Dear All,
I am running CUDA on WSL2 with ubuntu. I install cuda driver following the intruction given here. CUDA on WSL :: CUDA Toolkit Documentation
I was running GROMACS program on GPU. Graphcs card I have Geforse2060. Everything was ok. But recently driver got updated. Now GROMACS can not recognise it. I tried to rebuild the gromacs but no success. Here is the .nvidia-smi.exe output-
Fri Jul 9 17:29:30 2021
| NVIDIA-SMI 462.31 Driver Version: 462.31 CUDA Version: 11.2 |
| GPU Name TCC/WDDM | Bus-Id Disp.A | Volatile Uncorr. ECC |
| | | MIG M. |
| 0 GeForce RTX 2060 WDDM | 00000000:01:00.0 Off | N/A |
| N/A 39C P8 11W / N/A | 164MiB / 6144MiB | 0% Default |
| | | N/A |
| Processes: |
| ID ID Usage |
| No running processes found |
However the gromacs unable to find it.
Command line:
gmx pdb2gmx --version
GROMACS version: 2021.2
Verified release checksum is d91a739522d82c53dc47c2276b9ac5fae3b2119283e84e3a1c7bed8ce741fda2
Precision: mixed
Memory model: 64 bit
MPI library: thread_mpi
OpenMP support: enabled (GMX_OPENMP_MAX_THREADS = 64)
GPU support: CUDA
SIMD instructions: AVX2_256
FFT library: fftw-3.3.8-sse2-avx
RDTSCP usage: enabled
TNG support: enabled
Hwloc support: disabled
Tracing support: disabled
C compiler: /usr/bin/gcc GNU 9.3.0
C compiler flags: -mavx2 -mfma -Wno-missing-field-initializers -fexcess-precision=fast -funroll-all-loops -O3 -DNDEBUG
C++ compiler: /usr/bin/c++ GNU 9.3.0
C++ compiler flags: -mavx2 -mfma -Wno-missing-field-initializers -fexcess-precision=fast -funroll-all-loops -fopenmp -O3 -DNDEBUG
CUDA compiler: /usr/local/cuda/bin/nvcc nvcc: NVIDIA (R) Cuda compiler driver;Copyright (c) 2005-2020 NVIDIA Corporation;Built on Wed_Jul_22_19:09:09_PDT_2020;Cuda compilation tools, release 11.0, V11.0.221;Build cuda_11.0_bu.TC445_37.28845127_0
CUDA compiler flags:-std=c++17;-gencode;arch=compute_35,code=sm_35;-gencode;arch=compute_37,code=sm_37;-gencode;arch=compute_50,code=sm_50;-gencode;arch=compute_52,code=sm_52;-gencode;arch=compute_60,code=sm_60;-gencode;arch=compute_61,code=sm_61;-gencode;arch=compute_70,code=sm_70;-gencode;arch=compute_75,code=sm_75;-gencode;arch=compute_80,code=sm_80;-Wno-deprecated-gpu-targets;-gencode;arch=compute_35,code=compute_35;-gencode;arch=compute_53,code=compute_53;-gencode;arch=compute_80,code=compute_80;-use_fast_math;-D_FORCE_INLINES;-mavx2 -mfma -Wno-missing-field-initializers -fexcess-precision=fast -funroll-all-loops -fopenmp -O3 -DNDEBUG
CUDA driver: 0.0
CUDA runtime: N/A
As you see in the last line. May I know how to fix it?
Thank you
Best Regards
Veeru
