Upgrade to Ubuntu 16.04 - Dual Monitor Crashes (367.27)
After upgrading to Ubuntu 16.04 from 15.10, I can no longer use my second monitor. When I attache the monitor (mini display port), the Screen Display setting app fails to launch. When booting with the monitor attached, the Unity Daemon fails. If I disable the NVidia driver and use the Intel Power Save, I can then use the display port and the Screen Display app work fine.
NVRM version: NVIDIA UNIX x86_64 Kernel Module 367.27
nvidia-bug-report.log.gz (70.8 KB)
Here’s another attachment, the first was created under the Intel Power Save profile, which works with the second monitor. This one was created using the 367.27 driver. BTW, I also tried the 364.19 driver and I get the same issue.
nvidia-bug-report.log.gz (165 KB)
Hi! Same problem here with Ubuntu 16.04 x86_64 Kernel Module 367.27 (dell xps 15). Did you found a solution?
No, I’m using the Intel driver when connected to DisplayPort.
