michtw
1
On our Orin Nano custom carrier board, the USB 3.2 performance sucked.
The version of L4T is R35.5.
The USB 3.2 data transfer rate is only 38MB.
root@nx16:/mnt# ls -lh data
-rw-r--r-- 1 a a 2.0G 六 13 14:37 data
root@nx16:/mnt# pv data > /dev/null
2.00GiB 0:00:53 [38.4MiB/s] [================================>] 100%
/dev/sda1 on /mnt type ext4 (rw,relatime)
dmesg.txt (86.6 KB)
What is the performance of same ssd when tested on NV devkit?
michtw
4
According to the developer guide, there are several USB modes of USB 3.0.
How to check which USB mode the system is running?
https://docs.nvidia.com/jetson/archives/r35.5.0/DeveloperGuide/SO/JetsonOrinSeries.html
lsusb command will tell.
But performance things are more complicated… You could check lsusb first and also follow our previous suggestion…
michtw
6
The USB performance on NV devkit is normal.
Is the lsusb result shown on your board same as devkit result?
michtw
8
The root cause was the wrong device tree setting.
The USB2 port mapping property nvidia,usb2-companion of the usb3 was wrong.
After correcting it, we got USB 3 performance.
system
Closed
10
