Hi every one,
I’m using an USB 3.0 camera on Nvidia Jetson Nano board
This is the device information when I use the v4l2-ctl to check
v4l2-ctl --info --list-devices
3.0 USB Camera (usb-70090000.xusb-1.4):
/dev/video0
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : 3.0 USB Camera
Bus info : usb-70090000.xusb-1.4
Driver version: 4.9.140
Capabilities : 0x84200001
Video Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
I use this code to test the camera with Opencv
import cv2
import time
cap = cv2.VideoCapture(0)
if not cap.isOpened():
raise IOError("Cannot open webcam")
cap.release()
cv2.destroyAllWindows()
cap.set(cv2.CAP_PROP_FRAME_WIDTH,1920);
cap.set(cv2.CAP_PROP_FRAME_HEIGHT,1080);
for i in range(100):
start = time.time()
ret, frame = cap.read()
stop = time.time() - start
print('Exe time', stop)
cv2.imshow('large size', frame)
c = cv2.waitKey(1)
if c == 27:
break
cap.release()
The code works with USB 2.0 camera.
But it returns the ‘select timeout’ error with USB 3.0 camera above.
I tried the same code and camera on Ubuntu 16 installed on my desktop PC, it works without any error?
I guest some problem with the driver on Nvidia Jetson Nano.
Do you have any suggestion to fix the problem?
Thank you.
