Upgrade jtop to avoid or resolve a spurious [WARN] jetson-stats not supported for [L4T 39.2.1] message.
Choose one of the following commands to upgrade Jetson_Stats / Jtop:
1. uvx jtop-installer
2. pipx run jtop-installer
3.a curl -LsSf https://raw.githubusercontent.com/whitesscott/jtop_installer/main/bootstrap.py | python3 -
or
3.b curl -LsSf https://raw.githubusercontent.com/rbonghi/jetson_stats/master/scripts/upgrade-jtop.sh | bash
Thank you for sharing. I also discovered that, and I also found that in [L4T 39.2.1] and JetPack 7.2.1, the command :“curl -LsSf https://raw.githubusercontent.com/rbonghi/jetson_stats/master/scripts/install_jtop_torun_without_sudo.sh | bash” is used to install jtop. When opening jtop, it will display “Jetpack missing!” So I made the modifications based on this relevant content. I’m not sure if it will have any impact.
Jetpack missing! 问题修复-腾讯云开发者社区-腾讯云
Glad you were able to fix Jtop on your Jetson Xavier NX.
Excellent documentation of the steps to fix it.
