Upgrading DLSS library and using DLAA with F preset causes hard freeze in Hunt: Showdown 1896
Recently I discovered that Hunt Showdown starts hard freezing while using F preset for DLAA in combination with DLSS library upgrade in Proton. I’ve tried various combination of system components and multiple DLSS library versions, but nothing helps me to fix this issue.
Usually I’m playing around 10-20 minutes in the game and then the picture on my screen freezes and after a second it will desync for a one or two frame back and eventually freezes in this state.
The process is still working I believe, because sound from the game is pretty normal and the game doesn’t close itself until I manually do that.
I’ve already reported this issue to dxvk-nvapi repo on Github and publish my detailed test results here: Hunt: Showdown hard freezes with a new version of DLSS library · Issue #368 · jp7677/dxvk-nvapi · GitHub
My system specs
OS: NixOS Unstable
KDE: KDE Plasma 6.6.5 on Wayland
GPU: RTX 4060
Kernel: 6.18.32, 7.0.5, 7.0.9 and 7.0.10
Drivers: tested with 595.71.05 and 595.58.03
Proton: Tested with Proton Experimental, Proton-GE and two version of CachyOS proton.
Here’s log files taken from CachyOS proton and Proton Experimental.
proton-experimental-hunt.log (22.1 MB)
steam-594650.log (12.7 MB)
