Upgrade to JetPack 4.6.2
Hello!
I have many Jetson NANOs on the field with JetPack 4.4 and would like to upgrade them to (the latest supported) Jetpack 4.6.2.
  • Can I do that from the terminal e.g. without having physical access to device?
  • Are there any streamlined instructions for this? Because I saw your online instructions mention 5.x only ?
  • Does 4.6.2 support installing Jetpack-runtime only (without Jetpack-dev) as 5.x does ?
Reason for upgrade is TensorRT 8.x about which I read supports Torch-TensorRT
Hello JoskoCRO,
Yes, you can refer the following link for OTA update instruction.
NVIDIA Jetson Linux Developer Guide : Over-the-Air Update | NVIDIA Docs
The installation of JetPack runtime components only is supported from JetPack 5.0.2.
Thanks!!
