If you reboot after setting the time zone manually, the setting value is not saved and returned to the specific value.
What can I doubt? I downloaded the latest version of L4T and flashed it.
Thank you.
Thank you.
What do you see from:
ls -l /etc/timezone
cat /etc/timezone
Sometimes the timezone
file is a symbolic link to another, and if it happens to be that the link is to a disk/hard drive not yet mounted at the time of boot, then timezone setting will fail. If the file is a hard file and not a symbolic link, then it should always be correct. The “ls -l /etc/timezone
” is to determine if this is a symbolic link or hard link.
Check the system setting Date & Time on the gui.
Thank you.
I confirmed that it is a hard link.
Still, it cannot be applied after changing the timezone.
Thank you.
I saw this in another post, will comment there.
Thank you.
