I am facing an error that makes me very frustrated and upset.
I am a very new user to Omniverse & Isaac Sim. I am trying to run the Offline Dataset Generation script from the Documentation webpage: Offline Dataset Generation. However, when executing the command: ./python.sh standalone_examples/replicator/offline_generation.py, the weird error occurs:
DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
2023-06-16 21:47:11 [19,883ms] [Error] [__main__] Exception: DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
File "standalone_examples/replicator/offline_generation.py", line 338, in <module>
main()
File "standalone_examples/replicator/offline_generation.py", line 260, in main
simulate_falling_objects(forklift_prim)
File "standalone_examples/replicator/offline_generation.py", line 139, in simulate_falling_objects
world = World(physics_dt=1.0 / 90.0, stage_units_in_meters=1.0)
File "/home/davidzhuoranli/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/world/world.py", line 95, in __init__
device=device,
File "/home/davidzhuoranli/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/simulation_context/simulation_context.py", line 135, in __init__
device=device,
File "/home/davidzhuoranli/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/simulation_context/simulation_context.py", line 812, in _init_stage
self.render()
File "/home/davidzhuoranli/.local/share/ov/pkg/isaac_sim-2022.2.1/exts/omni.isaac.core/omni/isaac/core/simulation_context/simulation_context.py", line 485, in render
self._app.update()
RuntimeError: DoExecute : m_NvOFAPI->GetAPI()->nvOFExecuteVk(m_NvOFAPI->GetHandle(), &executeInParamsVk, &executeOutParamsVk)returned error 11 at /dvs/p4/build/sw/devrel/libdev/NGX/snippets/rel_tot/source/frameworks/opticalflow/v7/dev/Common/NvOFBase/NvOFVulkan.cpp;421
[20.344s] Simulation App Shutting Down
The Isaac Sim I am using is the latest 2022.2.1. My machine is ROG Strix G634JZ laptop. It has an Intel iGPU and a NVIDIA RTX4080 Laptop GPU. I have already disabled nouveau driver and installed the latest NVIDIA GPU driver 535.54.03 manually.
I will attach the full error log from terminal below, and I will also attach my system hardware configuration. Thanks a lot for your time and kind help on my issue. I will really appreciate your help and kindness. This is a very urgent asking for help post because I am starting to use Omniverse Isaac Sim for high-quality research projects with my professor. Thanks again!
I also found a very related post in the forum that might be very similar to my issue. I will attach it here for you to refer: a very similar post.
However, as I am using the latest NVIDIA GPU driver that has support to my RTX4080 Laptop GPU, which should have installed the latest Vulkan by default during the driver installation process. Therefore, I don’t understand the reasoning behind that post, and I also think my case is a bit different from that.
