
[   3.7089 ] Retrieving board information
[   3.7107 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   3.7114 ] MB2 Applet version 01.00.0000
[   3.7953 ] Saved platform info in chip_info.bin
[   3.7998 ] Chip minor revision: 2
[   3.8000 ] Bootrom revision: 0xf
[   3.8002 ] Ram code: 0x2
[   3.8003 ] Chip sku: 0xd0
[   3.8004 ] Chip Sample: non es
[   3.8004 ]
[   3.8007 ] Retrieving EEPROM data
[   3.8007 ] tegrarcm_v2 --oem platformdetails eeprom cvm /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/cvm.bin
[   3.8014 ] MB2 Applet version 01.00.0000
[   3.8726 ] Saved platform info in /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/cvm.bin
[   3.9071 ]
[   3.9074 ] Rebooting to recovery mode
[   3.9123 ] tegrarcm_v2 --ismb2
[   3.9149 ] MB2 Applet version 01.00.0000
[   3.9834 ]
[   3.9835 ] Rebooting to recovery mode
[   3.9882 ] tegrarcm_v2 --reboot recovery
[   3.9909 ] MB2 Applet version 01.00.0000
[   4.0668 ]
version 1.0.0
[   0.0025 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0026 ] Assuming zero filled SBK key : not reading
[   0.0025 ] Generating ratchet blob
[   0.0043 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0049 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0051 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0051 ]
[   0.0052 ] header_magic: 414e4452
[   0.0070 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[   0.0076 ]
[   0.0095 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[   0.0101 ] adding BCH for 1_boot.img
[   0.7718 ]
[   0.7746 ] tegrasign_v3.py --key  --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[   0.7747 ] Assuming zero filled SBK key : not reading
[   0.8496 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[   1.3950 ]
[   1.4526 ] Signed file: /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
version 1.0.0
[   0.0026 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0026 ] Generating ratchet blob
[   0.0044 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0050 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0052 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0052 ]
[   0.0053 ] header_magic: d00dfeed
[   0.0073 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[   0.0081 ]
[   0.0100 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[   0.0106 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[   0.0162 ]
[   0.0188 ] tegrasign_v3.py --key  --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0189 ] Assuming zero filled SBK key : not reading
[   0.0232 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[   0.0270 ]
[   0.0273 ] Signed file: /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
version 1.0.0
[   0.0081 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0082 ] Assuming zero filled SBK key
[   0.0082 ] header_magic: d00dfeed
[   0.0101 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-a02-bpmp-p2888-a04.dtb
[   0.0108 ]
[   0.0127 ] tegrahost_v2 --chip 0x19 0 --magicid  --appendsigheader 1_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[   0.0135 ] adding BCH for 1_tegra194-a02-bpmp-p2888-a04.dtb
[   0.0314 ]
[   0.0338 ] tegrasign_v3.py --key None --list 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0339 ] Assuming zero filled SBK key
[   0.0391 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[   0.0495 ]
[   0.0496 ] Generating RCM messages
[   0.0516 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0523 ] Header already present for mb1_t194_prod.bin
[   0.0555 ]
[   0.0576 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0577 ] Assuming zero filled SBK key
[   0.0598 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0599 ] Assuming zero filled SBK key
[   0.0640 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0673 ]
[   0.0692 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0704 ]
[   0.0724 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0732 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0734 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0735 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0735 ]
[   0.0753 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0760 ] RCM 0 is saved as rcm_0.rcm
[   0.0785 ] RCM 1 is saved as rcm_1.rcm
[   0.0786 ] RCM 2 is saved as rcm_2.rcm
[   0.0786 ] List of rcm files are saved in rcm_list.xml
[   0.0787 ]
[   0.0787 ] Signing RCM messages
[   0.0807 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0808 ] Assuming zero filled SBK key
[   0.0862 ] Copying signature to RCM mesages
[   0.0882 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0894 ]
[   0.0894 ] Boot Rom communication
[   0.0913 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.0919 ] BR_CID: 0x8802191164017147080000000d0280c0
[   0.1188 ] RCM version 0X190001
[   0.1591 ] Boot Rom communication completed
[   1.1750 ]
[   2.1808 ] tegrarcm_v2 --isapplet
[   2.1834 ] Applet version 01.00.0000
[   2.2551 ]
[   2.2576 ] tegrasign_v3.py --getmode mode.txt --key None
[   2.2577 ] Assuming zero filled SBK key
[   2.2577 ] Parsing partition layout
[   2.2596 ] tegraparser_v2 --pt flash.xml.tmp
[   2.2608 ]
[   2.2608 ] Creating list of images to be signed
[   2.2627 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   2.2634 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.2639 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.2645 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.2670 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.2677 ] adding BCH for spe_t194.bin
[   2.2702 ] adding BCH for spe_t194.bin
[   2.2721 ] adding BCH for nvtboot_t194.bin
[   2.2741 ] adding BCH for nvtboot_t194.bin
[   2.2777 ] Header already present for preboot_c10_prod_cr.bin
[   2.2816 ] Header already present for preboot_c10_prod_cr.bin
[   2.2820 ] Header already present for mce_c10_prod_cr.bin
[   2.2823 ] Header already present for mce_c10_prod_cr.bin
[   2.2838 ] adding BCH for mts_c10_prod_cr.bin
[   2.2868 ] adding BCH for mts_c10_prod_cr.bin
[   2.3481 ] adding BCH for cboot_t194.bin
[   2.4081 ] adding BCH for cboot_t194.bin
[   2.4168 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.4255 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.4308 ] adding BCH for tos-trusty_t194.img
[   2.4358 ] adding BCH for tos-trusty_t194.img
[   2.4433 ] adding BCH for eks.img
[   2.4503 ] adding BCH for eks.img
[   2.4504 ] adding BCH for bpmp_t194.bin
[   2.4509 ] adding BCH for bpmp_t194.bin
[   2.4664 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.4827 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.5006 ] adding BCH for xusb_sil_rel_fw
[   2.5186 ] adding BCH for xusb_sil_rel_fw
[   2.5211 ] adding BCH for camera-rtcpu-rce.img
[   2.5239 ] adding BCH for camera-rtcpu-rce.img
[   2.5288 ] adding BCH for adsp-fw.bin
[   2.5337 ] adding BCH for adsp-fw.bin
[   2.5351 ] Header already present for warmboot_t194_prod.bin
[   2.5368 ] Header already present for warmboot_t194_prod.bin
[   2.5375 ] adding BCH for boot.img
[   2.5588 ] adding BCH for boot.img
[   3.3250 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[   4.0814 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[   4.0917 ]
[   4.0918 ] Filling MB1 storage info
[   4.0918 ] Generating br-bct
[   4.0939 ] Performing cfg overlay
[   4.0939 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[   4.0942 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1.cfg
[   4.1288 ]
[   4.1289 ] Updating dev and MSS params in BR BCT
[   4.1290 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.2076 ]
[   4.2077 ] Updating bl info
[   4.2099 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   4.2119 ]
[   4.2120 ] Generating signatures
[   4.2141 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   4.2142 ] Assuming zero filled SBK key
[   4.4529 ] Send BCT from Host
[   4.4529 ] Generating br-bct
[   4.4551 ] Performing cfg overlay
[   4.4551 ] ['/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1.cfg']
[   4.4551 ] Updating dev and MSS params in BR BCT
[   4.4552 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.5315 ]
[   4.5315 ] Updating bl info
[   4.5336 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.5360 ]
[   4.5360 ] Updating smd info
[   4.5379 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   4.5390 ]
[   4.5391 ] Updating Odmdata
[   4.5409 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   4.5421 ]
[   4.5422 ] Get Signed section of bct
[   4.5441 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   4.5449 ]
[   4.5469 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   4.5475 ] Assuming zero filled SBK key
[   4.5790 ]
[   4.5790 ] Updating BCT with signature
[   4.5811 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   4.5823 ]
[   4.5824 ] Generating coldboot mb1-bct
[   4.5844 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   4.5851 ] MB1-BCT version: 0x1
[   4.5853 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   4.5858 ] Added Platform Config 0 data with size :- 3168
[   4.5872 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   4.5875 ] File read failed
[   4.5917 ] File read failed
[   4.6000 ] Added Platform Config 1 data with size :- 19640
[   4.6003 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   4.6008 ] Added Platform Config 2 data with size :- 24
[   4.6010 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   4.6014 ] Added Platform Config 4 data with size :- 348
[   4.6017 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   4.6019 ] Added Platform Config 3 data with size :- 92
[   4.6019 ]
[   4.6019 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   4.6020 ] Added Platform Config 5 data with size :- 68
[   4.6020 ]
[   4.6020 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   4.6020 ] Added Platform Config 7 data with size :- 392
[   4.6020 ]
[   4.6020 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   4.6020 ] Added Platform Config 8 data with size :- 12
[   4.6020 ]
[   4.6020 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   4.6020 ] Added Platform Config 9 data with size :- 32
[   4.6020 ]
[   4.6020 ] Updating mb1-bct with firmware information
[   4.6039 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.6046 ] MB1-BCT version: 0x1
[   4.6050 ]
[   4.6050 ] Updating mb1-bct with storage information
[   4.6068 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   4.6075 ] MB1-BCT version: 0x1
[   4.6080 ]
[   4.6080 ] Updating mb1-bct with ratchet information
[   4.6098 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   4.6106 ] MB1-BCT version: 0x1
[   4.6108 ] FwIndex: 1, MinRatchetLevel: 0
[   4.6109 ] FwIndex: 2, MinRatchetLevel: 0
[   4.6109 ] FwIndex: 3, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 4, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 5, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 6, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 7, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 11, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 12, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 13, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 14, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 15, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 16, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 17, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 18, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 19, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 30, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 31, MinRatchetLevel: 0
[   4.6110 ] FwIndex: 32, MinRatchetLevel: 0
[   4.6110 ]
[   4.6129 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[   4.6136 ]
[   4.6154 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[   4.6161 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[   4.6169 ]
[   4.6192 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.6193 ] Assuming zero filled SBK key
[   4.6234 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[   4.6246 ]
[   4.6247 ] Generating recovery mb1-bct
[   4.6269 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   4.6276 ] MB1-BCT version: 0x1
[   4.6280 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   4.6284 ] Added Platform Config 0 data with size :- 3168
[   4.6301 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   4.6303 ] File read failed
[   4.6344 ] File read failed
[   4.6428 ] Added Platform Config 1 data with size :- 19640
[   4.6432 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   4.6436 ] Added Platform Config 2 data with size :- 24
[   4.6439 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   4.6444 ] Added Platform Config 4 data with size :- 348
[   4.6446 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   4.6449 ] Added Platform Config 3 data with size :- 92
[   4.6449 ]
[   4.6449 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   4.6449 ] Added Platform Config 5 data with size :- 68
[   4.6450 ]
[   4.6450 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   4.6450 ] Added Platform Config 7 data with size :- 392
[   4.6450 ]
[   4.6450 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   4.6450 ] Added Platform Config 8 data with size :- 12
[   4.6450 ]
[   4.6450 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   4.6450 ] Added Platform Config 9 data with size :- 32
[   4.6450 ]
[   4.6450 ] Updating mb1-bct with firmware information
[   4.6471 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.6478 ] MB1-BCT version: 0x1
[   4.6482 ]
[   4.6482 ] Updating mb1-bct with storage information
[   4.6501 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   4.6508 ] MB1-BCT version: 0x1
[   4.6511 ]
[   4.6511 ] Updating mb1-bct with ratchet information
[   4.6530 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   4.6538 ] MB1-BCT version: 0x1
[   4.6540 ] FwIndex: 1, MinRatchetLevel: 0
[   4.6542 ] FwIndex: 2, MinRatchetLevel: 0
[   4.6542 ] FwIndex: 3, MinRatchetLevel: 0
[   4.6542 ] FwIndex: 4, MinRatchetLevel: 0
[   4.6542 ] FwIndex: 5, MinRatchetLevel: 0
[   4.6542 ] FwIndex: 6, MinRatchetLevel: 0
[   4.6542 ] FwIndex: 7, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 11, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 12, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 13, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 14, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 15, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 16, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 17, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 18, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 19, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 30, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 31, MinRatchetLevel: 0
[   4.6543 ] FwIndex: 32, MinRatchetLevel: 0
[   4.6543 ]
[   4.6562 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[   4.6571 ]
[   4.6591 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1.bct zerosbk
[   4.6599 ] adding BCH for mb1_bct_MB1.bct
[   4.6606 ]
[   4.6629 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.6630 ] Assuming zero filled SBK key
[   4.6670 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[   4.6682 ]
[   4.6683 ] Generating coldboot mem-bct
[   4.6702 ] tegrabct_v2 --chip 0x19 0 --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1.cfg --membct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_4.bct
[   4.6709 ] Packing sdram param for instance[0]
[   4.7469 ] Packing sdram param for instance[1]
[   4.7471 ] Packing sdram param for instance[2]
[   4.7474 ] Packing sdram param for instance[3]
[   4.7475 ] Packing sdram param for instance[4]
[   4.7475 ] Packing sdram param for instance[5]
[   4.7475 ] Packing sdram param for instance[6]
[   4.7475 ] Packing sdram param for instance[7]
[   4.7475 ] Packing sdram param for instance[8]
[   4.7475 ] Packing sdram param for instance[9]
[   4.7475 ] Packing sdram param for instance[10]
[   4.7475 ] Packing sdram param for instance[11]
[   4.7475 ] Packing sdram param for instance[12]
[   4.7475 ] Packing sdram param for instance[13]
[   4.7475 ] Packing sdram param for instance[14]
[   4.7475 ] Packing sdram param for instance[15]
[   4.7475 ]
[   4.7475 ] Getting sector size from pt
[   4.7496 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   4.7503 ]
[   4.7504 ] BlockSize read from layout is 200
[   4.7523 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_4.bct
[   4.7529 ] adding BCH for /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_1.bct
[   4.7550 ]
[   4.7568 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[   4.7575 ]
[   4.7594 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct zerosbk
[   4.7601 ] Header already present for mem_coldboot.bct
[   4.7604 ]
[   4.7626 ] tegrasign_v3.py --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.7626 ] Assuming zero filled SBK key
[   4.7667 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[   4.7678 ]
[   4.7679 ] Generating recovery mem-bct
[   4.7697 ] tegrabct_v2 --chip 0x19 0 --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1.cfg --membct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/5398/tmpl6655vfd1_4.bct
[   4.7704 ] Packing sdram param for instance[0]
[   4.8450 ] Packing sdram param for instance[1]
[   4.8452 ] Packing sdram param for instance[2]
[   4.8454 ] Packing sdram param for instance[3]
[   4.8455 ] Packing sdram param for instance[4]
[   4.8455 ] Packing sdram param for instance[5]
[   4.8455 ] Packing sdram param for instance[6]
[   4.8455 ] Packing sdram param for instance[7]
[   4.8455 ] Packing sdram param for instance[8]
[   4.8455 ] Packing sdram param for instance[9]
[   4.8455 ] Packing sdram param for instance[10]
[   4.8455 ] Packing sdram param for instance[11]
[   4.8456 ] Packing sdram param for instance[12]
[   4.8456 ] Packing sdram param for instance[13]
[   4.8456 ] Packing sdram param for instance[14]
[   4.8456 ] Packing sdram param for instance[15]
[   4.8456 ]
[   4.8457 ] Reading ramcode from backup chip_info.bin file
[   4.8457 ] RAMCODE Read from Device: 2
[   4.8478 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[   4.8485 ]
[   4.8504 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm.bct zerosbk
[   4.8512 ] adding BCH for mem_rcm.bct
[   4.8523 ]
[   4.8547 ] tegrasign_v3.py --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.8547 ] Assuming zero filled SBK key
[   4.8587 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[   4.8599 ]
[   4.8600 ] Sending BCTs
[   4.8618 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   4.8625 ] Applet version 01.00.0000
[   4.9321 ] Sending bct_bootrom
[   4.9326 ] [................................................] 100%
[   4.9339 ] Sending bct_mb1
[   4.9385 ] [................................................] 100%
[   4.9429 ] Sending bct_mem
[   4.9893 ] [................................................] 100%
[   5.0711 ]
[   5.0712 ] Generating blob
[   5.0751 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[   5.0783 ]
[   5.0825 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[   5.0855 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[   5.1094 ]
[   5.1140 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.1142 ] Assuming zero filled SBK key
[   5.1248 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[   5.1344 ]
[   5.1382 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[   5.1402 ]
[   5.1433 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[   5.1447 ] adding BCH for blob_nvtboot_recovery_t194.bin
[   5.1509 ]
[   5.1542 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.1543 ] Assuming zero filled SBK key
[   5.1598 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[   5.1628 ]
[   5.1649 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[   5.1657 ]
[   5.1676 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[   5.1683 ] Header already present for blob_preboot_c10_prod_cr.bin
[   5.1687 ]
[   5.1709 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.1710 ] Assuming zero filled SBK key
[   5.1752 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.1763 ]
[   5.1784 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[   5.1792 ]
[   5.1811 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[   5.1818 ] Header already present for blob_mce_c10_prod_cr.bin
[   5.1832 ]
[   5.1855 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.1855 ] Assuming zero filled SBK key
[   5.1897 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.1919 ]
[   5.1939 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[   5.1946 ]
[   5.1964 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[   5.1970 ] adding BCH for blob_mts_c10_prod_cr.bin
[   5.2587 ]
[   5.2612 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.2613 ] Assuming zero filled SBK key
[   5.2707 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.3038 ]
[   5.3066 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[   5.3073 ]
[   5.3092 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t194.bin zerosbk
[   5.3098 ] adding BCH for blob_bpmp_t194.bin
[   5.3252 ]
[   5.3276 ] tegrasign_v3.py --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.3277 ] Assuming zero filled SBK key
[   5.3332 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[   5.3423 ]
[   5.3445 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04.dtb
[   5.3453 ]
[   5.3472 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[   5.3479 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04.dtb
[   5.3662 ]
[   5.3687 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   5.3688 ] Assuming zero filled SBK key
[   5.3741 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[   5.3843 ]
[   5.3865 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[   5.3875 ]
[   5.3895 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194.bin zerosbk
[   5.3903 ] adding BCH for blob_spe_t194.bin
[   5.3923 ]
[   5.3946 ] tegrasign_v3.py --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.3947 ] Assuming zero filled SBK key
[   5.3987 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[   5.4005 ]
[   5.4025 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[   5.4034 ]
[   5.4055 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-trusty_t194.img zerosbk
[   5.4062 ] adding BCH for blob_tos-trusty_t194.img
[   5.4137 ]
[   5.4162 ] tegrasign_v3.py --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[   5.4163 ] Assuming zero filled SBK key
[   5.4210 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[   5.4258 ]
[   5.4278 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[   5.4286 ]
[   5.4305 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks.img zerosbk
[   5.4312 ] adding BCH for blob_eks.img
[   5.4314 ]
[   5.4336 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[   5.4337 ] Assuming zero filled SBK key
[   5.4378 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[   5.4387 ]
[   5.4409 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[   5.4417 ]
[   5.4437 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[   5.4443 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[   5.4497 ]
[   5.4520 ] tegrasign_v3.py --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   5.4521 ] Assuming zero filled SBK key
[   5.4563 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[   5.4599 ]
[   5.4620 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   5.4627 ] number of images in blob are 11
[   5.4630 ] blobsize is 6691768
[   5.4632 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 264064
[   5.4658 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 181152
[   5.4663 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   5.4667 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[   5.4671 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   5.4676 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[   5.4684 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 993104
[   5.4690 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[   5.4694 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[   5.4698 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[   5.4701 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 288624
[   5.4731 ]
[   5.4732 ] Sending bootloader and pre-requisite binaries
[   5.4753 ] tegrarcm_v2 --download blob blob.bin
[   5.4760 ] Applet version 01.00.0000
[   5.5487 ] Sending blob
[   5.5488 ] [................................................] 100%
[   6.4845 ]
[   6.4891 ] tegrarcm_v2 --boot recovery
[   6.4919 ] Applet version 01.00.0000
[   6.5687 ]
[   7.5749 ] tegrarcm_v2 --isapplet
[   7.9804 ]
[   7.9829 ] tegrarcm_v2 --ismb2
[   8.0516 ]
[   8.0552 ] tegradevflash_v2 --iscpubl
[   8.0561 ] Bootloader version 01.00.0000
[   8.0974 ] Bootloader version 01.00.0000
[   8.0988 ]
[   8.0989 ] Writing partition
[   8.1011 ] tegradevflash_v2 --write bpmp-fw-dtb 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
[   8.1020 ] Bootloader version 01.00.0000
[   8.1475 ] Writing partition bpmp-fw-dtb with 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
[   8.1490 ] [................................................] 100%
[   8.2464 ]
[   8.2467 ] Coldbooting the device
[   8.2516 ] tegrarcm_v2 --ismb2
[   8.3219 ]
[   8.3266 ] tegradevflash_v2 --reboot coldboot
[   8.3293 ] Bootloader version 01.00.0000
[   8.3621 ]
Flashing the original BPMP DTB
Here’s the logs for only flashing the BPMP DTB partition, with the original BPMP DTB. The display works.
$ dtdiff bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.BAK.dtb bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb
# L4T BSP Information:
# R32 , REVISION: 7.2
# Target Board Information:
# Name: jetson-agx-xavier-devkit, Board Family: t186ref, SoC: Tegra 194,
# OpMode: production, Boot Authentication: NS,
# Disk encryption: disabled ,
copying soft_fuses(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg)... done.
./tegraflash.py --chip 0x19 --applet "/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin" --skipuid --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg --bins "mb2_applet nvtboot_applet_t194.bin" --cmd "dump eeprom boardinfo cvm.bin;reboot recovery"
Welcome to Tegra Flash
version 1.0.0
Type ? or help for help and q or quit to exit
Use ! to execute system commands
[   0.0037 ] Generating RCM messages
[   0.0059 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin zerosbk
[   0.0066 ] Header already present for /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin
[   0.0096 ]
[   0.0116 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0117 ] Assuming zero filled SBK key
[   0.0137 ] tegrasign_v3.py --file /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0137 ] Assuming zero filled SBK key
[   0.0179 ] tegrahost_v2 --chip 0x19 0 --updatesigheader /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.hash zerosbk
[   0.0211 ]
[   0.0234 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg.pdf sfuse.bin
[   0.0243 ]
[   0.0262 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod_sigheader.bin 0 0
[   0.0271 ] RCM 0 is saved as rcm_0.rcm
[   0.0295 ] RCM 1 is saved as rcm_1.rcm
[   0.0297 ] RCM 2 is saved as rcm_2.rcm
[   0.0297 ] List of rcm files are saved in rcm_list.xml
[   0.0297 ]
[   0.0297 ] Signing RCM messages
[   0.0319 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0320 ] Assuming zero filled SBK key
[   0.0376 ] Copying signature to RCM mesages
[   0.0394 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.0407 ]
[   0.0408 ] Boot Rom communication
[   0.0427 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml --skipuid
[   0.0433 ] RCM version 0X190001
[   0.0705 ] Boot Rom communication completed
[   1.0859 ]
[   2.0883 ] tegrarcm_v2 --isapplet
[   2.0895 ] Applet version 01.00.0000
[   2.1552 ]
[   2.1572 ] tegrarcm_v2 --ismb2
[   2.2429 ]
[   2.2449 ] tegrahost_v2 --chip 0x19 --align nvtboot_applet_t194.bin
[   2.2456 ]
[   2.2475 ] tegrahost_v2 --chip 0x19 0 --magicid PLDT --appendsigheader nvtboot_applet_t194.bin zerosbk
[   2.2481 ] adding BCH for nvtboot_applet_t194.bin
[   2.2507 ]
[   2.2533 ] tegrasign_v3.py --key None --list nvtboot_applet_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   2.2533 ] Assuming zero filled SBK key
[   2.2575 ] tegrahost_v2 --chip 0x19 0 --updatesigheader nvtboot_applet_t194_sigheader.bin.encrypt nvtboot_applet_t194_sigheader.bin.hash zerosbk
[   2.2597 ]
[   2.2616 ] tegrarcm_v2 --download mb2 nvtboot_applet_t194_sigheader.bin.encrypt
[   2.2623 ] Applet version 01.00.0000
[   2.3300 ] Sending mb2
[   2.3301 ] [................................................] 100%
[   2.3460 ]
[   2.3481 ] tegrarcm_v2 --boot recovery
[   2.3487 ] Applet version 01.00.0000
[   2.4195 ]
[   3.4254 ] tegrarcm_v2 --isapplet
[   3.4967 ]
[   3.4989 ] tegrarcm_v2 --ismb2
[   3.4996 ] MB2 Applet version 01.00.0000
[   3.5865 ]
[   3.5886 ] tegrarcm_v2 --ismb2
[   3.5893 ] MB2 Applet version 01.00.0000
[   3.6703 ]
[   3.6753 ] Retrieving board information
[   3.6799 ] tegrarcm_v2 --oem platformdetails chip chip_info.bin
[   3.6829 ] MB2 Applet version 01.00.0000
[   3.7559 ] Saved platform info in chip_info.bin
[   3.7605 ] Chip minor revision: 2
[   3.7610 ] Bootrom revision: 0xf
[   3.7610 ] Ram code: 0x2
[   3.7610 ] Chip sku: 0xd0
[   3.7611 ] Chip Sample: non es
[   3.7611 ]
[   3.7619 ] Retrieving EEPROM data
[   3.7620 ] tegrarcm_v2 --oem platformdetails eeprom cvm /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/cvm.bin
[   3.7648 ] MB2 Applet version 01.00.0000
[   3.8377 ] Saved platform info in /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/cvm.bin
[   3.8725 ]
[   3.8726 ] Rebooting to recovery mode
[   3.8747 ] tegrarcm_v2 --ismb2
[   3.8755 ] MB2 Applet version 01.00.0000
[   3.9435 ]
[   3.9436 ] Rebooting to recovery mode
[   3.9483 ] tegrarcm_v2 --reboot recovery
[   3.9511 ] MB2 Applet version 01.00.0000
[   4.0303 ]
Board ID(2888) version(400) sku(0004) revision(M.0)
copying bctfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-memcfg-p2888.cfg)... done.
copying bctfile1(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-memcfg-sw-override.cfg)... done.
copying uphy_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg)... done.
copying minratchet_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg)... done.
copying device_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra19x-mb1-bct-device-sdmmc.cfg)... done.
copying misc_cold_boot_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg)... done.
copying misc_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-flash.cfg)... done.
copying pinmux_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg)... done.
copying gpioint_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg)... done.
copying pmic_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg)... done.
copying pmc_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg)... done.
copying prod_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg)... done.
copying scr_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying scr_cold_boot_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-scr-cbb-mini.cfg)... done.
copying bootrom_config(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg)... done.
copying dev_params(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/BCT/tegra194-br-bct-sdmmc.cfg)... done.
Existing bootloader(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_cpu_t194.bin) reused.
copying initrd(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/l4t_initrd.img)... done.
Making Boot image... done.
/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/tegraflash.py --chip 0x19 --key  --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign boot.img kernel
version 1.0.0
[   0.0004 ] Generating signature
[   0.0024 ] tegrasign_v3.py --getmode mode.txt --key
[   0.0025 ] Assuming zero filled SBK key : not reading
[   0.0051 ]
[   0.0071 ] tegrahost_v2 --chip 0x19 --align 1_boot.img
[   0.0077 ]
[   0.0096 ] tegrahost_v2 --chip 0x19 0 --magicid KRNL --ratchet_blob ratchet_blob.bin --appendsigheader 1_boot.img zerosbk
[   0.0102 ] adding BCH for 1_boot.img
[   0.7405 ]
[   0.7432 ] tegrasign_v3.py --key  --list 1_boot_sigheader.img_list.xml --pubkeyhash pub_key.key
[   0.7433 ] Assuming zero filled SBK key : not reading
[   0.8148 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_boot_sigheader.img.encrypt 1_boot_sigheader.img.hash zerosbk
[   1.2027 ]
[   1.2286 ] Signed file: /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/boot_sigheader.img.encrypt
l4t_sign_image.sh: Generate header for boot_sigheader.img.encrypt
l4t_sign_image.sh: chip 0x19: add 0x27cb800 to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for boot_sigheader.img.encrypt
l4t_sign_image.sh: the signed file is /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/boot_sigheader.img.encrypt
done.
Existing sosfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin) reused.
Existing tegraboot(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_t194.bin) reused.
Existing cpu_bootloader(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_cpu_t194.bin) reused.
Existing mb2blfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_recovery_t194.bin) reused.
Existing mtspreboot(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/preboot_c10_prod_cr.bin) reused.
Existing mcepreboot(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mce_c10_prod_cr.bin) reused.
Existing mtsproper(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mts_c10_prod_cr.bin) reused.
Existing mb1file(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/mb1_t194_prod.bin) reused.
Existing bpffile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/bpmp_t194.bin) reused.
copying bpfdtbfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/tegra194-a02-bpmp-p2888-a04.dtb)... done.
Existing scefile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/camera-rtcpu-sce.img) reused.
Existing camerafw(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/camera-rtcpu-rce.img) reused.
Existing spefile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/spe_t194.bin) reused.
Existing wb0boot(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/warmboot_t194_prod.bin) reused.
Existing tosfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/tos-trusty_t194.img) reused.
Existing eksfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/eks.img) reused.
copying dtbfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
Copying nv_boot_control.conf to rootfs
/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/tegraflash.py --chip 0x19 --key  --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --cmd sign kernel_tegra194-p2888-0001-p2822-0000.dtb kernel_dtb
version 1.0.0
[   0.0027 ] Assuming zero filled SBK key : not reading
[   0.0045 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0051 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0053 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0053 ]
[   0.0054 ] header_magic: d00dfeed
[   0.0074 ] tegrahost_v2 --chip 0x19 --align 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[   0.0081 ]
[   0.0102 ] tegrahost_v2 --chip 0x19 0 --magicid KDTB --ratchet_blob ratchet_blob.bin --appendsigheader 1_kernel_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[   0.0109 ] adding BCH for 1_kernel_tegra194-p2888-0001-p2822-0000.dtb
[   0.0164 ]
[   0.0190 ] tegrasign_v3.py --key  --list 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0191 ] Assuming zero filled SBK key : not reading
[   0.0234 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt 1_kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[   0.0269 ]
[   0.0275 ] Signed file: /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: Generate header for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: chip 0x19: add 0x45767 to offset  0x8 in sig file
l4t_sign_image.sh: Generate 16-byte-size-aligned base file for kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
l4t_sign_image.sh: the signed file is /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/temp_user_dir/kernel_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt
done.
        populating kernel to rootfs... done.
        populating initrd to rootfs... done.
        populating kernel_tegra194-p2888-0001-p2822-0000.dtb to rootfs... done.
Existing tbcfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/cboot_t194.bin) reused.
copying tbcdtbfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/kernel/dtb/tegra194-p2888-0001-p2822-0000.dtb)... done.
copying cfgfile(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/t186ref/cfg/flash_t194_sdmmc.xml) to flash.xml... done.
Existing flasher(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/nvtboot_recovery_cpu_t194.bin) reused.
Existing flashapp(/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/tegraflash.py) reused.
*** Updating [bpmp-fw-dtb] with tegra194-a02-bpmp-p2888-a04.dtb ***
./tegraflash.py --bl nvtboot_recovery_cpu_t194.bin  --chip 0x19 --applet mb1_t194_prod.bin --sdram_config tegra194-mb1-bct-memcfg-p2888.cfg,tegra194-memcfg-sw-override.cfg --uphy_config tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --minratchet_config tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg --device_config tegra19x-mb1-bct-device-sdmmc.cfg --misc_cold_boot_config tegra194-mb1-bct-misc-l4t.cfg --misc_config tegra194-mb1-bct-misc-flash.cfg --pinmux_config tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --gpioint_config tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --pmic_config tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --pmc_config tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --prod_config tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --scr_config tegra194-mb1-bct-scr-cbb-mini.cfg --scr_cold_boot_config tegra194-mb1-bct-scr-cbb-mini.cfg --br_cmd_config tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --dev_params tegra194-br-bct-sdmmc.cfg --soft_fuses tegra194-mb1-soft-fuses-l4t.cfg  --cfg  flash.xml --bin "mb2_bootloader nvtboot_recovery_t194.bin; mts_preboot preboot_c10_prod_cr.bin; mts_mce mce_c10_prod_cr.bin; mts_proper mts_c10_prod_cr.bin; bpmp_fw bpmp_t194.bin; bpmp_fw_dtb tegra194-a02-bpmp-p2888-a04.dtb; spe_fw spe_t194.bin; tlk tos-trusty_t194.img; eks eks.img; bootloader_dtb tegra194-p2888-0001-p2822-0000.dtb"  --odmdata 0x9190000  --cmd "signwrite bpmp-fw-dtb tegra194-a02-bpmp-p2888-a04.dtb; reboot"
version 1.0.0
[   0.0252 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0253 ] Assuming zero filled SBK key
[   0.0252 ] header_magic: d00dfeed
[   0.0271 ] tegrahost_v2 --chip 0x19 --align 1_tegra194-a02-bpmp-p2888-a04.dtb
[   0.0279 ]
[   0.0297 ] tegrahost_v2 --chip 0x19 0 --magicid  --appendsigheader 1_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[   0.0303 ] adding BCH for 1_tegra194-a02-bpmp-p2888-a04.dtb
[   0.0489 ]
[   0.0515 ] tegrasign_v3.py --key None --list 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   0.0515 ] Assuming zero filled SBK key
[   0.0569 ] tegrahost_v2 --chip 0x19 0 --updatesigheader 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[   0.0674 ]
[   0.0675 ] Generating RCM messages
[   0.0695 ] tegrahost_v2 --chip 0x19 0 --magicid MB1B --appendsigheader mb1_t194_prod.bin zerosbk
[   0.0701 ] Header already present for mb1_t194_prod.bin
[   0.0727 ]
[   0.0749 ] tegrasign_v3.py --getmode mode.txt --key None
[   0.0750 ] Assuming zero filled SBK key
[   0.0770 ] tegrasign_v3.py --file mb1_t194_prod_sigheader.bin --key None --length 1136 --offset 2960 --pubkeyhash pub_key.key
[   0.0770 ] Assuming zero filled SBK key
[   0.0809 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_t194_prod_sigheader.bin mb1_t194_prod_sigheader.hash zerosbk
[   0.0841 ]
[   0.0860 ] tegrabct_v2 --chip 0x19 0 --sfuse tegra194-mb1-soft-fuses-l4t.cfg sfuse.bin
[   0.0868 ]
[   0.0886 ] tegrabct_v2 --chip 0x19 0 --ratchet_blob ratchet_blob.bin --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   0.0892 ] FwIndex: 1, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 2, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 3, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 4, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 5, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 6, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 7, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 11, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 12, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 13, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 14, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 15, MinRatchetLevel: 0
[   0.0895 ] FwIndex: 16, MinRatchetLevel: 0
[   0.0896 ] FwIndex: 17, MinRatchetLevel: 0
[   0.0896 ] FwIndex: 18, MinRatchetLevel: 0
[   0.0896 ] FwIndex: 19, MinRatchetLevel: 0
[   0.0896 ] FwIndex: 30, MinRatchetLevel: 0
[   0.0896 ] FwIndex: 31, MinRatchetLevel: 0
[   0.0896 ] FwIndex: 32, MinRatchetLevel: 0
[   0.0896 ]
[   0.0915 ] tegrarcm_v2 --listrcm rcm_list.xml --chip 0x19 0 --sfuses sfuse.bin --download rcm mb1_t194_prod_sigheader.bin 0 0
[   0.0921 ] RCM 0 is saved as rcm_0.rcm
[   0.0946 ] RCM 1 is saved as rcm_1.rcm
[   0.0946 ] RCM 2 is saved as rcm_2.rcm
[   0.0946 ] List of rcm files are saved in rcm_list.xml
[   0.0946 ]
[   0.0946 ] Signing RCM messages
[   0.0967 ] tegrasign_v3.py --getmontgomeryvalues montgomery.bin --key None --list rcm_list.xml --pubkeyhash pub_key.key
[   0.0968 ] Assuming zero filled SBK key
[   0.1023 ] Copying signature to RCM mesages
[   0.1042 ] tegrarcm_v2 --chip 0x19 0 --updatesig rcm_list_signed.xml
[   0.1053 ]
[   0.1054 ] Boot Rom communication
[   0.1073 ] tegrarcm_v2 --chip 0x19 0 --rcm rcm_list_signed.xml
[   0.1080 ] BR_CID: 0x8802191164017147080000000d0280c0
[   0.1344 ] RCM version 0X190001
[   0.1781 ] Boot Rom communication completed
[   1.1936 ]
[   2.1970 ] tegrarcm_v2 --isapplet
[   2.1978 ] Applet version 01.00.0000
[   2.2661 ]
[   2.2687 ] tegrasign_v3.py --getmode mode.txt --key None
[   2.2688 ] Assuming zero filled SBK key
[   2.2689 ] Parsing partition layout
[   2.2711 ] tegraparser_v2 --pt flash.xml.tmp
[   2.2727 ]
[   2.2728 ] Creating list of images to be signed
[   2.2749 ] tegrahost_v2 --chip 0x19 0 --partitionlayout flash.xml.bin --ratchet_blob ratchet_blob.bin --list images_list.xml zerosbk
[   2.2757 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.2762 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.2768 ] MB1: Nvheader already present is mb1_t194_prod.bin
[   2.2792 ] Header already present for mb1_t194_prod_sigheader.bin
[   2.2894 ] adding BCH for spe_t194.bin
[   2.2916 ] adding BCH for spe_t194.bin
[   2.2933 ] adding BCH for nvtboot_t194.bin
[   2.2950 ] adding BCH for nvtboot_t194.bin
[   2.2986 ] Header already present for preboot_c10_prod_cr.bin
[   2.3020 ] Header already present for preboot_c10_prod_cr.bin
[   2.3024 ] Header already present for mce_c10_prod_cr.bin
[   2.3028 ] Header already present for mce_c10_prod_cr.bin
[   2.3040 ] adding BCH for mts_c10_prod_cr.bin
[   2.3071 ] adding BCH for mts_c10_prod_cr.bin
[   2.3704 ] adding BCH for cboot_t194.bin
[   2.4313 ] adding BCH for cboot_t194.bin
[   2.4411 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.4498 ] adding BCH for tegra194-p2888-0001-p2822-0000.dtb
[   2.4552 ] adding BCH for tos-trusty_t194.img
[   2.4603 ] adding BCH for tos-trusty_t194.img
[   2.4676 ] adding BCH for eks.img
[   2.4751 ] adding BCH for eks.img
[   2.4752 ] adding BCH for bpmp_t194.bin
[   2.4756 ] adding BCH for bpmp_t194.bin
[   2.4916 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.5083 ] adding BCH for tegra194-a02-bpmp-p2888-a04.dtb
[   2.5266 ] adding BCH for xusb_sil_rel_fw
[   2.5575 ] adding BCH for xusb_sil_rel_fw
[   2.5598 ] adding BCH for camera-rtcpu-rce.img
[   2.5623 ] adding BCH for camera-rtcpu-rce.img
[   2.5672 ] adding BCH for adsp-fw.bin
[   2.5722 ] adding BCH for adsp-fw.bin
[   2.5741 ] Header already present for warmboot_t194_prod.bin
[   2.5757 ] Header already present for warmboot_t194_prod.bin
[   2.5763 ] adding BCH for boot.img
[   2.5971 ] adding BCH for boot.img
[   3.3592 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[   4.1162 ] adding BCH for kernel_tegra194-p2888-0001-p2822-0000.dtb
[   4.1275 ]
[   4.1275 ] Filling MB1 storage info
[   4.1275 ] Generating br-bct
[   4.1296 ] Performing cfg overlay
[   4.1296 ] ['tegra194-mb1-bct-memcfg-p2888.cfg', 'tegra194-memcfg-sw-override.cfg']
[   4.1301 ] sw_memcfg_overlay.pl -c tegra194-mb1-bct-memcfg-p2888.cfg -s tegra194-memcfg-sw-override.cfg -o /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011.cfg
[   4.1640 ]
[   4.1641 ] Updating dev and MSS params in BR BCT
[   4.1642 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.2398 ]
[   4.2398 ] Updating bl info
[   4.2422 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin
[   4.2472 ]
[   4.2473 ] Generating signatures
[   4.2506 ] tegrasign_v3.py --key None --list images_list.xml --pubkeyhash pub_key.key
[   4.2507 ] Assuming zero filled SBK key
[   4.5285 ] Send BCT from Host
[   4.5285 ] Generating br-bct
[   4.5304 ] Performing cfg overlay
[   4.5304 ] ['/mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011.cfg']
[   4.5305 ] Updating dev and MSS params in BR BCT
[   4.5305 ] tegrabct_v2 --dev_param tegra194-br-bct-sdmmc.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011.cfg --brbct br_bct.cfg --sfuse tegra194-mb1-soft-fuses-l4t.cfg --chip 0x19 0
[   4.6083 ]
[   4.6083 ] Updating bl info
[   4.6104 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updateblinfo flash.xml.bin --updatesig images_list_signed.xml
[   4.6255 ]
[   4.6256 ] Updating smd info
[   4.6277 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 --updatesmdinfo flash.xml.bin
[   4.6286 ]
[   4.6287 ] Updating Odmdata
[   4.6306 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatefields Odmdata =0x9190000
[   4.6316 ]
[   4.6316 ] Get Signed section of bct
[   4.6334 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --listbct bct_list.xml
[   4.6342 ]
[   4.6360 ] tegrasign_v3.py --key None --list bct_list.xml --pubkeyhash pub_key.key --getmontgomeryvalues montgomery.bin
[   4.6367 ] Assuming zero filled SBK key
[   4.6694 ]
[   4.6695 ] Updating BCT with signature
[   4.6716 ] tegrabct_v2 --brbct br_bct_BR.bct --chip 0x19 0 --updatesig bct_list_signed.xml
[   4.6726 ]
[   4.6727 ] Generating coldboot mb1-bct
[   4.6747 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_cold_boot_bct.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011.cfg --misc tegra194-mb1-bct-misc-l4t.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   4.6754 ] MB1-BCT version: 0x1
[   4.6756 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   4.6761 ] Added Platform Config 0 data with size :- 3168
[   4.6775 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   4.6779 ] File read failed
[   4.6819 ] File read failed
[   4.6906 ] Added Platform Config 1 data with size :- 19640
[   4.6908 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   4.6913 ] Added Platform Config 2 data with size :- 24
[   4.6916 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   4.6919 ] Added Platform Config 4 data with size :- 348
[   4.6922 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   4.6925 ] Added Platform Config 3 data with size :- 92
[   4.6925 ]
[   4.6925 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   4.6925 ] Added Platform Config 5 data with size :- 68
[   4.6925 ]
[   4.6925 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   4.6925 ] Added Platform Config 7 data with size :- 392
[   4.6925 ]
[   4.6925 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   4.6925 ] Added Platform Config 8 data with size :- 12
[   4.6925 ]
[   4.6925 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   4.6925 ] Added Platform Config 9 data with size :- 32
[   4.6925 ]
[   4.6926 ] Updating mb1-bct with firmware information
[   4.6946 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.6953 ] MB1-BCT version: 0x1
[   4.6956 ]
[   4.6956 ] Updating mb1-bct with storage information
[   4.6975 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   4.6982 ] MB1-BCT version: 0x1
[   4.6986 ]
[   4.6987 ] Updating mb1-bct with ratchet information
[   4.7005 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_cold_boot_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   4.7012 ] MB1-BCT version: 0x1
[   4.7014 ] FwIndex: 1, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 2, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 3, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 4, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 5, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 6, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 7, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 11, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 12, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 13, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 14, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 15, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 16, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 17, MinRatchetLevel: 0
[   4.7017 ] FwIndex: 18, MinRatchetLevel: 0
[   4.7018 ] FwIndex: 19, MinRatchetLevel: 0
[   4.7018 ] FwIndex: 30, MinRatchetLevel: 0
[   4.7018 ] FwIndex: 31, MinRatchetLevel: 0
[   4.7018 ] FwIndex: 32, MinRatchetLevel: 0
[   4.7018 ]
[   4.7036 ] tegrahost_v2 --chip 0x19 --align mb1_cold_boot_bct_MB1.bct
[   4.7044 ]
[   4.7063 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_cold_boot_bct_MB1.bct zerosbk
[   4.7070 ] adding BCH for mb1_cold_boot_bct_MB1.bct
[   4.7078 ]
[   4.7101 ] tegrasign_v3.py --key None --list mb1_cold_boot_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.7102 ] Assuming zero filled SBK key
[   4.7145 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_cold_boot_bct_MB1_sigheader.bct.encrypt mb1_cold_boot_bct_MB1_sigheader.bct.hash zerosbk
[   4.7156 ]
[   4.7157 ] Generating recovery mb1-bct
[   4.7178 ] tegrabct_v2 --chip 0x19 0 --mb1bct mb1_bct.cfg --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011.cfg --misc tegra194-mb1-bct-misc-flash.cfg --scr tegra194-mb1-bct-scr-cbb-mini.cfg --pinmux tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg --pmc tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg --pmic tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg --brcommand tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg --prod tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg --gpioint tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg --uphy tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg --device tegra19x-mb1-bct-device-sdmmc.cfg
[   4.7185 ] MB1-BCT version: 0x1
[   4.7188 ] Parsing config file :tegra19x-mb1-pinmux-p2888-0000-a04-p2822-0000-b01.cfg
[   4.7193 ] Added Platform Config 0 data with size :- 3168
[   4.7208 ] Parsing config file :tegra194-mb1-bct-scr-cbb-mini.cfg
[   4.7211 ] File read failed
[   4.7252 ] File read failed
[   4.7336 ] Added Platform Config 1 data with size :- 19640
[   4.7337 ] Parsing config file :tegra19x-mb1-padvoltage-p2888-0000-a00-p2822-0000-a00.cfg
[   4.7342 ] Added Platform Config 2 data with size :- 24
[   4.7344 ] Parsing config file :tegra194-mb1-bct-pmic-p2888-0001-a04-E-0-p2822-0000.cfg
[   4.7348 ] Added Platform Config 4 data with size :- 348
[   4.7351 ] Parsing config file :tegra194-mb1-bct-reset-p2888-0000-p2822-0000.cfg
[   4.7352 ] Added Platform Config 3 data with size :- 92
[   4.7352 ]
[   4.7352 ] Parsing config file :tegra19x-mb1-prod-p2888-0000-p2822-0000.cfg
[   4.7352 ] Added Platform Config 5 data with size :- 68
[   4.7352 ]
[   4.7352 ] Parsing config file :tegra194-mb1-bct-gpioint-p2888-0000-p2822-0000.cfg
[   4.7352 ] Added Platform Config 7 data with size :- 392
[   4.7352 ]
[   4.7352 ] Parsing config file :tegra194-mb1-uphy-lane-p2888-0000-p2822-0000.cfg
[   4.7352 ] Added Platform Config 8 data with size :- 12
[   4.7352 ]
[   4.7352 ] Parsing config file :tegra19x-mb1-bct-device-sdmmc.cfg
[   4.7353 ] Added Platform Config 9 data with size :- 32
[   4.7353 ]
[   4.7353 ] Updating mb1-bct with firmware information
[   4.7371 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatefwinfo flash.xml.bin
[   4.7378 ] MB1-BCT version: 0x1
[   4.7381 ]
[   4.7381 ] Updating mb1-bct with storage information
[   4.7399 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --updatestorageinfo flash.xml.bin
[   4.7405 ] MB1-BCT version: 0x1
[   4.7409 ]
[   4.7409 ] Updating mb1-bct with ratchet information
[   4.7427 ] tegrabct_v2 --chip 0x19 --mb1bct mb1_bct_MB1.bct --minratchet tegra194-mb1-bct-ratchet-p2888-0000-p2822-0000.cfg
[   4.7433 ] MB1-BCT version: 0x1
[   4.7435 ] FwIndex: 1, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 2, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 3, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 4, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 5, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 6, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 7, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 11, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 12, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 13, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 14, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 15, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 16, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 17, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 18, MinRatchetLevel: 0
[   4.7437 ] FwIndex: 19, MinRatchetLevel: 0
[   4.7438 ] FwIndex: 30, MinRatchetLevel: 0
[   4.7438 ] FwIndex: 31, MinRatchetLevel: 0
[   4.7438 ] FwIndex: 32, MinRatchetLevel: 0
[   4.7438 ]
[   4.7456 ] tegrahost_v2 --chip 0x19 --align mb1_bct_MB1.bct
[   4.7463 ]
[   4.7481 ] tegrahost_v2 --chip 0x19 0 --magicid MBCT --ratchet_blob ratchet_blob.bin --appendsigheader mb1_bct_MB1.bct zerosbk
[   4.7489 ] adding BCH for mb1_bct_MB1.bct
[   4.7497 ]
[   4.7523 ] tegrasign_v3.py --key None --list mb1_bct_MB1_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.7524 ] Assuming zero filled SBK key
[   4.7571 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mb1_bct_MB1_sigheader.bct.encrypt mb1_bct_MB1_sigheader.bct.hash zerosbk
[   4.7582 ]
[   4.7583 ] Generating coldboot mem-bct
[   4.7603 ] tegrabct_v2 --chip 0x19 0 --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011.cfg --membct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_4.bct
[   4.7610 ] Packing sdram param for instance[0]
[   4.8363 ] Packing sdram param for instance[1]
[   4.8365 ] Packing sdram param for instance[2]
[   4.8367 ] Packing sdram param for instance[3]
[   4.8368 ] Packing sdram param for instance[4]
[   4.8368 ] Packing sdram param for instance[5]
[   4.8368 ] Packing sdram param for instance[6]
[   4.8369 ] Packing sdram param for instance[7]
[   4.8369 ] Packing sdram param for instance[8]
[   4.8369 ] Packing sdram param for instance[9]
[   4.8369 ] Packing sdram param for instance[10]
[   4.8369 ] Packing sdram param for instance[11]
[   4.8369 ] Packing sdram param for instance[12]
[   4.8369 ] Packing sdram param for instance[13]
[   4.8369 ] Packing sdram param for instance[14]
[   4.8369 ] Packing sdram param for instance[15]
[   4.8369 ]
[   4.8369 ] Getting sector size from pt
[   4.8389 ] tegraparser_v2 --getsectorsize flash.xml.bin sector_info.bin
[   4.8397 ]
[   4.8398 ] BlockSize read from layout is 200
[   4.8415 ] tegrahost_v2 --chip 0x19 0 --blocksize 512 --magicid MEMB --addsigheader_multi /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_4.bct
[   4.8422 ] adding BCH for /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_1.bct
[   4.8442 ]
[   4.8461 ] tegrahost_v2 --chip 0x19 --align mem_coldboot.bct
[   4.8468 ]
[   4.8488 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_coldboot.bct zerosbk
[   4.8495 ] Header already present for mem_coldboot.bct
[   4.8498 ]
[   4.8521 ] tegrasign_v3.py --key None --list mem_coldboot_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.8522 ] Assuming zero filled SBK key
[   4.8563 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_coldboot_sigheader.bct.encrypt mem_coldboot_sigheader.bct.hash zerosbk
[   4.8573 ]
[   4.8574 ] Generating recovery mem-bct
[   4.8593 ] tegrabct_v2 --chip 0x19 0 --sdram /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011.cfg --membct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_1.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_2.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_3.bct /mnt/pigeon/.local/build_bpmp_r32.7.2/bootloader/8063/tmp1i70x4011_4.bct
[   4.8600 ] Packing sdram param for instance[0]
[   4.9340 ] Packing sdram param for instance[1]
[   4.9343 ] Packing sdram param for instance[2]
[   4.9345 ] Packing sdram param for instance[3]
[   4.9346 ] Packing sdram param for instance[4]
[   4.9347 ] Packing sdram param for instance[5]
[   4.9347 ] Packing sdram param for instance[6]
[   4.9347 ] Packing sdram param for instance[7]
[   4.9347 ] Packing sdram param for instance[8]
[   4.9347 ] Packing sdram param for instance[9]
[   4.9347 ] Packing sdram param for instance[10]
[   4.9347 ] Packing sdram param for instance[11]
[   4.9347 ] Packing sdram param for instance[12]
[   4.9347 ] Packing sdram param for instance[13]
[   4.9347 ] Packing sdram param for instance[14]
[   4.9347 ] Packing sdram param for instance[15]
[   4.9347 ]
[   4.9348 ] Reading ramcode from backup chip_info.bin file
[   4.9349 ] RAMCODE Read from Device: 2
[   4.9369 ] tegrahost_v2 --chip 0x19 --align mem_rcm.bct
[   4.9377 ]
[   4.9397 ] tegrahost_v2 --chip 0x19 0 --magicid MEMB --ratchet_blob ratchet_blob.bin --appendsigheader mem_rcm.bct zerosbk
[   4.9405 ] adding BCH for mem_rcm.bct
[   4.9416 ]
[   4.9442 ] tegrasign_v3.py --key None --list mem_rcm_sigheader.bct_list.xml --pubkeyhash pub_key.key
[   4.9443 ] Assuming zero filled SBK key
[   4.9487 ] tegrahost_v2 --chip 0x19 0 --updatesigheader mem_rcm_sigheader.bct.encrypt mem_rcm_sigheader.bct.hash zerosbk
[   4.9503 ]
[   4.9504 ] Sending BCTs
[   4.9525 ] tegrarcm_v2 --download bct_bootrom br_bct_BR.bct --download bct_mb1 mb1_bct_MB1_sigheader.bct.encrypt --download bct_mem mem_rcm_sigheader.bct.encrypt
[   4.9532 ] Applet version 01.00.0000
[   5.0191 ] Sending bct_bootrom
[   5.0193 ] [................................................] 100%
[   5.0205 ] Sending bct_mb1
[   5.0253 ] [................................................] 100%
[   5.0291 ] Sending bct_mem
[   5.0758 ] [................................................] 100%
[   5.1580 ]
[   5.1581 ] Generating blob
[   5.1630 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_cpu_t194.bin
[   5.1660 ]
[   5.1706 ] tegrahost_v2 --chip 0x19 0 --magicid CPBL --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_cpu_t194.bin zerosbk
[   5.1732 ] adding BCH for blob_nvtboot_recovery_cpu_t194.bin
[   5.1934 ]
[   5.1984 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_cpu_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.1987 ] Assuming zero filled SBK key
[   5.2126 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt blob_nvtboot_recovery_cpu_t194_sigheader.bin.hash zerosbk
[   5.2258 ]
[   5.2305 ] tegrahost_v2 --chip 0x19 --align blob_nvtboot_recovery_t194.bin
[   5.2328 ]
[   5.2361 ] tegrahost_v2 --chip 0x19 0 --magicid MB2B --ratchet_blob ratchet_blob.bin --appendsigheader blob_nvtboot_recovery_t194.bin zerosbk
[   5.2377 ] adding BCH for blob_nvtboot_recovery_t194.bin
[   5.2447 ]
[   5.2482 ] tegrasign_v3.py --key None --list blob_nvtboot_recovery_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.2483 ] Assuming zero filled SBK key
[   5.2540 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_nvtboot_recovery_t194_sigheader.bin.encrypt blob_nvtboot_recovery_t194_sigheader.bin.hash zerosbk
[   5.2582 ]
[   5.2605 ] tegrahost_v2 --chip 0x19 --align blob_preboot_c10_prod_cr.bin
[   5.2613 ]
[   5.2633 ] tegrahost_v2 --chip 0x19 0 --magicid MTSP --appendsigheader blob_preboot_c10_prod_cr.bin zerosbk
[   5.2640 ] Header already present for blob_preboot_c10_prod_cr.bin
[   5.2643 ]
[   5.2666 ] tegrasign_v3.py --key None --list blob_preboot_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.2666 ] Assuming zero filled SBK key
[   5.2705 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_preboot_c10_prod_cr_sigheader.bin.encrypt blob_preboot_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.2715 ]
[   5.2736 ] tegrahost_v2 --chip 0x19 --align blob_mce_c10_prod_cr.bin
[   5.2743 ]
[   5.2762 ] tegrahost_v2 --chip 0x19 0 --magicid MTSM --appendsigheader blob_mce_c10_prod_cr.bin zerosbk
[   5.2769 ] Header already present for blob_mce_c10_prod_cr.bin
[   5.2786 ]
[   5.2809 ] tegrasign_v3.py --key None --list blob_mce_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.2810 ] Assuming zero filled SBK key
[   5.2851 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mce_c10_prod_cr_sigheader.bin.encrypt blob_mce_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.2873 ]
[   5.2894 ] tegrahost_v2 --chip 0x19 --align blob_mts_c10_prod_cr.bin
[   5.2901 ]
[   5.2921 ] tegrahost_v2 --chip 0x19 0 --magicid MTSB --appendsigheader blob_mts_c10_prod_cr.bin zerosbk
[   5.2928 ] adding BCH for blob_mts_c10_prod_cr.bin
[   5.3560 ]
[   5.3586 ] tegrasign_v3.py --key None --list blob_mts_c10_prod_cr_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.3587 ] Assuming zero filled SBK key
[   5.3679 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_mts_c10_prod_cr_sigheader.bin.encrypt blob_mts_c10_prod_cr_sigheader.bin.hash zerosbk
[   5.4016 ]
[   5.4040 ] tegrahost_v2 --chip 0x19 --align blob_bpmp_t194.bin
[   5.4047 ]
[   5.4067 ] tegrahost_v2 --chip 0x19 0 --magicid BPMF --ratchet_blob ratchet_blob.bin --appendsigheader blob_bpmp_t194.bin zerosbk
[   5.4074 ] adding BCH for blob_bpmp_t194.bin
[   5.4226 ]
[   5.4249 ] tegrasign_v3.py --key None --list blob_bpmp_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.4250 ] Assuming zero filled SBK key
[   5.4311 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_bpmp_t194_sigheader.bin.encrypt blob_bpmp_t194_sigheader.bin.hash zerosbk
[   5.4412 ]
[   5.4435 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-a02-bpmp-p2888-a04.dtb
[   5.4443 ]
[   5.4461 ] tegrahost_v2 --chip 0x19 0 --magicid BPMD --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-a02-bpmp-p2888-a04.dtb zerosbk
[   5.4468 ] adding BCH for blob_tegra194-a02-bpmp-p2888-a04.dtb
[   5.4652 ]
[   5.4679 ] tegrasign_v3.py --key None --list blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   5.4680 ] Assuming zero filled SBK key
[   5.4732 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.hash zerosbk
[   5.4836 ]
[   5.4859 ] tegrahost_v2 --chip 0x19 --align blob_spe_t194.bin
[   5.4870 ]
[   5.4890 ] tegrahost_v2 --chip 0x19 0 --magicid SPEF --ratchet_blob ratchet_blob.bin --appendsigheader blob_spe_t194.bin zerosbk
[   5.4899 ] adding BCH for blob_spe_t194.bin
[   5.4921 ]
[   5.4945 ] tegrasign_v3.py --key None --list blob_spe_t194_sigheader.bin_list.xml --pubkeyhash pub_key.key
[   5.4945 ] Assuming zero filled SBK key
[   5.4985 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_spe_t194_sigheader.bin.encrypt blob_spe_t194_sigheader.bin.hash zerosbk
[   5.5002 ]
[   5.5024 ] tegrahost_v2 --chip 0x19 --align blob_tos-trusty_t194.img
[   5.5052 ]
[   5.5096 ] tegrahost_v2 --chip 0x19 0 --magicid TOSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tos-trusty_t194.img zerosbk
[   5.5122 ] adding BCH for blob_tos-trusty_t194.img
[   5.5393 ]
[   5.5432 ] tegrasign_v3.py --key None --list blob_tos-trusty_t194_sigheader.img_list.xml --pubkeyhash pub_key.key
[   5.5434 ] Assuming zero filled SBK key
[   5.5514 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tos-trusty_t194_sigheader.img.encrypt blob_tos-trusty_t194_sigheader.img.hash zerosbk
[   5.5611 ]
[   5.5640 ] tegrahost_v2 --chip 0x19 --align blob_eks.img
[   5.5656 ]
[   5.5683 ] tegrahost_v2 --chip 0x19 0 --magicid EKSB --ratchet_blob ratchet_blob.bin --appendsigheader blob_eks.img zerosbk
[   5.5696 ] adding BCH for blob_eks.img
[   5.5700 ]
[   5.5733 ] tegrasign_v3.py --key None --list blob_eks_sigheader.img_list.xml --pubkeyhash pub_key.key
[   5.5734 ] Assuming zero filled SBK key
[   5.5805 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_eks_sigheader.img.encrypt blob_eks_sigheader.img.hash zerosbk
[   5.5823 ]
[   5.5854 ] tegrahost_v2 --chip 0x19 --align blob_tegra194-p2888-0001-p2822-0000.dtb
[   5.5871 ]
[   5.5898 ] tegrahost_v2 --chip 0x19 0 --magicid CDTB --ratchet_blob ratchet_blob.bin --appendsigheader blob_tegra194-p2888-0001-p2822-0000.dtb zerosbk
[   5.5912 ] adding BCH for blob_tegra194-p2888-0001-p2822-0000.dtb
[   5.6025 ]
[   5.6062 ] tegrasign_v3.py --key None --list blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb_list.xml --pubkeyhash pub_key.key
[   5.6063 ] Assuming zero filled SBK key
[   5.6141 ] tegrahost_v2 --chip 0x19 0 --updatesigheader blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.hash zerosbk
[   5.6217 ]
[   5.6250 ] tegrahost_v2 --chip 0x19 --generateblob blob.xml blob.bin
[   5.6263 ] number of images in blob are 11
[   5.6269 ] blobsize is 6691752
[   5.6272 ] Added binary blob_nvtboot_recovery_cpu_t194_sigheader.bin.encrypt of size 264064
[   5.6321 ] Added binary blob_nvtboot_recovery_t194_sigheader.bin.encrypt of size 181152
[   5.6326 ] Added binary blob_preboot_c10_prod_cr_sigheader.bin.encrypt of size 24016
[   5.6330 ] Added binary blob_mce_c10_prod_cr_sigheader.bin.encrypt of size 143200
[   5.6335 ] Added binary blob_mts_c10_prod_cr_sigheader.bin.encrypt of size 3430416
[   5.6350 ] Added binary blob_bpmp_t194_sigheader.bin.encrypt of size 856352
[   5.6360 ] Added binary blob_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt of size 993088
[   5.6370 ] Added binary blob_spe_t194_sigheader.bin.encrypt of size 94960
[   5.6375 ] Added binary blob_tos-trusty_t194_sigheader.img.encrypt of size 410560
[   5.6381 ] Added binary blob_eks_sigheader.img.encrypt of size 5136
[   5.6385 ] Added binary blob_tegra194-p2888-0001-p2822-0000_sigheader.dtb.encrypt of size 288624
[   5.6422 ]
[   5.6423 ] Sending bootloader and pre-requisite binaries
[   5.6446 ] tegrarcm_v2 --download blob blob.bin
[   5.6455 ] Applet version 01.00.0000
[   5.7145 ] Sending blob
[   5.7146 ] [................................................] 100%
[   6.6532 ]
[   6.6580 ] tegrarcm_v2 --boot recovery
[   6.6608 ] Applet version 01.00.0000
[   6.7347 ]
[   7.7407 ] tegrarcm_v2 --isapplet
[   8.3909 ]
[   8.3956 ] tegrarcm_v2 --ismb2
[   8.4673 ]
[   8.4723 ] tegradevflash_v2 --iscpubl
[   8.4750 ] Bootloader version 01.00.0000
[   8.5042 ] Bootloader version 01.00.0000
[   8.5053 ]
[   8.5054 ] Writing partition
[   8.5101 ] tegradevflash_v2 --write bpmp-fw-dtb 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
[   8.5128 ] Bootloader version 01.00.0000
[   8.5402 ] Writing partition bpmp-fw-dtb with 1_tegra194-a02-bpmp-p2888-a04_sigheader.dtb.encrypt
[   8.5426 ] [................................................] 100%
[   8.5996 ]
[   8.5997 ] Coldbooting the device
[   8.6020 ] tegrarcm_v2 --ismb2
[   8.6771 ]
[   8.6792 ] tegradevflash_v2 --reboot coldboot
[   8.6799 ] Bootloader version 01.00.0000
[   8.7201 ]
*** The [bpmp-fw-dtb] has been updated successfully. ***
@WayneWWW I think I figured it out. Using --sort for the decompiling/recompiling messes something up (even though the diff is nothing). If I remove it then everything works…
