Hello here!
Device: Jetson NANO on the reComputer J1010 carrier board + ADATA SD600Q ssd
Task: setup system on the external USB SSD disk.
I’ve tried to increase memory for the system and attached external ssd. It works fine, but found that disk didn’t wake up after reboot (when still attached to USB, no matter what, 2 or 3 version). As a symptom - bright blue LED on the ssd is off and very weak red led inside ssd is wisible. Dist doesn’t appear in the lsusb, lsblk or fdisk commands output. After reattach usb cable all works perfectly.
Long story short, problem I found was in autosuspend feature.
[ 1.174896] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 1.174906] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 1.175045] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 1.175146] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 1.175151] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.175155] usb usb2: Product: xHCI Host Controller
[ 1.175159] usb usb2: Manufacturer: Linux 4.9.299-tegra xhci-hcd
[ 1.175162] usb usb2: SerialNumber: 70090000.xusb
[ 1.176405] usbcore: registered new interface driver uas
[ 1.176497] usbcore: registered new interface driver usb-storage
[ 1.176628] usbcore: registered new interface driver usbserial
[ 1.180537] tegra-xusb 70090000.xusb: Upgrade port 0 to USB3.0
[ 1.180547] tegra-xusb 70090000.xusb: Upgrade port 1 to USB3.0
[ 1.188701] usbcore: registered new interface driver xpad
[ 1.199180] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 1.279195] usb usb2: usb_suspend_both: status 0
I’ve resolved it with append the usbcore.autosuspend=-1 into linux boot command:
LABEL primary
MENU LABEL primary kernel
LINUX /boot/Image
INITRD /boot/initrd
APPEND ${cbootargs} quiet root=/dev/sda1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_b
oot_part_access=1 nv-auto-config usbcore.autosuspend=-1
tested after reboot:
$ cat /proc/cmdline | grep autos
tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,4 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 gpt tegra_fbmem=0x800000@0x92cb4000 is_hdmi_initialised=1 earlycon=uart8250,mmio32,0x70006000 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config quiet root=/dev/sda1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 sdhci_tegra.en_boot_part_access=1 nv-auto-config usbcore.autosuspend=-1
After that usb ssd drive still active during reboot and all was as expected. But after moving boot target to the ssd autosuspend returned, but only in case of soft reboot (sudo reboot). If I repower device - all works as expected and it perfectly boots from ssd…
Does anybody has any idea what is wrong?
Current state of disks
# lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINT
loop0 7:0 0 16M 1 loop
sda 8:0 0 223,6G 0 disk
└─sda1 8:1 0 223,6G 0 part /
mmcblk0 179:0 0 14,7G 0 disk
├─mmcblk0p1 179:1 0 14G 0 part /mnt/mmc-DG4016_0xe130e723-part1
├─mmcblk0p2 179:2 0 1M 0 part
├─mmcblk0p3 179:3 0 6M 0 part
├─mmcblk0p4 179:4 0 80K 0 part
├─mmcblk0p5 179:5 0 64M 0 part
├─mmcblk0p6 179:6 0 1M 0 part
├─mmcblk0p7 179:7 0 6M 0 part
├─mmcblk0p8 179:8 0 80K 0 part
├─mmcblk0p9 179:9 0 64M 0 part
├─mmcblk0p10 179:10 0 192K 0 part
├─mmcblk0p11 179:11 0 256K 0 part
├─mmcblk0p12 179:12 0 63M 0 part
├─mmcblk0p13 179:13 0 512K 0 part
├─mmcblk0p14 179:14 0 256K 0 part
├─mmcblk0p15 179:15 0 256K 0 part
├─mmcblk0p16 179:16 0 300M 0 part
└─mmcblk0p17 179:17 0 185,4M 0 part
mmcblk0boot0 179:32 0 4M 1 disk
mmcblk0boot1 179:64 0 4M 1 disk
mmcblk0rpmb 179:96 0 4M 0 disk
mmcblk1 179:128 0 29,4G 0 disk
└─mmcblk1p1 179:129 0 29,4G 0 part /mnt/mmc-USD00_0x636ab60d-part1
zram0 252:0 0 494,5M 0 disk [SWAP]
zram1 252:1 0 494,5M 0 disk [SWAP]
zram2 252:2 0 494,5M 0 disk [SWAP]
zram3 252:3 0 494,5M 0 disk [SWAP]
as you can see root is on the ssd.
Version of the linux used:
# uname -r
4.9.299-tegra
