Upgrading from CUDA from 5.5 to 8.0
Hi
I wondered if anyone else experiencing this issue?
We successfully installed the version 8.0 repo: cuda-repo-rhel6-8.0.44-1.x86_64
Then when we tried to install/upgrade the packages as per install guide but we get many errors.
The main ones are below. Any help would be appreciated.
Thank you.
yum clean expire-cache
yum install cuda
Error: Package: cuda-5-5-5.5-22.x86_64 (@nvidia_cuda_repo_rhel6_x86_64)
Requires: xorg-x11-drv-nvidia-libs(x86-32) >= 319.00
Removing: 1:xorg-x11-drv-nvidia-libs-319.37-2.el6.i686 (@nvidia_cuda_repo_rhel6_x86_64)
xorg-x11-drv-nvidia-libs(x86-32) = 1:319.37-2.el6
Obsoleted By: cuda-drivers-367.48-1.x86_64 (cuda)
Not found
Updated By: 1:xorg-x11-drv-nvidia-libs-343.19-1.el6.i686 (cuda)
xorg-x11-drv-nvidia-libs(x86-32) = 1:343.19-1.el6
Error: Package: 1:xorg-x11-drv-nvidia-libs-331.62-2.el6.i686 (cuda)
Requires: xorg-x11-drv-nvidia = 1:331.62-2.el6
Removing: 1:xorg-x11-drv-nvidia-319.37-2.el6.x86_64 (@nvidia_cuda_repo_rhel6_x86_64)
xorg-x11-drv-nvidia = 1:319.37-2.el6
Updated By: 1:xorg-x11-drv-nvidia-367.48-1.el6.x86_64 (cuda)
xorg-x11-drv-nvidia = 1:367.48-1.el6
Error: Package: 1:xorg-x11-drv-nvidia-libs-340.29-1.el6.i686 (cuda)
Requires: xorg-x11-drv-nvidia = 1:340.29-1.el6
Error: Package: 1:xorg-x11-drv-nvidia-devel-331.62-2.el6.i686 (cuda)
Requires: xorg-x11-drv-nvidia-gl(x86-32) = 1:331.62-2.el6
Error: Package: 1:xorg-x11-drv-nvidia-devel-340.29-1.el6.i686 (cuda)
Requires: xorg-x11-drv-nvidia-gl(x86-32) = 1:340.29-1.el6
Requires: xorg-x11-drv-nvidia-devel(x86-32) >= 319.00
Removing: 1:xorg-x11-drv-nvidia-devel-319.37-2.el6.i686 (@nvidia_cuda_repo_rhel6_x86_64)
xorg-x11-drv-nvidia-devel(x86-32) = 1:319.37-2.el6
Not found
Updated By: 1:xorg-x11-drv-nvidia-devel-343.19-1.el6.i686 (cuda)
xorg-x11-drv-nvidia-devel(x86-32) = 1:343.19-1.el6
Error: Package: 1:xorg-x11-drv-nvidia-devel-343.19-1.el6.i686 (cuda)
Requires: xorg-x11-drv-nvidia-gl(x86-32) = 1:343.19-1.el6
Error: Package: 1:xorg-x11-drv-nvidia-libs-343.19-1.el6.i686 (cuda)
Requires: xorg-x11-drv-nvidia = 1:343.19-1.el6
Requires: libGLESv1_CM.so.1
Requires: libGLESv2.so.2
You could try using --skip-broken to work around the problem
