UPHY configuration using ODMDATA
In the link UPHY lane configuration using ODMDATA was explained. We are not using UPHY1, so I don’t want UPHY1 to be configured. So I have modified the ODMDATA available in p3701.conf.common file as below.
Original line:
ODMDATA=“gbe-uphy-config-22,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0,gbe0-enable-10g”;
Modified line:
ODMDATA=“gbe-uphy-config-22,hsstp-lane-map-3,hsio-uphy-config-0,gbe0-enable-10g”;
After this change only flashing is enough? Do I need to build anything?
I have flashed the devkit after the above change without any build, but there is no change in the UPHY config value.
nvidia@tegra-ubuntu:~$ sudo cat /sys/kernel/debug/bpmp/debug/uphy/config
[sudo] password for nvidia:
0x00584000
Will this ODMDATA info will be saved in any partition of the storage device(ex: if we are flashing on eMMC then on which partition this data will be saved)?
My requirement is that I don’t want to config UPHY1, as I am not using UPHY1 in my custom board.
duplicated with Disabling only UPHY1 configuration - #5 by rkk2
