USB-C Specification - Jetson AGX Orin Development Kit Carrier Board
I need some further information on the Jetson AGX Orin Development Kit Carrier board.
The reference states, that the USB-C (J39 and J40) is USB 3.2 Gen 2. But what Gen is this exactly? Gen 2x2? 2x1? I cannot find any information on this.
Also, does the Carrier Board support full (100W) power range in “booth directions”? E.g. can I power a device with 30W via PD of the Development Carrier Board?
Sincerely
You can find below info in module datasheet. The max output of VBUS is about 15W.
The NVIDIA Jetson AGX Orin SOM provides 4x USB 2.0 and 3x USB3.2 Gen2 x1 port for communication to external peripheral devices. In host mode, the USB3.2 host controller supports up to Gen2 Super Speed+, 10 Gbps. In device mode, the USB3.2 controller supports up to Gen1 Super Speed.
Note: There are two hubs internal for USB 3.2. Each has 10 Gbps bandwidth. One hub is for ports 0 and 1. The other for ports 2 and 3
