Updating firmware + usb overlay
Continuing the discussion from Nvidia AGX Orin USB connection issues:
I’ve updated my Jetson orin by changing the versions in nvidia-l4t-apt-source.list and running apt update and upgrade. Now I’m trying to install the overlay_usb_35.3.1, but I’m getting an error.
I have downloaded an extracted the BSP, then I replaced the two files by the corresponding ones from the overlay_xusb. But when running this line:
$ sudo FAB=000 BOARDID=3701 FUSELEVEL=fuselevel_production BOARDSKU=0000 ./build_l4t_bup.sh jetson-agx-orin-devkit mmcblk0p1
I get the following output:
~/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra$ sudo FAB=000 BOARDID=3701 FUSELEVEL=fuselevel_production BOARDSKU=0000 ./build_l4t_bup.sh jetson-agx-orin-devkit mmcblk0p1
# L4T BSP Information:
# R35 , REVISION: 3.1
# User release: 0.0
/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/flash.sh: line 1705: /home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/rootfs/etc/user_release_version: No such file or directory
Board ID(3701) version(000) sku(0000) revision()
copying bctfile(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-sdram-l4t.dts)... done.
copying minratchet_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-ratchet-p3701-0000.dts)... done.
copying device_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-device-p3701-0000.dts)... done.
copying misc_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-misc-p3701-0000.dts)... done.
copying pinmux_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pinmux-p3701-0000.dtsi)... done.
copying gpioint_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-gpioint-p3701-0000.dts)... done.
copying pmic_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-pmic-p3701-0000.dts)... done.
copying pmc_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-padvoltage-p3701-0000.dtsi)... done.
copying deviceprod_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-cprod-p3701-0000.dts)... done.
copying prod_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-prod-p3701-0000.dts)... done.
copying scr_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-scr-p3701-0000.dts)... done.
copying wb0sdram(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-p3701-0000-wb0sdram-l4t.dts)... done.
copying bootrom_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb1-bct-reset-p3701-0000.dts)... done.
Existing uphylane_config(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/tegra234-mb1-bct-uphylane-si.dtsi) reused.
copying dev_params(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct-p3701-0000.dts)... done.
copying dev_params_b(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-br-bct_b-p3701-0000.dts)... done.
copying mb2bct_cfg(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/t186ref/BCT/tegra234-mb2-bct-misc-p3701-0000.dts)... done.
Existing pscfwfile(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/pscfw_t234_prod.bin) reused.
Existing pscbl1file(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/psc_bl1_t234_prod.bin) reused.
Existing mtsmcefile(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/mce_flash_o10_cr_prod.bin) reused.
Existing mb2applet(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/applet_t234.bin) reused.
Existing bootloader(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/mb2_t234.bin) reused.
copying initrd(/home/simon/Downloads/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/bootloader/l4t_initrd.img)... done.
bl is uefi
Making Boot image... failed.
Hi simon_hick,
Could you just run the following command to flash the board after you apply the overlay to your BSP package?
$sudo ./flash.sh jetson-agx-orin-devkit mmcblk0p1
Wouldn’t flashing the Orin, overwrite what is currently on it?
Not that’s stopping me from trying, here is the output from the command:
output.txt (19.2 KB)
I’m using the devkit.
/home/cgsc/.local/share/Trash/files/Jetson_Linux_R35.3.1_aarch64/Linux_for_Tegra/tools/ota_tools/version_upgrade/ota_make_recovery_img_dtb.sh: line 177: strings: command not found
How did you get your BSP package for AGX Orin?
Could you try using the BSP package downloaded from SDKM?
I took it from here previously.
So now, I’ve downloaded the files with sdkm, extracted Jetson_Linux_R35.3.1_aarch64.tbz2 and replaced the two files by those given in overlay_xusb_35.3.1. I then ran
and I now get this output:
output.txt (19.0 KB)
Please refer to
Serial device hangs after closing, unable to re-open without first unplugging it - #9 by DaneLLL
