Is there a way to update an Orin Nano Dev Kit that boots from SSD without refreshing the SSD? The system is running JetPack6.1. The QSPI needs to be updated to go Super, I know that can be done with a SD card image. However, I don’t know how to properly update the SSD to take advantage of Super once the QSPI has been updated. Is it possible from a repository pull, or does it need to be reflashed?
You would need to re-flash the whole system to enable the config. Please re-flash it through SDKManager.
