I have tried to update my Jetson Orin Nano developer kit to JetPack 7.2.1. It was on 6.2.3 so I make a thumbnail with the jetsoninstaller-r39.2.1-2026-08-07-18-30-47-arm64.iso and booted. It went through the firmware update quite happily and then installed r39.2.1 on my nvme drive but when it rebooted I was stuck with a display at 640x480 !!!
I tried many things as suggested on various sites but to no avail.
I finished by reverting back to JetPack 6.2.3 with the SDK Manager and everything is OK now.
Could you please advise on the proper way to upgrade to 7.2.1? Have I to go first to 7.2 ?
What is the connection and interface you are using for that monitor?
Normal connection through dp connector and everything was working before and now after having set back to jetpack 6.
Is there any adapter involved or it is a pure DP to DP connection?
Do you have the xorg log from Jetpack7? Want to check what log you saw.
I have an active DP to HDMI connector and luckily I tried to install once on my SD card so I have all the logs.
First for JetPack 7 : Xorg.0.log (23.3 KB)
And my current log for JetPack 6 Xorg.0.log (26.1 KB)
And you can see that my monitor is correctly detected in JP6 and not in JP7 …
That is the key that I want to clarify in previous comment.
If you don’t use a DP-HDMI adapter, will you observe the same issue? Does that monitor have a native DP port on it?
Just want to do an experiment here to know if the adapter here is the key to reproduce problem.
[ 39.965] (WW) NVIDIA(0): NVIDIA (DFP-0) does not have an EDID, or its EDID does not
[ 39.965] (WW) NVIDIA(0): contain a maximum image size; cannot compute DPI from
[ 39.965] (WW) NVIDIA(0): NVIDIA (DFP-0)'s EDID.
The monitor’s EDID is gone on JP7 xorg log.
No my monitor has only HDMI ports otherwise I would have used it. But I don’t understand why with exactly the same hardware it works on JP6 and not in JP7.
My adapter is a BENFEI (BENFEI Active DisplayPort to HDMI Adapter 4K@60Hz 1080p@120Hz Grey | Compatible with PC/Laptops or Desktops/Tablets/DisplayPort Docking Stations, supporting Eyefinity : Amazon.fr: Computers)
Hi @megardd,
Could you share the DCE log with us so we can see what is going on in your use case?
The log should exist in the following path, /sys/kernel/debug/tegra_dce/dce_logs/logs.
The sys directory is empty on my SDcard:
sudo ls -al /media/domdom/APP/sys
total 8
drwxr-xr-x 2 root root 4096 Apr 22 2024 .
drwxr-xr-x 24 root root 4096 Jul 2 2025 ..
and a search for dce_logs returns nothing.
On my JP6 system there is is no /sys/kernel/debug/tegra_dce/dce_logs directory and all the entries are dated Jul 29 or earlier …
sudo ls -al /sys/kernel/debug/tegra_dce
total 0
drwxr-xr-x 4 root root 0 Jul 29 15:41 .
drwx------ 70 root root 0 Jan 1 1970 ..
-r--r--r-- 1 root root 0 Jul 29 15:41 admin_echo
-r--r--r-- 1 root root 0 Jul 29 15:41 boot
-r--r--r-- 1 root root 0 Jul 29 15:41 boot_status
-r--r--r-- 1 root root 0 Jul 29 15:41 config_ast
-r--r--r-- 1 root root 0 Jul 29 15:41 dump_hsp_regs
-r--r--r-- 1 root root 0 Jul 29 15:41 load_fw
drwxr-xr-x 4 root root 0 Jul 29 15:41 perf
-r--r--r-- 1 root root 0 Jul 29 15:41 reset
drwxr-xr-x 3 root root 0 Jul 29 15:41 tests
You could not check them on your sdcard… those nodes are sysfs that you need to check them on your jetson.
It would not boot without reflashing my firmware which I am NOT ready to do !!!
