In bring up an additional Orin AGX board using JP5.0 the UFP USB (next to 40-pin) (https://developer.nvidia.com/embedded/learn/jetson-agx-orin-devkit-user-guide/howto.html#use-usb-port) does not present the virtual ethernet connection l4tbr0.
The device does not enumerate on the host, and on the device there is no response in the dmesg at all. I have tested multiple units and multiple Orin AGX boards.
When using a Xavier AGX this port presents a the virtual ethernet connection without any additional configuration. Is there a setting that is needed to enable the UFP port.
Sorry for the late response, is this still an issue to support? Thanks
We just checked, the l4tbr0 interface is still the flash typr C usb port on the devkit.
