Hi, we have several NXs and devices and we use the same USB-Ethernet adapter with them.
But we got a certain NX(Model: P3668) which always have the following dmseg output
[ 239.579218] usb usb2: usb_suspend_both: status 0
[ 240.577992] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 241.469935] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 241.470383] usb usb1-port2: attempt power cycle
[ 243.101651] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 243.997632] usb usb1-port2: Cannot enable. Maybe the USB cable is bad?
[ 243.997860] usb usb1-port2: unable to enumerate USB device
[ 243.998081] usb usb1: usb_suspend_both: status 0
At the same time, we can get normal output from the others good NXs like this
[ 15.213404] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 15.236783] usb 1-2: New USB device found, idVendor=05e3, idProduct=0610
[ 15.236805] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 15.236815] usb 1-2: Product: USB2.1 Hub
[ 15.236821] usb 1-2: Manufacturer: GenesysLogic
[ 15.239716] hub 1-2:1.0: USB hub found
[ 15.240016] hub 1-2:1.0: 4 ports detected
[ 15.553398] usb 1-2.2: new high-speed USB device number 3 using tegra-xusb
[ 15.580904] usb 1-2.2: New USB device found, idVendor=0b95, idProduct=1790
[ 15.580970] usb 1-2.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 15.580982] usb 1-2.2: Product: AX88179
[ 15.580989] usb 1-2.2: Manufacturer: ASIX Elec. Corp.
[ 15.580994] usb 1-2.2: SerialNumber: 0000000001367D
[ 15.976651] ax88179_178a 1-2.2:1.0 eth1: register 'ax88179_178a' at usb-3610000.xhci-2.2, ASIX AX88179 USB 3.0 Gigabit Ethernet, 90:96:f3:4a:44:a9
In addition, we also tested with carrier board, but on carrier board all the NXs work fine with the same USB-Ethernet adapter(Both USB2.0 and 3.0).
To summarise,
issue NX + our device => NG
issue NX + carrier board (dev kit) => OK
other NXs(N=5) + our device => OK
other NXs(N=5) + carrier board (dev kit) => OK
Could this be a HW issue to this certain NX?
(We flashed the same customized image to all NXs)
