It runs deepstream test usb python example perfectly
I have a python code (it uses dlib and yolo) and want to run it on opencv but it seems impossible to run properly.
videocapture(0) gives bad results like 2 fps in 4k
Can you suggest a gst pipeline that begins with v4l2src and ends in appsink, that I can use
with cap = cv2.VideoCapture(gst_url, cv2.CAP_GSTREAMER)
There is no easy way to combine deepstream python and get frames to opencv… Or is there?
Thank you for that reply. But it is not quite the answer of the topic. Can this deepstream app give frames to opencv in python, so that it can process it?
