I have a large dataset stored on external devices using the BTRFS file system. In order to handle the volume of data, I am using ZSTD compression on the filesystem, however, support for this compression method was only added in Kernel 4.14.
JetPack 4.6 only uses kernel 4.9.
I wanted to ask if anyone has had experience upgrading the kernel on the Xavier boards and about the compatibility with the CUDA drivers. I don’t want to move over to JetPack 5.x yet so any solution staying at 4.6 would be appreciated.
