I have rendering econ camera through USB of Jetson Nano at 1080P. I am using the following gstreamer pipeline. The video is flickering. Any solution for this?
what if you run it without caps? like to remove parameters and reduce number of arguments to a littlest possible extent to run the stream?
and try smth like the below to retrieve supported modes:
Thanks for your response. With the above pipeline, I am getting the following error:
Setting pipeline to PAUSED …
No protocol specified
ERROR: Pipeline doesn’t want to pause.
ERROR: from element /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0: Could not initialise Xv output
Additional debug info:
xvimagesink.c(1773): gst_xv_image_sink_open (): /GstPipeline:pipeline0/GstXvImageSink:xvimagesink0:
Could not open display (null)
Setting pipeline to NULL …
Freeing pipeline …
