I have been trying to upgrade to v1.2.0 today on a machine where I have previously been running v1.1.0.
I have completed the installation, although to complete, I had to run two non-listed steps:
- When hit with WARNING: An NVIDIA kernel module ‘nvidia-uvm’ appears to be already loaded in your kernel, I ran: sudo lsof /dev/nvidia* and killed the processes. This enabled install.sh to run further.
- I then needed to run docker login nvcr.io -u ‘$oauthtoken’ -p “$NGC_CLI_API_KEY” when the containers would not pull (as shown in image). This enabled install.sh to finish.
Following this, when I re-accessed the GUI, the omniverse launcher only showed v1.1.0 so I hit uninstall on this incase there was an issue due to the old version being present.
I now want to run the GUI, but when running ~/aodt_1.2.0/frontend/start.sh I get:
I can run both ~/aodt_1.2.0/backend/start.sh or docker compose up -d from within the backend directory seemingly successfully, but at no point have I been able to see the v1.2.0 UI.
I look forward to hearing back.
