Please see the CUDA release notes for comments about this issue. The problem is you are running a long computation on your primary display adapter. During the computation, the GPU can’t be used to update the display.
Therefore we recommend using one GPU for the primary display, and a G80 GPU for CUDA computation. Please see the release notes.
After my last post, I found discussions to use another device for the primary display in this forum. I have a NV4x-based adapter and will try it tomorrow.
I hope CUDA applications would work better with single G8x(and with other platforms) in future!
Mark, I have come here from the other direction - I was looking at the release notes and wanted to ask about this and so I have checked the forums.
Can the windows watchdog be kicked from the CUDA API ? I was under the impression that the kernel driver must do this. I would understand that the video would not update whilst the card is still in use but having a 5 second limit on the processing time seems like a barrier that can be easily overcome - but not if there is no API call available to use.
To put it simply, Is this something that is planned to be addressed in a near future driver / CUDA interface or is this something that we have to live with for a while ? And what is the recommended workaround when you want to use DX or OGL to display data after a very big calculation - interleave short idle times into the calculation every few seconds so that the 2D video driver catches up ?
Asking around, a developer of CUDA software has noted that this is only an issue if you have one kernel running hogging the GPU. As I have been told, if the problem is broken up into chunks and the intermediates are stored to global memory space then it will function no problem. I assume that freeing the process handle allows the card to accept other requests and function as a video card - which presumably gives a chance to kick the watchdog. This being the case and assuming that the global memory can be recovered undamaged, then the problem, as far as I am concerned, is a non issue. It would be much appreciated if anyone can confirm that this is correct.
