Sorry, I didn’t plug the USB 3.0 device into the wrong slot. This is the new dmesg log,
You can see obvious mistakes.
a.log (97.9 KB)
[ 7.703903] tegradc 15210000.nvdisplay: blank - powerdown
[ 7.703911] tegradc 15220000.nvdisplay: blank - powerdown
[ 8.017392] usb usb2: usb_suspend_both: status 0
[ 8.017413] tegra-xusb 3530000.xhci: entering ELPG
[ 8.022195] tegra-xusb 3530000.xhci: entering ELPG done
[ 8.031112] tegra-xusb 3530000.xhci: exiting ELPG
[ 8.034841] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 8.036304] tegra-xusb 3530000.xhci: exiting ELPG done
[ 8.467150] eqos 2490000.ether_qos eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 8.467730] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 8.470450] usb usb2: usb_suspend_both: status 0
[ 8.704859] fuse init (API version 7.26)
[ 9.205359] usb usb2: usb_suspend_both: status -16
[ 9.205481] usb usb2: usb_suspend_both: status 0
[ 9.301249] usb 1-3: new high-speed USB device number 10 using tegra-xusb
[ 9.989565] usb 1-3: Device not responding to setup address.
[ 10.021326] usb usb2: usb_suspend_both: status -16
[ 10.021446] usb usb2: usb_suspend_both: status 0
[ 10.201546] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 10.417216] usb 1-3: device not accepting address 10, error -22
[ 11.731619] usb usb1: usb_suspend_both: status 0
[ 12.438849] usb 1-3: new high-speed USB device number 12 using tegra-xusb
[ 13.097424] usb usb2: usb_suspend_both: status 0
[ 13.463745] usb 1-3: Device not responding to setup address.
[ 14.702171] usb 1-3: Device not responding to setup address.
[ 14.913236] usb 1-3: device not accepting address 12, error -71
[ 15.513564] usb 1-3: new high-speed USB device number 13 using tegra-xusb
[ 15.933644] usb usb2: usb_suspend_both: status 0
[ 16.538453] usb 1-3: Device not responding to setup address.
[ 17.774166] usb 1-3: Device not responding to setup address.
[ 17.985486] usb 1-3: device not accepting address 13, error -71
[ 17.991923] usb usb1-port3: attempt power cycle
[ 20.442176] usb usb1: usb_suspend_both: status 0
[ 22.226899] usb usb2: usb_suspend_both: status 0
[ 22.338082] usb usb1: usb_suspend_both: status 0
[ 22.721452] usb 1-3: new high-speed USB device number 16 using tegra-xusb
[ 23.266244] usb usb2: usb_suspend_both: status 0
[ 23.416115] usb 1-3: Device not responding to setup address.
[ 23.437894] usb usb2: usb_suspend_both: status -16
[ 23.453612] usb usb2: usb_suspend_both: status -16
[ 23.469565] usb usb2: usb_suspend_both: status -16
[ 23.485644] usb usb2: usb_suspend_both: status -16
[ 23.501645] usb usb2: usb_suspend_both: status -16
[ 23.517647] usb usb2: usb_suspend_both: status -16
[ 23.533747] usb usb2: usb_suspend_both: status -16
[ 23.549684] usb usb2: usb_suspend_both: status -16
[ 23.565641] usb usb2: usb_suspend_both: status -16
[ 23.581632] usb usb2: usb_suspend_both: status -16
[ 23.597599] usb usb2: usb_suspend_both: status -16
[ 23.613570] usb usb2: usb_suspend_both: status -16
[ 23.629877] usb usb2: usb_suspend_both: status -16
[ 23.630211] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 23.653723] usb usb2: usb_suspend_both: status -16
[ 23.845472] usb 1-3: device not accepting address 16, error -22
[ 24.742034] usb usb1: usb_suspend_both: status 0
[ 26.349764] usb usb1: usb_suspend_both: status 0
[ 27.725837] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[ 27.874034] usb usb2: usb_suspend_both: status 0
[ 27.953607] usb usb2: usb_suspend_both: status -16
[ 28.521519] usb 1-3: new high-speed USB device number 19 using tegra-xusb
[ 28.698737] usb usb2: usb_suspend_both: status 0
[ 28.787065] usb 1-3: Device not responding to setup address.
[ 28.809794] usb usb2: usb_suspend_both: status -16
[ 28.825678] usb usb2: usb_suspend_both: status -16
[ 28.841812] usb usb2: usb_suspend_both: status -16
[ 28.857610] usb usb2: usb_suspend_both: status -16
[ 28.873585] usb usb2: usb_suspend_both: status -16
[ 28.889549] usb usb2: usb_suspend_both: status -16
[ 28.905642] usb usb2: usb_suspend_both: status -16
[ 28.921644] usb usb2: usb_suspend_both: status -16
[ 28.937586] usb usb2: usb_suspend_both: status -16
[ 28.953598] usb usb2: usb_suspend_both: status -16
[ 28.969560] usb usb2: usb_suspend_both: status -16
[ 28.985548] usb usb2: usb_suspend_both: status -16
[ 29.001775] usb usb2: usb_suspend_both: status -16
[ 29.002265] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 29.017371] usb usb2: usb_suspend_both: status -16
[ 29.033567] usb usb2: usb_suspend_both: status -16
[ 29.049980] usb usb2: usb_suspend_both: status -16
[ 29.065683] usb usb2: usb_suspend_both: status -16
[ 29.081683] usb usb2: usb_suspend_both: status -16
[ 29.097684] usb usb2: usb_suspend_both: status -16
[ 29.113619] usb usb2: usb_suspend_both: status -16
[ 29.129751] usb usb2: usb_suspend_both: status -16
[ 29.145891] usb usb2: usb_suspend_both: status -16
[ 29.161728] usb usb2: usb_suspend_both: status -16
[ 29.177606] usb usb2: usb_suspend_both: status -16
[ 29.193600] usb usb2: usb_suspend_both: status -16
[ 29.209648] usb usb2: usb_suspend_both: status -16
[ 29.217435] usb 1-3: device not accepting address 19, error -22
[ 29.229412] usb usb2: usb_suspend_both: status -16
[ 29.245649] usb usb2: usb_suspend_both: status -16
[ 29.261647] usb usb2: usb_suspend_both: status -16
[ 29.281543] usb usb2: usb_suspend_both: status -16
[ 29.297579] usb usb2: usb_suspend_both: status -16
[ 29.313686] usb usb2: usb_suspend_both: status -16
[ 29.329579] usb usb2: usb_suspend_both: status -16
[ 29.345666] usb usb2: usb_suspend_both: status -16
[ 29.361659] usb usb2: usb_suspend_both: status -16
[ 29.377706] usb usb2: usb_suspend_both: status -16
[ 29.393646] usb usb2: usb_suspend_both: status -16
[ 29.409512] usb usb2: usb_suspend_both: status -16
[ 29.425660] usb usb2: usb_suspend_both: status -16
[ 29.441844] usb usb2: usb_suspend_both: status -16
[ 29.457614] usb usb2: usb_suspend_both: status -16
[ 29.473726] usb usb2: usb_suspend_both: status -16
[ 29.489642] usb usb2: usb_suspend_both: status -16
[ 29.505693] usb usb2: usb_suspend_both: status -16
[ 29.521577] usb usb2: usb_suspend_both: status -16
[ 29.537614] usb usb2: usb_suspend_both: status -16
[ 29.553735] usb usb2: usb_suspend_both: status -16
[ 29.569728] usb usb2: usb_suspend_both: status -16
[ 29.585659] usb usb2: usb_suspend_both: status -16
[ 29.601648] usb usb2: usb_suspend_both: status -16
[ 29.725553] usb usb2: usb_suspend_both: status -16
[ 29.726090] usb usb2: usb_suspend_both: status 0
[ 30.737854] usb usb1: usb_suspend_both: status 0
[ 32.741859] usb usb1: usb_suspend_both: status 0
[ 33.270126] usb usb2: usb_suspend_both: status 0
[ 34.221321] usb usb1: usb_suspend_both: status 0
[ 37.365803] usb usb1: usb_suspend_both: status 0
[ 37.846046] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[ 39.754015] usb usb2: usb_suspend_both: status 0
[ 39.769563] usb usb1: usb_suspend_both: status 0
[ 39.769602] tegra-xusb 3530000.xhci: entering ELPG
[ 39.779891] tegra-xusb 3530000.xhci: entering ELPG done
[ 39.783757] tegra-xusb 3530000.xhci: exiting ELPG
[ 39.791383] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 39.793798] tegra-xusb 3530000.xhci: exiting ELPG done
[ 40.873426] usb 1-3: new high-speed USB device number 27 using tegra-xusb
[ 41.222001] usb 1-3: Device not responding to setup address.
[ 41.409949] usb usb2: usb_suspend_both: status 0
[ 41.433528] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 41.649503] usb 1-3: device not accepting address 27, error -22
[ 41.777473] usb 1-3: new high-speed USB device number 28 using tegra-xusb
[ 42.050509] usb 1-3: Device not responding to setup address.
[ 42.279369] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 42.497792] usb 1-3: device not accepting address 28, error -22
[ 42.504443] usb usb1-port3: attempt power cycle
[ 43.890069] usb usb2: usb_suspend_both: status 0
[ 44.801699] usb usb2: usb_suspend_both: status -16
[ 44.802098] usb usb2: usb_suspend_both: status 0
[ 45.077717] usb 1-3: new high-speed USB device number 29 using tegra-xusb
[ 46.034029] usb usb2: usb_suspend_both: status 0
[ 46.473842] usb usb1: usb_suspend_both: status 0
[ 46.473970] tegra-xusb 3530000.xhci: entering ELPG
[ 46.488947] tegra-xusb 3530000.xhci: entering ELPG done
[ 46.488976] tegra-xusb 3530000.xhci: exiting ELPG
[ 46.494045] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 46.495501] tegra-xusb 3530000.xhci: exiting ELPG done
[ 46.861793] usb 1-3: new high-speed USB device number 30 using tegra-xusb
[ 46.883921] usb 1-3: device descriptor read/8, error -71
[ 46.890094] usb usb2: usb_suspend_both: status -16
[ 46.890489] usb usb2: usb_suspend_both: status 0
[ 47.019709] usb 1-3: device descriptor read/8, error -71
[ 47.253232] usb 1-3: new high-speed USB device number 31 using tegra-xusb
[ 47.687004] usb 1-3: device descriptor read/all, error -71
[ 47.694086] usb usb1-port3: attempt power cycle
[ 47.709840] usb usb2: usb_suspend_both: status -16
[ 47.725553] usb usb2: usb_suspend_both: status -16
[ 47.741683] usb usb2: usb_suspend_both: status -16
[ 47.757685] usb usb2: usb_suspend_both: status -16
[ 47.773645] usb usb2: usb_suspend_both: status -16
[ 47.789599] usb usb2: usb_suspend_both: status -16
[ 47.805715] usb usb2: usb_suspend_both: status -16
[ 47.821725] usb usb2: usb_suspend_both: status -16
[ 47.837636] usb usb2: usb_suspend_both: status -16
[ 47.853626] usb usb2: usb_suspend_both: status -16
[ 47.869546] usb usb2: usb_suspend_both: status -16
[ 47.885673] usb usb2: usb_suspend_both: status -16
[ 47.901693] usb usb2: usb_suspend_both: status -16
[ 47.917570] usb usb2: usb_suspend_both: status -16
[ 47.933586] usb usb2: usb_suspend_both: status -16
[ 47.949939] usb usb2: usb_suspend_both: status -16
[ 47.965520] usb usb2: usb_suspend_both: status -16
[ 47.981532] usb usb2: usb_suspend_both: status -16
[ 47.997856] usb usb2: usb_suspend_both: status -16
[ 48.013578] usb usb2: usb_suspend_both: status -16
[ 48.029765] usb usb2: usb_suspend_both: status -16
[ 48.045371] usb usb2: usb_suspend_both: status -16
[ 48.061349] usb usb2: usb_suspend_both: status -16
[ 48.077435] usb usb2: usb_suspend_both: status -16
[ 48.093460] usb usb2: usb_suspend_both: status -16
[ 48.109512] usb usb2: usb_suspend_both: status -16
[ 48.125589] usb usb2: usb_suspend_both: status -16
[ 48.141788] usb usb2: usb_suspend_both: status -16
[ 48.157708] usb usb2: usb_suspend_both: status -16
[ 48.177516] usb usb2: usb_suspend_both: status -16
[ 48.193565] usb usb2: usb_suspend_both: status -16
[ 48.209620] usb usb2: usb_suspend_both: status -16
[ 48.225574] usb usb2: usb_suspend_both: status -16
[ 48.241594] usb usb2: usb_suspend_both: status -16
[ 48.257612] usb usb2: usb_suspend_both: status -16
[ 48.273620] usb usb2: usb_suspend_both: status -16
[ 48.289566] usb usb2: usb_suspend_both: status -16
[ 48.305803] usb usb2: usb_suspend_both: status -16
[ 48.321562] usb usb2: usb_suspend_both: status -16
[ 48.337566] usb usb2: usb_suspend_both: status -16
[ 48.353604] usb usb2: usb_suspend_both: status -16
[ 48.369606] usb usb2: usb_suspend_both: status -16
[ 48.385561] usb usb2: usb_suspend_both: status -16
[ 48.401688] usb usb2: usb_suspend_both: status -16
[ 48.417679] usb usb2: usb_suspend_both: status -16
[ 48.433630] usb usb2: usb_suspend_both: status -16
[ 48.449644] usb usb2: usb_suspend_both: status -16
[ 48.465757] usb usb2: usb_suspend_both: status -16
[ 48.481595] usb usb2: usb_suspend_both: status -16
[ 48.497527] usb usb2: usb_suspend_both: status -16
[ 48.621332] usb usb2: usb_suspend_both: status -16
[ 48.621737] usb usb2: usb_suspend_both: status 0
[ 49.369710] usb usb2-port2: config error
[ 50.118404] usb usb2: usb_suspend_both: status 0
[ 50.629525] usb usb1-port3: Cannot enable. Maybe the USB cable is bad?
[ 51.525766] usb usb1: usb_suspend_both: status 0
[ 53.058031] usb usb2: usb_suspend_both: status 0
[ 53.113732] usb usb2: usb_suspend_both: status -16
[ 53.114116] usb usb2: usb_suspend_both: status 0
[ 53.401495] usb 1-3: new high-speed USB device number 35 using tegra-xusb
[ 53.910285] usb 1-3: Device not responding to setup address.
[ 54.143422] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 54.357653] usb 1-3: device not accepting address 35, error -22
[ 54.485530] usb 1-3: new high-speed USB device number 36 using tegra-xusb
[ 54.726380] usb 1-3: Device not responding to setup address.
[ 54.939381] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 55.153708] usb 1-3: device not accepting address 36, error -22
[ 55.160856] usb usb1-port3: attempt power cycle
[ 55.750191] usb usb2: usb_suspend_both: status 0
[ 57.609835] usb usb1: usb_suspend_both: status 0
[ 60.369768] usb usb1: usb_suspend_both: status 0
[ 60.914247] usb usb2-port2: Cannot enable. Maybe the USB cable is bad?
[ 61.066333] usb usb2: usb_suspend_both: status 0
[ 62.001735] usb usb1: usb_suspend_both: status 0
[ 62.949632] usb usb2: usb_suspend_both: status 0
[ 62.949664] tegra-xusb 3530000.xhci: entering ELPG
[ 62.955168] tegra-xusb 3530000.xhci: entering ELPG done
[ 62.963429] tegra-xusb 3530000.xhci: exiting ELPG
[ 62.968201] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 62.970871] tegra-xusb 3530000.xhci: exiting ELPG done
[ 63.753504] usb 1-3: new high-speed USB device number 40 using tegra-xusb
[ 64.019247] usb 1-3: Device not responding to setup address.
[ 64.233976] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 64.449252] usb 1-3: device not accepting address 40, error -22
[ 64.573567] usb 1-3: new high-speed USB device number 41 using tegra-xusb
[ 64.837881] usb 1-3: Device not responding to setup address.
[ 64.982701] usb usb2: usb_suspend_both: status 0
[ 65.050194] tegra-xusb 3530000.xhci: ERROR: unexpected setup address command completion code 0x11.
[ 65.265491] usb 1-3: device not accepting address 41, error -22
[ 65.272254] usb usb1-port3: attempt power cycle
[ 66.861646] usb usb2: usb_suspend_both: status -16
[ 66.877576] usb usb2: usb_suspend_both: status -16
[ 66.893980] usb usb2: usb_suspend_both: status -16
[ 66.909600] usb usb2: usb_suspend_both: status -16
[ 66.925720] usb usb2: usb_suspend_both: status -16
[ 66.941743] usb usb2: usb_suspend_both: status -16
[ 66.953373] usb 1-3: new high-speed USB device number 42 using tegra-xusb
[ 66.957670] usb usb2: usb_suspend_both: status -16
[ 66.973686] usb usb2: usb_suspend_both: status -16
[ 66.989799] usb usb2: usb_suspend_both: status -16
[ 67.005522] usb usb2: usb_suspend_both: status -16
[ 67.021619] usb usb2: usb_suspend_both: status -16
[ 67.037737] usb usb2: usb_suspend_both: status -16
[ 67.053586] usb usb2: usb_suspend_both: status -16
[ 67.069585] usb usb2: usb_suspend_both: status -16
[ 67.085620] usb usb2: usb_suspend_both: status -16
[ 67.101584] usb usb2: usb_suspend_both: status -16
[ 67.117716] usb usb2: usb_suspend_both: status -16
[ 67.133697] usb usb2: usb_suspend_both: status -16
[ 67.149686] usb usb2: usb_suspend_both: status -16
[ 67.165704] usb usb2: usb_suspend_both: status -16
[ 67.181686] usb usb2: usb_suspend_both: status -16
[ 67.197611] usb usb2: usb_suspend_both: status -16
[ 67.213556] usb usb2: usb_suspend_both: status -16
[ 67.213907] usb usb2: usb_suspend_both: status 0
[ 67.253547] usb usb2: usb_suspend_both: status -16
[ 67.270025] usb usb2: usb_suspend_both: status -16
[ 67.285744] usb usb2: usb_suspend_both: status -16
[ 67.301898] usb usb2: usb_suspend_both: status -16
[ 67.317559] usb usb2: usb_suspend_both: status -16
[ 67.333547] usb usb2: usb_suspend_both: status -16
[ 67.349564] usb usb2: usb_suspend_both: status -16
[ 67.365566] usb usb2: usb_suspend_both: status -16
[ 67.381573] usb usb2: usb_suspend_both: status -16
[ 67.397580] usb usb2: usb_suspend_both: status -16
[ 67.413626] usb usb2: usb_suspend_both: status -16
[ 67.429599] usb usb2: usb_suspend_both: status -16
[ 67.446025] usb usb2: usb_suspend_both: status -16
[ 67.461675] usb usb2: usb_suspend_both: status -16
[ 67.477663] usb usb2: usb_suspend_both: status -16
[ 67.493650] usb usb2: usb_suspend_both: status -16
[ 67.509619] usb usb2: usb_suspend_both: status -16
[ 67.525765] usb usb2: usb_suspend_both: status -16
[ 67.541548] usb usb2: usb_suspend_both: status -16
[ 67.557616] usb usb2: usb_suspend_both: status -16
[ 67.573561] usb usb2: usb_suspend_both: status -16
[ 67.589648] usb usb2: usb_suspend_both: status -16
[ 67.605585] usb usb2: usb_suspend_both: status -16
[ 67.621587] usb usb2: usb_suspend_both: status -16
[ 67.637760] usb usb2: usb_suspend_both: status -16
[ 67.653654] usb usb2: usb_suspend_both: status -16
[ 67.670195] usb usb2: usb_suspend_both: status -16
[ 67.685876] usb usb2: usb_suspend_both: status -16
[ 67.701629] usb usb2: usb_suspend_both: status -16
[ 67.717610] usb usb2: usb_suspend_both: status -16
[ 67.733604] usb usb2: usb_suspend_both: status -16
[ 67.749582] usb usb2: usb_suspend_both: status -16
[ 67.765628] usb usb2: usb_suspend_both: status -16
[ 67.781623] usb usb2: usb_suspend_both: status -16
[ 67.797927] usb usb2: usb_suspend_both: status -16
[ 67.814269] usb usb2: usb_suspend_both: status -16
[ 67.830587] usb usb2: usb_suspend_both: status -16
[ 67.845463] usb usb2: usb_suspend_both: status -16
[ 67.861422] usb usb2: usb_suspend_both: status -16
[ 67.877760] usb usb2: usb_suspend_both: status -16
[ 67.893712] usb usb2: usb_suspend_both: status -16
[ 67.909622] usb usb2: usb_suspend_both: status -16
[ 67.925656] usb usb2: usb_suspend_both: status -16
[ 67.941551] usb usb2: usb_suspend_both: status -16
[ 67.957596] usb usb2: usb_suspend_both: status -16
[ 67.973628] usb usb2: usb_suspend_both: status -16
[ 67.989708] usb usb2: usb_suspend_both: status -16
[ 68.005583] usb usb2: usb_suspend_both: status -16
[ 68.021591] usb usb2: usb_suspend_both: status -16
[ 68.145518] usb usb2: usb_suspend_both: status -16
[ 68.145877] usb usb2: usb_suspend_both: status 0
[ 68.249756] usb usb2: usb_suspend_both: status -16
[ 68.266370] usb usb2: usb_suspend_both: status -16
[ 68.282269] usb usb2: usb_suspend_both: status -16
[ 68.297997] usb usb2: usb_suspend_both: status -16
[ 68.314078] usb usb2: usb_suspend_both: status -16
[ 68.329932] usb usb2: usb_suspend_both: status -16
[ 68.346029] usb usb2: usb_suspend_both: status -16
[ 68.361987] usb usb2: usb_suspend_both: status -16
[ 68.378099] usb usb2: usb_suspend_both: status -16
[ 68.394067] usb usb2: usb_suspend_both: status -16
[ 68.410125] usb usb2: usb_suspend_both: status -16
[ 68.426593] usb usb2: usb_suspend_both: status -16
[ 68.441948] usb usb2: usb_suspend_both: status -16
[ 68.458464] usb usb2: usb_suspend_both: status -16
[ 68.474313] usb usb2: usb_suspend_both: status -16
[ 68.490456] usb usb2: usb_suspend_both: status -16
[ 68.506349] usb usb2: usb_suspend_both: status -16
[ 68.522319] usb usb2: usb_suspend_both: status -16
[ 68.538236] usb usb2: usb_suspend_both: status -16
[ 68.554319] usb usb2: usb_suspend_both: status -16
[ 68.570344] usb usb2: usb_suspend_both: status -16
[ 68.586461] usb usb2: usb_suspend_both: status -16
[ 68.602415] usb usb2: usb_suspend_both: status -16
[ 68.618415] usb usb2: usb_suspend_both: status -16
[ 68.634430] usb usb2: usb_suspend_both: status -16
[ 68.654448] usb usb2: usb_suspend_both: status -16
[ 68.670514] usb usb2: usb_suspend_both: status -16
[ 68.686586] usb usb2: usb_suspend_both: status -16
[ 68.706564] usb usb2: usb_suspend_both: status -16
[ 68.722573] usb usb2: usb_suspend_both: status -16
[ 68.738596] usb usb2: usb_suspend_both: status -16
[ 68.754594] usb usb2: usb_suspend_both: status -16
[ 68.770641] usb usb2: usb_suspend_both: status -16
[ 68.786712] usb usb2: usb_suspend_both: status -16
[ 68.802923] usb usb2: usb_suspend_both: status -16
[ 68.819069] usb usb2: usb_suspend_both: status -16
[ 68.834918] usb usb2: usb_suspend_both: status -16
[ 68.850739] usb usb2: usb_suspend_both: status -16
[ 68.866739] usb usb2: usb_suspend_both: status -16
[ 68.882742] usb usb2: usb_suspend_both: status -16
[ 68.898945] usb usb2: usb_suspend_both: status -16
[ 68.914856] usb usb2: usb_suspend_both: status -16
[ 68.930842] usb usb2: usb_suspend_both: status -16
[ 68.947299] usb usb2: usb_suspend_both: status -16
[ 68.962735] usb usb2: usb_suspend_both: status -16
[ 68.978916] usb usb2: usb_suspend_both: status -16
[ 68.995098] usb usb2: usb_suspend_both: status -16
[ 69.011267] usb usb2: usb_suspend_both: status -16
[ 69.026960] usb usb2: usb_suspend_both: status -16
[ 69.042957] usb usb2: usb_suspend_both: status -16
[ 69.059162] usb usb2: usb_suspend_both: status -16
[ 69.075036] usb usb2: usb_suspend_both: status -16
[ 69.091191] usb usb2: usb_suspend_both: status -16
[ 69.095220] usb usb1: usb_suspend_both: status 0
[ 69.107155] usb usb2: usb_suspend_both: status -16
[ 69.123286] usb usb2: usb_suspend_both: status -16
[ 69.139211] usb usb2: usb_suspend_both: status -16
[ 69.155232] usb usb2: usb_suspend_both: status -16
[ 69.171228] usb usb2: usb_suspend_both: status -16
[ 69.187153] usb usb2: usb_suspend_both: status -16
[ 69.203296] usb usb2: usb_suspend_both: status -16
[ 69.219331] usb usb2: usb_suspend_both: status -16
[ 69.235340] usb usb2: usb_suspend_both: status -16
[ 69.251284] usb usb2: usb_suspend_both: status -16
[ 69.267341] usb usb2: usb_suspend_both: status -16
[ 69.283330] usb usb2: usb_suspend_both: status -16
[ 69.299382] usb usb2: usb_suspend_both: status -16
[ 69.315416] usb usb2: usb_suspend_both: status -16
[ 69.331414] usb usb2: usb_suspend_both: status -16
[ 69.347512] usb usb2: usb_suspend_both: status -16
[ 69.367396] usb usb2: usb_suspend_both: status -16
[ 69.383472] usb usb2: usb_suspend_both: status -16
[ 69.399489] usb usb2: usb_suspend_both: status -16
[ 69.415501] usb usb2: usb_suspend_both: status -16
[ 69.431547] usb usb2: usb_suspend_both: status -16
[ 69.448060] usb usb2: usb_suspend_both: status -16
[ 69.463809] usb usb2: usb_suspend_both: status -16
[ 69.479643] usb usb2: usb_suspend_both: status -16
[ 69.495647] usb usb2: usb_suspend_both: status -16
[ 69.511652] usb usb2: usb_suspend_both: status -16
[ 69.527806] usb usb2: usb_suspend_both: status -16
[ 69.543712] usb usb2: usb_suspend_both: status -16
[ 69.559788] usb usb2: usb_suspend_both: status -16
[ 69.575749] usb usb2: usb_suspend_both: status -16
[ 69.591780] usb usb2: usb_suspend_both: status -16
[ 69.607805] usb usb2: usb_suspend_both: status -16
[ 69.623850] usb usb2: usb_suspend_both: status -16
[ 69.639847] usb usb2: usb_suspend_both: status -16
[ 69.655836] usb usb2: usb_suspend_both: status -16
[ 69.671933] usb usb2: usb_suspend_both: status -16
[ 69.687884] usb usb2: usb_suspend_both: status -16
[ 69.703940] usb usb2: usb_suspend_both: status -16
[ 69.719920] usb usb2: usb_suspend_both: status -16
[ 69.736011] usb usb2: usb_suspend_both: status -16
[ 69.751990] usb usb2: usb_suspend_both: status -16
[ 69.768005] usb usb2: usb_suspend_both: status -16
[ 69.784019] usb usb2: usb_suspend_both: status -16
[ 69.800066] usb usb2: usb_suspend_both: status -16
[ 69.816306] usb usb2: usb_suspend_both: status -16
[ 69.832300] usb usb2: usb_suspend_both: status -16
[ 69.848188] usb usb2: usb_suspend_both: status -16
[ 69.864174] usb usb2: usb_suspend_both: status -16
[ 69.880189] usb usb2: usb_suspend_both: status -16
[ 69.896316] usb usb2: usb_suspend_both: status -16
[ 69.912257] usb usb2: usb_suspend_both: status -16
[ 69.928379] usb usb2: usb_suspend_both: status -16
[ 69.944363] usb usb2: usb_suspend_both: status -16
[ 69.960283] usb usb2: usb_suspend_both: status -16
[ 69.976297] usb usb2: usb_suspend_both: status -16
[ 69.992356] usb usb2: usb_suspend_both: status -16
[ 70.008395] usb usb2: usb_suspend_both: status -16
[ 70.024289] usb usb2: usb_suspend_both: status -16
[ 70.040387] usb usb2: usb_suspend_both: status -16
[ 70.056430] usb usb2: usb_suspend_both: status -16
[ 70.072430] usb usb2: usb_suspend_both: status -16
[ 70.088425] usb usb2: usb_suspend_both: status -16
[ 70.104500] usb usb2: usb_suspend_both: status -16
[ 70.120504] usb usb2: usb_suspend_both: status -16
[ 70.136557] usb usb2: usb_suspend_both: status -16
[ 70.152664] usb usb2: usb_suspend_both: status -16
[ 70.168602] usb usb2: usb_suspend_both: status -16
[ 70.184614] usb usb2: usb_suspend_both: status -16
[ 70.200628] usb usb2: usb_suspend_both: status -16
[ 70.216626] usb usb2: usb_suspend_both: status -16
[ 70.232632] usb usb2: usb_suspend_both: status -16
[ 70.248687] usb usb2: usb_suspend_both: status -16
[ 70.264815] usb usb2: usb_suspend_both: status -16
[ 70.280745] usb usb2: usb_suspend_both: status -16
[ 70.296747] usb usb2: usb_suspend_both: status -16
[ 70.312739] usb usb2: usb_suspend_both: status -16
[ 70.328746] usb usb2: usb_suspend_both: status -16
[ 70.344770] usb usb2: usb_suspend_both: status -16
[ 70.360886] usb usb2: usb_suspend_both: status -16
[ 70.376851] usb usb2: usb_suspend_both: status -16
[ 70.392820] usb usb2: usb_suspend_both: status -16
[ 70.408938] usb usb2: usb_suspend_both: status -16
[ 70.424970] usb usb2: usb_suspend_both: status -16
[ 70.440926] usb usb2: usb_suspend_both: status -16
[ 70.457061] usb usb2: usb_suspend_both: status -16
[ 70.473027] usb usb2: usb_suspend_both: status -16
[ 70.488989] usb usb2: usb_suspend_both: status -16
[ 70.505044] usb usb2: usb_suspend_both: status -16
[ 70.520957] usb usb2: usb_suspend_both: status -16
[ 70.537031] usb usb2: usb_suspend_both: status -16
[ 70.553074] usb usb2: usb_suspend_both: status -16
[ 70.569113] usb usb2: usb_suspend_both: status -16
[ 70.585154] usb usb2: usb_suspend_both: status -16
[ 70.601156] usb usb2: usb_suspend_both: status -16
[ 70.617101] usb usb2: usb_suspend_both: status -16
[ 70.633143] usb usb2: usb_suspend_both: status -16
[ 70.649163] usb usb2: usb_suspend_both: status -16
[ 70.665187] usb usb2: usb_suspend_both: status -16
[ 70.681244] usb usb2: usb_suspend_both: status -16
[ 70.697202] usb usb2: usb_suspend_both: status -16
[ 70.713256] usb usb2: usb_suspend_both: status -16
[ 70.729300] usb usb2: usb_suspend_both: status -16
[ 70.745265] usb usb2: usb_suspend_both: status -16
[ 70.761300] usb usb2: usb_suspend_both: status -16
[ 70.777360] usb usb2: usb_suspend_both: status -16
[ 70.793314] usb usb2: usb_suspend_both: status -16
[ 70.809350] usb usb2: usb_suspend_both: status -16
[ 70.825594] usb usb2: usb_suspend_both: status -16
[ 70.841739] usb usb2: usb_suspend_both: status -16
[ 70.857477] usb usb2: usb_suspend_both: status -16
[ 70.873457] usb usb2: usb_suspend_both: status -16
[ 70.889613] usb usb2: usb_suspend_both: status -16
[ 70.905523] usb usb2: usb_suspend_both: status -16
[ 70.921686] usb usb2: usb_suspend_both: status -16
[ 70.937534] usb usb2: usb_suspend_both: status -16
[ 70.953568] usb usb2: usb_suspend_both: status -16
[ 70.969603] usb usb2: usb_suspend_both: status -16
[ 70.985661] usb usb2: usb_suspend_both: status -16
[ 71.001685] usb usb2: usb_suspend_both: status -16
[ 71.017688] usb usb2: usb_suspend_both: status -16
[ 71.033680] usb usb2: usb_suspend_both: status -16
[ 71.049692] usb usb2: usb_suspend_both: status -16
[ 71.050010] usb usb2: usb_suspend_both: status 0
[ 71.050127] tegra-xusb 3530000.xhci: entering ELPG
[ 71.062315] tegra-xusb 3530000.xhci: entering ELPG done
[ 71.062399] tegra-xusb 3530000.xhci: exiting ELPG
[ 71.072226] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 71.074660] tegra-xusb 3530000.xhci: exiting ELPG done
[ 73.080019] tegra-xusb 3530000.xhci: entering ELPG
[ 73.095892] tegra-xusb 3530000.xhci: entering ELPG done
[ 73.106697] tegra-xusb 3530000.xhci: exiting ELPG
[ 73.112291] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 73.114559] tegra-xusb 3530000.xhci: exiting ELPG done
[ 75.118486] tegra-xusb 3530000.xhci: entering ELPG
[ 75.126787] tegra-xusb 3530000.xhci: entering ELPG done
[ 75.132972] tegra-xusb 3530000.xhci: exiting ELPG
[ 75.142173] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 75.144420] tegra-xusb 3530000.xhci: exiting ELPG done
[ 77.148187] tegra-xusb 3530000.xhci: entering ELPG
[ 77.153717] tegra-xusb 3530000.xhci: entering ELPG done
[ 77.162083] tegra-xusb 3530000.xhci: exiting ELPG
[ 77.166044] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 77.167495] tegra-xusb 3530000.xhci: exiting ELPG done
[ 79.169311] tegra-xusb 3530000.xhci: entering ELPG
[ 79.174003] tegra-xusb 3530000.xhci: entering ELPG done
[ 79.182998] tegra-xusb 3530000.xhci: exiting ELPG
[ 79.187016] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 79.188474] tegra-xusb 3530000.xhci: exiting ELPG done
[ 82.003262] tegra-xusb 3530000.xhci: entering ELPG
[ 82.008339] tegra-xusb 3530000.xhci: entering ELPG done
[ 82.016917] tegra-xusb 3530000.xhci: exiting ELPG
[ 82.020903] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 82.022355] tegra-xusb 3530000.xhci: exiting ELPG done
[ 84.024415] tegra-xusb 3530000.xhci: entering ELPG
[ 84.029008] tegra-xusb 3530000.xhci: entering ELPG done
[ 84.038058] tegra-xusb 3530000.xhci: exiting ELPG
[ 84.042014] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 84.043458] tegra-xusb 3530000.xhci: exiting ELPG done
[ 86.045459] tegra-xusb 3530000.xhci: entering ELPG
[ 86.050119] tegra-xusb 3530000.xhci: entering ELPG done
[ 86.059102] tegra-xusb 3530000.xhci: exiting ELPG
[ 86.063058] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 86.064504] tegra-xusb 3530000.xhci: exiting ELPG done
[ 88.066553] tegra-xusb 3530000.xhci: entering ELPG
[ 88.075004] tegra-xusb 3530000.xhci: entering ELPG done
[ 88.080343] tegra-xusb 3530000.xhci: exiting ELPG
[ 88.086345] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 88.087787] tegra-xusb 3530000.xhci: exiting ELPG done
[ 90.091368] tegra-xusb 3530000.xhci: entering ELPG
[ 90.096273] tegra-xusb 3530000.xhci: entering ELPG done
[ 90.105229] tegra-xusb 3530000.xhci: exiting ELPG
[ 90.109218] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 90.110660] tegra-xusb 3530000.xhci: exiting ELPG done
[ 92.111853] tegra-xusb 3530000.xhci: entering ELPG
[ 92.116429] tegra-xusb 3530000.xhci: entering ELPG done
[ 92.125485] tegra-xusb 3530000.xhci: exiting ELPG
[ 92.129492] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 92.130937] tegra-xusb 3530000.xhci: exiting ELPG done
[ 94.132460] tegra-xusb 3530000.xhci: entering ELPG
[ 94.137194] tegra-xusb 3530000.xhci: entering ELPG done
[ 94.146113] tegra-xusb 3530000.xhci: exiting ELPG
[ 94.150074] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 94.151523] tegra-xusb 3530000.xhci: exiting ELPG done
[ 96.152994] tegra-xusb 3530000.xhci: entering ELPG
[ 96.157621] tegra-xusb 3530000.xhci: entering ELPG done
[ 96.166638] tegra-xusb 3530000.xhci: exiting ELPG
[ 96.170614] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 96.172061] tegra-xusb 3530000.xhci: exiting ELPG done
[ 98.173454] tegra-xusb 3530000.xhci: entering ELPG
[ 98.178092] tegra-xusb 3530000.xhci: entering ELPG done
[ 98.187333] tegra-xusb 3530000.xhci: exiting ELPG
[ 98.192660] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 98.194146] tegra-xusb 3530000.xhci: exiting ELPG done
[ 100.954533] tegra-xusb 3530000.xhci: entering ELPG
[ 100.965130] tegra-xusb 3530000.xhci: entering ELPG done
[ 100.972830] tegra-xusb 3530000.xhci: exiting ELPG
[ 100.978120] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 100.979700] tegra-xusb 3530000.xhci: exiting ELPG done
[ 102.982683] tegra-xusb 3530000.xhci: entering ELPG
[ 102.994525] tegra-xusb 3530000.xhci: entering ELPG done
[ 102.997454] tegra-xusb 3530000.xhci: exiting ELPG
[ 103.004875] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 103.007291] tegra-xusb 3530000.xhci: exiting ELPG done
[ 105.010947] tegra-xusb 3530000.xhci: entering ELPG
[ 105.026098] tegra-xusb 3530000.xhci: entering ELPG done
[ 105.026125] tegra-xusb 3530000.xhci: exiting ELPG
[ 105.030690] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 105.032222] tegra-xusb 3530000.xhci: exiting ELPG done
[ 107.035255] tegra-xusb 3530000.xhci: entering ELPG
[ 107.049720] tegra-xusb 3530000.xhci: entering ELPG done
[ 107.049765] tegra-xusb 3530000.xhci: exiting ELPG
[ 107.062452] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 107.063976] tegra-xusb 3530000.xhci: exiting ELPG done
[ 109.067449] tegra-xusb 3530000.xhci: entering ELPG
[ 109.079274] tegra-xusb 3530000.xhci: entering ELPG done
[ 109.082140] tegra-xusb 3530000.xhci: exiting ELPG
[ 109.088650] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 109.090143] tegra-xusb 3530000.xhci: exiting ELPG done
[ 111.091714] tegra-xusb 3530000.xhci: entering ELPG
[ 111.104985] tegra-xusb 3530000.xhci: entering ELPG done
[ 111.106057] tegra-xusb 3530000.xhci: exiting ELPG
[ 111.111308] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 111.113751] tegra-xusb 3530000.xhci: exiting ELPG done
[ 113.115801] tegra-xusb 3530000.xhci: entering ELPG
[ 113.127454] tegra-xusb 3530000.xhci: entering ELPG done
[ 113.130555] tegra-xusb 3530000.xhci: exiting ELPG
[ 113.137263] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 113.138728] tegra-xusb 3530000.xhci: exiting ELPG done
[ 115.140030] tegra-xusb 3530000.xhci: entering ELPG
[ 115.159944] tegra-xusb 3530000.xhci: entering ELPG done
[ 115.160057] tegra-xusb 3530000.xhci: exiting ELPG
[ 115.168954] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 115.171055] tegra-xusb 3530000.xhci: exiting ELPG done
[ 118.108252] tegra-xusb 3530000.xhci: entering ELPG
[ 118.121878] tegra-xusb 3530000.xhci: entering ELPG done
[ 118.122589] tegra-xusb 3530000.xhci: exiting ELPG
[ 118.127335] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 118.129693] tegra-xusb 3530000.xhci: exiting ELPG done
[ 120.132361] tegra-xusb 3530000.xhci: entering ELPG
[ 120.144696] tegra-xusb 3530000.xhci: entering ELPG done
[ 120.146998] tegra-xusb 3530000.xhci: exiting ELPG
[ 120.154364] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 120.156792] tegra-xusb 3530000.xhci: exiting ELPG done
[ 122.972489] tegra-xusb 3530000.xhci: entering ELPG
[ 122.986010] tegra-xusb 3530000.xhci: entering ELPG done
[ 122.986849] tegra-xusb 3530000.xhci: exiting ELPG
[ 122.992134] tegra-xusb 3530000.xhci: Firmware timestamp: 2019-07-08 19:32:42 UTC, Version: 55.15 release
[ 122.994548] tegra-xusb 3530000.xhci: exiting ELPG done
