USB boot problem
Hi
I have a problem with booting L4T from a USB memory stick.
When I just have the on board eMMC and the USB stick, everything is fine.
However, when I add a PCIe Solid State Disk into the system, L4T fails to boot because of block device enumeration order.
Here is a log of the problem :
U-Boot 2014.10-geip-mc10k1-rel1.0ear3-L4T-R21.4 -rc2 (Sep 24 2015 - 01:29:49)
TEGRA124
Board: GE MC10K1
I2C:   ready
DRAM:  2 GiB
MMC:   Tegra SD/MMC: 0, Tegra SD/MMC: 1
tegra-pcie: PCI regions:
tegra-pcie:   I/O: 0x12000000-0x12010000
tegra-pcie:   non-prefetchable memory: 0x13000000-0x20000000
tegra-pcie:   prefetchable memory: 0x20000000-0x40000000
tegra-pcie: 2x1, 1x1 configuration
tegra-pcie: probing port 0, using 2 lanes
tegra-pcie: probing port 1, using 1 lanes
In:    serial
Out:   serial
Err:   serial
Net:   e1000: 00:80:8e:04:11:5b
       e1000#0
Hit any key to stop autoboot:  2  1  0
(Re)start USB...
USB0:   USB EHCI 1.10
scanning bus 0 for devices... 2 USB Device(s) found
USB1:   USB EHCI 1.10
scanning bus 1 for devices... 5 USB Device(s) found
USB2:   USB EHCI 1.10
scanning bus 2 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
       scanning usb for ethernet devices... 0 Ethernet Device(s) found
USB device 0:
    Device 0: Vendor: SanDisk  Rev: 0001 Prod: Extreme
            Type: Removable Hard Disk
            Capacity: 29923.1 MB = 29.2 GB (61282631 x 512)
... is now current device
Scanning usb 0...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
791 bytes read in 618 ms (1000 Bytes/s)
GE MC10K1 USB boot options
1:	primary kernel
Enter choice: 1:	primary kernel
Retrieving file: /boot/zImage
5913720 bytes read in 490 ms (11.5 MiB/s)
append: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 scsi_mod.scan=async root=/dev/sda1 rw rootwait
Retrieving file: /boot/tegra124-mc10k1-pm375.dtb
57095 bytes read in 431 ms (128.9 KiB/s)
Kernel image @ 0x81000000 [ 0x000000 - 0x5a3c78 ]
## Flattened Device Tree blob at 82000000
   Booting using the fdt blob at 0x82000000
   Using Device Tree in place at 82000000, end 82010f06
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpu
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 3.10.40-geip-mc10k1-main-L4T-R21.3 (212461347@ES-GV8X73J) (gcc version 4.6.3 (Ubuntu/Linaro 4.6.3-1ubuntu5) ) #4 SMP PREEMPT Wed Jul 15 15:24:14 BST 2015
[    0.000000] CPU: ARMv7 Processor [413fc0f3] revision 3 (ARMv7), cr=10c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine: mc10k1, model: GE MC10K1 NVIDIA Tegra124 PM375, serial: 0
[    0.000000] Truncating memory at 0x80000000 to fit in 32-bit physical address space
[    0.000000] Found tsec, start=0xf4900000 size=2000000
[    0.000000] Tegra reserved memory:
[    0.000000] LP0:                    f46ff000 - f46ff80f
[    0.000000] Bootloader framebuffer: 00000000 - 00000000
[    0.000000] Bootloader framebuffer2: 00000000 - 00000000
[    0.000000] Framebuffer:            f8500000 - f96fffff
[    0.000000] 2nd Framebuffer:        f9700000 - fdefffff
[    0.000000] Carveout:               00000000 - 00000000
[    0.000000] Vpr:                    00000000 - 00000000
[    0.000000] Tsec:                   f4900000 - f68fffff
[    0.000000] cma: CMA: reserved 16 MiB at ae800000
[    0.000000] Memory policy: ECC disabled, Data cache writealloc
[    0.000000] DTS File Name: arch/arm/boot/dts/tegra124-mc10k1-pm375.dts
[    0.000000] Tegra12: CPU Speedo value 2241, Soc Speedo value 2184, Gpu Speedo value 2049
[    0.000000] Tegra12: CPU Speedo ID 5, Soc Speedo ID 0, Gpu Speedo ID 1
[    0.000000] Tegra12: CPU Process ID 0,Soc Process ID 1,Gpu Process ID 0
[    0.000000] Tegra Revision: A01 SKU: 0x87 CPU Process: 0 Core Process: 1
[    0.000000] tegra: PLLP fixed rate: 408000000
[    0.000000] tegra_clk_shared_bus_user_init: c2bus client se left ON
[    0.000000] tegra_clk_shared_bus_user_init: c4bus client vi left ON
[    0.000000] Lowering cpu_lp maximum rate from 1350000000 to 1044000000
[    0.000000] Lowering sbus maximum rate from 420000000 to 372000000
[    0.000000] Lowering vic03 maximum rate from 900000000 to 756000000
[    0.000000] Lowering tsec maximum rate from 900000000 to 756000000
[    0.000000] Lowering msenc maximum rate from 600000000 to 480000000
[    0.000000] Lowering se maximum rate from 600000000 to 480000000
[    0.000000] Lowering vde maximum rate from 600000000 to 480000000
[    0.000000] Lowering host1x maximum rate from 500000000 to 408000000
[    0.000000] Lowering vi maximum rate from 700000000 to 600000000
[    0.000000] Lowering isp maximum rate from 700000000 to 600000000
[    0.000000] Lowering c4bus maximum rate from 700000000 to 600000000
[    0.000000] Lowering pll_c maximum rate from 1400000000 to 1066000000
[    0.000000] Lowering pll_c2 maximum rate from 1200000000 to 1066000000
[    0.000000] Lowering pll_c3 maximum rate from 1200000000 to 1066000000
[    0.000000] Lowering hdmi maximum rate from 594000000 to 297000000
[    0.000000] Lowering sdmmc1 maximum rate from 208000000 to 204000000
[    0.000000] Lowering sdmmc3 maximum rate from 208000000 to 204000000
[    0.000000] Lowering gbus maximum rate from 1032000000 to 852000000
[    0.000000] Lowering cpu_g maximum rate from 3000000000 to 2218500000
[    0.000000] tegra dvfs: VDD_CPU nominal 1260mV, scaling enabled
[    0.000000] tegra dvfs: VDD_CORE nominal 1150mV, scaling enabled
[    0.000000] tegra dvfs: VDD_GPU nominal 1200mV, scaling enabled
[    0.000000] Switching to timer-based delay loop
[    0.000000] tegra_powergate_init: DONE
[    0.000000] tegra12_plle_clk_enable: pll_e is already enabled
[    0.000000] PERCPU: Embedded 9 pages/cpu @c1df2000 s15360 r8192 d13312 u36864
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 490768
[    0.000000] Kernel command line: console=ttyS0,115200n8 console=tty1 no_console_suspend=1 lp0_vec=2064@0xf46ff000 mem=2015M@2048M memtype=255 ddr_die=2048M@2048M section=256M pmuboard=0x0177:0x0000:0x02:0x43:0x00 tsec=32M@3913M otf_key=c75e5bb91eb3bd947560357b64422f85 usbcore.old_scheme_first=1 core_edp_mv=1150 core_edp_ma=4000 tegraid=40.1.1.0.0 debug_uartport=lsport,3 power_supply=Adapter audio_codec=rt5640 modem_id=0 android.kerneltype=normal fbcon=map:1 commchip_id=0 usb_port_owner_info=0 lane_owner_info=6 emc_max_dvfs=0 touch_id=0@0 board_info=0x0177:0x0000:0x02:0x43:0x00 scsi_mod.scan=async root=/dev/sda1 rw rootwait
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 1923MB = 1923MB total
[    0.000000] Memory: 1921000k/1921000k available, 142360k reserved, 1190908K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xf0000000 - 0xff000000   ( 240 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xef800000   ( 760 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc0ac20d4   (10985 kB)
[    0.000000]       .init : 0xc0ac3000 - 0xc0b41c00   ( 507 kB)
[    0.000000]       .data : 0xc0b42000 - 0xc0c83b18   (1287 kB)
[    0.000000]        .bss : 0xc0c83b18 - 0xc0d0d394   ( 551 kB)
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000] NR_IRQS:960
[    0.000000] the number of interrupt controllers found is 5
[    0.000000] Architected local timer running at 12.00MHz (phys).
[    0.000000] sched_clock: 56 bits at 12MHz, resolution 83ns, wraps every 2863311536128ns
[    0.000000] Ignoring duplicate/late registration of read_current_timer delay
[    0.000000] Console: colour dummy device 80x30
[    0.000000] console [tty1] enabled
[    0.003761] Calibrating delay loop (skipped), value calculated using timer frequency.. lpj=12000
[    0.003831] pid_max: default: 32768 minimum: 301
[    0.004145] Mount-cache hash table entries: 512
[    0.025584] Initializing cgroup subsys debug
[    0.025628] Initializing cgroup subsys freezer
[    0.025715] CPU: Testing write buffer coherency: ok
[    0.025811] ftrace: allocating 33277 entries in 65 pages
[    0.068305] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.068350] Setting up static identity map for 0xc07bb1d8 - 0xc07bb274
[    0.072330] ftrace: Allocated trace_printk buffers
[    0.079986] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.083005] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[    0.086040] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[    0.086229] Brought up 4 CPUs
[    0.086294] SMP: Total of 4 processors activated.
[    0.086312] CPU: All CPU(s) started in SVC mode.
[    0.087305] devtmpfs: initialized
[    0.095762] pinctrl core: initialized pinctrl subsystem
[    0.096104] regulator-dummy: no parameters
[    0.096844] NET: Registered protocol family 16
[    0.099140] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.100443] tegra_smmu tegra_smmu: Loaded Tegra IOMMU driver
[    0.101481] console [pstore-1] enabled
[    0.101522] ramoops: attached 0x200000@0xf8300000, ecc: 0/0
[    0.101890] cpuidle: using governor ladder
[    0.101913] cpuidle: using governor menu
[    0.105594] ardbeg_camera_auxdata: update camera lookup table.
[    0.114113] tegra-gpio 6000d000.gpio: Initialising GPIO state 0: name default
[    0.114505] gpiochip_add: registered GPIOs 0 to 255 on device: tegra-gpio
[    0.121220] Wake16 for irq=34
[    0.123645] Wake58 for irq=81
[    0.123712] Wake41 for irq=129
[    0.123732] Wake43 for irq=129
[    0.123778] Wake40 for irq=53
[    0.123796] Wake42 for irq=53
[    0.128119] board_info: id:sku:fab:major:minor = 0x0177:0x100a:0x0f:0x04:0x01
[    0.128203] board_info: id:sku:fab:major:minor = 0x0177:0x100a:0x0f:0x04:0x01
[    0.128228] Board Type: MC10K1A
[    0.128243] GE Tracking version: $Change$
[    0.128330] Selecting UARTD as the debug console
[    0.128373] The debug console clock name is uartd
[    0.128524] MC10K1A: Override portmap: 0x201
[    0.128545] MC10K1A: xHCI: SS0 & USB2 P1 Enabled
[    0.128857] ardbeg_modem_init: modem_id = 0
[    0.131158] Clear bootloader IO dpd settings
[    0.131390] Loading GE MC10K1 Rev4 EMC tables.
[    0.131637] tegra: pll_m is selected as scalable EMC clock source
[    0.131683] Lowering emc maximum rate from 1200000000 to 792000000
[    0.131713] tegra: validated EMC DFS table
[    0.131858] ardbeg_edp_init: CPU regulator 11000 mA
[    0.436038] ardbeg_edp_init: GPU regulator 10500 mA
[    0.437050] swapper/0 isomgr_init(): iso emc max clk=792000KHz
[    0.437073] swapper/0 isomgr_init(): max_iso_bw=6336000KB[    0.437434] ardbeg_touch_init init raydium touch
[    0.437581] Raydium - touch platform_id :  8
[    0.527241] platform tegradc.0: IOVA linear map 0xf8500000(1200000)
[    0.530164] platform tegradc.0: IOVA linear map 0xf9700000(4800000)
[    0.534608] platform tegradc.1: IOVA linear map 0xf8500000(1200000)
[    0.537527] platform tegradc.1: IOVA linear map 0xf9700000(4800000)
[    0.538042] tegra11_soctherem_oc_int_init(): OC interrupts are not enabled
[    0.538447] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.538479] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.538796] mc-err: Started MC error interface!
[    0.549040] bio: create slab <bio-0> at 0
[    0.550921] reg-fixed-voltage 0.regulator: Consumer c1 does not have device name
[    0.550958] reg-fixed-voltage 0.regulator: Consumer c2 does not have device name
[    0.551090] vdd-ac-bat: 8400 mV
[    0.551227] reg-fixed-voltage 1.regulator: Consumer c1 does not have device name
[    0.551263] reg-fixed-voltage 1.regulator: Consumer c2 does not have device name
[    0.551390] vdd-3v3-aon: 3300 mV
[    0.551546] reg-fixed-voltage 8.regulator: Consumer c1 does not have device name
[    0.551581] reg-fixed-voltage 8.regulator: Consumer c2 does not have device name
[    0.551615] reg-fixed-voltage 8.regulator: Consumer c3 does not have device name
[    0.551653] reg-fixed-voltage 8.regulator: Consumer c6 does not have device name
[    0.551685] reg-fixed-voltage 8.regulator: Consumer c7 does not have device name
[    0.551716] reg-fixed-voltage 8.regulator: Consumer c8 does not have device name
[    0.551747] reg-fixed-voltage 8.regulator: Consumer c9 does not have device name
[    0.551779] reg-fixed-voltage 8.regulator: Consumer c10 does not have device name
[    0.551811] reg-fixed-voltage 8.regulator: Consumer c11 does not have device name
[    0.551843] reg-fixed-voltage 8.regulator: Consumer c12 does not have device name
[    0.551993] reg-3v3-supply: 3300 mV
[    0.553570] vgaarb: loaded
[    0.554172] SCSI subsystem initialized
[    0.554560] usbcore: registered new interface driver usbfs
[    0.554626] usbcore: registered new interface driver hub
[    0.554735] usbcore: registered new device driver usb
[    0.557521] as3722 4-0040: AS3722 ID: ID1:ID2:ID3 = 0x0c:0x01:0x15
[    0.557552] as3722 4-0040: Final OTP version 1V21
[    0.562523] gpiochip_add: registered GPIOs 1016 to 1023 on device: as3722-gpio
[    0.562726] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.562786] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.562838] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.562872] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.562905] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.562938] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.562995] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.563028] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.563082] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.563117] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.563150] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[    0.563182] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[    0.563215] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[    0.563280] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.563313] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.563345] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.563377] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.563412] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[    0.563447] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.563479] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.563512] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[    0.563545] as3722-regulator as3722-regulator.0: Consumer c11 does not have device name
[    0.563578] as3722-regulator as3722-regulator.0: Consumer c12 does not have device name
[    0.563610] as3722-regulator as3722-regulator.0: Consumer c13 does not have device name
[    0.563642] as3722-regulator as3722-regulator.0: Consumer c14 does not have device name
[    0.563674] as3722-regulator as3722-regulator.0: Consumer c15 does not have device name
[    0.563730] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.563762] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.563815] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.563848] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.563880] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.563912] as3722-regulator as3722-regulator.0: Consumer c4 does not have device name
[    0.563944] as3722-regulator as3722-regulator.0: Consumer c5 does not have device name
[    0.563976] as3722-regulator as3722-regulator.0: Consumer c6 does not have device name
[    0.564008] as3722-regulator as3722-regulator.0: Consumer c7 does not have device name
[    0.564040] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.564090] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.564150] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.564183] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.564273] as3722-regulator as3722-regulator.0: Consumer c8 does not have device name
[    0.564305] as3722-regulator as3722-regulator.0: Consumer c9 does not have device name
[    0.564337] as3722-regulator as3722-regulator.0: Consumer c10 does not have device name
[    0.564390] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.564441] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.564474] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.564506] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.564559] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.564591] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.564647] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.564696] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.564729] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.564808] as3722-regulator as3722-regulator.0: Consumer c1 does not have device name
[    0.564842] as3722-regulator as3722-regulator.0: Consumer c2 does not have device name
[    0.564874] as3722-regulator as3722-regulator.0: Consumer c3 does not have device name
[    0.565784] vdd-cpu: 650 <--> 1300 mV at 1000 mV 3500 mA
[    0.566538] vdd-core: applied init 1000000uV constraint
[    0.567140] vdd-core: 700 <--> 1350 mV at 1000 mV 3500 mA
[    0.568330] vddio-ddr: at 1350 mV
[    0.568657] as3722-sd3: no parameters
[    0.569238] avdd-pll-pex: 1050 mV
[    0.570427] vdd-1v8: at 1800 mV
[    0.570758] vdd-gpu: applied init 1000000uV constraint
[    0.571636] vdd-gpu: 650 <--> 1200 mV at 1000 mV 3500 mA
[    0.572140] avdd-pll: at 1050 mV at 300 mA
[    0.573412] vdd-cam: 1800 mV at 150 mA
[    0.574079] avdd-dsi-csi: at 1200 mV at 150 mA
[    0.575322] vdd-rtc: 800 mV at 150 mA
[    0.575795] avdd-cam: 2800 mV at 150 mA
[    0.576287] vdd-1v2-cam: 1175 mV at 150 mA
[    0.576651] vddio-sdmmc-2: 1800 <--> 3300 mV at 150 mA
[    0.577145] vdd-1v1-cam: 1275 mV at 150 mA
[    0.578114] avdd-spi: 3300 mV at 150 mA
[    0.578628] vdd-2v7-cam: 2800 mV at 150 mA
[    0.579126] vpp-fuse: 1800 mV at 150 mA
[    0.580237] Linux video capture interface: v2.00
[    0.580311] pps_core: LinuxPPS API ver. 1 registered
[    0.580334] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.580378] PTP clock support registered
[    0.581401] Advanced Linux Sound Architecture Driver Initialized.
[    0.582144] usb0-vbus: 5000 mV
[    0.582471] usb1-usb2-vbus: 5000 mV
[    0.582756] vdd-hdmi: 5000 mV
[    0.583040] avdd-hdmi-pll: 3300 mV
[    0.583090] avdd-hdmi-pll: supplied by avdd-pll-pex
[    0.583260] reg-fixed-sync-voltage 6.regulator: Consumer c1 does not have device name
[    0.583423] vdd-lcd-bl: 3300 mV
[    0.583597] reg-fixed-sync-voltage 7.regulator: Consumer c1 does not have device name
[    0.583756] vdd-lcd-bl-en: 5000 mV
[    0.583906] reg-fixed-sync-voltage 9.regulator: Consumer c3 does not have device name
[    0.584037] reg-5v0-supply: 5000 mV
[    0.584200] reg-fixed-sync-voltage a.regulator: Consumer c1 does not have device name
[    0.584236] reg-fixed-sync-voltage a.regulator: Consumer c2 does not have device name
[    0.584269] reg-fixed-sync-voltage a.regulator: Consumer c3 does not have device name
[    0.584336] reg-fixed-sync-voltage a.regulator: Consumer c10 does not have device name
[    0.584370] reg-fixed-sync-voltage a.regulator: Consumer c11 does not have device name
[    0.584403] reg-fixed-sync-voltage a.regulator: Consumer c12 does not have device name
[    0.584436] reg-fixed-sync-voltage a.regulator: Consumer c13 does not have device name
[    0.584468] reg-fixed-sync-voltage a.regulator: Consumer c14 does not have device name
[    0.584500] reg-fixed-sync-voltage a.regulator: Consumer c15 does not have device name
[    0.584647] reg-1v8-supply: 1800 mV
[    0.584937] reg-fixed-sync-voltage b.regulator: Consumer c1 does not have device name
[    0.585094] reg-dcdc-1v2: 1200 mV
[    0.585273] reg-fixed-sync-voltage c.regulator: Consumer c7 does not have device name
[    0.585307] reg-fixed-sync-voltage c.regulator: Consumer c8 does not have device name
[    0.585891] as3722-gpio2-supply: 3300 mV
[    0.586097] reg-fixed-sync-voltage d.regulator: Consumer c1 does not have device name
[    0.586608] as3722-gpio4-supply: 3300 mV
[    0.586898] sdmmc-en-supply: 3300 mV
[    0.587149] vdd-cdc-1v2-aud: 1200 mV
[    0.587310] reg-fixed-sync-voltage 10.regulator: Consumer c1 does not have device name
[    0.587346] reg-fixed-sync-voltage 10.regulator: Consumer c2 does not have device name
[    0.587397] reg-fixed-sync-voltage 10.regulator: Consumer c3 does not have device name
[    0.587524] reg-aon-1v8: 1800 mV
[    0.587682] reg-fixed-sync-voltage 11.regulator: Consumer c1 does not have device name
[    0.587809] reg-aon-1v2: 1200 mV
[    0.590795] as3722-adc-extcon as3722-adc-extcon.2: USB-Host is connected
[    0.594093] tegra: started io power detection dynamic control
[    0.594120] tegra: NO_IO_POWER setting 0x0
[    0.594146] Switching to clocksource arch_sys_counter
[    0.614940] nvmap_heap_init: nvmap_heap_init: created heap block cache
[    0.615130] nvmap_page_pool_init: Total MB RAM: 1891
[    0.615154] nvmap_page_pool_init: nvmap page pool size: 60512 pages (236 MB)
[    0.705378] nvmap_page_pool_init: highmem=25600, pool_size=60512,totalram=484346, freeram=455650, totalhigh=297727, freehigh=272057
[    0.706124]  iram: dma coherent mem declare 0x40001000,258048
[    0.706939] misc nvmap: created heap iram base 0x40001000 size (252KiB)
[    0.707092] nvmap:inner cache maint threshold=2097152
[    0.716714] Wake39 for irq=52
[    0.716805] tegra-otg tegra-otg: otg transceiver registered
[    0.717151] NET: Registered protocol family 2
[    0.717865] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    0.718069] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.718291] TCP: Hash tables configured (established 8192 bind 8192)
[    0.718354] TCP: reno registered
[    0.718380] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.718437] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.718770] NET: Registered protocol family 1
[    0.719161] RPC: Registered named UNIX socket transport module.
[    0.719187] RPC: Registered udp transport module.
[    0.719226] RPC: Registered tcp transport module.
[    0.719248] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.719534] tegra-fuse tegra-fuse: Fuse driver initialized succesfully
[    0.724631] host1x host1x: initialized
[    0.725807] CPU PMU: probing PMU on CPU 0
[    0.725842] hw perfevents: enabled with ARMv7 Cortex-A15 PMU driver, 7 counters available
[    0.726484] tegra_throttle : init passed
[    0.726588] Tegra cpuquiet initialized: disabled
[    0.726728] cpu-tegra: init EDP limit: 2218 MHz
[    0.727753] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type CPU-therm
[    0.728133] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type GPU-therm
[    0.728380] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type MEM-therm
[    0.728614] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[    0.730129] bounce pool size: 64 pages
[    0.731548] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    0.731827] NTFS driver 2.1.30 [Flags: R/O].
[    0.731980] fuse init (API version 7.22)
[    0.732231] msgmni has been set to 1457
[    0.733795] io scheduler noop registered (default)
[    0.752167] PCI host bridge to bus 0000:00
[    0.752197] pci_bus 0000:00: root bus resource [mem 0x32100000-0x3fffffff]
[    0.752246] pci_bus 0000:00: root bus resource [mem 0x12100000-0x320fffff pref]
[    0.752278] pci_bus 0000:00: root bus resource [io  0x1000-0xffff]
[    0.752306] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[    0.752683] PCI: bus0: Fast back to back transfers disabled
[    0.752714] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.755262] PCI: bus1: Fast back to back transfers disabled
[    0.755624] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    0.755654] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    0.755968] PCI host bridge to bus 0000:02
[    0.755996] pci_bus 0000:02: root bus resource [mem 0x32100000-0x3fffffff]
[    0.756024] pci_bus 0000:02: root bus resource [mem 0x12100000-0x320fffff pref]
[    0.756055] pci_bus 0000:02: root bus resource [io  0x10000-0x1ffff]
[    0.756082] pci_bus 0000:02: No busn resource found for root bus, will use [bus 02-ff]
[    0.756477] PCI: bus2: Fast back to back transfers disabled
[    0.756506] pci 0000:02:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[    0.759263] PCI: bus3: Fast back to back transfers disabled
[    0.759559] pcieport 0000:02:00.0: Signaling PME through PCIe PME interrupt
[    0.759590] pci 0000:03:00.0: Signaling PME through PCIe PME interrupt
[    0.759855] pcieport 0000:02:00.0: BAR 8: assigned [mem 0x32100000-0x322fffff]
[    0.759890] pcieport 0000:02:00.0: BAR 9: assigned [mem 0x12100000-0x121fffff pref]
[    0.759924] pcieport 0000:02:00.0: BAR 7: assigned [io  0x10000-0x10fff]
[    0.759957] pci 0000:03:00.0: BAR 0: assigned [mem 0x32100000-0x321fffff]
[    0.759993] pci 0000:03:00.0: BAR 6: assigned [mem 0x12100000-0x121fffff pref]
[    0.760026] pci 0000:03:00.0: BAR 3: assigned [mem 0x32200000-0x32203fff]
[    0.760059] pci 0000:03:00.0: BAR 2: assigned [io  0x10000-0x1001f]
[    0.760092] pcieport 0000:02:00.0: PCI bridge to [bus 03]
[    0.760119] pcieport 0000:02:00.0:   bridge window [io  0x10000-0x10fff]
[    0.760150] pcieport 0000:02:00.0:   bridge window [mem 0x32100000-0x322fffff]
[    0.760182] pcieport 0000:02:00.0:   bridge window [mem 0x12100000-0x121fffff pref]
[    0.760250] pcieport 0000:00:00.0: BAR 8: assigned [mem 0x32300000-0x323fffff]
[    0.760284] pcieport 0000:00:00.0: BAR 9: assigned [mem 0x12200000-0x122fffff pref]
[    0.760317] pcieport 0000:00:00.0: BAR 7: assigned [io  0x1000-0x1fff]
[    0.760350] pci 0000:01:00.0: BAR 6: assigned [mem 0x12200000-0x1221ffff pref]
[    0.760386] pci 0000:01:00.0: BAR 5: assigned [mem 0x32300000-0x323001ff]
[    0.760419] pci 0000:01:00.0: BAR 4: assigned [io  0x1000-0x101f]
[    0.760451] pci 0000:01:00.0: BAR 0: assigned [io  0x1020-0x1027]
[    0.760483] pci 0000:01:00.0: BAR 2: assigned [io  0x1028-0x102f]
[    0.760514] pci 0000:01:00.0: BAR 1: assigned [io  0x1030-0x1033]
[    0.760546] pci 0000:01:00.0: BAR 3: assigned [io  0x1034-0x1037]
[    0.760578] pcieport 0000:00:00.0: PCI bridge to [bus 01]
[    0.760605] pcieport 0000:00:00.0:   bridge window [io  0x1000-0x1fff]
[    0.760635] pcieport 0000:00:00.0:   bridge window [mem 0x32300000-0x323fffff]
[    0.760666] pcieport 0000:00:00.0:   bridge window [mem 0x12200000-0x122fffff pref]
[    0.761333] pwm-backlight pwm-backlight: unable to request PWM, trying legacy API
[    0.761442] sysedp_create_consumer: unable to create pwm-backlight, no consumer_data for pwm-backlight found
[    0.762258] tsec tsec: initialized
[    0.763741] isp isp.0: initialized
[    0.764708] isp isp.1: initialized
[    0.766256] falcon vic03.0: initialized
[    0.767496] falcon msenc: initialized
[    0.768326] tegradc tegradc.0: DSI: HS clock rate is 464500
[    0.769704] p,wuxga-10-1 panel dt support not available
[    1.048798] tegradc tegradc.0: nominal-pclk:154700000 parent:154500000 div:1.0 pclk:154500000 153153000~168623000
[    1.137381] tegradc tegradc.0: DSI pad calibration done
[    1.144516] tegradc tegradc.0: probed
[    1.145005] tegradc tegradc.0: fb registered
[    1.145027] tegradc tegradc.0: nominal-pclk:154679000 parent:463500000 div:3.0 pclk:154500000 153132210~168600110
[    1.150912] gpio wake4 for gpio=111
[    1.165639] tegradc tegradc.1: nominal-pclk:108003000 parent:216000000 div:2.0 pclk:108000000 106922970~117723270
[    1.166941] tegradc tegradc.1: probed
[    1.168003] tegradc tegradc.1: Display timing doesn't meet restrictions.
[    1.168034] tegradc tegradc.1: can't configure dc with mode 1280x1024
[    1.168379] tegradc tegradc.1: Display timing doesn't meet restrictions.
[    1.168386] tegradc tegradc.1: can't configure dc with mode 1280x1024
[    1.168390] fbcon_init: detected unhandled fb_set_par error, error code -22
[    1.180920] Console: switching to colour frame buffer device 160x64
[    1.193239] tegradc tegradc.1: fb registered
[    1.193351] hdmi_state_machine_worker (tid edb06580): state 7 (Takeover from bootloader), hpd 1, pending_hpd_evt 1
[    1.193528] hdmi_state_machine_set_state_l: switching from state 7 (Takeover from bootloader) to state 1 (Check Plug)
[    1.196714] tegra-apbdma tegra-apbdma: Tegra20 APB DMA driver register 32 channels
[    1.197550] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    1.198912] serial8250.0: ttyS0 at MMIO 0x70006300 (irq = 122) is a Tegra
[    1.234984] hdmi_state_machine_worker (tid edb06580): state 1 (Check Plug), hpd 1, pending_hpd_evt 0
[    1.234991] hdmi_state_machine_set_state_l: switching from state 1 (Check Plug) to state 2 (Check EDID)
[    1.307048] hdmi_state_machine_worker (tid edb06580): state 2 (Check EDID), hpd 1, pending_hpd_evt 0
[    1.332371] panel size 38 by 30
[    3.708703] console [ttyS0] enabled
[    3.708824] tegradc tegradc.1: nominal-pclk:108003000 parent:216000000 div:2.0 pclk:108000000 106922970~117723270
[    3.709372] serial-tegra.0: ttyTHS0 at MMIO 0x70006000 (irq = 68) is a SERIAL_TEGRA
[    3.709695] serial-tegra.1: ttyTHS1 at MMIO 0x70006040 (irq = 69) is a SERIAL_TEGRA
[    3.709999] serial-tegra.2: ttyTHS2 at MMIO 0x70006200 (irq = 78) is a SERIAL_TEGRA
[    3.712148]  (null): coherent DMA mask is unset
[    3.712159] gk20a gk20a.0: failed to allocate secure buffer -12
[    3.715996] loop: module loaded
[    3.716317] nct1008_nct72 0-004c: success in enabling rail vdd_nct72
[    3.716416] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x4c
[    3.716512] nct1008_nct72 0-004c: nct1008_read_reg: err -121
[    3.716518] NCT72: ERR: remote sensor circuit is open (0xffffff87)
[    3.716608] tegra-i2c tegra12-i2c.0: no acknowledge from address 0x4c
[    3.716693] nct1008_nct72 0-004c: nct1008_write_reg: err -121
[    3.716700] nct1008_nct72 0-004c:
[    3.716700]  exit nct1008_configure_sensor, err=-121
[    3.716709] nct1008_nct72 0-004c:
[    3.716709]  error file: /home/212461347/mc10k1/Linux_for_Tegra/kernel/drivers/misc/nct1008.c : nct1008_probe(), line=1453
[    3.716715] nct1008_nct72 0-004c:
[    3.716715]  exit nct1008_probe, err=-121
[    3.716724] nct1008_nct72 0-004c: success in disabling rail vdd_nct72
[    3.716801] nct1008_nct72: probe of 0-004c failed with error -121
[    3.717353] tegra_profiler: Branch: Dev
[    3.717356] tegra_profiler: Version: 1.88
[    3.717359] tegra_profiler: Samples version: 31
[    3.717362] tegra_profiler: IO version: 16
[    3.717369] armv7_pmu: arch: Cortex A15, type: 4, ver: 0
[    3.717408] tegra_profiler: power_clk: init
[    3.717548] tegra_profiler: auth: init
[    3.717920] GPS: mt3332_gps_mod_init: platform_driver_register ret = 0
[    3.729345] ahci 0000:01:00.0: AHCI 0001.0000 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    3.729357] ahci 0000:01:00.0: flags: 64bit ncq sntf led pio slum part
[    3.732784] tegradc tegradc.1: nominal-pclk:108003000 parent:216000000 div:2.0 pclk:108000000 106922970~117723270
[    3.991953] handle_check_edid_l: audio_switch 1
[    4.001119] Display connected, hpd_switch 1
[    4.009950] handle_check_edid_l: setting audio and infoframes
[    4.020458] hdmi_state_machine_set_state_l: switching from state 2 (Check EDID) to state 4 (Enabled)
[    4.034545] hdmi_state_machine_worker (tid edb06580): state 4 (Enabled), hpd 1, pending_hpd_evt 0
[    4.049133] scsi0 : ahci
[    4.049475] ata1: SATA max UDMA/133 abar m512@0x32300000 port 0x32300100 irq 642
[    4.050458] tegra-sata tegra-sata.0: AHCI 0001.0301 32 slots 2 ports 3 Gbps 0x1 impl TEGRA-SATA mode
[    4.050469] tegra-sata tegra-sata.0: flags: 64bit ncq sntf pm led pmp pio slum part sadm apst
[    4.051736] scsi1 : tegra-sata
[    4.052066] scsi2 : tegra-sata
[    4.052325] ata2: SATA max UDMA/133 irq 55
[    4.052329] ata3: DUMMY
[    4.054377] tun: Universal TUN/TAP device driver, 1.6
[    4.054380] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[    4.054572] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.0.3-k
[    4.054575] igb: Copyright (c) 2007-2013 Intel Corporation.
[    4.084400] igb 0000:03:00.0: added PHC on eth0
[    4.084406] igb 0000:03:00.0: Intel(R) Gigabit Ethernet Network Connection
[    4.084414] igb 0000:03:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 00:80:8e:04:11:5b
[    4.084466] igb 0000:03:00.0: eth0: PBA No: 101100-000
[    4.084474] igb 0000:03:00.0: Using MSI-X interrupts. 4 rx queue(s), 4 tx queue(s)
[    4.084662] usbcore: registered new interface driver asix
[    4.084709] usbcore: registered new interface driver ax88179_178a
[    4.084746] usbcore: registered new interface driver cdc_ether
[    4.084803] usbcore: registered new interface driver smsc95xx
[    4.084841] usbcore: registered new interface driver cdc_subset
[    4.084906] usbcore: registered new interface driver cdc_ncm
[    4.084925] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    4.085155] tegra USB phy - inst[1] platform info:
[    4.085159] port_otg: no
[    4.085162] has_hostpc: yes
[    4.085165] phy_interface: USB_PHY_INTF_UTMI
[    4.085168] op_mode: TEGRA_USB_OPMODE_HOST
[    4.085171] qc2_voltage: 0
[    4.085174] vbus_gpio: -1
[    4.085177] hot_plug: disabled
[    4.085179] remote_wakeup: enabled
[    4.086729] tegra-ehci tegra-ehci.1: Tegra EHCI Host Controller
[    4.086757] tegra-ehci tegra-ehci.1: new USB bus registered, assigned bus number 1
[    4.086848] Wake40 for irq=53
[    4.086851] Wake42 for irq=53
[    4.086875] tegra-ehci tegra-ehci.1: irq 53, io mem 0x7d004000
[    4.090249] tegra-ehci tegra-ehci.1: USB 2.0 started, EHCI 1.10
[    4.090337] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    4.090346] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.090352] usb usb1: Product: Tegra EHCI Host Controller
[    4.090358] usb usb1: Manufacturer: Linux 3.10.40-geip-mc10k1-main-L4T-R21.3 ehci_hcd
[    4.090364] usb usb1: SerialNumber: tegra-ehci.1
[    4.090879] hub 1-0:1.0: USB hub found
[    4.090898] hub 1-0:1.0: 1 port detected
[    4.091261] tegra USB phy - inst[2] platform info:
[    4.091263] port_otg: no
[    4.091266] has_hostpc: yes
[    4.091269] phy_interface: USB_PHY_INTF_UTMI
[    4.091271] op_mode: TEGRA_USB_OPMODE_HOST
[    4.091274] qc2_voltage: 0
[    4.091276] vbus_gpio: -1
[    4.091279] hot_plug: disabled
[    4.091281] remote_wakeup: enabled
[    4.092707] tegra-ehci tegra-ehci.2: Tegra EHCI Host Controller
[    4.092730] tegra-ehci tegra-ehci.2: new USB bus registered, assigned bus number 2
[    4.092822] Wake41 for irq=129
[    4.092825] Wake43 for irq=129
[    4.092847] tegra-ehci tegra-ehci.2: irq 129, io mem 0x7d008000
[    4.096253] tegra-ehci tegra-ehci.2: USB 2.0 started, EHCI 1.10
[    4.096336] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    4.096344] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    4.096351] usb usb2: Product: Tegra EHCI Host Controller
[    4.096357] usb usb2: Manufacturer: Linux 3.10.40-geip-mc10k1-main-L4T-R21.3 ehci_hcd
[    4.096363] usb usb2: SerialNumber: tegra-ehci.2
[    4.096892] hub 2-0:1.0: USB hub found
[    4.096910] hub 2-0:1.0: 1 port detected
[    4.097307] ehci-pci: EHCI PCI platform driver
[    4.097587] tegra_xusb_read_usb_calib: usb_calib0 = 0x02c5838a
[    4.098647] tegra-xhci tegra-xhci: XUSB device id = 0xfa3 (T124+)
[    4.099226] tegra-xhci tegra-xhci: 131072 bytes log buffer physical 0x2147614720 virtual 0xf008c000
[    4.100839] usbcore: registered new interface driver usb-storage
[    4.100953] usbcore: registered new interface driver usbserial
[    4.100993] usbcore: registered new interface driver option
[    4.101028] usbserial: USB Serial support registered for GSM modem (1-port)
[    4.101141] usbcore: registered new interface driver pl2303
[    4.101173] usbserial: USB Serial support registered for pl2303
[    4.101185] Nvidia Tegra High-Speed USB Device Controller driver (Apr 30, 2012)
[    4.101359] tegra USB phy - inst[0] platform info:
[    4.101362] port_otg: yes
[    4.101364] has_hostpc: yes
[    4.101367] phy_interface: USB_PHY_INTF_UTMI
[    4.101369] op_mode: TEGRA_USB_OPMODE_DEVICE
[    4.101372] qc2_voltage: 0
[    4.101374] vbus_pmu_irq: 0
[    4.101376] vbus_gpio: -1
[    4.101379] charging: enabled
[    4.101381] remote_wakeup: disabled
[    4.104175] tegra-udc tegra-udc.0: usb_bat_chg regulator not registered: USB charging will not be enabled
[    4.142358] as3722-rtc as3722-rtc.1: rtc core: registered as3722 as rtc0
[    4.142366] as3722-rtc as3722-rtc.1: RTC interrupt 449
[    4.252611] i2c /dev entries driver
[    4.253843] tegra_dtv_probe: probing dtv.
[    4.254285] setup_stream: bufsize = 4096, bufnum = 4
[    4.254286] usbcore: registered new interface driver uvcvideo
[    4.254288] USB Video Class driver (1.1.1)
[    4.255142] zram: Created 1 device(s) ...
[    4.255236] otg state changed: SUSPEND --> HOST
[    4.255506] tegra USB phy - inst[0] platform info:
[    4.255509] port_otg: yes
[    4.255512] has_hostpc: yes
[    4.255515] phy_interface: USB_PHY_INTF_UTMI
[    4.255517] op_mode: TEGRA_USB_OPMODE_HOST
[    4.255520] qc2_voltage: 0
[    4.255522] vbus_gpio: -1
[    4.255525] hot_plug: disabled
[    4.255528] remote_wakeup: enabled
[    4.256961] sdhci: Secure Digital Host Controller Interface driver
[    4.256964] sdhci: Copyright(c) Pierre Ossman
[    4.256967] sdhci-pltfm: SDHCI platform and OF driver helper
[    4.257331] sdhci-tegra sdhci-tegra.3: vddio_sd_slot regulator not found: -517. Assuming vddio_sd_slot is not required.
[    4.257484] sdhci-tegra sdhci-tegra.3: Speedo value 2184
[    4.257493] sdhci-tegra sdhci-tegra.3: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[    4.358267] ata2: SATA link down (SStatus 0 SControl 300)
[    4.358364] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.376548] ata1.00: ATA-8: PLEXTOR PX-AG128M6e, 1.04, max UDMA/133
[    4.376556] ata1.00: 250069680 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[    4.398266] usb 2-1: new full-speed USB device number 2 using tegra-ehci
[    4.413175] ata1.00: configured for UDMA/133
[    4.413532] scsi 0:0:0:0: Direct-Access     ATA      PLEXTOR PX-AG128 1.04 PQ: 0 ANSI: 5
[    4.414161] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    4.414279] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[    4.414697] sd 0:0:0:0: [sda] Write Protect is off
[    4.414835] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.420269]  sda: unknown partition table
[    4.421160] sd 0:0:0:0: [sda] Attached SCSI disk
[    4.483971] usb 2-1: New USB device found, idVendor=0451, idProduct=2046
[    4.483980] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.492747] hub 2-1:1.0: USB hub found
[    4.500373] hub 2-1:1.0: 4 ports detected
[    4.866864] usb 2-1.2: new full-speed USB device number 3 using tegra-ehci
[    4.932098] usb 2-1.2: not running at top speed; connect to a high speed hub
[    4.964382] usb 2-1.2: New USB device found, idVendor=413c, idProduct=1010
[    4.964391] usb 2-1.2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    4.964397] usb 2-1.2: Product: USB 2.0 Hub [MTT]
[    4.970814] hub 2-1.2:1.0: USB hub found
[    4.977138] hub 2-1.2:1.0: 4 ports detected
[    5.257453] tegra-ehci tegra-ehci.0: Tegra EHCI Host Controller
[    5.257477] tegra-ehci tegra-ehci.0: new USB bus registered, assigned bus number 3
[    5.257609] tegra-ehci tegra-ehci.0: irq 52, io mem 0x7d000000
[    5.263255] tegra-ehci tegra-ehci.0: USB 2.0 started, EHCI 1.10
[    5.263345] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002
[    5.263353] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.263360] usb usb3: Product: Tegra EHCI Host Controller
[    5.263366] usb usb3: Manufacturer: Linux 3.10.40-geip-mc10k1-main-L4T-R21.3 ehci_hcd
[    5.263372] usb usb3: SerialNumber: tegra-ehci.0
[    5.263917] hub 3-0:1.0: USB hub found
[    5.263936] hub 3-0:1.0: 1 port detected
[    5.373178] usb 2-1.2.1: new low-speed USB device number 4 using tegra-ehci
[    5.442677] mmc0: no vqmmc regulator found
[    5.444914] usb 2-1.2.1: New USB device found, idVendor=0458, idProduct=003a
[    5.444922] usb 2-1.2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.444929] usb 2-1.2.1: Product: Optical Mouse
[    5.444935] usb 2-1.2.1: Manufacturer: Genius
[    5.491550] mmc0: no vmmc regulator found
[    5.499761] mmc0: Invalid maximum block size, assuming 512 bytes
[    5.510027] sysedp_create_consumer: unable to create sdhci-tegra.3, no consumer_data for sdhci-tegra.3 found[    5.513900] usb 2-1.2.4: new low-speed USB device number 5 using tegra-ehci
[    5.559244] mmc0: SDHCI controller on sdhci-tegra.3 [sdhci-tegra.3] using ADMA
[    5.559909] usb 2-1.2.4: New USB device found, idVendor=413c, idProduct=2110
[    5.559917] usb 2-1.2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    5.559924] usb 2-1.2.4: Product: Dell Wired Multimedia Keyboard
[    5.559930] usb 2-1.2.4: Manufacturer: Dell
[    5.619269] sdhci-tegra sdhci-tegra.2: Speedo value 2184
[    5.629331] sdhci-tegra sdhci-tegra.2: Tuning constraints: nom_mv 1150, boot_mv 1150, min_or_mv 1100
[    5.643661] mmc1: no vqmmc regulator found
[    5.652513] mmc1: no vmmc regulator found
[    5.661249] mmc1: Invalid maximum block size, assuming 512 bytes
[    5.672067] sysedp_create_consumer: unable to create sdhci-tegra.2, no consumer_data for sdhci-tegra.2 found[    5.680254] usb 3-1: new high-speed USB device number 2 using tegra-ehci
[    5.712288] usb 3-1: New USB device found, idVendor=0781, idProduct=5580
[    5.722247] mmc1: SDHCI controller on sdhci-tegra.2 [sdhci-tegra.2] using ADMA
[    5.722412] gpio wake56 for gpio=170
[    5.725978] tegra-se tegra12-se: tegra_se_probe: complete
[    5.755502] usb 3-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    5.772891] usb 3-1: Product: Extreme
[    5.773705] input: Genius Optical Mouse as /devices/platform/tegra-ehci.2/usb2/2-1/2-1.2/2-1.2.1/2-1.2.1:1.0/input/input0
[    5.773997] hid-generic 0003:0458:003A.0001: input: USB HID v1.11 Mouse [Genius Optical Mouse] on usb-tegra-ehci.2-1.2.1/input0
[    5.814428] usb 3-1: Manufacturer: SanDisk
[    5.823827] usb 3-1: SerialNumber: AA010313152207356253
[    5.824741] input: Dell Dell Wired Multimedia Keyboard as /devices/platform/tegra-ehci.2/usb2/2-1/2-1.2/2-1.2.4/2-1.2.4:1.0/input/input1
[    5.824987] hid-generic 0003:413C:2110.0002: input: USB HID v1.10 Keyboard [Dell Dell Wired Multimedia Keyboard] on usb-tegra-ehci.2-1.2.4/input0
[    5.871171] usb-storage 3-1:1.0: USB Mass Storage device detected
[    5.883058] scsi3 : usb-storage 3-1:1.0
[    5.883899] input: Dell Dell Wired Multimedia Keyboard as /devices/platform/tegra-ehci.2/usb2/2-1/2-1.2/2-1.2.4/2-1.2.4:1.1/input/input2
[    5.884139] hid-generic 0003:413C:2110.0003: input: USB HID v1.10 Mouse [Dell Dell Wired Multimedia Keyboard] on usb-tegra-ehci.2-1.2.4/input1
[    5.884236] usbcore: registered new interface driver usbhid
[    5.884239] usbhid: USB HID core driver
[    5.884736] tegra-hier-ictlr tegra-hier-ictlr: probed
[    5.985118] mmc0: new high speed DDR MMC card at address 0001
[    5.996708] mmcblk mmc0:0001: Card claimed for testing.
[    6.007820] mmcblk0: mmc0:0001 VM010B 3.60 GiB
[    6.018127] mmcblk0boot0: mmc0:0001 VM010B partition 1 512 KiB
[    6.029766] mmcblk0boot1: mmc0:0001 VM010B partition 2 512 KiB
[    6.043635]  mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8
[    6.056492]  mmcblk0boot1: unknown partition table
[    6.067827]  mmcblk0boot0: unknown partition table
[    6.106920] usbcore: registered new interface driver snd-usb-audio
[    6.119792] oprofile: using timer interrupt.
[    6.129844] GACT probability NOT on
[    6.138853] Mirror/redirect action on
[    6.149170] u32 classifier
[    6.157494]     Actions configured
[    6.166638] Netfilter messages via NETLINK v0.30.
[    6.176959] nf_conntrack version 0.5.0 (16384 buckets, 65536 max)
[    6.189115] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[    6.201581] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[    6.213222] xt_time: kernel timezone is -0000
[    6.223373] ip_tables: (C) 2000-2006 Netfilter Core Team
[    6.234421] arp_tables: (C) 2002 David S. Miller
[    6.244575] TCP: cubic registered
[    6.253507] NET: Registered protocol family 10
[    6.264279] mip6: Mobile IPv6
[    6.272688] ip6_tables: (C) 2000-2006 Netfilter Core Team
[    6.283726] sit: IPv6 over IPv4 tunneling driver
[    6.294741] NET: Registered protocol family 17
[    6.304697] NET: Registered protocol family 15
[    6.314636] NET: Registered protocol family 35
[    6.324433] NET: Registered protocol family 37
[    6.333940] NET: Registered protocol family 41
[    6.344702] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    6.381284] Registering SWP/SWPB emulation handler
[    6.391167] last reset is due to power on reset
[    6.391167]
[    6.407222] Disabling clocks left on by bootloader:
[    6.417089]    audio_2x
[    6.424537]    audio
[    6.431626]    audio4
[    6.438700]    audio3
[    6.445777]    audio2
[    6.452774]    audio1
[    6.459597]    audio0
[    6.466347]    hdmi_audio
[    6.473295]    entropy
[    6.479907]    dsi2-fixed
[    6.486735]    dsi1-fixed
[    6.493507]    nor
[    6.499600]    trace
[    6.505794]    sdmmc3_ddr
[    6.512463]    cclk_lp
[    6.518662]    pll_x_out0
[    6.525005]    pll_m_out1
[    6.531329] tegra_dvfs: vdd_cpu connected to regulator
[    6.540196] tegra_dvfs: vdd_core connected to regulator
[    6.548991] tegra_dvfs: vdd_gpu connected to regulator
[    6.558539] tegra_dvfs: registered vdd_cpu simon notifier
[    6.567458] cpu_cold cooling device is registered
[    6.575561] cpu_hot cooling device is registered
[    6.575674] Tegra CPU DFLL is initialized with use_dfll = 1
[    6.575740] CPU rate: 696 MHz
[    6.826797] tegra dvfs: tegra sysfs cap interface is initialized
[    6.835881] tegra dvfs: tegra sysfs gpu & emc interface is initialized
[    6.845373] tegra dvfs: registered vdd_gpu simon notifier
[    6.854341] tegra_actmon.emc: Completed initialization (0)
[    6.863024] tegra_actmon.avp: Completed initialization (0)
[    6.871575] tegra_mon.cpu_emc: Completed initialization (0)
[    6.882767] reg-aon-1v2: incomplete constraints, leaving on
[    6.891371] reg-aon-1v8: incomplete constraints, leaving on
[    6.899844] vdd-cdc-1v2-aud: incomplete constraints, leaving on
[    6.908741] sdmmc-en-supply: incomplete constraints, leaving on
[    6.917637] reg-dcdc-1v2: incomplete constraints, leaving on
[    6.926284] reg-5v0-supply: incomplete constraints, leaving on
[    6.935095] vpp-fuse: incomplete constraints, leaving on
[    6.943391] vdd-2v7-cam: incomplete constraints, leaving on
[    6.951972] avdd-spi: incomplete constraints, leaving on
[    6.960320] vdd-1v1-cam: incomplete constraints, leaving on
[    6.969060] vddio-sdmmc-2: incomplete constraints, leaving on
[    6.977902] scsi 3:0:0:0: Direct-Access     SanDisk  Extreme          0001 PQ: 0 ANSI: 6
[    6.989096] vdd-1v2-cam: incomplete constraints, leaving on
[    6.997833] avdd-cam: incomplete constraints, leaving on
[    6.998577] sd 3:0:0:0: Attached scsi generic sg1 type 0
[    7.014617] vdd-cam: incomplete constraints, leaving on
[    7.023054] as3722-sd3: incomplete constraints, leaving on
[    7.031698] reg-3v3-supply: incomplete constraints, leaving on
[    7.040604] vdd-3v3-aon: incomplete constraints, leaving on
[    7.049349] vdd-ac-bat: incomplete constraints, leaving on
[    7.057986] regulator-dummy: incomplete constraints, leaving on
[    7.067894] gpio wake51 for gpio=128
[    7.074807] input: gpio-keys.4 as /devices/platform/gpio-keys.4/input/input3
[    7.085857] as3722-rtc as3722-rtc.1: setting system clock to 2015-09-25 08:55:10 UTC (1443171310)
[    7.098896] ALSA device list:
[    7.104936]   #0: HDA NVIDIA Tegra at 0x70038000 irq 113
[    7.172802] sd 3:0:0:0: [sdb] 61282631 512-byte logical blocks: (31.3 GB/29.2 GiB)
[    7.184420] sd 3:0:0:0: [sdb] Write Protect is off
[    7.193170] sd 3:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    7.217924]  sdb: sdb1
[    7.226788] sd 3:0:0:0: [sdb] Attached SCSI removable disk
[    7.235815] VFS: Cannot open root device "sda1" or unknown-block(8,1): error -6
[    7.246610] Please append a correct "root=" boot option; here are the available partitions:
[    7.258478] 0800       125034840 sda  driver: sd
[    7.266682] b300         3784704 mmcblk0  driver: mmcblk
[    7.275553]   b301         3145728 mmcblk0p1 7369c667-ff51-ec4a-29cd-baabf2fbe346
[    7.286755]   b302            4096 mmcblk0p2 f854c27c-e81b-8de7-765a-2e63339fc99a
[    7.297935]   b303           65536 mmcblk0p3 b70d3266-5831-5aa3-255d-051758e95ed4
[    7.309168]   b304            4096 mmcblk0p4 c6cdb2ab-b49b-1154-0e82-7441213ddc87
[    7.320431]   b305            4096 mmcblk0p5 a13ee970-e141-67fc-3e01-7e97eadc6b96
[    7.331780]   b306            4096 mmcblk0p6 2a5c388f-b0ec-fb3b-32af-3c54ec18db5c
[    7.343126]   b307            4096 mmcblk0p7 43fe1a02-fafb-3aaa-fb29-d1e6053c7c94
[    7.354505]   b308          519168 mmcblk0p8 61bed875-f989-bb5c-a899-0f95b1ebf1b3
[    7.365915] b320             512 mmcblk0boot1  (driver?)
[    7.375249] b310             512 mmcblk0boot0  (driver?)
[    7.384500] 0810        30641315 sdb  driver: sd
[    7.393075]   0811        30641299 sdb1 00000000-01
[    7.401911] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8,1)
[    7.414180] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.40-geip-mc10k1-main-L4T-R21.3 #4
[    7.426635] [<c0016418>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[    7.439387] [<c0012f48>] (show_stack+0x18/0x1c) from [<c07a73b4>] (panic+0x94/0x1e8)
[    7.451311] [<c07a73b4>] (panic+0x94/0x1e8) from [<c0ac3fd0>] (mount_block_root+0xe8/0x194)
[    7.463892] [<c0ac3fd0>] (mount_block_root+0xe8/0x194) from [<c0ac4164>] (mount_root+0xe8/0x108)
[    7.476957] [<c0ac4164>] (mount_root+0xe8/0x108) from [<c0ac42ac>] (prepare_namespace+0x128/0x18c)
[    7.490223] [<c0ac42ac>] (prepare_namespace+0x128/0x18c) from [<c0ac3c64>] (kernel_init_freeable+0xe0/0x114)
[    7.504429] [<c0ac3c64>] (kernel_init_freeable+0xe0/0x114) from [<c079d4f0>] (kernel_init+0x10/0xec)
[    7.517973] [<c079d4f0>] (kernel_init+0x10/0xec) from [<c000ef18>] (ret_from_fork+0x14/0x20)
[    7.530837] CPU1: stopping
[    7.537954] CPU: 1 PID: 0 Comm: swapper/1 Not tainted 3.10.40-geip-mc10k1-main-L4T-R21.3 #4
[    7.550826] [<c0016418>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[    7.564000] [<c0012f48>] (show_stack+0x18/0x1c) from [<c00153a8>] (handle_IPI+0x17c/0x1a8)
[    7.576854] [<c00153a8>] (handle_IPI+0x17c/0x1a8) from [<c0008520>] (gic_handle_irq+0x84/0x1ac)
[    7.590219] [<c0008520>] (gic_handle_irq+0x84/0x1ac) from [<c000ea40>] (__irq_svc+0x40/0x70)
[    7.603346] Exception stack(0xee287eb0 to 0xee287ef8)
[    7.613098] 7ea0:                                     ee287f00 000063db 0018f6f5 000063db
[    7.626095] 7ec0: 00000000 c1dfd7d8 bdc983bd 00000001 ee286000 c0c724f4 c0cfe838 00000001
[    7.639106] 7ee0: 00000000 ee287ef8 c02b0e54 c003e32c 20000113 ffffffff
[    7.650596] [<c000ea40>] (__irq_svc+0x40/0x70) from [<c003e32c>] (tegra_idle_enter_clock_gating+0x58/0x7c)
[    7.665200] [<c003e32c>] (tegra_idle_enter_clock_gating+0x58/0x7c) from [<c003e098>] (tegra_idle_enter_pd+0x54/0x290)
[    7.680825] [<c003e098>] (tegra_idle_enter_pd+0x54/0x290) from [<c0584ed8>] (cpuidle_enter_state+0x44/0xf8)
[    7.695603] [<c0584ed8>] (cpuidle_enter_state+0x44/0xf8) from [<c058506c>] (cpuidle_idle_call+0xe0/0x2b0)
[    7.710241] [<c058506c>] (cpuidle_idle_call+0xe0/0x2b0) from [<c000fd0c>] (arch_cpu_idle+0x10/0x40)
[    7.724367] [<c000fd0c>] (arch_cpu_idle+0x10/0x40) from [<c00b1028>] (cpu_idle_loop+0x60/0x25c)
[    7.738179] [<c00b1028>] (cpu_idle_loop+0x60/0x25c) from [<c00b1238>] (freezing_slow_path+0x0/0x78)
[    7.752367] CPU2: stopping
[    7.760267] CPU: 2 PID: 0 Comm: swapper/2 Not tainted 3.10.40-geip-mc10k1-main-L4T-R21.3 #4
[    7.773883] [<c0016418>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[    7.787800] [<c0012f48>] (show_stack+0x18/0x1c) from [<c00153a8>] (handle_IPI+0x17c/0x1a8)
[    7.801393] [<c00153a8>] (handle_IPI+0x17c/0x1a8) from [<c0008520>] (gic_handle_irq+0x84/0x1ac)
[    7.815451] [<c0008520>] (gic_handle_irq+0x84/0x1ac) from [<c000ea40>] (__irq_svc+0x40/0x70)
[    7.829269] Exception stack(0xee289eb0 to 0xee289ef8)
[    7.839713] 9ea0:                                     ee289f00 0006ca31 01b28c4a 0006ca31
[    7.853351] 9ec0: 00000000 c1e067d8 a4c9c762 00000001 ee288000 c0c724f4 c0cfe838 00000002
[    7.867016] 9ee0: 00000000 ee289ef8 c02b0e54 c003e32c 20000113 ffffffff
[    7.879113] [<c000ea40>] (__irq_svc+0x40/0x70) from [<c003e32c>] (tegra_idle_enter_clock_gating+0x58/0x7c)
[    7.894318] [<c003e32c>] (tegra_idle_enter_clock_gating+0x58/0x7c) from [<c003e098>] (tegra_idle_enter_pd+0x54/0x290)
[    7.910526] [<c003e098>] (tegra_idle_enter_pd+0x54/0x290) from [<c0584ed8>] (cpuidle_enter_state+0x44/0xf8)
[    7.925848] [<c0584ed8>] (cpuidle_enter_state+0x44/0xf8) from [<c058506c>] (cpuidle_idle_call+0xe0/0x2b0)
[    7.940992] [<c058506c>] (cpuidle_idle_call+0xe0/0x2b0) from [<c000fd0c>] (arch_cpu_idle+0x10/0x40)
[    7.955629] [<c000fd0c>] (arch_cpu_idle+0x10/0x40) from [<c00b1028>] (cpu_idle_loop+0x60/0x25c)
[    7.969929] [<c00b1028>] (cpu_idle_loop+0x60/0x25c) from [<c00b1238>] (freezing_slow_path+0x0/0x78)
[    7.984593] CPU3: stopping
[    7.995159] CPU: 3 PID: 0 Comm: swapper/3 Not tainted 3.10.40-geip-mc10k1-main-L4T-R21.3 #4
[    8.011464] [<c0016418>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[    8.028083] [<c0012f48>] (show_stack+0x18/0x1c) from [<c00153a8>] (handle_IPI+0x17c/0x1a8)
[    8.044351] [<c00153a8>] (handle_IPI+0x17c/0x1a8) from [<c0008520>] (gic_handle_irq+0x84/0x1ac)
[    8.061044] [<c0008520>] (gic_handle_irq+0x84/0x1ac) from [<c000ea40>] (__irq_svc+0x40/0x70)
[    8.077478] Exception stack(0xee28beb0 to 0xee28bef8)
[    8.090530] bea0:                                     ee28bf00 00021a24 00868925 00021a24
[    8.106797] bec0: 00000000 c1e0f7d8 b7197836 00000001 ee28a000 c0c724f4 c0cfe838 00000003
[    8.123063] bee0: 00000000 ee28bef8 c02b0e54 c003e32c 20000113 ffffffff
[    8.137781] [<c000ea40>] (__irq_svc+0x40/0x70) from [<c003e32c>] (tegra_idle_enter_clock_gating+0x58/0x7c)
[    8.155684] [<c003e32c>] (tegra_idle_enter_clock_gating+0x58/0x7c) from [<c003e098>] (tegra_idle_enter_pd+0x54/0x290)
[    8.174658] [<c003e098>] (tegra_idle_enter_pd+0x54/0x290) from [<c0584ed8>] (cpuidle_enter_state+0x44/0xf8)
[    8.192811] [<c0584ed8>] (cpuidle_enter_state+0x44/0xf8) from [<c058506c>] (cpuidle_idle_call+0xe0/0x2b0)
[    8.210871] [<c058506c>] (cpuidle_idle_call+0xe0/0x2b0) from [<c000fd0c>] (arch_cpu_idle+0x10/0x40)
[    8.228406] [<c000fd0c>] (arch_cpu_idle+0x10/0x40) from [<c00b1028>] (cpu_idle_loop+0x60/0x25c)
[    8.245631] [<c00b1028>] (cpu_idle_loop+0x60/0x25c) from [<c00b1238>] (freezing_slow_path+0x0/0x78)
[   36.082205] ------------[ cut here ]------------
[   36.098592] WARNING: at /home/212461347/mc10k1/Linux_for_Tegra/kernel/kernel/watchdog.c:269 watchdog_check_hardlockup_other_cpu+0xe8/0x11c()
[   36.123642] Watchdog detected hard LOCKUP on cpu 1
[   36.128434] Modules linked in:
[   36.155553] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.40-geip-mc10k1-main-L4T-R21.3 #4
[   36.176423] [<c0016418>] (unwind_backtrace+0x0/0x140) from [<c0012f48>] (show_stack+0x18/0x1c)
[   36.197248] [<c0012f48>] (show_stack+0x18/0x1c) from [<c0063b48>] (warn_slowpath_common+0x54/0x70)
[   36.218449] [<c0063b48>] (warn_slowpath_common+0x54/0x70) from [<c0063c10>] (warn_slowpath_fmt+0x38/0x48)
[   36.240266] [<c0063c10>] (warn_slowpath_fmt+0x38/0x48) from [<c00d1818>] (watchdog_check_hardlockup_other_cpu+0xe8/0x11c)
[   36.263142] [<c00d1818>] (watchdog_check_hardlockup_other_cpu+0xe8/0x11c) from [<c00d188c>] (watchdog_timer_fn+0x40/0x184)
[   36.286470] [<c00d188c>] (watchdog_timer_fn+0x40/0x184) from [<c008e180>] (__run_hrtimer+0x88/0x2c0)
[   36.308022] [<c008e180>] (__run_hrtimer+0x88/0x2c0) from [<c008efcc>] (hrtimer_interrupt+0x124/0x2cc)
[   36.329243] [<c008efcc>] (hrtimer_interrupt+0x124/0x2cc) from [<c05b2b94>] (arch_timer_handler_phys+0x30/0x38)
[   36.351570] [<c05b2b94>] (arch_timer_handler_phys+0x30/0x38) from [<c00d5650>] (handle_percpu_devid_irq+0x8c/0x1c0)
[   36.374272] [<c00d5650>] (handle_percpu_devid_irq+0x8c/0x1c0) from [<c00d1c50>] (generic_handle_irq+0x34/0x48)
[   36.396544] [<c00d1c50>] (generic_handle_irq+0x34/0x48) from [<c000f878>] (handle_IRQ+0x40/0x98)
[   36.417840] [<c000f878>] (handle_IRQ+0x40/0x98) from [<c00084e0>] (gic_handle_irq+0x44/0x1ac)
[   36.438957] [<c00084e0>] (gic_handle_irq+0x44/0x1ac) from [<c000ea40>] (__irq_svc+0x40/0x70)
[   36.459780] Exception stack(0xee0b7e88 to 0xee0b7ed0)
[   36.476955] 7e80:                   27b76bbe 00000000 ff691f00 00000f3f c0cf03e8 00002edf
[   36.497745] 7ea0: 27b75c7f c0c238f4 00006c98 c13ad440 c0c8d378 00000000 00000000 ee0b7ed0
[   36.518787] 7ec0: c02a2f84 c02a2f6c 80000113 ffffffff
[   36.536118] [<c000ea40>] (__irq_svc+0x40/0x70) from [<c02a2f6c>] (__timer_delay+0x38/0x64)
[   36.556612] [<c02a2f6c>] (__timer_delay+0x38/0x64) from [<c07a74d0>] (panic+0x1b0/0x1e8)
[   36.576988] [<c07a74d0>] (panic+0x1b0/0x1e8) from [<c0ac3fd0>] (mount_block_root+0xe8/0x194)
[   36.596974] [<c0ac3fd0>] (mount_block_root+0xe8/0x194) from [<c0ac4164>] (mount_root+0xe8/0x108)
[   36.618059] [<c0ac4164>] (mount_root+0xe8/0x108) from [<c0ac42ac>] (prepare_namespace+0x128/0x18c)
[   36.639572] [<c0ac42ac>] (prepare_namespace+0x128/0x18c) from [<c0ac3c64>] (kernel_init_freeable+0xe0/0x114)
[   36.661249] [<c0ac3c64>] (kernel_init_freeable+0xe0/0x114) from [<c079d4f0>] (kernel_init+0x10/0xec)
[   36.682624] [<c079d4f0>] (kernel_init+0x10/0xec) from [<c000ef18>] (ret_from_fork+0x14/0x20)
[   36.703035] ---[ end trace ed1caa0b8d834daa ]---
What I have worked out is that the PCIe device get enumerated as a block device first so the boot parameter “root=/dev/sda1” now refers to the wrong block device.
I have searched for solutions and found what I thought was a solution but it does not work. I found that the “root=” boot parameter can be set to use UUID (like this “root=UUID=f0685ccb-0ad9-43ad-950d-6def5cf76187” but this does not work on the Jetson.
I think it is because the USB enumeration does not include the UUID for the memory stick, it does for the partitions on the eMMC.
Does anyone know how I can solve this (get USB boot to work with SSD attached) please?
Hi
I have found a working solution BUT the UUID still does not work.
I found out how to use PARTUUID instead.
The following is part of a dump of the output when the boot fails (system has 1 SSD on PCIe, 1 Sata drive and the USB memory device) :
[    4.354375] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.362816] ata1.00: FORCE: horkage modified (dump_id)
[    4.376926] ata1.00: ATA-8: PLEXTOR PX-AG128M6e, 1.04, max UDMA/133
[    4.376935] ata1.00: 250069680 sectors, multi 1: LBA48 NCQ (depth 31/32), AA
[    4.411332] usb 2-1: new full-speed USB device number 2 using tegra-ehci
[    4.413569] ata1.00: configured for UDMA/133
[    4.413906] scsi 0:0:0:0: Direct-Access     ATA      PLEXTOR PX-AG128 1.04 PQ: 0 ANSI: 5
[    4.414572] sd 0:0:0:0: Attached scsi generic sg0 type 0
[    4.414635] sd 0:0:0:0: [sda] 250069680 512-byte logical blocks: (128 GB/119 GiB)
[    4.415055] sd 0:0:0:0: [sda] Write Protect is off
[    4.415194] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.420697]  sda: unknown partition table
[    4.421619] sd 0:0:0:0: [sda] Attached SCSI disk
[    4.515326] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    4.523991] ata2.00: ATA-8: ST9250315AS, 0001SDM1, max UDMA/133
[    4.524002] ata2.00: 488397168 sectors, multi 16: LBA48 NCQ (depth 31/32)
[    4.547060] ata2.00: configured for UDMA/133
[    4.560501] scsi 1:0:0:0: Direct-Access     ATA      ST9250315AS      0001 PQ: 0 ANSI: 5
[    4.561000] sd 1:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[    4.561115] sd 1:0:0:0: Attached scsi generic sg1 type 0
[    4.561323] sd 1:0:0:0: [sdb] Write Protect is off
[    4.561463] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.595597]  sdb: sdb1 sdb2
[    4.596783] sd 1:0:0:0: [sdb] Attached SCSI disk
[    5.926413] usb 3-1: Manufacturer: SanDisk
[    5.935652] usb 3-1: SerialNumber: AA010313152207356253
[    5.982691] usb-storage 3-1:1.0: USB Mass Storage device detected
[    5.994549] scsi3 : usb-storage 3-1:1.0
[    7.073116] scsi 3:0:0:0: Direct-Access     SanDisk  Extreme          0001 PQ: 0 ANSI: 6
[    7.087309] sd 3:0:0:0: Attached scsi generic sg2 type 0
[    7.247944] sd 3:0:0:0: [sdc] 61282631 512-byte logical blocks: (31.3 GB/29.2 GiB)
[    7.259438] sd 3:0:0:0: [sdc] Write Protect is off
[    7.268068] sd 3:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    7.292824]  sdc: sdc1
[    7.301687] sd 3:0:0:0: [sdc] Attached SCSI removable disk
[    7.310618] VFS: Cannot open root device "sda1" or unknown-block(8,1): error -6
[    7.321315] Please append a correct "root=" boot option; here are the available partitions:
[    7.333220] 0800       125034840 sda  driver: sd
[    7.341427] 0810       244198584 sdb  driver: sd
[    7.349612]   0811          512000 sdb1 00003ab1-01
[    7.358004]   0812       243685376 sdb2 00003ab1-02
[    7.366441] b300         3784704 mmcblk0  driver: mmcblk
[    7.375357]   b301         3145728 mmcblk0p1 7369c667-ff51-ec4a-29cd-baabf2fbe346
[    7.386623]   b302            4096 mmcblk0p2 f854c27c-e81b-8de7-765a-2e63339fc99a
[    7.397962]   b303           65536 mmcblk0p3 b70d3266-5831-5aa3-255d-051758e95ed4
[    7.409289]   b304            4096 mmcblk0p4 c6cdb2ab-b49b-1154-0e82-7441213ddc87
[    7.420641]   b305            4096 mmcblk0p5 a13ee970-e141-67fc-3e01-7e97eadc6b96
[    7.432029]   b306            4096 mmcblk0p6 2a5c388f-b0ec-fb3b-32af-3c54ec18db5c
[    7.443527]   b307            4096 mmcblk0p7 43fe1a02-fafb-3aaa-fb29-d1e6053c7c94
[    7.455098]   b308          519168 mmcblk0p8 61bed875-f989-bb5c-a899-0f95b1ebf1b3
[    7.466724] b320             512 mmcblk0boot1  (driver?)
[    7.476201] b310             512 mmcblk0boot0  (driver?)
[    7.485667] 0820        30641315 sdc  driver: sd
[    7.494472]   0821        30641299 sdc1 00000000-01
[    7.503564] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(8,1)
At the end, the kernel presents a list of block devices that are available with all the available information to the kernel. I noticed that the USB device does not have a valid UUID but the 00000000-01 I gussed is a part_uuid number.
Now I changed
root=/dev/sda1
to
root=PARTUUID=00000000-01
and the system boots up and all the drive are there !
Yeah!
I wonder why a UUID is not present during the kernel boot? It is there after booting into Unity desktop.
I expect your rootdev should be /dev/mmcblk0p1 , It may something wrong to recognize wrong block device .
There are two steps that you can try to correct rootdev :
Step1 :
Please find the partuuid from “/dev/disk/by-partuuid” corresponding to mmcblk0p1
root@tegra-ubuntu:/# ls -lah /dev/disk/by-partuuid/ | grep mmcblk0p1
lrwxrwxrwx 1 root root 15 Jan 4 01:17 7369c667-ff51-ec4a-29cd-baabf2fbe346 -> …/…/mmcblk0p1
Step2 :
While flashing kernel, pass PARTUUID in root instead of /dev/mmcblk0p1
sudo ./flash.sh -C “root=PARTUUID=“7369c667-ff51-ec4a-29cd-baabf2fbe346” rootfstype=ext4 rw” -k 6 -K /…/zImage jetson-tk1 mmcblk0p1
here flash.sh command mandates rootdev (mmcblk0p1) to be specified.
while kernel boots it can be seen that root has changed to " root=PARTUUID=7369c667-ff51-ec4a-29cd-baabf2fbe346 rootfstype=ext4 rw "
Of course, you can also change root paramters in extlinux.conf files for bootloader
