I can go weeks at a time without this bug, but every once in a while /dev/video0 disappears on reboot and no amount of soft resets or unplugging the USB camera and inserting it in a different (or the same) USB port will bring it back.
I have also tried turning the Nano off and turning it back on.
Anyone got any ideas?
Last time I encountered this bug I just quit using the nano until I found a good time to flash a new SD image and pull my code back down from github… which fixed it for a few weeks until it happened again.
When I plug the same camera in now syslog shows the following:
Blockquote
Feb 7 19:57:01 jarvis kernel: [ 486.630891] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
Feb 7 19:57:01 jarvis kernel: [ 486.842773] usb 1-2.3: new low-speed USB device number 4 using tegra-xusb
Feb 7 19:57:01 jarvis kernel: [ 486.843921] usb 1-2.3: Device not responding to setup address.
Feb 7 19:57:01 jarvis kernel: [ 487.059948] usb 1-2.3: Device not responding to setup address.
Feb 7 19:57:01 jarvis kernel: [ 487.270795] usb 1-2.3: device not accepting address 4, error -71
Feb 7 19:57:01 jarvis kernel: [ 487.356279] usb 1-2.3: new low-speed USB device number 5 using tegra-xusb
Feb 7 19:57:01 jarvis kernel: [ 487.357523] usb 1-2.3: Device not responding to setup address.
Feb 7 19:57:02 jarvis kernel: [ 487.571827] usb 1-2.3: Device not responding to setup address.
Feb 7 19:57:02 jarvis kernel: [ 487.782769] usb 1-2.3: device not accepting address 5, error -71
Feb 7 19:57:02 jarvis kernel: [ 487.789651] usb 1-2-port3: attempt power cycle
Feb 7 19:57:03 jarvis kernel: [ 488.810758] tegra-xusb-padctl 7009f000.xusb_padctl: power down UTMI pad 1
Feb 7 19:57:03 jarvis kernel: [ 488.834883] usb 1-2: usb_suspend_both: status 0
