USB 3.2 Hub
In Jetson documentation, connection to a USB 3.2 port is shown as below
If a USB hub IC was used instead, is the connection scheme flipped such that SS_RX lines from the Jetson connect to SS_TX lines on the hub IC and opposite? Is that what is explained in the table below
Lastly, can AC capacitors be added in series to both RX and TX lines or would that impede the DC levels needed on the RX side?
Hi, both questions depend on your hub requirements. Please refer to its data sheet for these. Basically, it should be TX to RX and RX to TX, and the AC caps are necessary if there is no one on the whole line.
