I’ve been following the chat mentioned here :
Q1. According to the existing setup with and without applying the above change I see same behaviour :
- The Clock is set rightly to 204Mhz :
root@mistral-desktop:~# cat /sys/kernel/debug/mmc1/*
204000000
clock: 204000000 Hz
actual clock: 24960000 Hz
vdd: 21 (3.3 ~ 3.4 V)
bus mode: 2 (push-pull)
chip select: 0 (don’t care)
power mode: 2 (on)
bus width: 2 (4 bits)
timing spec: 6 (sd uhs SDR104)
signal voltage: 1 (1.80 V)
driver type: 0 (driver type B)
cat: ‘/sys/kernel/debug/mmc1/mmc1:0001’: Is a directory
speed = 0
- With benchmarking tool :
usb2.0 :
write= 21.9MB/s
read= 36.6 MB/s
usb-3.0:
write = 11.2 MB/s
read = 102 MB/s
Q2. Is this the maximum speed of R/W over USB2.0/3.0 supported ?
Input from dmesg :
dmesg | grep mmc1
[ 0.617768] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 1.343033] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA 64-bit with 64 bit addr
[ 1.595449] mmc1: Applying tuning correction
[ 1.595476] mmc1: Tap value after applying correction 183
[ 1.595503] mmc1: hw tuning done …
[ 1.602799] mmc1: new ultra high speed SDR104 SDIO card at address 0001
[ 61.472437] mmc1: current speed
Thanks in advance…
