Uridecodebin pad_added callback does not get called and uridecodebin does not report any error hence no frames and deleting source hangs pipeline
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version DS 6.1.1
• TensorRT Version 8.2.4
• NVIDIA GPU Driver Version (valid for GPU only) 510.47.03
• Issue Type( questions, new requirements, bugs) bug
I have build custom app based on runtime_add_del.py and I am able to add/delete RTSP source but sometime when I add uridecodebin then pad added callback is not raised and do not see any error into bus callback for source connection failure. when we try to delete such source then pipeline hangs in stream-mux release pad.
Attached are the logs for same.
[camera_configuration_controller.py:95:add_camera_configuration:20230314T08:53:23:INFO] Start processing to add ClothingColor for camera 9010aade-8a88-44f1-b9f3-763638e53c86 on stream rtsp://192.168.168.25:8005/restream
[services.py:68:publish_in_queue:20230314T08:53:23:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c6e01124-0546-47c4-bf24-13301d082779 for add_camera
[stream_manager.py:383:run_message_consumer:20230314T08:53:25:DEBUG] Incoming msg received {‘id’: ‘e82a5fed-fe8e-4300-b024-f5e94248f602’, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’}
[stream_manager.py:423:run_stream_manager:20230314T08:53:25:DEBUG] Action received: {‘id’: ‘e82a5fed-fe8e-4300-b024-f5e94248f602’, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678784005.4893122} at 1678784005.4893594 with 1678784005.4893122
[stream_manager.py:178:add_source:20230314T08:53:25:DEBUG] Stream index selected : 23 source {‘id’: ‘e82a5fed-fe8e-4300-b024-f5e94248f602’, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678784005.4893122} streams {}
[stream_manager.py:181:add_source:20230314T08:53:25:INFO] Tile index : 23 source {‘id’: ‘e82a5fed-fe8e-4300-b024-f5e94248f602’, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678784005.4893122}
[stream.py:93:init:20230314T08:53:25:INFO] stream_id 9010aade-8a88-44f1-b9f3-763638e53c86, stream_type 0 Enabled_rules : {}
[generic_gstreamer.py:588:create_uridecode_bin:20230314T08:53:25:INFO] Creating uridecodebin for 9010aade-8a88-44f1-b9f3-763638e53c86 for rtsp://192.168.168.25:8005/restream
[stream.py:228:run:20230314T08:53:25:INFO] source added successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[generic_gstreamer.py:441:_decodebin_child_added_cb:20230314T08:53:54:INFO] rtsp source connected successfully for 9010aade-8a88-44f1-b9f3-763638e53c86
[generic_gstreamer.py:496:_decodebin_newpad_added_cb:20230314T08:53:54:INFO] sourcebin linked to streammux with vrate disabled : 9010aade-8a88-44f1-b9f3-763638e53c86
[services.py:68:publish_in_queue:20230314T09:23:00:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c6e01124-0546-47c4-bf24-13301d082779 for add_camera
[stream_manager.py:383:run_message_consumer:20230314T09:23:02:DEBUG] Incoming msg received {‘id’: ‘e82a5fed-fe8e-4300-b024-f5e94248f602’, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’}
[stream_manager.py:423:run_stream_manager:20230314T09:23:20:DEBUG] Action received: {‘id’: ‘e82a5fed-fe8e-4300-b024-f5e94248f602’, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678785782.7135847} at 1678785800.7362635 with 1678785782.7135847
[stream_manager.py:178:add_source:20230314T09:23:20:DEBUG] Stream index selected : 17 source {‘id’: ‘e82a5fed-fe8e-4300-b024-f5e94248f602’, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678785782.7135847} streams {21: <deepstream.stream.Stream object at 0x7f59d7ac6ca0>, 5: <deepstream.stream.Stream object at 0x7f59d7ac64c0>, 4: <deepstream.stream.Stream object at 0x7f59d7ac6f70>, 18: <deepstream.stream.Stream object at 0x7f59d7b14130>}
[stream_manager.py:181:add_source:20230314T09:23:20:INFO] Tile index : 17 source {‘id’: ‘e82a5fed-fe8e-4300-b024-f5e94248f602’, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678785782.7135847}
[stream.py:93:init:20230314T09:23:20:INFO] stream_id 9010aade-8a88-44f1-b9f3-763638e53c86, stream_type 0 Enabled_rules : {}
[generic_gstreamer.py:588:create_uridecode_bin:20230314T09:23:20:INFO] Creating uridecodebin for 9010aade-8a88-44f1-b9f3-763638e53c86 for rtsp://192.168.168.25:8005/restream
[stream.py:228:run:20230314T09:23:20:INFO] source added successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[services.py:42:delete_config:20230314T09:24:01:ERROR] 9010aade-8a88-44f1-b9f3-763638e53c86 is not available
[services.py:68:publish_in_queue:20230314T09:24:01:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c6e01124-0546-47c4-bf24-13301d082779 for delete_camera
10.244.0.53 - - [14/Mar/2023 09:24:01] “DELETE /1.0/Tyco/configuration/9010aade-8a88-44f1-b9f3-763638e53c86 HTTP/1.1” 200 -
[stream_manager.py:383:run_message_consumer:20230314T09:24:01:DEBUG] Incoming msg received {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘action’: ‘delete_camera’}
[stream_manager.py:423:run_stream_manager:20230314T09:24:01:DEBUG] Action received: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘action’: ‘delete_camera’, ‘action_timestamp’: 1678785841.7710671} at 1678785841.7711256 with 1678785841.7710671
[stream_manager.py:207:delete_source:20230314T09:24:01:INFO] deleting source : 9010aade-8a88-44f1-b9f3-763638e53c86
[stream.py:276:stop:20230314T09:24:01:INFO] source removed successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:214:delete_source:20230314T09:24:01:INFO] successfully deleted source : 17->9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:360:_reconnect_source:20230314T09:24:01:INFO] Trying to reconnect: 17 → 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:271:publish_message:20230314T09:24:01:INFO] Publish success: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: <Action.RECONNECT: ‘reconnect_camera’>, ‘action_timestamp’: 1678785841.7762458, ‘stream_index’: 17}
[stream_manager.py:383:run_message_consumer:20230314T09:24:02:DEBUG] Incoming msg received {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: ‘reconnect_camera’, ‘action_timestamp’: 1678785841.7762458, ‘stream_index’: 17}
[stream_manager.py:423:run_stream_manager:20230314T09:24:06:DEBUG] Action received: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8005/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: ‘reconnect_camera’, ‘action_timestamp’: 1678785841.7762458, ‘stream_index’: 17} at 1678785846.7802637 with 1678785841.7762458
[stream_manager.py:455:run_stream_manager:20230314T09:24:06:WARNING] Stream we are reconnecting deleted already: 9010aade-8a88-44f1-b9f3-763638e53c86
10.244.0.53 - - [14/Mar/2023 09:51:16] “DELETE /1.0/Tyco/configuration/9010aade-8a88-44f1-b9f3-763638e53c86 HTTP/1.1” 200 -
[camera_configuration_controller.py:95:add_camera_configuration:20230314T09:51:24:INFO] Start processing to add ClothingColor for camera 9010aade-8a88-44f1-b9f3-763638e53c86 on stream rtsp://192.168.168.25:8011/restream
[services.py:68:publish_in_queue:20230314T09:51:24:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c14bf167-0ac0-46be-b4ba-fe669308f188 for add_camera
[stream_manager.py:383:run_message_consumer:20230314T09:51:24:DEBUG] Incoming msg received {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8011/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’}
[stream_manager.py:423:run_stream_manager:20230314T09:51:24:DEBUG] Action received: {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8011/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678787484.757347} at 1678787484.7573984 with 1678787484.757347
[stream_manager.py:178:add_source:20230314T09:51:24:DEBUG] Stream index selected : 13 source {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8011/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678787484.757347} streams {}
[stream_manager.py:181:add_source:20230314T09:51:24:INFO] Tile index : 13 source {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8011/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: 0, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678787484.757347}
[stream.py:93:init:20230314T09:51:24:INFO] stream_id 9010aade-8a88-44f1-b9f3-763638e53c86, stream_type 0 Enabled_rules : {}
[generic_gstreamer.py:588:create_uridecode_bin:20230314T09:51:24:INFO] Creating uridecodebin for 9010aade-8a88-44f1-b9f3-763638e53c86 for rtsp://192.168.168.25:8011/restream
[stream.py:228:run:20230314T09:51:24:INFO] source added successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[generic_gstreamer.py:441:_decodebin_child_added_cb:20230314T09:51:43:INFO] rtsp source connected successfully for 9010aade-8a88-44f1-b9f3-763638e53c86
[generic_gstreamer.py:496:_decodebin_newpad_added_cb:20230314T09:51:43:INFO] sourcebin linked to streammux with vrate disabled : 9010aade-8a88-44f1-b9f3-763638e53c86
[services.py:42:delete_config:20230314T11:17:44:ERROR] 9010aade-8a88-44f1-b9f3-763638e53c86 is not available
[services.py:68:publish_in_queue:20230314T11:17:44:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c14bf167-0ac0-46be-b4ba-fe669308f188 for delete_camera
10.244.0.53 - - [14/Mar/2023 11:17:44] “DELETE /1.0/Tyco/configuration/9010aade-8a88-44f1-b9f3-763638e53c86 HTTP/1.1” 200 -
[stream_manager.py:383:run_message_consumer:20230314T11:17:44:DEBUG] Incoming msg received {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘action’: ‘delete_camera’}
[stream_manager.py:423:run_stream_manager:20230314T11:17:44:DEBUG] Action received: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘action’: ‘delete_camera’, ‘action_timestamp’: 1678792664.469135} at 1678792664.469207 with 1678792664.469135
[stream_manager.py:207:delete_source:20230314T11:17:44:INFO] deleting source : 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:360:_reconnect_source:20230314T11:17:44:INFO] Trying to reconnect: 13 → 9010aade-8a88-44f1-b9f3-763638e53c86
[stream.py:276:stop:20230314T11:17:44:INFO] source removed successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:214:delete_source:20230314T11:17:44:INFO] successfully deleted source : 13->9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:264:publish_message:20230314T11:17:45:INFO] republishing {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8011/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: <Action.RECONNECT: ‘reconnect_camera’>, ‘action_timestamp’: 1678792664.9832454, ‘stream_index’: 13}
[stream_manager.py:383:run_message_consumer:20230314T11:17:45:DEBUG] Incoming msg received {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8011/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: ‘reconnect_camera’, ‘action_timestamp’: 1678792664.9832454, ‘stream_index’: 13}
[stream_manager.py:423:run_stream_manager:20230314T11:17:49:DEBUG] Action received: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8011/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: ‘reconnect_camera’, ‘action_timestamp’: 1678792664.9832454, ‘stream_index’: 13} at 1678792669.9872742 with 1678792664.9832454
[stream_manager.py:455:run_stream_manager:20230314T11:17:49:WARNING] Stream we are reconnecting deleted already: 9010aade-8a88-44f1-b9f3-763638e53c86
10.244.0.53 - - [14/Mar/2023 11:27:16] “DELETE /1.0/Tyco/configuration/9010aade-8a88-44f1-b9f3-763638e53c86 HTTP/1.1” 200 -
[camera_configuration_controller.py:95:add_camera_configuration:20230314T11:27:25:INFO] Start processing to add ClothingColor for camera 9010aade-8a88-44f1-b9f3-763638e53c86 on stream rtsp://192.168.168.25:8020/restream
[services.py:68:publish_in_queue:20230314T11:27:25:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c14bf167-0ac0-46be-b4ba-fe669308f188 for add_camera
[stream_manager.py:383:run_message_consumer:20230314T11:27:25:DEBUG] Incoming msg received {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8020/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’}
[stream_manager.py:423:run_stream_manager:20230314T11:27:25:DEBUG] Action received: {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8020/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678793245.1336298} at 1678793245.1337032 with 1678793245.1336298
[stream_manager.py:178:add_source:20230314T11:27:25:DEBUG] Stream index selected : 3 source {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8020/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678793245.1336298} streams {1: <deepstream.stream.Stream object at 0x7f9e19a7fc70>, 11: <deepstream.stream.Stream object at 0x7f9e19aacf70>, 16: <deepstream.stream.Stream object at 0x7f9d962d7220>, 2: <deepstream.stream.Stream object at 0x7f9d962d7280>}
[stream_manager.py:181:add_source:20230314T11:27:25:INFO] Tile index : 3 source {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8020/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678793245.1336298}
[stream.py:93:init:20230314T11:27:25:INFO] stream_id 9010aade-8a88-44f1-b9f3-763638e53c86, stream_type 0 Enabled_rules : {}
[generic_gstreamer.py:588:create_uridecode_bin:20230314T11:27:25:INFO] Creating uridecodebin for 9010aade-8a88-44f1-b9f3-763638e53c86 for rtsp://192.168.168.25:8020/restream
[stream.py:228:run:20230314T11:27:25:INFO] source added successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[generic_gstreamer.py:441:_decodebin_child_added_cb:20230314T11:27:27:INFO] rtsp source connected successfully for 9010aade-8a88-44f1-b9f3-763638e53c86
[generic_gstreamer.py:496:_decodebin_newpad_added_cb:20230314T11:27:27:INFO] sourcebin linked to streammux with vrate disabled : 9010aade-8a88-44f1-b9f3-763638e53c86
[services.py:42:delete_config:20230314T11:41:04:ERROR] 9010aade-8a88-44f1-b9f3-763638e53c86 is not available
[services.py:68:publish_in_queue:20230314T11:41:04:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c14bf167-0ac0-46be-b4ba-fe669308f188 for delete_camera
10.244.0.53 - - [14/Mar/2023 11:41:04] “DELETE /1.0/Tyco/configuration/9010aade-8a88-44f1-b9f3-763638e53c86 HTTP/1.1” 200 -
[stream_manager.py:383:run_message_consumer:20230314T11:41:04:DEBUG] Incoming msg received {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘action’: ‘delete_camera’}
[stream_manager.py:423:run_stream_manager:20230314T11:41:04:DEBUG] Action received: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘action’: ‘delete_camera’, ‘action_timestamp’: 1678794064.8145528} at 1678794064.8146148 with 1678794064.8145528
[stream_manager.py:207:delete_source:20230314T11:41:04:INFO] deleting source : 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:360:_reconnect_source:20230314T11:41:04:INFO] Trying to reconnect: 3 → 9010aade-8a88-44f1-b9f3-763638e53c86
[stream.py:276:stop:20230314T11:41:05:INFO] source removed successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:214:delete_source:20230314T11:41:05:INFO] successfully deleted source : 3->9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:264:publish_message:20230314T11:41:05:INFO] republishing {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8020/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: <Action.RECONNECT: ‘reconnect_camera’>, ‘action_timestamp’: 1678794065.3335342, ‘stream_index’: 3}
[stream_manager.py:383:run_message_consumer:20230314T11:41:05:DEBUG] Incoming msg received {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8020/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: ‘reconnect_camera’, ‘action_timestamp’: 1678794065.3335342, ‘stream_index’: 3}
[stream_manager.py:423:run_stream_manager:20230314T11:41:10:DEBUG] Action received: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8020/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: ‘reconnect_camera’, ‘action_timestamp’: 1678794065.3335342, ‘stream_index’: 3} at 1678794070.338283 with 1678794065.3335342
[stream_manager.py:455:run_stream_manager:20230314T11:41:10:WARNING] Stream we are reconnecting deleted already: 9010aade-8a88-44f1-b9f3-763638e53c86
10.244.0.53 - - [14/Mar/2023 11:45:45] “DELETE /1.0/Tyco/configuration/9010aade-8a88-44f1-b9f3-763638e53c86 HTTP/1.1” 200 -
[camera_configuration_controller.py:95:add_camera_configuration:20230314T11:45:53:INFO] Start processing to add ClothingColor for camera 9010aade-8a88-44f1-b9f3-763638e53c86 on stream rtsp://192.168.168.25:8022/restream
[services.py:68:publish_in_queue:20230314T11:45:53:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c14bf167-0ac0-46be-b4ba-fe669308f188 for add_camera
[stream_manager.py:383:run_message_consumer:20230314T11:45:53:DEBUG] Incoming msg received {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’}
[stream_manager.py:423:run_stream_manager:20230314T11:45:53:DEBUG] Action received: {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678794353.6285903} at 1678794353.6286542 with 1678794353.6285903
[stream_manager.py:178:add_source:20230314T11:45:53:DEBUG] Stream index selected : 13 source {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678794353.6285903} streams {1: <deepstream.stream.Stream object at 0x7f9e19a7fc70>, 16: <deepstream.stream.Stream object at 0x7f9d962d7220>}
[stream_manager.py:181:add_source:20230314T11:45:53:INFO] Tile index : 13 source {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678794353.6285903}
[stream.py:93:init:20230314T11:45:53:INFO] stream_id 9010aade-8a88-44f1-b9f3-763638e53c86, stream_type 0 Enabled_rules : {}
[generic_gstreamer.py:588:create_uridecode_bin:20230314T11:45:53:INFO] Creating uridecodebin for 9010aade-8a88-44f1-b9f3-763638e53c86 for rtsp://192.168.168.25:8022/restream
[stream.py:228:run:20230314T11:45:53:INFO] source added successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[generic_gstreamer.py:441:_decodebin_child_added_cb:20230314T11:45:56:INFO] rtsp source connected successfully for 9010aade-8a88-44f1-b9f3-763638e53c86
[generic_gstreamer.py:496:_decodebin_newpad_added_cb:20230314T11:45:56:INFO] sourcebin linked to streammux with vrate disabled : 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:360:_reconnect_source:20230314T17:52:34:INFO] Trying to reconnect: 13 → 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:271:publish_message:20230314T17:52:34:INFO] Publish success: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: <Action.RECONNECT: ‘reconnect_camera’>, ‘action_timestamp’: 1678816354.140989, ‘stream_index’: 13}
[stream_manager.py:357:_reconnect_source:20230314T17:52:34:DEBUG] Already reconnecting: 13 → 9010aade-8a88-44f1-b9f3-763638e53c86
[services.py:68:publish_in_queue:20230314T17:52:44:INFO] Data has been publised for 9010aade-8a88-44f1-b9f3-763638e53c86 with topic ClothingColor_c14bf167-0ac0-46be-b4ba-fe669308f188 for add_camera
[stream_manager.py:383:run_message_consumer:20230314T17:52:46:DEBUG] Incoming msg received {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’}
[stream_manager.py:423:run_stream_manager:20230314T17:52:55:DEBUG] Action received: {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678816366.7310643} at 1678816375.746285 with 1678816366.7310643
[stream_manager.py:178:add_source:20230314T17:52:55:DEBUG] Stream index selected : 19 source {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678816366.7310643} streams {23: <deepstream.stream.Stream object at 0x7f3ab30f8d30>, 11: <deepstream.stream.Stream object at 0x7f3ab30f8c70>}
[stream_manager.py:181:add_source:20230314T17:52:55:INFO] Tile index : 19 source {‘id’: None, ‘stream_type’: 0, ‘stream_type_name’: ‘ClothingColor’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘homography_configuration’: None, ‘save_output_to_file’: None, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘gpu_id’: ‘0’, ‘action’: ‘add_camera’, ‘action_timestamp’: 1678816366.7310643}
[stream.py:93:init:20230314T17:52:55:INFO] stream_id 9010aade-8a88-44f1-b9f3-763638e53c86, stream_type 0 Enabled_rules : {}
[generic_gstreamer.py:588:create_uridecode_bin:20230314T17:52:55:INFO] Creating uridecodebin for 9010aade-8a88-44f1-b9f3-763638e53c86 for rtsp://192.168.168.25:8022/restream
[stream.py:228:run:20230314T17:52:55:INFO] source added successfully : 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:360:_reconnect_source:20230315T07:26:55:INFO] Trying to reconnect: 19 → 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:264:publish_message:20230315T07:26:55:INFO] republishing {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: <Action.RECONNECT: ‘reconnect_camera’>, ‘action_timestamp’: 1678865215.023329, ‘stream_index’: 19}
[stream_manager.py:357:_reconnect_source:20230315T07:26:55:DEBUG] Already reconnecting: 19 → 9010aade-8a88-44f1-b9f3-763638e53c86
[stream_manager.py:383:run_message_consumer:20230315T07:26:55:DEBUG] Incoming msg received {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: ‘reconnect_camera’, ‘action_timestamp’: 1678865215.023329, ‘stream_index’: 19}
[stream_manager.py:423:run_stream_manager:20230315T07:26:55:DEBUG] Action received: {‘stream_id’: ‘9010aade-8a88-44f1-b9f3-763638e53c86’, ‘source_uri’: ‘rtsp://192.168.168.25:8022/restream’, ‘rules’: [{‘key’: ‘ColorClothing’, ‘label’: ‘Clothing Color’, ‘event_code’: 228, ‘roi’: [{‘key’: ‘ColorClothingRegionOfInterest’, ‘data_type’: ‘CC101’, ‘value’: [{‘X’: 0.008333333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.013333333333333334}, {‘X’: 0.9883333333333333, ‘Y’: 0.9888888888888889}, {‘X’: 0.008333333333333333, ‘Y’: 0.9888888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘CC101’}, {‘key’: ‘min_color_histogram’, ‘data_type’: ‘number’, ‘value’: 1}], ‘advance_settings’: }, {‘key’: ‘DefaultObjectDetection’, ‘label’: ‘Object Detection’, ‘event_code’: 207, ‘roi’: , ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘1678784002373’}], ‘advance_settings’: }, {‘key’: ‘PeopleCounting’, ‘label’: ‘People Counting’, ‘event_code’: 210, ‘roi’: [{‘key’: ‘RegionOfInterestOrientation’, ‘data_type’: ‘PC101’, ‘value’: [{‘X’: 0.9783333333333334, ‘Y’: 0.03777777777777778}, {‘X’: 0.021666666666666667, ‘Y’: 0.9777777777777777}, {‘X’: 0.20666666666666667, ‘Y’: 0.1688888888888889}]}, {‘key’: ‘RegionOfInterest’, ‘data_type’: None, ‘value’: }], ‘general_settings’: [{‘key’: ‘name’, ‘data_type’: ‘string’, ‘value’: ‘PC101’}, {‘key’: ‘category’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}, {‘key’: ‘object_class’, ‘data_type’: ‘list’, ‘value’: [‘Person’]}], ‘advance_settings’: }], ‘stream_type’: 0, ‘action’: ‘reconnect_camera’, ‘action_timestamp’: 1678865215.023329, ‘stream_index’: 19} at 1678865215.0641506 with 1678865215.023329
[stream_manager.py:207:delete_source:20230315T07:26:55:INFO] deleting source : 9010aade-8a88-44f1-b9f3-763638e53c86
How do you locate that? Just from your log attacked, it seems to have some problems on server. Are you building your own rtsp server or using the real rtsp source?
[services.py:42:delete_config:20230314T09:24:01:ERROR] 9010aade-8a88-44f1-b9f3-763638e53c86 is not available
Hi @yuweiw,
I have added some logs to delete source function and I see logs before pad releases are visible and post pad release are not visible.
I am created RTSP server using GStreamer. Below is our source deployment.
RTSP source → Restremer (GStreamer based pipeline) → uridecodebin
Above log with error is expected as we have deprecated file for camera sources which it expects to remove key and then report.
If you use the demo code without changes, can it works well?
Just from your description, there are two possible reasons:
  • You don’t set the pipeline to PLAY state
  • Your server has no data output
You can debug your own code first.
demo code is not sufficient for our use case. we add cameras at runtime and we do not know at prior how many cameras to be added when pipeline get started.
pipeline is set to play state only as other cameras attach to output the inference result.
RTSP server url I can play into VLC or any other RTSP client. behaviour is random, if I start pipeline with 10 cameras one time some set of cameras get connected and send inference output and some cameras does not output anything.
OK. Could you attach your code to us? We can repro the problem in our env. If you don’t want to expose the code to public, you can message to me.
Also, You can narrow the scope gradually by debugging it with gdb to see where the pipeline hangs.
