The Jetson implementation guide mentions the requirement for 2 sets of ac coupling capacitors on both the SSRX and SSTX pairs when connecting between the TX2 SOM and an on-board USB device.
Our application has a USB hub co-located on the same board as the Jetson TX2. the question I have is where are the AC coupling capacitors placed when making the upstream connection?
The only discontiuity (Unless the USB hub device package is counted as a discontinuity), is the Samtec SEAF socket for the TX2 SOM. Should all 4 capacitors (2 on the sstx signals and 2 on the ssrx signals) be located as close as possible to the TX2 connector, or is there a more favored placement?
