I have created a USB stick that appears to boot. It appears to go through the mb1, mb2, cboot and boot the kernel and then stops.
However, the configuration steps nor a login prompt appears. I have programmed the USB stick as defined in the instruction from the section called " To set up a flash drive manually for booting" from the following web page:
I have a few questions:
Is this the correct procedure?
Should I see a setup/boot prompt?
What version of USB stick should be used? Usb2 or usb3?
Is 16M or 32M better to use?
